path: root/Documentation/filesystems/udf.txt
2009-04-02udf: implement mode and dmode mounting optionsMarcin Slusarz
"dmode" allows overriding permissions of directories and "mode" allows overriding permissions of files. Signed-off-by: Marcin Slusarz <marcin.slusarz@gmail.com> Cc: Jan Kara <jack@suse.cz> Signed-off-by: Jan Kara <jack@suse.cz>
2006-11-16[PATCH] Update udf documentation to reflect current state of read/write supportPhillip Susi
Change Documentation/filesystems/udf.txt from saying that read/write mounts on cd media are not supported to instead state the current level of support. Specifically that it works fine on dvd+rw media and can be made to work on cd-rw media via the pktcdvd device. Cc: Peter Osterlund <petero2@telia.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-03-25[PATCH] udf: fix uid/gid options and add uid/gid=ignore and forget optionsPhillip Susi
As Pekka Enberg pointed out, with the if still following the else, you can still get a null uid written to the disk if you specify a default uid= without uid=forget. In other words, if the desktop user is uid=1000 and the mount option uid=1000 is given ( which is done on ubuntu automatically and probably other distributions that use hal ), then if any other user besides uid 1000 owns a file then a 0 will be written to the media as the owning uid instead. Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
