path: root/Documentation/filesystems/xfs.txt
2011-05-24xfs: add online discard supportChristoph Hellwig
Now that we have reliably tracking of deleted extents in a transaction we can easily implement "online" discard support which calls blkdev_issue_discard once a transaction commits. The actual discard is a two stage operation as we first have to mark the busy extent as not available for reuse before we can start the actual discard. Note that we don't bother supporting discard for the non-delaylog mode. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Alex Elder <aelder@sgi.com>
2010-07-26xfs: remove obsolete osyncisosync mount optionChristoph Hellwig
Since Linux 2.6.33 the kernel has support for real O_SYNC, which made the osyncisosync option a no-op. Warn the users about this and remove the mount flag for it. Signed-off-by: Christoph Hellwig <hch@lst.de> Reviewed-by: Dave Chinner <dchinner@redhat.com> Signed-off-by: Dave Chinner <david@fromorbit.com>
2008-10-30[XFS] remove restricted chown parameter from xfs linuxTim Shimmin
On Linux all filesystems are supposed to be operating under Posix' restricted chown. Restricted chown means it restricts chown to the owner unless you have CAP_FOWNER. NOTE: that 2 files outside of fs/xfs have been modified too for this change. Reviewed-by: Dave Chinner <david@fromorbit.com> SGI-PV: 988919 SGI-Modid: 2.6.x-xfs-melb:linux:32413b Signed-off-by: Tim Shimmin <tes@sgi.com> Signed-off-by: Christoph Hellwig <hch@infradead.org> Signed-off-by: David Chinner <david@fromorbit.com> Signed-off-by: Lachlan McIlroy <lachlan@sgi.com>
2008-04-18[XFS] Update XFS documentation for noikeep/ikeep.Josef Sipek
Mention how DMAPI affects default for noikeep. Slightly modified since Josef's patch was based on an old xfs.txt prior to Dave's (dgc) checkin which missed going to oss. Signed-off-by: Josef Sipek <jeffpc@josefsipek.net> Signed-off-by: Tim Shimmin <tes@sgi.com>
2008-04-18[XFS] Update XFS Documentation for ikeep and ihashsizeDavid Chinner
Update xfs docs for: * In memory inode hashes has been removed. * noikeep is now the default. SGI-PV: 969561 SGI-Modid: 2.6.x-xfs-melb:linux:29481b Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Tim Shimmin <tes@sgi.com>
2005-11-03[XFS] Update XFS documentation.Nathan Scott
Signed-off-by: Nathan Scott <nathans@sgi.com>
