path: root/Documentation/filesystems
2008-04-23[patch 7/7] vfs: mountinfo: show dominating group idMiklos Szeredi
Show peer group ID of nearest dominating group that has intersection with the mount's namespace. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-23[patch 6/7] vfs: mountinfo: add /proc/<pid>/mountinfoRam Pai
[mszeredi@suse.cz] rewrite and split big patch into managable chunks /proc/mounts in its current form lacks important information: - propagation state - root of mount for bind mounts - the st_dev value used within the filesystem - identifier for each mount and it's parent It also suffers from the following problems: - not easily extendable - ambiguity of mountpoints within a chrooted environment - doesn't distinguish between filesystem dependent and independent options - doesn't distinguish between per mount and per super block options This patch introduces /proc/<pid>/mountinfo which attempts to address all these deficiencies. Code shared between /proc/<pid>/mounts and /proc/<pid>/mountinfo is extracted into separate functions. Thanks to Al Viro for the help in getting the design right. Signed-off-by: Ram Pai <linuxram@us.ibm.com> Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2008-04-19sysfs: refill attribute buffer when reading from offset 0Dan Williams
Requiring userspace to close and re-open sysfs attributes has been the policy since before 2.6.12. It allows userspace to get a consistent snapshot of kernel state and consume it with incremental reads and seeks. Now, if the file position is zero the kernel assumes userspace wants to see the new value. The application for this change is to allow a userspace RAID metadata handler to check the state of an array without causing any memory allocations. Thus not causing writeback to a raid array that might be blocked waiting for userspace to take action. Cc: Neil Brown <neilb@suse.de> Acked-by: Tejun Heo <htejun@gmail.com> Signed-off-by: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-18[XFS] Update XFS documentation for noikeep/ikeep.Josef Sipek
Mention how DMAPI affects default for noikeep. Slightly modified since Josef's patch was based on an old xfs.txt prior to Dave's (dgc) checkin which missed going to oss. Signed-off-by: Josef Sipek <jeffpc@josefsipek.net> Signed-off-by: Tim Shimmin <tes@sgi.com>
2008-04-18[XFS] Update XFS Documentation for ikeep and ihashsizeDavid Chinner
Update xfs docs for: * In memory inode hashes has been removed. * noikeep is now the default. SGI-PV: 969561 SGI-Modid: 2.6.x-xfs-melb:linux:29481b Signed-off-by: David Chinner <dgc@sgi.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Tim Shimmin <tes@sgi.com>
2008-04-15Fix typos in Documentation/filesystems/seq_file.txtDmitri Vorobiev
A couple of typos crept into the newly added document about the seq_file interface. This patch corrects those typos and simultaneously deletes unnecessary trailing spaces. Signed-off-by: Dmitri Vorobiev <dmitri.vorobiev@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-11Documentation: move rpc-cache.txt to filesystems/J. Bruce Fields
This file is nfs-related. (Maybe Documentation/filesystems/ would benefit from a separate nfs/ directory at some point.) Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-04-11Documentation: move nfsroot.txt to filesystems/J. Bruce Fields
Documentation/ is a little large, and filesystems/ seems an obvious place for this file. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-03-30Fixes to the seq_file documentJan Engelhardt
On Friday 2008-03-28 19:20, Jonathan Corbet wrote: >commit 9756ccfda31b4c4544aa010aacf71b6672d668e8 >Date: Fri Mar 28 11:19:56 2008 -0600 > > Add the seq_file documentation patch on top: - add const qualifiers - remove void* casts - use proper specifier (%Ld is not valid) Signed-off-by: Jonathan Corbet <corbet@lwn.net> Signed-off-by: Jan Engelhardt <jengelh@computergmbh.de>
2008-03-30Add the seq_file documentationJonathan Corbet
This is an updated version of the document describing the seq_file interface. Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2008-03-12laptops: move laptop-mode.txt to Documentation/laptops/Randy Dunlap
Move laptop-mode.txt into the laptops/ sub-directory to consolidate laptop doc files there. Update references to the file's location. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-08mount options: add documentationMiklos Szeredi
This series addresses the problem of showing mount options in /proc/mounts. Several filesystems which use mount options, have not implemented a .show_options superblock operation. Several others have implemented this callback, but have not kept it fully up to date with the parsed options. Q: Why do we need correct option showing in /proc/mounts? A: We want /proc/mounts to fully replace /etc/mtab. The reasons for this are: - unprivileged mounters won't be able to update /etc/mtab - /etc/mtab doesn't work with private mount namespaces - /etc/mtab can become out-of-sync with reality Q: Can't this be done, so that filesystems need not bother with implementing a .show_mounts callback, and keeping it up to date? A: Only in some cases. Certain filesystems allow modification of a subset of options in their remount_fs method. It is not possible to take this into account without knowing exactly how the filesystem handles options. For the simple case (no remount or remount resets all options) the patchset introduces two helpers: generic_show_options() save_mount_options() These can also be used to emulate the old /etc/mtab behavior, until proper support is added. Even if this is not 100% correct, it's still better than showing no options at all. The following patches fix up most in-tree filesystems, some have been compile tested only, some have been reviewed and acked by the maintainer. Table displaying status of all in-kernel filesystems: - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - legend: none - fs has options, but doesn't define ->show_options() some - fs defines ->show_options(), but some only options are shown good - fs shows all options noopt - fs does not have options patch - a patch will be posted merged - a patch has been merged by subsystem maintainer 9p good adfs patch affs patch afs patch autofs patch autofs4 patch befs patch bfs noopt cifs some coda noopt configfs noopt cramfs noopt debugfs noopt devpts patch ecryptfs good efs noopt ext2 patch ext3 good ext4 merged fat patch freevxfs noopt fuse patch fusectl noopt gfs2 good gfs2meta noopt hfs good hfsplus good hostfs patch hpfs patch hppfs noopt hugetlbfs patch isofs patch jffs2 noopt jfs merged minix noopt msdos ->fat ncpfs patch nfs some nfsd noopt ntfs good ocfs2 good ocfs2/dlmfs noopt openpromfs noopt proc noopt qnx4 noopt ramfs noopt reiserfs patch romfs noopt smbfs good sysfs noopt sysv noopt udf patch ufs good vfat ->fat xfs good mm/shmem.c patch drivers/oprofile/oprofilefs.c noopt drivers/infiniband/hw/ipath/ipath_fs.c noopt drivers/misc/ibmasm/ibmasmfs.c noopt drivers/usb/core (usbfs) merged drivers/usb/gadget (gadgetfs) noopt drivers/isdn/capi/capifs.c patch kernel/cpuset.c noopt fs/binfmt_misc.c noopt net/sunrpc/rpc_pipe.c noopt arch/powerpc/platforms/cell/spufs patch arch/s390/hypfs good ipc/mqueue.c noopt security (securityfs) noopt security/selinux/selinuxfs.c noopt kernel/cgroup.c good security/smack/smackfs.c noopt in -mm: reiser4 some unionfs good - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - This patch: Document the rules for handling mount options in the .show_options super operation. Signed-off-by: Miklos Szeredi <mszeredi@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08isofs: implement dmode optionJan Kara
Implement dmode option for iso9660 filesystem to allow setting of access rights for directories on the filesystem. Signed-off-by: Jan Kara <jack@suse.cz> Cc: "Ilya N. Golubev" <gin@mo.msk.ru> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: remove iget() and the read_inode() super op as being obsoleteDavid Howells
Remove the old iget() call and the read_inode() superblock operation it uses as these are really obsolete, and the use of read_inode() does not produce proper error handling (no distinction between ENOMEM and EIO when marking an inode bad). Furthermore, this removes the temptation to use iget() to find an inode by number in a filesystem from code outside that filesystem. iget_locked() should be used instead. A new function is added in an earlier patch (iget_failed) that is to be called to mark an inode as bad, unlock it and release it should the get routine fail. Mark iget() and read_inode() as being obsolete and remove references to them from the documentation. Typically a filesystem will be modified such that the read_inode function becomes an internal iget function, for example the following: void thingyfs_read_inode(struct inode *inode) { ... } would be changed into something like: struct inode *thingyfs_iget(struct super_block *sp, unsigned long ino) { struct inode *inode; int ret; inode = iget_locked(sb, ino); if (!inode) return ERR_PTR(-ENOMEM); if (!(inode->i_state & I_NEW)) return inode; ... unlock_new_inode(inode); return inode; error: iget_failed(inode); return ERR_PTR(ret); } and then thingyfs_iget() would be called rather than iget(), for example: ret = -EINVAL; inode = iget(sb, ino); if (!inode || is_bad_inode(inode)) goto error; becomes: inode = thingyfs_iget(sb, ino); if (IS_ERR(inode)) { ret = PTR_ERR(inode); goto error; } Note that is_bad_inode() does not need to be called. The error returned by thingyfs_iget() should render it unnecessary. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07iget: introduce a function to register iget failureDavid Howells
Introduce a function to register failure in an inode construction path. This includes marking the inode under construction as bad, unlocking it and releasing it. Signed-off-by: David Howells <dhowells@redhat.com> Acked-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Documentation: move sharedsubtrees.txt to filesystems/J. Bruce Fields
This documentation is also vfs-related. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07Documentation: move dnotify.txt to filesystems/J. Bruce Fields
I'm inclined to think dnotify belongs in filesystems/. Signed-off-by: J. Bruce Fields <bfields@citi.umich.edu> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06get rid of NR_OPEN and introduce a sysctl_nr_openEric Dumazet
NR_OPEN (historically set to 1024*1024) actually forbids processes to open more than 1024*1024 handles. Unfortunatly some production servers hit the not so 'ridiculously high value' of 1024*1024 file descriptors per process. Changing NR_OPEN is not considered safe because of vmalloc space potential exhaust. This patch introduces a new sysctl (/proc/sys/fs/nr_open) wich defaults to 1024*1024, so that admins can decide to change this limit if their workload needs it. [akpm@linux-foundation.org: export it for sparc64] Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Richard Henderson <rth@twiddle.net> Cc: Ivan Kokshaysky <ink@jurassic.park.msu.ru> Cc: "David S. Miller" <davem@davemloft.net> Cc: Ralf Baechle <ralf@linux-mips.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05Document lowmem_reserve_ratioYasunori Goto
Though the lower_zone_protection was changed to lowmem_reserve_ratio, the document has been not changed. The lowmem_reserve_ratio seems quite hard to estimate, but there is no guidance. This patch is to change document for it. Signed-off-by: Yasunori Goto <y-goto@jp.fujitsu.com> Cc: Andrea Arcangeli <andrea@cpushare.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05mm/page-writeback: highmem_is_dirtyable optionBron Gondwana
Add vm.highmem_is_dirtyable toggle A 32 bit machine with HIGHMEM64 enabled running DCC has an MMAPed file of approximately 2Gb size which contains a hash format that is written randomly by the dbclean process. On 2.6.16 this process took a few minutes. With lowmem only accounting of dirty ratios, this takes about 12 hours of 100% disk IO, all random writes. Include a toggle in /proc/sys/vm/highmem_is_dirtyable which can be set to 1 to add the highmem back to the total available memory count. [akpm@linux-foundation.org: Fix the CONFIG_DETECT_SOFTLOCKUP=y build] Signed-off-by: Bron Gondwana <brong@fastmail.fm> Cc: Ethan Solomita <solo@google.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: WU Fengguang <wfg@mail.ustc.edu.cn> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-03Documentation/filesystems/porting fixesOliver Pinter
typo fix and whitespace cleanup Signed-off-by: Oliver Pinter <oliver.pntr@gmail.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03doc: use correct debugfs mountpointRandy Dunlap
Use the normal, expected mountpoint in the relay(fs) example for debugfs. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03Documentation: missing proc/$PID/stat fieldLeonardo Chiquitto
There's a missing field in the /proc/$PID/stat output documented in Documentation/filesystems/proc.txt. Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03correct missing a double quote in configfs.txtMasatake YAMATO
Signed-off-by: Masatake YAMATO <jet@gyve.org> Acked-by: Joel Becker <Joel.Becker@oracle.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-03Documentation: fix type errorDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2008-02-01[AUDIT] break large execve argument logging into smaller messagesEric Paris
execve arguments can be quite large. There is no limit on the number of arguments and a 4G limit on the size of an argument. this patch prints those aruguments in bite sized pieces. a userspace size limitation of 8k was discovered so this keeps messages around 7.5k single arguments larger than 7.5k in length are split into multiple records and can be identified as aX[Y]= Signed-off-by: Eric Paris <eparis@redhat.com>
2008-01-31[IPV4] route cache: Introduce rt_genid for smooth cache invalidationEric Dumazet
Current ip route cache implementation is not suited to large caches. We can consume a lot of CPU when cache must be invalidated, since we currently need to evict all cache entries, and this eviction is sometimes asynchronous. min_delay & max_delay can somewhat control this asynchronism behavior, but whole thing is a kludge, regularly triggering infamous soft lockup messages. When entries are still in use, this also consumes a lot of ram, filling dst_garbage.list. A better scheme is to use a generation identifier on each entry, so that cache invalidation can be performed by changing the table identifier, without having to scan all entries. No more delayed flushing, no more stalling when secret_interval expires. Invalidated entries will then be freed at GC time (controled by ip_rt_gc_timeout or stress), or when an invalidated entry is found in a chain when an insert is done. Thus we keep a normal equilibrium. This patch : - renames rt_hash_rnd to rt_genid (and makes it an atomic_t) - Adds a new rt_genid field to 'struct rtable' (filling a hole on 64bit) - Checks entry->rt_genid at appropriate places :
2008-01-29ext4: Add multi block allocator for ext4Alex Tomas
Signed-off-by: Alex Tomas <alex@clusterfs.com> Signed-off-by: Andreas Dilger <adilger@clusterfs.com> Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Eric Sandeen <sandeen@redhat.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu>
2008-01-28ext4: Add the journal checksum featureGirish Shilamkar
The journal checksum feature adds two new flags i.e JBD2_FEATURE_INCOMPAT_ASYNC_COMMIT and JBD2_FEATURE_COMPAT_CHECKSUM. JBD2_FEATURE_CHECKSUM flag indicates that the commit block contains the checksum for the blocks described by the descriptor blocks. Due to checksums, writing of the commit record no longer needs to be synchronous. Now commit record can be sent to disk without waiting for descriptor blocks to be written to disk. This behavior is controlled using JBD2_FEATURE_ASYNC_COMMIT flag. Older kernels/e2fsck should not be able to recover the journal with _ASYNC_COMMIT hence it is made incompat. The commit header has been extended to hold the checksum along with the type of the checksum. For recovery in pass scan checksums are verified to ensure the sanity and completeness(in case of _ASYNC_COMMIT) of every transaction. Signed-off-by: Andreas Dilger <adilger@clusterfs.com> Signed-off-by: Girish Shilamkar <girish@clusterfs.com> Signed-off-by: Dave Kleikamp <shaggy@linux.vnet.ibm.com> Signed-off-by: Mingming Cao <cmm@us.ibm.com>
2008-01-25[PATCH 2/2] ocfs2: cluster aware flock()Mark Fasheh
Hook up ocfs2_flock(), using the new flock lock type in dlmglue.c. A new mount option, "localflocks" is added so that users can revert to old functionality as need be. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25ocfs2: Local alloc window size changeable via mount optionSunil Mushran
Local alloc is a performance optimization in ocfs2 in which a node takes a window of bits from the global bitmap and then uses that for all small local allocations. This window size is fixed to 8MB currently. This patch allows users to specify the window size in MB including disabling it by passing in 0. If the number specified is too large, the fs will use the default value of 8MB. mount -o localalloc=X /dev/sdX /mntpoint Signed-off-by: Sunil Mushran <sunil.mushran@oracle.com> Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25ocfs2: Support commit= mount optionMark Fasheh
Mostly taken from ext3. This allows the user to set the jbd commit interval, in seconds. The default of 5 seconds stays the same, but now users can easily increase the commit interval. Typically, this would be increased in order to benefit performance at the expense of data-safety. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2008-01-25ocfs2: Documentation updateMark Fasheh
Remove 'readpages' from the list in ocfs2.txt. Instead of having two identical lists, I just removed the list in the OCFS2 section of fs/Kconfig and added a pointer to Documentation/filesystems/ocfs2.txt. Signed-off-by: Mark Fasheh <mark.fasheh@oracle.com>
2007-10-239p: add virtio transportEric Van Hensbergen
This adds a transport to 9p for communicating between guests and a host using a virtio based transport. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-10-22exportfs: update documentationChristoph Hellwig
Update documentation to the current state of affairs. Remove duplicated method descruptions in exportfs.h and point to Documentation/filesystems/ Exporting instead. Add a little file header comment in expfs.c describing what's going on and mentioning Neils and my copyright [1]. Signed-off-by: Christoph Hellwig <hch@lst.de> Cc: Neil Brown <neilb@suse.de> Cc: "J. Bruce Fields" <bfields@fieldses.org> Cc: <linux-ext4@vger.kernel.org> Cc: Dave Kleikamp <shaggy@austin.ibm.com> Cc: Anton Altaparmakov <aia21@cantab.net> Cc: David Chinner <dgc@sgi.com> Cc: Timothy Shimmin <tes@sgi.com> Cc: OGAWA Hirofumi <hirofumi@mail.parknet.co.jp> Cc: Hugh Dickins <hugh@veritas.com> Cc: Chris Mason <mason@suse.com> Cc: Jeff Mahoney <jeffm@suse.com> Cc: "Vladimir V. Saveliev" <vs@namesys.com> Cc: Steven Whitehouse <swhiteho@redhat.com> Cc: Mark Fasheh <mark.fasheh@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-20proc.txt: Add /proc/stat fieldLeonardo Chiquitto
This patch updates the "cat /proc/stat" output found in Documentation/filesystems/proc.txt. Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20docs/sysfs: add missing word to sysfs attribute explanationShaun Zinck
Add the obvious missing word. Signed-off-by: Shaun Zinck <shaun.zinck@gmail.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20documentation/ext3: grammar fixesShaun Zinck
Fix some grammar in the explanation of the Journal Block Device layer. Signed-off-by: Shaun Zinck <shaun.zinck@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20Documentation/filesystems/vfs.txt: typo fixShaun Zinck
2007-10-20Documentation/filesystems/files.txt: remove rcuref_inc_lf() reverencesEric Dumazet
rcuref_inc_lf() is not used anymore. Replace it by atomic_inc_not_zero() Signed-off-by: Eric Dumazet <dada1@cosmosbay.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20typo fixesMatt LaPlante
Most of these fixes were already submitted for old kernel versions, and were approved, but for some reason they never made it into the releases. Because this is a consolidation of a couple old missed patches, it touches both Kconfigs and documentation texts. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19Fix misspellings of "system", "controller", "interrupt" and "necessary".Robert P. J. Day
Fix the various misspellings of "system", controller", "interrupt" and "[un]necessary". Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-17Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ericvh/v9fs: 9p: remove sysctl 9p: fix bad kconfig cross-dependency 9p: soften invalidation in loose_mode 9p: attach-per-user 9p: rename uid and gid parameters 9p: define session flags 9p: Make transports dynamic
2007-10-179p: attach-per-userLatchesar Ionkov
The 9P2000 protocol requires the authentication and permission checks to be done in the file server. For that reason every user that accesses the file server tree has to authenticate and attach to the server separately. Multiple users can share the same connection to the server. Currently v9fs does a single attach and executes all I/O operations as a single user. This makes using v9fs in multiuser environment unsafe as it depends on the client doing the permission checking. This patch improves the 9P2000 support by allowing every user to attach separately. The patch defines three modes of access (new mount option 'access'): - attach-per-user (access=user) (default mode for 9P2000.u) If a user tries to access a file served by v9fs for the first time, v9fs sends an attach command to the server (Tattach) specifying the user. If the attach succeeds, the user can access the v9fs tree. As there is no uname->uid (string->integer) mapping yet, this mode works only with the 9P2000.u dialect. - allow only one user to access the tree (access=<uid>) Only the user with uid can access the v9fs tree. Other users that attempt to access it will get EPERM error. - do all operations as a single user (access=any) (default for 9P2000) V9fs does a single attach and all operations are done as a single user. If this mode is selected, the v9fs behavior is identical with the current one. Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-10-179p: rename uid and gid parametersLatchesar Ionkov
Change the names of 'uid' and 'gid' parameters to the more appropriate 'dfltuid' and 'dfltgid'. This also sets the default uid/gid to -2 (aka nfsnobody) Signed-off-by: Latchesar Ionkov <lucho@ionkov.net> Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-10-179p: Make transports dynamicEric Van Hensbergen
This patch abstracts out the interfaces to underlying transports so that new transports can be added as modules. This should also allow kernel configuration of transports without ifdef-hell. Signed-off-by: Eric Van Hensbergen <ericvh@gmail.com>
2007-10-17x86: expand /proc/interrupts to include missing vectors, v2Joe Korty
Add missing IRQs and IRQ descriptions to /proc/interrupts. /proc/interrupts is most useful when it displays every IRQ vector in use by the system, not just those somebody thought would be interesting. This patch inserts the following vector displays to the i386 and x86_64 platforms, as appropriate: rescheduling interrupts TLB flush interrupts function call interrupts thermal event interrupts threshold interrupts spurious interrupts A threshold interrupt occurs when ECC memory correction is occuring at too high a frequency. Thresholds are used by the ECC hardware as occasional ECC failures are part of normal operation, but long sequences of ECC failures usually indicate a memory chip that is about to fail. Thermal event interrupts occur when a temperature threshold has been exceeded for some CPU chip. IIRC, a thermal interrupt is also generated when the temperature drops back to a normal level. A spurious interrupt is an interrupt that was raised then lowered by the device before it could be fully processed by the APIC. Hence the apic sees the interrupt but does not know what device it came from. For this case the APIC hardware will assume a vector of 0xff. Rescheduling, call, and TLB flush interrupts are sent from one CPU to another per the needs of the OS. Typically, their statistics would be used to discover if an interrupt flood of the given type has been occuring. AK: merged v2 and v4 which had some more tweaks AK: replace Local interrupts with Local timer interrupts AK: Fixed description of interrupt types. [ tglx: arch/x86 adaptation ] [ mingo: small cleanup ] Signed-off-by: Joe Korty <joe.korty@ccur.com> Signed-off-by: Andi Kleen <ak@suse.de> Cc: Tim Hockin <thockin@hockin.org> Cc: Andi Kleen <ak@suse.de> Cc: Ingo Molnar <mingo@elte.hu> Cc: "H. Peter Anvin" <hpa@zytor.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Ingo Molnar <mingo@elte.hu> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2007-10-17Documentation: add entries to filesystems/00-INDEX for several untracked filesDenis Cheng
Signed-off-by: Denis Cheng <crquan@gmail.com> Cc: Rob Landley <rob@landley.net> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17quota: send messages via netlinkJan Kara
Implement sending of quota messages via netlink interface. The advantage is that in userspace we can better decide what to do with the message - for example display a dialogue in your X session or just write the message to the console. As a bonus, we can get rid of problems with console locking deep inside filesystem code once we remove the old printing mechanism. Signed-off-by: Jan Kara <jack@suse.cz> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17docs: ramdisk/initrd/initramfs correctionsRandy Dunlap
initrd/initramfs/ramdisk docs: - fix typos/spellos/grammar - clarify RAM disk config location - correct cpio option Acked-by: Bryan O'Sullivan <bos@serpentine.com> Acked-by: Rob Landley <rob@landley.net> Cc: Werner Almesberger <werner@almesberger.net> Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
