path: root/Documentation/ftrace.txt
2008-11-28ftrace: improve documentationwalimis
Impact: extend documentation with notice of using wild cards correctly We know that we can use wild cards to set set_ftrace_filter, but there's problem when using them naively such as: echo h* > /debug/tracing/set_ftrace_filter If there are files named with "h" prefix in current directory, echo "h*" will echo these filenames to set_ftrace_filter, not the intended "h*". For example: $ cat /debug/tracing/available_filter_functions |grep ^hr |wc -l 23 $ ls $ touch hraa hrdd $ ls hraa hrdd $ echo hr* > /debug/tracing/set_ftrace_filter $ cat /debug/tracing/set_ftrace_filter No output in /debug/tracing/set_ftrace_filter! If we use '' to escape wild cards, it works: $ ls hraa hrdd $ echo "hr*" > /debug/tracing/set_ftrace_filter $ cat /debug/tracing/set_ftrace_filter |wc -l 23 This problem can lead to unexpected result if current directory has a lot of files. Signed-off-by: walimis <walimisdev@gmail.com> Acked-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-26ftrace: add function tracing to single threadSteven Rostedt
Impact: feature to function trace a single thread This patch adds the ability to function trace a single thread. The file: /debugfs/tracing/set_ftrace_pid contains the pid to trace. Valid pids are any positive integer. Writing any negative number to this file will disable the pid tracing and the function tracer will go back to tracing all of threads. This feature works with both static and dynamic function tracing. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-23tracing: identify which executable object the userspace address belongs toTörök Edwin
Impact: modify+improve the userstacktrace tracing visualization feature Store thread group leader id, and use it to lookup the address in the process's map. We could have looked up the address on thread's map, but the thread might not exist by the time we are called. The process might not exist either, but if you are reading trace_pipe, that is unlikely. Example usage: mount -t debugfs nodev /sys/kernel/debug cd /sys/kernel/debug/tracing echo userstacktrace >iter_ctrl echo sym-userobj >iter_ctrl echo sched_switch >current_tracer echo 1 >tracing_enabled cat trace_pipe >/tmp/trace& .... run application ... echo 0 >tracing_enabled cat /tmp/trace You'll see stack entries like: /lib/libpthread-2.7.so[+0xd370] You can convert them to function/line using: addr2line -fie /lib/libpthread-2.7.so 0xd370 Or: addr2line -fie /usr/lib/debug/libpthread-2.7.so 0xd370 For non-PIC/PIE executables this won't work: a.out[+0x73b] You need to run the following: addr2line -fie a.out 0x40073b (where 0x400000 is the default load address of a.out) Signed-off-by: Török Edwin <edwintorok@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-23tracing: add support for userspace stacktraces in tracing/iter_ctrlTörök Edwin
Impact: add new (default-off) tracing visualization feature Usage example: mount -t debugfs nodev /sys/kernel/debug cd /sys/kernel/debug/tracing echo userstacktrace >iter_ctrl echo sched_switch >current_tracer echo 1 >tracing_enabled .... run application ... echo 0 >tracing_enabled Then read one of 'trace','latency_trace','trace_pipe'. To get the best output you can compile your userspace programs with frame pointers (at least glibc + the app you are tracing). Signed-off-by: Török Edwin <edwintorok@gmail.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-13ftrace: rename iter_ctrl to trace_optionsSteven Rostedt
Impact: rename file /debug/tracing/iter_ctrl to /debug/tracing/trace_options The original ftrace had a file called "iter_ctrl" that would control the way the output was iterated. But this file grew into a catch all for different trace options. This patch renames the file from iter_ctrl to trace_options to reflect this change. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-13ftrace: show buffer size in kilobytesSteven Rostedt
Impact: change the units of buffer_size_kb to kilobytes This patch changes the units of the buffer_size_kb file to kilobytes. Reading and writing to the file uses kilobytes as units. To help users to know what units are used, the output of the file now looks like: # cat /debug/tracing/buffer_size_kb 1408 Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-13ftrace: rename trace_entries to buffer_size_kbSteven Rostedt
Impact: rename of debugfs file trace_entries to buffer_size_kb The original ftrace had fixed size entries, and the number of entries was shown and modified via the file called trace_entries. By converting to the unified trace buffer, we now allow for variable size entries which makes the meaning of trace_entries pointless. Since trace_size might be confused to the size of the trace, this patch names it "buffer_size_kb" (thanks to Arjan van de Ven for this idea). [ mingo@elte.hu: changed from buffer_size to buffer_size_kb ] ( Note, the units are still bytes - the next patch changes that, to keep the wide rename patch separate from the unit-change patch. ) Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-04ftrace: ftrace.txt version updateSteven Rostedt
Impact: Documentation update only Update the version that the ftrace document was written for. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-11-04ftrace: update txt documentSteven Rostedt
Impact: Documentation update only A lot of changes have gone into ftrace. This patch updates the ftrace.txt document. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-10-31ftrace: handle archs that do not support irqs_disabled_flagsSteven Rostedt
Impact: build fix on non-lockdep architectures Some architectures do not support a way to read the irq flags that is set from "local_irq_save(flags)" to determine if interrupts were disabled or enabled. Ftrace uses this information to display to the user if the trace occurred with interrupts enabled or disabled. Besides the fact that those archs that do not support this will fail to compile, unless they fix it, we do not want to have the trace simply say interrupts were not disabled or they were enabled, without knowing the real answer. This patch adds a 'X' in the output to let the user know that the architecture they are running on does not support a way for the tracer to determine if interrupts were enabled or disabled. It also lets those same archs compile with tracing enabled. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-08-01dual license ftrace.txtSteven Rostedt
I asked legal about the licensing of ftrace.txt, and they told me that, unless the Documentation directory is specifically set up to handle non GPL licenses (which it does not appear to be), then it would be best to put ftrace.txt under the GPL. This patch adds a dual license to ftrace.txt such that it is under both the FDL and the GPL. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-15ftrace: ftrace.txt updatesSteven Rostedt
This patch includes ftrace.txt updates that address (mostly) comments from Andrew Morton. It also includes updates that were suggested by Randy Dunlap, John Kacur and David Teigland. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-14ftrace: document updatesSteven Rostedt
The following updates were recommended by Elias Oltmanns and Randy Dunlap. [ updates based on Andrew Morton's comments are still to come. ] Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-10ftrace: DocumentationSteven Rostedt
This is the long awaited ftrace.txt. It explains in quite detail how to use ftrace and the various tracers. Signed-off-by: Steven Rostedt <srostedt@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
