path: root/Documentation/gpio.txt
2009-06-12trivial: Miscellaneous documentation typo fixesMatt LaPlante
Fix various typos in documentation txts. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-04-02gpio: gpio_{request,free}() now required (feature removal)David Brownell
We want to phase out the GPIO "autorequest" mechanism in gpiolib and require all callers to use gpio_request(). - Update feature-removal-schedule - Update the documentation now - Convert the relevant pr_warning() in gpiolib to a WARN() so folk using this mechanism get a noisy stack dump Some drivers and board init code will probably need to change. Implementations not using gpiolib will still be fine; they are already required to implement gpio_{request,free}() stubs. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16gpiolib: request/free hooksDavid Brownell
Add a new internal mechanism to gpiolib to support low power operations by letting gpio_chip instances see when their GPIOs are in use. When no GPIOs are active, chips may be able to enter lower powered runtime states by disabling clocks and/or power domains. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: "Magnus Damm" <magnus.damm@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16gpiolib: gpio_to_irq() hooksDavid Brownell
Add a new gpiolib mechanism: gpio_chip instances can provide mappings between their (input) GPIOs and any associated IRQs. This makes it easier for platforms to support IRQs that are provided by board-specific external chips instead of as part of their core (such as SOC-integrated GPIOs). Also update the irq_to_gpio() description, saying to avoid it because it's not always supported. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25gpiolib: allow user-selectionMichael Buesch
This patch adds functionality to the gpio-lib subsystem to make it possible to enable the gpio-lib code even if the architecture code didn't request to get it built in. The archtitecture code does still need to implement the gpiolib accessor functions in its asm/gpio.h file. This patch adds the implementations for x86 and PPC. With these changes it is possible to run generic GPIO expansion cards on every architecture that implements the trivial wrapper functions. Support for more architectures can easily be added. Signed-off-by: Michael Buesch <mb@bu3sch.de> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Stephen Rothwell <sfr@canb.auug.org.au> Cc: David Brownell <david-b@pacbell.net> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Jesper Nilsson <jesper.nilsson@axis.com> Cc: Ralf Baechle <ralf@linux-mips.org> Cc: Paul Mackerras <paulus@samba.org> Cc: Benjamin Herrenschmidt <benh@kernel.crashing.org> Cc: Ingo Molnar <mingo@elte.hu> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Jean Delvare <khali@linux-fr.org> Cc: Samuel Ortiz <sameo@openedhand.com> Cc: Kumar Gala <galak@gate.crashing.org> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Adrian Bunk <bunk@stusta.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-25gpio: sysfs interfaceDavid Brownell
This adds a simple sysfs interface for GPIOs. /sys/class/gpio /export ... asks the kernel to export a GPIO to userspace /unexport ... to return a GPIO to the kernel /gpioN ... for each exported GPIO #N /value ... always readable, writes fail for input GPIOs /direction ... r/w as: in, out (default low); write high, low /gpiochipN ... for each gpiochip; #N is its first GPIO /base ... (r/o) same as N /label ... (r/o) descriptive, not necessarily unique /ngpio ... (r/o) number of GPIOs; numbered N .. N+(ngpio - 1) GPIOs claimed by kernel code may be exported by its owner using a new gpio_export() call, which should be most useful for driver debugging. Such exports may optionally be done without a "direction" attribute. Userspace may ask to take over a GPIO by writing to a sysfs control file, helping to cope with incomplete board support or other "one-off" requirements that don't merit full kernel support: echo 23 > /sys/class/gpio/export ... will gpio_request(23, "sysfs") and gpio_export(23); use /sys/class/gpio/gpio-23/direction to (re)configure it, when that GPIO can be used as both input and output. echo 23 > /sys/class/gpio/unexport ... will gpio_free(23), when it was exported as above The extra D-space footprint is a few hundred bytes, except for the sysfs resources associated with each exported GPIO. The additional I-space footprint is about two thirds of the current size of gpiolib (!). Since no /dev node creation is involved, no "udev" support is needed. Related changes: * This adds a device pointer to "struct gpio_chip". When GPIO providers initialize that, sysfs gpio class devices become children of that device instead of being "virtual" devices. * The (few) gpio_chip providers which have such a device node have been updated. * Some gpio_chip drivers also needed to update their module "owner" field ... for which missing kerneldoc was added. * Some gpio_chips don't support input GPIOs. Those GPIOs are now flagged appropriately when the chip is registered. Based on previous patches, and discussion both on and off LKML. A Documentation/ABI/testing/sysfs-gpio update is ready to submit once this merges to mainline. [akpm@linux-foundation.org: a few maintenance build fixes] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> Cc: Greg KH <greg@kroah.com> Cc: Kay Sievers <kay.sievers@vrfy.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-28gpio: define gpio_is_valid()Guennadi Liakhovetski
Introduce a gpio_is_valid() predicate; use it in gpiolib. Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@pengutronix.de> [ use inline function; follow the gpio_* naming convention; work without gpiolib; all programming interfaces need docs ] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-03-04gpio: <linux/gpio.h> and "no GPIO support here" stubsDavid Brownell
Add a <linux/gpio.h> defining fail/warn stubs for GPIO calls on platforms that don't support the GPIO programming interface. That includes the arch-specific implementation glue otherwise. This facilitates a new model for GPIO usage: drivers that can use GPIOs if they're available, but don't require them. One example of such a driver is NAND driver for various FreeScale chips. On platforms update with GPIO support, they can be used instead of a worst-case delay to verify that the BUSY signal is off. (Also includes a couple minor unrelated doc updates.) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-05gpiolib: update Documentation/gpio.txtDavid Brownell
Update Documentation/gpio.txt, primarily to include the new "gpiolib" infrastructure. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Jean Delvare <khali@linux-fr.org> Cc: Eric Miao <eric.miao@marvell.com> Cc: Sam Ravnborg <sam@ravnborg.org> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Philipp Zabel <philipp.zabel@gmail.com> Cc: Russell King <rmk@arm.linux.org.uk> Cc: Ben Gardner <bgardner@wabtec.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-24minor gpio doc updateDavid Brownell
Fix doc bug noted by Uwe Kleine-König: gpio_set_direction() is long gone, replaced by gpio_direction_input() and gpio_direction_output(). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: <ukleinek@informatik.uni-freiburg.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-19gpio calls don't need i/o barriersDavid Brownell
Clarify that drivers using the GPIO operations don't need to issue io barrier instructions themselves. Previously this wasn't clear, and at least one platform assumed otherwise (and would thus break various otherwise-portable drivers which don't issue barriers). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-17gpio interface loosens call restrictionsDavid Brownell
Loosen gpio_{request,free}() and gpio_direction_{in,out}put() call context restrictions slightly, so a common idiom is no longer an error: board init code setting up spinlock-safe GPIOs before tasking is enabled. The issue was caught by some paranoid code with might_sleep() checks. The legacy platform-specific GPIO interfaces stick to spinlock-safe GPIOs, so this change reflects current implementations and won't break anything. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-11Documentation/gpio.txt mentions GENERIC_GPIODavid Brownell
Documentation/gpio.txt should mention the Kconfig GENERIC_GPIO flag, for platforms to declare when relevant. This should help minimize goofs like omitting it, or not depending on it when needed. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-12[PATCH] doc: gpio.txt describes open-drain emulationDavid Brownell
Update the GPIO docs to describe the idiom whereby open drain signals are emulated by toggling the GPIO direction. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-03-16[PATCH] gpio_direction_output() needs an initial valueDavid Brownell
It's been pointed out that output GPIOs should have an initial value, to avoid signal glitching ... among other things, it can be some time before a driver is ready. This patch corrects that oversight, fixing - documentation - platforms supporting the GPIO interface - users of that call (just one for now, others are pending) There's only one user of this call for now since most platforms are still using non-generic GPIO setup code, which in most cases already couples the initial value with its "set output mode" request. Note that most platforms are clear about the hardware letting the output value be set before the pin direction is changed, but the s3c241x docs are vague on that topic ... so those chips might not avoid the glitches. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Andrew Victor <andrew@sanpeople.com> Acked-by: Milan Svoboda <msvoboda@ra.rockwell.com> Acked-by: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Russell King <rmk@arm.linux.org.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-16[PATCH] GPIO core documentationDavid Brownell
Small updates to the GPIO documentation, addressing feedback and fixing a few spelling errors. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] GPIO coreDavid Brownell
This defines a simple and minimalist programming interface for GPIO APIs: - Documentation/gpio.txt ... describes things (read it) - include/asm-arm/gpio.h ... defines the ARM hook, which just punts to <asm/arch/gpio.h> for any implementation - include/asm-generic/gpio.h ... implement "can sleep" variants as calling the normal ones, for systems that don't handle i2c expanders. The immediate need for such a cross-architecture API convention is to support drivers that work the same on AT91 ARM and AVR32 AP7000 chips, which embed many of the same controllers but have different CPUs. However, several other users have been reported, including a driver for a hardware watchdog chip and some handhelds.org multi-CPU button drivers. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
