path: root/Documentation/gpu
2016-10-11Merge tag 'drm-for-v4.9' of git://people.freedesktop.org/~airlied/linuxLinus Torvalds
Pull drm updates from Dave Airlie: "Core: - Fence destaging work - DRIVER_LEGACY to split off legacy drm drivers - drm_mm refactoring - Splitting drm_crtc.c into chunks and documenting better - Display info fixes - rbtree support for prime buffer lookup - Simple VGA DAC driver Panel: - Add Nexus 7 panel - More simple panels i915: - Refactoring GEM naming - Refactored vma/active tracking - Lockless request lookups - Better stolen memory support - FBC fixes - SKL watermark fixes - VGPU improvements - dma-buf fencing support - Better DP dongle support amdgpu: - Powerplay for Iceland asics - Improved GPU reset support - UVD/VEC powergating support for CZ/ST - Preinitialised VRAM buffer support - Virtual display support - Initial SI support - GTT rework - PCI shutdown callback support - HPD IRQ storm fixes amdkfd: - bugfixes tilcdc: - Atomic modesetting support mediatek: - AAL + GAMMA engine support - Hook up gamma LUT - Temporal dithering support imx: - Pixel clock from devicetree - drm bridge support for LVDS bridges - active plane reconfiguration - VDIC deinterlacer support - Frame synchronisation unit support - Color space conversion support analogix: - PSR support - Better panel on/off support rockchip: - rk3399 vop/crtc support - PSR support vc4: - Interlaced vblank timing - 3D rendering CPU overhead reduction - HDMI output fixes tda998x: - HDMI audio ASoC support sunxi: - Allwinner A33 support - better TCON support msm: - DT binding cleanups - Explicit fence-fd support sti: - remove sti415/416 support etnaviv: - MMUv2 refactoring - GC3000 support exynos: - Refactoring HDMI DCC/PHY - G2D pm regression fix - Page fault issues with wait for vblank There is no nouveau work in this tree, as Ben didn't get a pull request in, and he was fighting moving to atomic and adding mst support, so maybe best it waits for a cycle" * tag 'drm-for-v4.9' of git://people.freedesktop.org/~airlied/linux: (1412 commits) drm/crtc: constify drm_crtc_index parameter drm/i915: Fix conflict resolution from backmerge of v4.8-rc8 to drm-next drm/i915/guc: Unwind GuC workqueue reservation if request construction fails drm/i915: Reset the breadcrumbs IRQ more carefully drm/i915: Force relocations via cpu if we run out of idle aperture drm/i915: Distinguish last emitted request from last submitted request drm/i915: Allow DP to work w/o EDID drm/i915: Move long hpd handling into the hotplug work drm/i915/execlists: Reinitialise context image after GPU hang drm/i915: Use correct index for backtracking HUNG semaphores drm/i915: Unalias obj->phys_handle and obj->userptr drm/i915: Just clear the mmiodebug before a register access drm/i915/gen9: only add the planes actually affected by ddb changes drm/i915: Allow PCH DPLL sharing regardless of DPLL_SDVO_HIGH_SPEED drm/i915/bxt: Fix HDMI DPLL configuration drm/i915/gen9: fix the watermark res_blocks value drm/i915/gen9: fix plane_blocks_per_line on watermarks calculations drm/i915/gen9: minimum scanlines for Y tile is not always 4 drm/i915/gen9: fix the WaWmMemoryReadLatency implementation drm/i915/kbl: KBL also needs to run the SAGV code ...
2016-09-22drm: Remove dirty property from docsDaniel Vetter
We removed it in commit 6ab10b76ff6252bd9be0849c40f5865e39a29961 Author: Daniel Vetter <daniel.vetter@ffwll.ch> Date: Fri Aug 12 22:48:45 2016 +0200 drm/kms: Nuke dirty_info property Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Signed-off-by: Sean Paul <seanpaul@chromium.org> Link: http://patchwork.freedesktop.org/patch/msgid/1474448370-32227-7-git-send-email-daniel.vetter@ffwll.ch
2016-09-22drm/doc: Document color space handlingDaniel Vetter
Again move it from the unmaintainable csv into DOC free-form overview sections. v2: Types Lionel&Sean spotted. Cc: Lionel Landwerlin <lionel.g.landwerlin@intel.com> Reviewed-by: Sean Paul <seanpaul@chromium.org> Reviewed-by: Lionel Landwerlin <lionel.g.landwerlin@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Signed-off-by: Sean Paul <seanpaul@chromium.org> Link: http://patchwork.freedesktop.org/patch/msgid/1474448370-32227-6-git-send-email-daniel.vetter@ffwll.ch
2016-09-22drm/doc: Polish plane composition property docsDaniel Vetter
Try to spec a bit more precisely how they all fit together, now that at least the code is for all the additional properties is in one place. Also remove the entries for the standardized properties from the table, because that thing is supremely unmaintaineable. v2: Fix typos Sean spotted. Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Cc: Sean Paul <seanpaul@chromium.org> Cc: Benjamin Gaignard <benjamin.gaignard@linaro.org> Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Signed-off-by: Sean Paul <seanpaul@chromium.org> Link: http://patchwork.freedesktop.org/patch/msgid/1474448370-32227-4-git-send-email-daniel.vetter@ffwll.ch
2016-09-22drm/doc: Polish for drm_plane.[hc]Daniel Vetter
Big thing is untangling and carefully documenting the different uapi types of planes. I also sprinkled a few more cross references around to make this easier to discover. As usual, remove the kerneldoc for internal functions which are not exported. Aside: We should probably go OCD on all the ioctl handlers and consistenly give them an _ioctl postfix. Acked-by: Archit Taneja <architt@codeaurora.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Signed-off-by: Sean Paul <seanpaul@chromium.org> Link: http://patchwork.freedesktop.org/patch/msgid/1474448370-32227-2-git-send-email-daniel.vetter@ffwll.ch
2016-09-22drm: Extract drm_plane.[hc]Daniel Vetter
Just pure code movement, cleanup and polish will happen in later patches. v2: Don't forget all the ioctl! To extract those cleanly I decided to put check_src_coords into drm_framebuffer.c (and give it a drm_framebuffer_ prefix), since that just checks framebuffer constraints. v3: rebase over PAGE_FLIP_TARGET. Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> [seanpaul] This patch as posted on the list was rebased on: commit 6f00975c619064a18c23fd3aced325ae165a73b9 Author: Daniel Vetter <daniel.vetter@ffwll.ch> Date: Sat Aug 20 12:22:11 2016 +0200 drm: Reject page_flip for !DRIVER_MODESET so as a result of moving the page_flip ioctl, this fix has been rolled into this patch. Signed-off-by: Sean Paul <seanpaul@chromium.org>
2016-09-19drm: Move all decl for drm_edid.c to drm_edid.hDaniel Vetter
Some were still left in drm_crtc.h. Also include drm_edid.h in the rst files. Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/20160831160913.12991-4-daniel.vetter@ffwll.ch
2016-09-19drm: Extract drm_bridge.hDaniel Vetter
We don't want to burry the bridge structures kerneldoc in drm_crtc.h. Cc: Archit Taneja <archit.taneja@gmail.com> Reviewed-by: Archit Taneja <architt@codeaurora.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/20160831160913.12991-3-daniel.vetter@ffwll.ch
2016-09-01drm/doc: Add a few words on validation with IGTTomeu Vizoso
Also provide some pointers for building IGT as some kernel hackers might not be that familiar with building stuff on Linux distros. Signed-off-by: Tomeu Vizoso <tomeu.vizoso@collabora.com> Cc: Daniel Vetter <daniel.vetter@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/1472715695-19812-1-git-send-email-tomeu.vizoso@collabora.com
2016-08-29drm/doc: Polish docs for drm_property&drm_property_blobDaniel Vetter
- remove kerneldoc for drm-internal functions - drm_property_replace_global_blob isn't actually atomic, and doesn't need to be. Update docs&comments to match - document all the types and try to link things a bit better - nits all over v2: Appease checkpatch in the moved code (Archit) Reviewed-by: Archit Taneja <architt@codeaurora.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/20160829082757.17913-9-daniel.vetter@ffwll.ch
2016-08-29drm: Extract drm_property.[hc]Daniel Vetter
This just contains the base property classes and all the code to handle blobs. I think for any kind of standardized/shared properties it's better to have separate files - this is fairly big already as-is. v2: resurrect misplaced hunk (Daniel Stone) Cc: Daniel Stone <daniel@fooishbar.org> Reviewed-by: Archit Taneja <architt@codeaurora.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/20160829082757.17913-7-daniel.vetter@ffwll.ch
2016-08-29drm: Extract drm_mode_object.[hc]Daniel Vetter
Just for the struct drm_mode_object base class. The header file was already partially extracted to help untangle the include loops. v2: - Also move the generic get/set property ioctls. At first this seemed like a bad idea since it requires making drm_mode_crtc_set_obj_prop non-static. But eventually that will get split away too (like the connector version already is) for both crtc and planes. Hence I reconsidered. - drm_mode_object.[hc] instead of drm_modeset.[hc], which requires renaming the drm_modeset.h header I already started building up. This is more consistent (matches the name of the main structure), and I want to be able to use drm_modeset.[hc] for the basic modeset init/cleanup functionality like drm_mode_config_init. Reviewed-by: Archit Taneja <architt@codeaurora.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/20160829082757.17913-3-daniel.vetter@ffwll.ch
2016-08-29drm/doc: Polish kerneldoc for encodersDaniel Vetter
- Move missing bits into struct drm_encoder docs. - Explain that encoders are 95% internal and only 5% uapi, and that in general the uapi part is broken. - Remove verbose comments for functions not exposed to drivers. v2: Review from Archit: - Appease checkpatch in the moved code. - Make it clearer that bridges are not exposed to userspace. Reviewed-by: Archit Taneja <architt@codeaurora.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/20160829082757.17913-2-daniel.vetter@ffwll.ch
2016-08-29drm: Extract drm_encoder.[hc]Daniel Vetter
Same treatment as before. Only hiccup is drm_crtc_mask, which unfortunately can't be resolved until drm_crtc.h is less of a monster. Untangle the header loop with a forward declaration for that static inline. Reviewed-by: Archit Taneja <architt@codeaurora.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/20160829082757.17913-1-daniel.vetter@ffwll.ch
2016-08-24drm/doc: Fix vga_switcheroo xrefDaniel Vetter
Reported-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Chris Wilson <chris@chris-wilson.co.uk> Fixes: b754b35b089d ("vgaarbiter: rst-ifiy and polish kerneldoc") Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/20160824101916.30125-1-daniel.vetter@ffwll.ch
2016-08-24drm/doc: Document uapi requirements in DRMDaniel Vetter
Everyone knows them, except all the new folks joining from the ARM side haven't lived through all the pain of the past years and are entirely surprised when I raise this. Definitely time to document this. Last time this was a big discussion was about 6 years ago, when qcom tried to land a kernel driver without userspace. Dave Airlie made the rules really clear: http://airlied.livejournal.com/73115.html This write-up here is essentially what I've put into a presentation a while ago, which was also reviewed by Dave: http://blog.ffwll.ch/2015/05/gfx-kernel-upstreaming-requirements.html v2: Fix typos Eric&Rob spotted. v3: Nitpick from Jani. Cc: Dave Airlie <airlied@gmail.com> Cc: Oded Gabbay <oded.gabbay@gmail.com> Cc: Russell King <rmk+kernel@armlinux.org.uk> Cc: Tomi Valkeinen <tomi.valkeinen@ti.com> Cc: Eric Anholt <eric@anholt.net> Cc: Thomas Hellstrom <thellstrom@vmware.com> Cc: Sinclair Yeh <syeh@vmware.com> Cc: Lucas Stach <l.stach@pengutronix.de> Cc: Benjamin Gaignard <benjamin.gaignard@linaro.org> Cc: Mark Yao <mark.yao@rock-chips.com> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: Ben Skeggs <bskeggs@redhat.com> Cc: Rob Clark <robdclark@gmail.com> Cc: CK Hu <ck.hu@mediatek.com> Cc: Xinliang Liu <z.liuxinliang@hisilicon.com> Cc: Philipp Zabel <p.zabel@pengutronix.de> Cc: Stefan Agner <stefan@agner.ch> Cc: Inki Dae <inki.dae@samsung.com> Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: Boris Brezillon <boris.brezillon@free-electrons.com> Cc: Jani Nikula <jani.nikula@linux.intel.com> Cc: Daniel Vetter <daniel.vetter@intel.com> Cc: Thierry Reding <thierry.reding@gmail.com> Cc: Christian König <christian.koenig@amd.com> Cc: Alex Deucher <alexander.deucher@amd.com> Cc: Gerd Hoffmann <kraxel@redhat.com> Cc: Brian Starkey <brian.starkey@arm.com> Cc: Liviu Dudau <liviu.dudau@arm.com> Cc: Alexey Brodkin <abrodkin@synopsys.com> Acked-by: Dave Airlie <airlied@gmail.com> Reviewed-by: Rob Clark <robdclark@gmail.com> Reviewed-by: Christian König <christian.koenig@amd.com> Reviewed-by: Eric Anholt <eric@anholt.net> Reviewed-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Signed-off-by: Dave Airlie <airlied@redhat.com>
2016-08-18doc-rst: add index to sub-foldersMarkus Heiser
Add a index if only a sub-folder is build e.g.:: make SPHINXDIRS=media cleandocs htmldocs BTW: removed dead search link in the top-index file Signed-off-by: Markus Heiser <markus.heiser@darmarIT.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-08-16vgaarbiter: rst-ifiy and polish kerneldocDaniel Vetter
Move the documentation into Documentation/gpu, link it up and pull in the kernel doc. No actual text changes except that I did polish the kerneldoc a bit, especially for vga_client_register(). v2: Remove some rst from vga-switcheroo.rst that I don't understand, but which seems to be the reason why the new vgaarbiter.rst sometimes drops out of the sidebar index. v3: Drop one level of headings and clarify the vgaarb one a bit. v4: Fix some typos (Sean). Cc: Jonathan Corbet <corbet@lwn.net> Cc: linux-doc@vger.kernel.org Cc: Sean Paul <seanpaul@chromium.org> Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1471034937-651-20-git-send-email-daniel.vetter@ffwll.ch
2016-08-16drm: Update connector documentationDaniel Vetter
- Shuffle docs from drm-kms.rst into the structure docs where it makes sense. - Put the remaining bits into a new overview section. One thing I've changed is around probing: Old docs says that you _must_ use the probe helpers, which isn't correct. Helpers are always optional. v2: Review from Sean. Cc: Sean Paul <seanpaul@chromium.org> Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1471034937-651-17-git-send-email-daniel.vetter@ffwll.ch
2016-08-16drm/doc: Include new drm_blend.cDaniel Vetter
There's not much point in kerneldoc if it's not included: - It won't show up in the pretty html pages. - The comments itself won't get parsed, which means 0day won't pick up changes, resulting in stale docs fast. Also, uapi really should be core, not helpers, so move drm_blend.c to that. That also means that the zpos normilize function loses it's helper status (and we might as well call it always). For that, EXPORT_SYMBOL. Just spotted while integrating docs and noticing that one was missing. With sphinx there's really no excuse any more to not build the docs and make sure it's all nice! $ make DOCBOOKS="" htmldocs Cc: Marek Szyprowski <m.szyprowski@samsung.com> Cc: Benjamin Gaignard <benjamin.gaignard@linaro.org> Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1471034937-651-15-git-send-email-daniel.vetter@ffwll.ch
2016-08-16drm: Extract drm_connector.[hc]Daniel Vetter
Pulls in quite a lot of connector related structures (cmdline mode, force/status enums, display info), but I think that all makes perfect sense. Also had to move a few more core kms object stuff into drm_modeset.h. And as a first cleanup remove the kerneldoc for the 2 connector IOCTL - DRM core docs are aimed at drivers, no point documenting internal in excruciating detail. v2: And also pull in all the connector property code. Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1471034937-651-14-git-send-email-daniel.vetter@ffwll.ch
2016-08-16drm/doc: Update drm_framebuffer docsDaniel Vetter
- Move the intro section into a DOC comment, and update it slightly. - kernel-doc for struct drm_framebuffer! v2: - Copypaste fail (Sean). - Explain the linear @offsets clearer (Ville). Cc: Sean Paul <seanpaul@chromium.org> Cc: Ville Syrjälä <ville.syrjala@linux.intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1471034937-651-12-git-send-email-daniel.vetter@ffwll.ch
2016-08-16drm: Extract drm_framebuffer.[hc]Daniel Vetter
Also start with drm_modeset.h with the core bits, since we need to untangle this mess somehow. That allows us to move the drm_modes.h include to the right spot, except for the temporary connector status enum. That will get fixed as soon as drm_connector.h exists. v2: Rebase. v3: Move drm_crtc_force_disable_all back again, that wasn't meant to be moved (Sean). v4: Rebase. Cc: Sean Paul <seanpaul@chromium.org> Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch>
2016-08-16drm/doc: Include drm_atomic.hDaniel Vetter
Accidentally the wrong file. Oops. Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/1471034937-651-10-git-send-email-daniel.vetter@ffwll.ch
2016-08-16drm/doc: Reorg for drm-kms.rstDaniel Vetter
- Again adjust headings a bit, and don't mix up the initialization sections with other stuff. - Remove the doc for output polling, that vfunc is now properly documented in the vfunc reference sections. - Move the grab-bag with all the core stuff (i.e. drm_crtc.[hc]) to the front for a more prominent place. Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1471034937-651-5-git-send-email-daniel.vetter@ffwll.ch
2016-08-16drm/doc: Reorg drm-mm.rstDaniel Vetter
- Readjust headings - we lost one level through the extraction into a separate .rst file. - Merge helper reference sections with the helper documentation - that split was just an artifact of the docbook toolchain sucking at too deep nesting levels. No such problems with sphinx. - Move the cma helpers in with the gem documentation, since they're helpers to implement gem using CMA/dma memory as a backend. Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1471034937-651-4-git-send-email-daniel.vetter@ffwll.ch
2016-08-16drm/kms-helpers: Extract drm_modeset_helper.[hc]Daniel Vetter
While reviewing docs I spotted that we have a few functions that really just don't fit into their containing helper library section. Extract them and shovel them all into a new library for random one-off aux stuff. v2: Remove wrongly added files for real. Cc: Sean Paul <seanpaul@chromium.org> Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1471034937-651-3-git-send-email-daniel.vetter@ffwll.ch
2016-08-16drm/doc: Light drm-kms-helper.rst cleanupDaniel Vetter
- Move the common vtable stuff to the top - Move "Tile Group" to a more appropriate heading level - Throw away the old intro for the crtc helpers (it's entirely stale, e.g. helpers have become modular years ago), and replace it with a general intro about the motivation behind helpers. - Reorder helpers to group them together a bit better, and explain that grouping in the intro. - Make sure the introductory DOC section is always first. v2: - Remove bogus files accidentally added (Sean). - Spelling fixes (Sean). Cc: Sean Paul <seanpaul@chromium.org> Reviewed-by: Sean Paul <seanpaul@chromium.org> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1471034937-651-2-git-send-email-daniel.vetter@ffwll.ch
2016-08-15Merge tag 'drm-intel-next-2016-08-08' of ↵Dave Airlie
git://anongit.freedesktop.org/drm-intel into drm-next - refactor ddi buffer programming a bit (Ville) - large-scale renaming to untangle naming in the gem code (Chris) - rework vma/active tracking for accurately reaping idle mappings of shared objects (Chris) - misc dp sst/mst probing corner case fixes (Ville) - tons of cleanup&tunings all around in gem - lockless (rcu-protected) request lookup, plus use it everywhere for non(b)locking waits (Chris) - pipe crc debugfs fixes (Rodrigo) - random fixes all over * tag 'drm-intel-next-2016-08-08' of git://anongit.freedesktop.org/drm-intel: (222 commits) drm/i915: Update DRIVER_DATE to 20160808 drm/i915: fix aliasing_ppgtt leak drm/i915: Update comment before i915_spin_request drm/i915: Use drm official vblank_no_hw_counter callback. drm/i915: Fix copy_to_user usage for pipe_crc Revert "drm/i915: Track active streams also for DP SST" drm/i915: fix WaInsertDummyPushConstPs drm/i915: Assert that the request hasn't been retired drm/i915: Repack fence tiling mode and stride into a single integer drm/i915: Document and reject invalid tiling modes drm/i915: Remove locking for get_tiling drm/i915: Remove pinned check from madvise ioctl drm/i915: Reduce locking inside swfinish ioctl drm/i915: Remove (struct_mutex) locking for busy-ioctl drm/i915: Remove (struct_mutex) locking for wait-ioctl drm/i915: Do a nonblocking wait first in pread/pwrite drm/i915: Remove unused no-shrinker-steal drm/i915: Tidy generation of the GTT mmap offset drm/i915/shrinker: Wait before acquiring struct_mutex under oom drm/i915: Simplify do_idling() (Ironlake vt-d w/a) ...
2016-08-14doc-rst: add stand-alone conf.py to gpu folderMarkus Heiser
With the gpu/conf.py, the gpu folder can be build and distributed stand-alone. To compile only the html of 'gpu' folder use:: make SPHINXDIRS="gpu" htmldocs Signed-off-by: Markus Heiser <markus.heiser@darmarIT.de> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-08-08drm: Mark up legacy/dri1 drivers with DRM_LEGACYDaniel Vetter
It's super confusing that new drivers need to be marked with DRIVER_MODESET when really it means DRIVER_MODERN. Much better to invert the meaning and rename it to something that's suitably off-putting. Since there's over 100 places using DRIVER_MODESET we need to roll out this change without a flag day. v2: Update docs. Reviewed-by: Frank Binns <frank.binns@imgtec.com> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1470251470-30830-1-git-send-email-daniel.vetter@ffwll.ch
2016-08-05Merge remote-tracking branch 'airlied/drm-next' into drm-intel-next-queuedDaniel Vetter
Backmerge the 4.8 pull request state from Dave - conflicts were getting out of hand, and Chris has some patches which outright don't apply without everything merged together again. Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
2016-08-04drm/i915: Separate intel_frontbuffer into its own headerChris Wilson
In view of adding inline functions into the intel_frontbuffer section, we first split the header into its own file so that we can integrate it more easily with kerneldoc. Signed-off-by: Chris Wilson <chris@chris-wilson.co.uk> Cc: Daniel Vetter <daniel.vetter@ffwll.ch> Reviewed-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/1470324762-2545-19-git-send-email-chris@chris-wilson.co.uk
2016-07-29drm: add generic zpos propertyMarek Szyprowski
version 8: - move drm_blend.o from drm-y to drm_kms_helper-y to avoid EXPORT_SYMBOL(drm_atomic_helper_normalize_zpos) - remove dead function declarations in drm_crtc.h version 7: - remove useless EXPORT_SYMBOL() - better z-order wording in Documentation version 6: - add zpos in gpu documentation file - merge Ville patch about zpos initial value and API improvement. I have split Ville patch between zpos core and drivers version 5: - remove zpos range check and comeback to 0 to N-1 normalization algorithm version 4: - make sure that normalized zpos value is stay in the defined property range and warn user if not This patch adds support for generic plane's zpos property property with well-defined semantics: - added zpos properties to plane and plane state structures - added helpers for normalizing zpos properties of given set of planes - well defined semantics: planes are sorted by zpos values and then plane id value if zpos equals Normalized zpos values are calculated automatically when generic muttable zpos property has been initialized. Drivers can simply use plane_state->normalized_zpos in their atomic_check and/or plane_update callbacks without any additional calls to DRM core. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Compare to Marek's original patch zpos property is now specific to each plane and no more to the core. Normalize function take care of the range of per plane defined range before set normalized_zpos. Signed-off-by: Benjamin Gaignard <benjamin.gaignard@linaro.org> Reviewed-by: Ville Syrjälä <ville.syrjala@linux.intel.com> Acked-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Tested-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Cc: Inki Dae <inki.dae@samsung.com> Cc: Daniel Vetter <daniel@ffwll.ch> Cc: Ville Syrjala <ville.syrjala@linux.intel.com> Cc: Joonyoung Shim <jy0922.shim@samsung.com> Cc: Seung-Woo Kim <sw0312.kim@samsung.com> Cc: Andrzej Hajda <a.hajda@samsung.com> Cc: Krzysztof Kozlowski <k.kozlowski@samsung.com> Cc: Bartlomiej Zolnierkiewicz <b.zolnierkie@samsung.com> Cc: Tobias Jakobi <tjakobi@math.uni-bielefeld.de> Cc: Gustavo Padovan <gustavo@padovan.org> Cc: vincent.abriou@st.com Cc: fabien.dessenne@st.com Cc: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
2016-07-19drm/doc: Spinx leftoversDaniel Vetter
This is unfortunately not all the sphinx noise when building the gpu documentations. But the remaining warnings have completely bogus line and probably also file sources, and I just can't find them. Probably some serious debuggging of the line annotations in the sphinx/kernel-doc toolchain needed first. Acked-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1468612088-9721-11-git-send-email-daniel.vetter@ffwll.ch
2016-07-19drm: Extract&Document drm_irq.hDaniel Vetter
The drm_irq docs want one function from drmP.h, but that one is a serious mess. Extract it, and while at it improve the docs a bit. There's a bit a header loop issue since core data structures like drm_device and drm_driver aren't in their own headers yet, which means the drm_irq.h include in drmP.h needs to be in just the right spot :( Also noticed that drm_vblank_crtc->last_wait is entirely unused, remove it. v2: git add drm_irq.h ... Acked-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
2016-07-19drm/drm-kms.rst: Remove unused drm_fourcc.h include directiveDaniel Vetter
Right now there's nothing, and kernel-doc produces a warning because of that. Remove it until we need it for a clean build. Cc: Laurent Pinchart <laurent.pinchart+renesas@ideasonboard.com> Acked-by: Chris Wilson <chris@chris-wilson.co.uk> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com> Link: http://patchwork.freedesktop.org/patch/msgid/1468612088-9721-1-git-send-email-daniel.vetter@ffwll.ch
2016-07-12vga_switcheroo: Sphinxify docsLukas Wunner
Fix up formatting glitches remaining after the automatic rst conversion. Cc: Jonathan Corbet <corbet@lwn.net> Cc: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Lukas Wunner <lukas@wunner.de> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/3a369602ae35fdbf5e4a12f7e172088c89fa27bb.1468225027.git.lukas@wunner.de
2016-06-21drm: document drm_auth.cDaniel Vetter
Also extract drm_auth.h for nicer grouping. v2: Nuke the other comments since they don't really explain a lot, and within the drm core we generally only document functions exported to drivers: The main audience for these docs are driver writers. v3: Limit the exposure of drm_master internals by only including drm_auth.h where it is neede (Chris). v4: Spelling polish (Emil). Cc: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Chris Wilson <chris@chris-wilson.co.uk> Reviewed-by: Emil Velikov <emil.l.velikov@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
2016-06-21drm: Lobotomize set_busid nonsense for !pci driversDaniel Vetter
We already have a fallback in place to fill out the unique from dev->unique, which is set to something reasonable in drm_dev_alloc. Which means we only need to have a special set_busid for pci devices, to be able to care the backwards compat code for drm 1.1 around, which libdrm still needs. While developing and testing this patch things blew up in really interesting ways, and the code is rather confusing in naming things between the kernel code, ioctl #defines and libdrm. For the next brave dragon slayer, document all this madness properly in the userspace interface section of gpu.tmpl. v2: Make drm_dev_set_unique static and update kerneldoc. v3: Entire rewrite, plus document what's going on for posterity in the gpu docbook uapi section. v4: Drop accidental amdgpu hunk (Emil). v5: Drop accidental omapdrm vblank counter change (Emil). v6: Rebase on top of the sphinx conversion. Cc: Gustavo Padovan <gustavo.padovan@collabora.co.uk> Cc: Emil Velikov <emil.l.velikov@gmail.com> Tested-by: Gustavo Padovan <gustavo.padovan@collabora.co.uk> (virt_gpu) Reviewed-by: Emil Velikov <emil.l.velikov@gmail.com> Signed-off-by: Daniel Vetter <daniel.vetter@intel.com>
2016-06-21Documentation/gpu: split up mm, kms and kms-helpers from internalsJani Nikula
Make the documents more manageable. Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/be992e56eb8442d6e03b52444df5a42525085718.1466506505.git.jani.nikula@intel.com
2016-06-21Documentation/gpu: convert the KMS properties table to CSVJani Nikula
Pandoc really did a bad job of converting the big KMS properties table to RST. Instead, put the properties into a separate plain text CSV file, and include it in the RST file. The generated output isn't very pretty, but at least the information is there, and it's stored in a format that's easier to process and improve upon at a later time. The CSV file was generated by copy-pasting the table from the HTML generated by the DocBook toolchain into LibreOffice Calc, and then saved as CSV, unmodified. Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/17053ff08caf5cfac4f478437ef796f83a31d772.1466506505.git.jani.nikula@intel.com
2016-06-21Documentation/gpu: use recommended order of heading markersJani Nikula
While splitting the document up, the headings "shifted" from what pandoc generated. Use the following order for headings for consistency: ============== Document title ============== First ===== Second ------ Third ~~~~~ Leave the lower level headings as they are; I think those are less important. Although RST doesn't mandate a specific order ("Rather than imposing a fixed number and order of section title adornment styles, the order enforced will be the order as encountered."), having the higher levels the same overall makes it easier to follow the documents. [I'm sort of kind of writing the recommendation for docs-next in the mean time, but this order seems sensible, and is what I'm proposing.] Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/126f42734defac6cbb8496a481d58db7b38461dd.1466506505.git.jani.nikula@intel.com
2016-06-21Documentation/gpu: split up the gpu documentationJani Nikula
Make the gpu documentation easier to manage by splitting to separate files. Again, this is just the split, no real edits. Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/bd2b599b5105c28c8f05923005e6cc9b7efa7fc1.1466506505.git.jani.nikula@intel.com
2016-06-21Documentation/gpu: add new gpu.rst converted from DocBook gpu.tmplJani Nikula
This is the first step towards converting the DocBook gpu.tmpl to Sphinx and reStructuredText, the new kernel documentation tool and markup. Use Jon's "cheesy conversion script" in Documentation/sphinx/tmplcvt to do the rough conversion. Do the manual edits in follow-up patches. Add a new Documentation/gpu directories for the graphics related documentation. (Hooray, now we can have directories based on topics rather than tools under Documentation.) We also won't remove the DocBook gpu.tmpl yet so it's easier to build both and compare the results for parity. Signed-off-by: Jani Nikula <jani.nikula@intel.com> Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Link: http://patchwork.freedesktop.org/patch/msgid/bc7b4f9ac037632e0c8469c079d21fad5eaa39a0.1466506505.git.jani.nikula@intel.com
