path: root/Documentation/hid
2014-06-04Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial into next Pull trivial tree changes from Jiri Kosina: "Usual pile of patches from trivial tree that make the world go round" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits) staging: go7007: remove reference to CONFIG_KMOD aic7xxx: Remove obsolete preprocessor define of: dma: doc fixes doc: fix incorrect formula to calculate CommitLimit value doc: Note need of bc in the kernel build from 3.10 onwards mm: Fix printk typo in dmapool.c modpost: Fix comment typo "Modules.symvers" Kconfig.debug: Grammar s/addition/additional/ wimax: Spelling s/than/that/, wording s/destinatary/recipient/ aic7xxx: Spelling s/termnation/termination/ arm64: mm: Remove superfluous "the" in comment of: Spelling s/anonymouns/anonymous/ dma: imx-sdma: Spelling s/determnine/determine/ ath10k: Improve grammar in comments ath6kl: Spelling s/determnine/determine/ of: Improve grammar for of_alias_get_id() documentation drm/exynos: Spelling s/contro/control/ radio-bcm2048.c: fix wrong overflow check doc: printk-formats: do not mention casts for u64/s64 doc: spelling error changes ...
2014-05-05doc: spelling error changesCarlos Garcia
Fixed multiple spelling errors. Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Carlos E. Garcia <carlos@cgarcia.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-04-01HID: uhid: Add UHID_CREATE2 + UHID_INPUT2Petri Gynther
UHID_CREATE2: HID report descriptor data (rd_data) is an array in struct uhid_create2_req, instead of a pointer. Enables use from languages that don't support pointers, e.g. Python. UHID_INPUT2: Data array is the last field of struct uhid_input2_req. Enables userspace to write only the required bytes to kernel (ev.type + ev.u.input2.size + the part of the data array that matters), instead of the entire struct uhid_input2_req. Note: UHID_CREATE2 increases the total size of struct uhid_event slightly, thus increasing the size of messages that are queued for userspace. However, this won't affect the userspace processing of these events. [Jiri Kosina <jkosina@suse.cz>: adjust to hid_get_raw_report() and hid_output_raw_report() API changes] Signed-off-by: Petri Gynther <pgynther@google.com> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-02-24HID: make .raw_request mandatoryBenjamin Tissoires
SET_REPORT and GET_REPORT are mandatory in the HID specification. Make the corresponding API in hid-core mandatory too, which removes the need to test against it in some various places. Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Reviewed-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-02-17HID: Add HID transport driver documentationBenjamin Tissoires
Add David Herrmann's documentation for the new low-level HID transport driver functions. Signed-off-by: Frank Praznik <frank.praznik@oh.rr.com> Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Signed-off-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-07-31HID: uhid: use generic hidinput_input_event()David Herrmann
HID core provides the same functionality and can convert the input event to a raw output report. We can thus drop UHID_OUTPUT_EV and rely on the mandatory UHID_OUTPUT. User-space wasn't able to do anything with UHID_OUTPUT_EV, anyway. They don't have access to the report fields. Signed-off-by: David Herrmann <dh.herrmann@gmail.com> Acked-by: Benjamin Tissoires <benjamin.tissoires@redhat.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-12-14HID: remove x bit from sensor docJiri Kosina
Reported-by: Xose Vazquez Perez <xose.vazquez@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-11-19doc: fix quite a few typos within DocumentationMasanari Iida
Correct spelling typo in Documentations Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-09-06HID: sensors: add documentationsrinivas pandruvada
Added a summary of HID sensor framework. Signed-off-by: srinivas pandruvada <srinivas.pandruvada@intel.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz> Signed-off-by: Jonathan Cameron <jic23@kernel.org>
2012-06-18HID: uhid: add documentationDavid Herrmann
This describes the protocol used by uhid for user-space applications. It describes the details like non-blocking I/O and readv/writev for multiple events per syscall. Signed-off-by: David Herrmann <dh.herrmann@googlemail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-22HID: Move hiddev.txt to the new Documentation/hid directoryAlan Ott
With the new Documentation/hid directory, it makes sense to have hiddev.txt here as well. Signed-off-by: Alan Ott <alan@signal11.us> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-22HID: Documentation for hidrawAlan Ott
Documenation for the hidraw driver, with sample program. Signed-off-by: Alan Ott <alan@signal11.us> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
