path: root/Documentation/hwmon/adm1275
2016-03-05hwmon: (adm1275) Add support for ADM1278Guenter Roeck
ADM1278 is mostly compatible to other chips of the same series. Besides the usual difference in coefficients, it supports a temperature sensor, and it can measure both input and output voltage at the same time. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-03-05Doc: hwmon: Fix typo "montoring" in hwmonMasanari Iida
This patch fix typos found in files within Documentation/hwmon. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-08-09hwmon: (adm1275) Add support for ADM1293 and ADM1294Guenter Roeck
ADM1293 and ADM1294 are mostly compatible with other chips of the same series, but have more configuration options. There are also some differences in register details. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2013-03-03hwmon: Update my e-mail address in driver documentationGuenter Roeck
Most of the hwmon driver documentation still listed my old invalid e-mail address. Fix it. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Acked-by: Jean Delvare <khali@linux-fr.org>
2012-03-21Merge tag 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging Pull hwmon changes for v3.4 from Guenter Roeck: "Mostly cleanup. No new drivers this time around, but support for several chips added to existing drivers: TPS40400, TPS40422, MTD040, MAX34446, ZL9101M, ZL9117M, and LM96080. Also, added watchdog support for SCH56xx, and additional attributes for a couple of drivers." * tag 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/groeck/linux-staging: (137 commits) hwmon: (sch56xx) Add support for the integrated watchdog (v2) hwmon: (w83627ehf) Add support for temperature offset registers hwmon: (jc42) Remove unnecessary device IDs hwmon: (zl6100) Add support for ZL9101M and ZL9117M hwmon: (adm1275) Add support for ADM1075 hwmon: (max34440) Add support for MAX34446 hwmon: (pmbus) Add more virtual registers hwmon: (pmbus) Add support for Lineage Power MDT040 hwmon: (pmbus) Add support for TI TPS40400 and TPS40422 hwmon: (max34440) Add support for 'lowest' output voltage attribute hwmon: (jc42) Convert to use devm_kzalloc hwmon: (max16065) Convert to use devm_kzalloc hwmon: (smm665) Convert to use devm_kzalloc hwmon: (ltc4261) Convert to use devm_kzalloc hwmon: (pmbus) Simplify remove functions hwmon: (pmbus) Convert pmbus drivers to use devm_kzalloc hwmon: (lineage-pem) Convert to use devm_kzalloc hwmon: (hwmon-vid) Fix checkpatch issues hwmon: (hwmon-vid) Add new entries to VRM model table hwmon: (lm80) Add detection of NatSemi/TI LM96080 ...
2012-03-18hwmon: (adm1275) Add support for ADM1075Guenter Roeck
2012-03-07Documentation: Fix multiple typo in DocumentationMasanari Iida
Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-10-24hwmon: (pmbus/adm1275) Add support for ADM1276Guenter Roeck
ADM1276 is mostly compatible to ADM1275, with added support for input power measurement. Add support for it to the ADM1275 driver. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2011-10-24hwmon: (pmbus/adm1275) Add support for second current limitGuenter Roeck
ADM1275 supports a second current limit, which can be configured as either lower or upper limit. Add support for it and report it as either lower or upper critical current limit. Also replace error return code EINVAL for unsupported pages with ENXIO as this is more appropriate for the observed condition. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Jean Delvare <khali@linux-fr.org>
2011-07-28hwmon: (adm1275) Add support for peak attributesGuenter Roeck
Add support for voltage and current peak (historic maximum) attributes. Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Robert Coulson <robert.coulson@ericsson.com>
2011-05-19hwmon: (pmbus) Add support for Analog Devices ADM1275Guenter Roeck
Add support for Analog Devices ADM1275 Hot-Swap Controller and Digital Power Monitor Signed-off-by: Guenter Roeck <guenter.roeck@ericsson.com> Reviewed-by: Tom Grennan <tom.grennan@ericsson.com>
