path: root/Documentation/hwmon/lm87
2008-10-17hwmon: (lm87) Add support for configuration through platform_dataBen Hutchings
The lm87 driver normally assumes that firmware configured the chip correctly. Since this is not always the case, alllow platform code to set the channel register value via platform_data. All other configuration registers can be changed after driver initialisation. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-02-07hwmon: (lm87) Add support for the Analog Devices ADM1024Jean Delvare
It happens that the Analog Devices ADM1024 is fully compatible with the National Semiconductor LM87, so support for the former can easily be added to the lm87 driver. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Mark M. Hoffman <mhoffman@lightlink.com>
2005-07-11[PATCH] I2C: Move hwmon drivers (3/3)Jean Delvare
Part 3: Move the drivers documentation, plus two general documentation files. Note that the patch "adds trailing whitespace", because it does move the files as-is, and some files happen to have trailing whitespace. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
