path: root/Documentation/hwmon
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-05hwmon: Remove the deprecated adt7473 driverAmerigo Wang
adt7473 driver is obsoleted by adt7475 driver. And it is scheduled to be removed in Feb 2010. Signed-off-by: WANG Cong <amwang@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-03-05hwmon: Driver for Andigilog aSC7621 family monitoring chipsGeorge Joseph
Hwmon driver for Andigilog aSC7621 family monitoring chips. Signed-off-by: George Joseph <george.joseph@fairview5.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-03-05hwmon: Add driver for ADT7411 voltage and temperature sensorWolfram Sang
Add basic support for the ADT7411. Reads out all conversion results (via I2C, SPI yet missing) and allows some on-the-fly configuration. Tested with a custom board. Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-03-05hwmon: (it87) Validate auto pwm settingsJean Delvare
Before switching to automatic fan control mode, make sure that all the trip points make sense. Otherwise, the control loop could lead to weird fan behavior. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-03-05hwmon: (it87) Add support for old automatic fan speed controlJean Delvare
Add support for the automatic fan speed control interface as implemented by IT8705F chips up to revision F and IT8712F chips up to revision G. This implementation fits very well in our standard sysfs interface. I implemented the old and not the new interface because the only chip I have at hand is an old one, and the new interface is more difficult to map to the standard sysfs interface. Adding support later should be possible though, if someone with a supported chip is interested. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-03-05hwmon: (it87) Drop dead web links in documentationJean Delvare
Unfortunately ITE is no longer publicly providing datasheets for their IT87xxF series of chips. They may send them on request if you ask politely. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-03-05hwmon: (it87) Add support for beep on alarmJean Delvare
The IT87xxF chips support beeping on alarm, if properly wired and configured. There is one control bit for each input type (temperature, fan, voltage.) Let the user see and change them. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2010-03-05hwmon: (lm90) Add SMBus alert supportJean Delvare
Tested successfully with an ADM1032 chip on its evaluation board. It should work fine with all other chips as well. At this point this is more of a proof-of-concept, we don't do anything terribly useful on SMBus alert: we simply log the event. But this could later evolve into libsensors signaling so that user-space applications can take an appropriate action. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: David Brownell <dbrownell@users.sourceforge.net> Cc: Trent Piepho <tpiepho@freescale.com>
2010-03-05hwmon: (lm90) Add support for the Winbond/Nuvoton W83L771AWG/ASGJean Delvare
This chips is found on several Zotac Ion ITX boards, amongst others. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: MC Matti <mcmatti17@googlemail.com> Cc: Manuel Lamotte-Schubert <mls@pronego.com>
2010-02-09tree-wide: Assorted spelling fixesDaniel Mack
In particular, several occurances of funny versions of 'success', 'unknown', 'therefore', 'acknowledge', 'argument', 'achieve', 'address', 'beginning', 'desirable', 'separate' and 'necessary' are fixed. Signed-off-by: Daniel Mack <daniel@caiaq.de> Cc: Joe Perches <joe@perches.com> Cc: Junio C Hamano <gitster@pobox.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-01-11Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: Make PCI device ids constant hwmon: (coretemp) Fix TjMax for Atom N450/D410/D510 CPUs hwmon: (k10temp) Blacklist more family 10h processors hwmon: (asus_atk0110) Add debugfs interface hwmon: (asus_atk0110) Refactor interface probe code hwmon: (adt7462) Fix pin 28 monitoring
2010-01-11hwmon: driver for Texas Instruments amc6821 chipTomaz Mertelj
Signed-off-by: <tomaz.mertelj@guest.arnes.si> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-01-10hwmon: (k10temp) Blacklist more family 10h processorsClemens Ladisch
The latest version of the Revision Guide for AMD Family 10h Processors lists two more processor revisions which may be affected by erratum 319. Change the blacklisting code to correctly detect those processors, by implementing AMD's recommended algorithm. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Andreas Herrmann <herrmann.der.user@googlemail.com>
2009-12-16hwmon: New driver for AMD Family 10h/11h CPUsClemens Ladisch
This adds a driver for the internal temperature sensor of AMD Family 10h and 11h CPUs. Signed-off-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-12-15lis3: update documentation to match latest changesSamu Onkalo
[akpm@linux-foundation.org: s/q/g/ (Randy)] Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Acked-by: Éric Piel <Eric.Piel@tremplin-utc.net> Cc: Pavel Machek <pavel@ucw.cz> Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15lis3: update documentation and commentsÉric Piel
Most of the documentation and comments were written when the driver was only supporting one type of chip, only via ACPI/HP. Update the info to the much clearer understanding that we have now. Signed-off-by: Éric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-15hwmon: w83627ehf updatesDaniel J Blueman
Add control of fan minimum turn-on output levels, decoupling it from the fan turn-off output level. Add control of rate of change of fan output level. These in turn allow lower turn-off rotor speed and smoother transitions for better thermal and acoustic control authority. Add support for constant fan speed and proportional-response operations modes. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: Daniel J Blueman <daniel.blueman@gmail.com> Cc: Jean Delvare <khali@linux-fr.org> Cc: David Hubbard <david.c.hubbard@gmail.com> Cc: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-09hwmon: (adt7475) Add VID support for the ADT7476Jean Delvare
The ADT7476 has 5 dedicated pins for VID input, and the +12V input can optionally be used as a 6th VID pin. Add support for VID input. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Jordan Crouse <jordan@cosmicpenguin.net> Cc: "Darrick J. Wong" <djwong@us.ibm.com>
2009-12-09hwmon: (adt7475) Add support for the ADT7476Jean Delvare
Add support for the Analog Devices ADT7476 chip. This chip is largely compatible with the ADT7473 and ADT7475, with additional features. In particular, it has 5 voltage inputs instead of 2, and VID input pins. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Jordan Crouse <jordan@cosmicpenguin.net> Cc: "Darrick J. Wong" <djwong@us.ibm.com>
2009-12-09hwmon: (adt7475) Add support for the ADT7490Jean Delvare
Add support for the Analog Devices ADT7490 chip. This chip is largely compatible with the ADT7473 and ADT7475, with additional features. In particular, it has 6 voltage inputs instead of 2. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Jordan Crouse <jordan@cosmicpenguin.net> Cc: "Darrick J. Wong" <djwong@us.ibm.com>
2009-12-09hwmon: (adt7475) New documentationJean Delvare
New documentation for the adt7475 driver, based on the adt7473 driver documentation. It is IMHO much more useful that the previous documentation which was essentially redundant with sysfs-interface. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Jordan Crouse <jordan@cosmicpenguin.net> Cc: "Darrick J. Wong" <djwong@us.ibm.com>
2009-12-09hwmon: (adt7475) Add support for the ADT7473Jean Delvare
Add support for the ADT7473 to the adt7475 driver, and mark the adt7473 driver for removal. The ADT7473 and ADT7475 chips are almost the same chip and essentially compatible, so there's no point in having separate drivers for them. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: "Mark M. Hoffman" <mhoffman@lightlink.com> Cc: Hans de Goede <hdegoede@redhat.com> Cc: Jordan Crouse <jordan@cosmicpenguin.net> Cc: "Darrick J. Wong" <djwong@us.ibm.com>
2009-12-09hwmon: (f71882fg) Add support for the f71889fg (version 2)Hans de Goede
This adds support for the Fintek f71889fg to the f71882fg driver, many thanks to Gerd v. Egidy for providing (remote) access to a machine which such an ic. Note that this bit of the patch: - val = SENSORS_LIMIT(val, 0, 255); + + if (data->type == f71889fg) + val = SENSORS_LIMIT(val, -128, 127); + else + val = SENSORS_LIMIT(val, 0, 127); Changes behaviour for already supported models, the new behaviour is correct as the already supported models have bit 7 of the involved registers fixed at 0, so the previous behaviour which allowed setting temp zone limits > 127 was not correct. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-12-09hwmon: Add Freescale MC13783 ADC driverLuotao Fu
This driver provides support for the ADC integrated into the Freescale MC13783 PMIC. Signed-off-by: Luotao Fu <l.fu@pengutronix.de> Signed-off-by: Sascha Hauer <s.hauer@pengutronix.de> Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Cc: Eric Piel <eric.piel@tremplin-utc.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-12-09hwmon: (w83627hf) Drop the force_addr module parameterJean Delvare
This module parameter is there to workaround broken BIOS. I'm not even sure if it was used in the past 5 years, and it gets in the way of converting the driver to the MFD infrastructure. So tell the users how they can do the same from user-space. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Rodolfo Giometti <giometti@linux.it>
2009-12-09hwmon: (it87) Verify the VID pin usageJean Delvare
The VID input pins can alternatively be used as GPIOs. Make sure we have at least 4 pins used for VID, otherwise don't bother reading and exposing VID. Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Adam Nielsen <a.nielsen@shikadi.net>
2009-12-09hwmon: Clarify autopwm trip points documentationJean Delvare
Document the case of hybrid automatic fan speed control implementations, where trip points are associated to both PWM output channels and temperature input channels. Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-10-29hwmon: enhance the sysfs API for power metersDarrick J. Wong
Augment the documentation of the hwmon sysfs API to accomodate ACPI power meters and the current desired behavior of power capping hardware drivers. Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Len Brown <len.brown@intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-04ltc4215/ltc4245: Discard obsolete detect methodsJean Delvare
There is no point in implementing a detect callback for the LTC4215 and LTC4245, as these devices can't be detected. It was there solely to handle "force" module parameters to instantiate devices, but now we have a better sysfs interface that can do the same. So we can get rid of the ugly module parameters and the detect callbacks. This shrinks the binary module sizes by 36% and 46%, respectively. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Ira W. Snyder <iws@ovro.caltech.edu>
2009-09-23Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: hwmon: (ltc4245) Clear faults at startup hwmon: (ltc4215) Clear faults at startup hwmon: (coretemp) Add Lynnfield CPU hwmon: (coretemp) Add support for Penryn mobile CPUs hwmon: (coretemp) Fix Atom CPUs support hwmon: Delete deprecated FSC drivers hwmon: (adm1031) Add sysfs files for temperature offsets
2009-09-23hwmon: (coretemp) Add Lynnfield CPUHuaxu Wan
Add Lynnfield processor support. Lynnfield is a quad-core Nehalem based microprocessor for Desktop market, which is introduced in September 2009. Signed-off-by: Huaxu Wan <huaxu.wan@linux.intel.com> Signed-off-by: Kent Liu <kent.liu@linux.intel.com> Acked-by: Rudolf Marek <r.marek@assembler.cz> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-09-23hwmon: (coretemp) Add support for Penryn mobile CPUsRudolf Marek
Following patch adds support for mobile Penryn CPUs. Intel documents this poorly. I asked the Coretemp author for some help. This is totally untested and may not work. Please test! Signed-off-by: Rudolf Marek <r.marek@assembler.cz> Cc: Huaxu Wan <huaxu.wan@linux.intel.com> Cc: Kent Liu <kent.liu@linux.intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-09-23hwmon: (coretemp) Fix Atom CPUs supportRudolf Marek
Fix Atom CPUs support. Intel documents TjMax at 90 degrees C but some Atoms may have 125 degrees C (this is undocumented speculation). Signed-off-by: Rudolf Marek <r.marek@assembler.cz> Cc: Huaxu Wan <huaxu.wan@linux.intel.com> Cc: Kent Liu <kent.liu@linux.intel.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-09-23hwmon: Delete deprecated FSC driversJean Delvare
The legacy fscpos and fscher drivers have been replaced by the unified fschmd driver. The transition period is over now, we can delete them. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Hans de Goede <hdegoede@redhat.com>
2009-09-23Merge branch 'release' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6 * 'release' of git://git.kernel.org/pub/scm/linux/kernel/git/lenb/linux-acpi-2.6: (119 commits) ACPI: don't pass handle for fixed hardware notifications ACPI: remove null pointer checks in deferred execution path ACPI: simplify deferred execution path acerhdf: additional BIOS versions acerhdf: convert to dev_pm_ops acerhdf: fix fan control for AOA150 model thermal: add missing Kconfig dependency acpi: switch /proc/acpi/{debug_layer,debug_level} to seq_file hp-wmi: fix rfkill memory leak on unload ACPI: remove unnecessary #ifdef CONFIG_DMI ACPI: linux/acpi.h should not include linux/dmi.h hwmon driver for ACPI 4.0 power meters topstar-laptop: add new driver for hotkeys support on Topstar N01 thinkpad_acpi: fix rfkill memory leak on unload thinkpad-acpi: report brightness events when required thinkpad-acpi: don't poll by default any of the reserved hotkeys thinkpad-acpi: Fix procfs hotkey reset command thinkpad-acpi: deprecate hotkey_bios_mask thinkpad-acpi: hotkey poll fixes thinkpad-acpi: be more strict when detecting a ThinkPad ...
2009-09-21trivial: doc: hpfall: accept disk device to unload as argumentFrans Pop
Allows users who use an IDE driver for their disk to use hpfall without having to modify the source. By default /dev/sda is used. Suggested by Christian Thaeter in http://lkml.org/lkml/2009/3/25/505. While we're add it, improve error message if opening /dev/freefall fails. Signed-off-by: Frans Pop <elendil@planet.nl> Cc: Christian Thaeter <ct@pipapo.org> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-21trivial: doc: hpfall: reduce risk that hpfall can do harmChristian Thaeter
Improve the example code to be at least useable, as in not causing harm (as shown below). Code can still be improved further, but this adds some basic safeguards. 1. hpfall *MUST* mlockall(MCL_CURRENT|MCL_FUTURE); itself! Since the Program sits and waits most of the time it becomes very likely swapped out. If it gets woken up when the laptop drops from the table while it is swapped out it actually triggers harddrive activity! 2. Daemonize hpfall using 'daemon(0,0)' (quick and dirty). 3. Give hpfall realtime priority. Should give a chance that it has less latency when woken up. Signed-off-by: Christian Thaeter <ct@pipapo.org> Signed-off-by: Frans Pop <elendil@planet.nl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-21trivial: fix typo "to to" in multiple filesAnand Gadiyar
Signed-off-by: Anand Gadiyar <gadiyar@ti.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-21trivial: cleanup hpfall example code (checkpatch)Frans Pop
This patch makes hpfall.c conform to kernel coding style. I have not fixed the C99 // comments on two lines as they help indicate that those are not actually comments but incomplete code. Before: total: 10 errors, 6 warnings, 101 lines checked After: total: 2 errors, 0 warnings, 99 lines checked Signed-off-by: Frans Pop <elendil@planet.nl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-19Merge branch 'power-meter' into releaseLen Brown
2009-09-19hwmon driver for ACPI 4.0 power metersDarrick J. Wong
This driver exposes ACPI 4.0 compliant power meters as hardware monitoring devices. This second revision of the driver also exports the ACPI string info as sysfs attributes, a list of the devices that the meter measures, and will send ACPI notifications over the ACPI netlink socket. This latest revision only enables the power capping controls if it can be confirmed that the power cap can be enforced by the hardware and explains how the notification interfaces work. [akpm@linux-foundation.org: remove default-y] [akpm@linux-foundation.org: build fix] Signed-off-by: Darrick J. Wong <djwong@us.ibm.com> Cc: Zhang Rui <rui.zhang@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-18Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6 * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/sameo/mfd-2.6: (55 commits) regulator: Voltage count for AB3100 mfd: Convert WM8350 to use request_threaded_irq() mfd: Update MAINTAINERS patterns for WM831x mfd: Fix twl4030-power warnings regulator: AB3100 support rtc: AB3100 RTC support mfd: Fix ab3100-otp build failure mfd: OMAP: Board-specifc twl4030 DPS scripts for RX51 board mfd: Print warning for twl4030 out-of-order script loading mfd: Add support for TWL4030/5030 dynamic power switching mfd: AB3100 OTP readout regulator: Add Freescale MC13783 driver mfd: Add Freescale MC13783 driver mfd: AB3100 disable irq nosync mfd: AB3100 alter default setting mfd: AB3100 propagate error mfd: AB3100 accessor function cleanups rtc: Add support for RTCs on Wolfson WM831x devices regulator: get pcap data from the parent device input: PCAP2 misc input driver ...
2009-09-17hwmon: WM831x PMIC hardware monitoring driverMark Brown
This driver adds support for the hardware monitoring features of the WM831x PMICs to the hwmon API. Monitoring is provided for the system voltages supported natively by the WM831x, the chip temperature, the battery temperature and the auxiliary inputs of the WM831x. Currently no alarms are supported, though digital comparators on the WM831x devices would allow these to be provided. Since the auxiliary and battery temperature input scaling depends on the system configuration the value is reported as a voltage to userspace. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-17hwmon: Add WM835x PMIC hardware monitoring driverMark Brown
This driver provides reporting of the status supply voltage rails of the WM835x series of PMICs via the hwmon API. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Samuel Ortiz <sameo@linux.intel.com>
2009-09-15hwmon: (pcf8591) Documentation clean-upsJean Delvare
Clean up the pcf8591 driver documentation: * The PCF8591 chip is now an NXP product. * Fix a sysfs path. * Fix the name of sysfs attributes. * And a few other random fixes. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Aurelien Jarno <aurelien@aurel32.net>
2009-09-15hwmon: (tmp421) Add documentationAndre Prendel
Add documentation for the tmp421 driver. Signed-off-by: Andre Prendel <andre.prendel@gmx.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-06-15hwmon: (f71882fg) Add support for the F71858FHans de Goede
Add support for the hwmon part of the Fintek F71858FG superio IC to the f71882fg driver. Many thanks to Jelle de Jong for lending me a motherboard with this superio on it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2009-06-15hwmon: (w83627ehf) Add W83627DHG-P supportJean Delvare
Add support for the new incarnation of the Winbond/Nuvoton W83627DHG chip known as W83627DHG-P. It is basically the same as the original W83627DHG with an additional automatic can speed control mode (not supported by the driver yet.) Signed-off-by: Jean Delvare <khali@linux-fr.org> Tested-by: Madhu <madhu.chinakonda@gmail.com>
2009-06-15hwmon: (tmp401) Add documentationAndre Prendel
Documentation for the tmp401 driver. The documentation describes the tmp401 driver and the supported Texas Instruments TMP401 and TMP411 temperature sensor chips. Further documentation for new sysfs attributes supported by this driver is added to Documentation/hwmon/sysfs-interface. Signed-off-by: Andre Prendel <andre.prendel@gmx.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Jean Delvare <khali@linux-fr.org>
