path: root/Documentation/hwmon
2016-09-08hwmon: (max6650) Allow fan shutdown and initial rpm targetMike Looijmans
The fan can be stopped by writing "3" to pwm1_enable in sysfs. Add devicetree property for early initialization of the fan controller to prevent overheating, for example when resetting the board while the fan was completely turned off. Also improve error reporting, I2C failures were ignored while writing new values. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-09-08hwmon: (ucd9000) Add support for UCD90160 Power Supply SequencerMatt Weber
The UCD90160 Power Supply Sequencer reuses the existing register layout, so just an id addition was required. Signed-off-by: Matthew Weber <matthew.weber@rockwellcollins.com> Signed-off-by: Ronak Desai <ronak.desai@rockwellcollins.com> [groeck: Updated description, ordered alphabetically, added documentation] Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-09-08hwmon: Add xgene hwmon driverhotran
This patch adds hardware temperature and power reading support for APM X-Gene SoC using the mailbox communication interface. Signed-off-by: Hoan Tran <hotran@apm.com> Reviewed-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-09-08hwmon: (adt7470) Expose PWM frequency to sysfsJoshua Scott
The ADT7470 supports a variety of PWM frequencies. This patch allows the frequency to be configured and viewed through the sysfs entry pwm1_freq. Signed-off-by: Joshua Scott <joshua.scott@alliedtelesis.co.nz> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-09-08hwmon: (core) Add basic pwm attribute support to new APIGuenter Roeck
Add basic pwm attribute support (no auto attributes) to new API. Reviewed-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-09-08hwmon: (core) Document new kernel APIGuenter Roeck
Describe the new registration API function as well as the data structures it requires. Acked-by: Punit Agrawal <punit.agrawal@arm.com> Reviewed-by: Jonathan Cameron <jic23@kernel.org> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-08-12hwmon: (ftsteutates) Correct ftp urls in driver documentationThilo Cestonaro
Signed-off-by: Thilo Cestonaro <thilo@cestona.ro> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-07-20hwmon: Add driver for FTS BMC chip "Teutates"Thilo Cestonaro
This driver implements hardware monitoring and watchdog support for the FTS BMC Chip "Teutates". Signed-off-by: Thilo Cestonaro <thilo@cestona.ro> [groeck: Updated subject and description; fixed dependencies] Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-07-16hwmon: (sht3x) add humidity heater element controlMatt Ranostay
The enables control of the SHT31 sensors heating element that can turned on to remove excess humidity. Cc: Guenter Roeck <linux@roeck-us.net> Cc: David Frey <david.frey@sensirion.com> Signed-off-by: Matt Ranostay <mranostay@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-06-27hwmon: (jc42) Add support for Microchip MCP9808 temperature sensorAlison Schofield
MCP9808 is not officially compliant to JC-42, similar to MCP9804, but its registers are compatible to JC-42. Signed-off-by: Alison Schofield <amsfield22@gmail.com> Cc: Daniel Baluta <daniel.baluta@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-06-27hwmon: Update guildelines for submitting patchesGuenter Roeck
Add more details to the guidelines for submitting patches. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-06-27hwmon: Add support for INA3221 Triple Current/Voltage MonitorsAndrew F. Davis
Add support for the the INA3221 26v capable, Triple channel, Bi-Directional, Zero-Drift, Low-/High-Side, Current/Voltage Monitor with I2C interface. Signed-off-by: Andrew F. Davis <afd@ti.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-06-27hwmon: (tmp401) Add support for TI TMP461Andrew F. Davis
2016-06-27hwmon: add support for Sensirion SHT3x sensorsDavid Frey
This driver implements support for the Sensirion SHT3x-DIS chip, a humidity and temperature sensor. Temperature is measured in degrees celsius, relative humidity is expressed as a percentage. In the sysfs interface, all values are scaled by 1000, i.e. the value for 31.5 degrees celsius is 31500. Signed-off-by: Pascal Sachs <pascal.sachs@sensirion.com> [groeck: Fixed 'Variable length array is used' gcc warning] Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-06-27hwmon: (max1668) Fix typo in documentationAndrea Gelmini
Signed-off-by: Andrea Gelmini <andrea.gelmini@gelma.net> [groeck: Updated subject] Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-06-27hwmon: (abituguru) Fix typos in documentationAndrea Gelmini
2016-05-26Merge branch 'hwmon-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging Pull hwmon fixlets from Jean Delvare. * 'hwmon-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jdelvare/staging: Documentation/hwmon: Update links in max34440 hwmon: (emc2103) Fix typo in MODULE_PARM_DESC
2016-05-26Documentation/hwmon: Update links in max34440Glenn Dayton
It appears the website for maxim-ic.com changed to maximintegrated.com. Signed-off-by: Glenn Dayton <glenn.dayton24@gmail.com> Signed-off-by: Jean Delvare <jdelvare@suse.de>
2016-05-19Merge tag 'docs-for-linus' of git://git.lwn.net/linuxLinus Torvalds
Pull Documentation updates from Jon Corbet: "A bit busier this time around. The most interesting thing (IMO) this time around is some beginning infrastructural work to allow documents to be written using restructured text. Maybe someday, in a galaxy far far away, we'll be able to eliminate the DocBook dependency and have a much better integrated set of kernel docs. Someday. Beyond that, there's a new document on security hardening from Kees, the movement of some sample code over to samples/, a number of improvements to the serial docs from Geert, and the usual collection of corrections, typo fixes, etc" * tag 'docs-for-linus' of git://git.lwn.net/linux: (55 commits) doc: self-protection: provide initial details serial: doc: Use port->state instead of info serial: doc: Always refer to tty_port->mutex Documentation: vm: Spelling s/paltform/platform/g Documentation/memcg: update kmem limit doc as codes behavior docproc: print a comment about autogeneration for rst output docproc: add support for reStructuredText format via --rst option docproc: abstract terminating lines at first space docproc: abstract docproc directive detection docproc: reduce unnecessary indentation docproc: add variables for subcommand and filename kernel-doc: use rst C domain directives and references for types kernel-doc: produce RestructuredText output kernel-doc: rewrite usage description, remove duplicated comments Doc: correct the location of sysrq.c Documentation: fix common spelling mistakes samples: v4l: from Documentation to samples directory samples: connector: from Documentation to samples directory Documentation: xillybus: fix spelling mistake Documentation: x86: fix spelling mistakes ...
2016-04-28Documentation: fix common spelling mistakesKees Cook
This fixes several spelling mistakes in the Documentation/ tree, which are caught by checkpatch.pl's spell checking. Signed-off-by: Kees Cook <keescook@chromium.org> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-04-19hwmon: (it87) Add support for IT8628EGuenter Roeck
IT8628E is functionally identical to IT8620E. Tested-by: Martin Blumenstingl <martin.blumenstingl@googlemail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-04-19hwmon: (fam15h_power) Add documentation for TDP and accumulated power algorithmHuang Rui
This patch adds the description to explain the TDP reporting mechanism and accumulated power algorithm. Signed-off-by: Huang Rui <ray.huang@amd.com> Cc: Borislav Petkov <bp@alien8.de> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-04-19hwmon: (max31722) Add support for MAX31722/MAX31723 temperature sensorsTiberiu Breana
Add basic support for the Maxim Integrated MAX31722/MAX31723 SPI temperature sensors / thermostats. Includes: - ACPI support; - raw temperature readings; - power management Datasheet: https://datasheets.maximintegrated.com/en/ds/MAX31722-MAX31723.pdf Signed-off-by: Tiberiu Breana <tiberiu.a.breana@intel.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-03-08hwmon: Create an NSA320 hardware monitoring driverAdam Baker
Create a driver to support the hardware monitoring chip present in the Zyxel NSA320 and some of the other Zyxel NAS devices. The driver reads fan speed and temperature from a suitably pre-programmed MCU on the device. Signed-off-by: Adam Baker <linux@baker-net.org.uk> [groeck: Dropped .owner field initialization] Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-03-05hwmon: (adm1275) Add support for ADM1278Guenter Roeck
ADM1278 is mostly compatible to other chips of the same series. Besides the usual difference in coefficients, it supports a temperature sensor, and it can measure both input and output voltage at the same time. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-03-05hwmon: (ntc_thermistor) Add support for ncpXXxh103Joseph McNally
This patch adds support for the Murata NCP15XH103 thermistor series. Signed-off-by: Joseph McNally <jmcna06@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-03-05Doc: hwmon: Fix typo "montoring" in hwmonMasanari Iida
This patch fix typos found in files within Documentation/hwmon. Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2016-03-05hwmon: Add LTC2990 sensor driverMike Looijmans
This adds support for the Linear Technology LTC2990 I2C System Monitor. The LTC2990 supports a combination of voltage, current and temperature monitoring. This driver currently only supports reading two currents by measuring two differential voltages across series resistors, in addition to the Vcc supply voltage and internal temperature. This is sufficient to support the Topic Miami SOM which uses this chip to monitor the currents flowing into the FPGA and the CPU parts. Signed-off-by: Mike Looijmans <mike.looijmans@topic.nl> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-12-18hwmon: (pmbus) Add client driver for LTC3815Guenter Roeck
LTC3815 is a Monolithic Synchronous DC/DC Step-Down Converter. Cc: Michael Jones <mike@proclivis.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-12-18hwmon: (htu21) Remove driverGuenter Roeck
HTU21 is now supported by IIO, and can be instantiated as hwmon driver using the iio-hwmon bridge. An explicit hwmon driver is no longer needed. Cc: William Markezana <william.markezana@meas-spec.com> Cc: Ludovic Tancerel <ludovic.tancerel@maplehightech.com> Cc: Jonathan Cameron <jic23@kernel.org> Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-11-10Merge tag 'armsoc-drivers' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc Pull ARM SoC driver updates from Olof Johansson: "As we've enabled multiplatform kernels on ARM, and greatly done away with the contents under arch/arm/mach-*, there's still need for SoC-related drivers to go somewhere. Many of them go in through other driver trees, but we still have drivers/soc to hold some of the "doesn't fit anywhere" lowlevel code that might be shared between ARM and ARM64 (or just in general makes sense to not have under the architecture directory). This branch contains mostly such code: - Drivers for qualcomm SoCs for SMEM, SMD and SMD-RPM, used to communicate with power management blocks on these SoCs for use by clock, regulator and bus frequency drivers. - Allwinner Reduced Serial Bus driver, again used to communicate with PMICs. - Drivers for ARM's SCPI (System Control Processor). Not to be confused with PSCI (Power State Coordination Interface). SCPI is used to communicate with the assistant embedded cores doing power management, and we have yet to see how many of them will implement this for their hardware vs abstracting in other ways (or not at all like in the past). - To make confusion between SCPI and PSCI more likely, this release also includes an update of PSCI to interface version 1.0. - Rockchip support for power domains. - A driver to talk to the firmware on Raspberry Pi" * tag 'armsoc-drivers' of git://git.kernel.org/pub/scm/linux/kernel/git/arm/arm-soc: (57 commits) soc: qcom: smd-rpm: Correct size of outgoing message bus: sunxi-rsb: Add driver for Allwinner Reduced Serial Bus bus: sunxi-rsb: Add Allwinner Reduced Serial Bus (RSB) controller bindings ARM: bcm2835: add mutual inclusion protection drivers: psci: make PSCI 1.0 functions initialization version dependent dt-bindings: Correct paths in Rockchip power domains binding document soc: rockchip: power-domain: don't try to print the clock name in error case soc: qcom/smem: add HWSPINLOCK dependency clk: berlin: add cpuclk ARM: berlin: dts: add CLKID_CPU for BG2Q ARM: bcm2835: Add the Raspberry Pi firmware driver soc: qcom: smem: Move RPM message ram out of smem DT node soc: qcom: smd-rpm: Correct the active vs sleep state flagging soc: qcom: smd: delete unneeded of_node_put firmware: qcom-scm: build for correct architecture level soc: qcom: smd: Correct SMEM items for upper channels qcom-scm: add missing prototype for qcom_scm_is_available() qcom-scm: fix endianess issue in __qcom_scm_is_call_available soc: qcom: smd: Reject send of too big packets soc: qcom: smd: Handle big endian CPUs ...
2015-10-14Merge tag 'arm-scpi-for-v4.4' of ↵Arnd Bergmann
git://git.kernel.org/pub/scm/linux/kernel/git/sudeep.holla/linux into next/drivers Merge "ARM System Control and Power Interface(SCPI) support" from Sudeep Holla It adds support for the following features provided by SCP firmware using different subsystems in Linux: 1. SCPI mailbox protocol driver which using mailbox framework 2. Clocks provided by SCP using clock framework 3. CPU DVFS(cpufreq) using existing arm-big-little driver 4. SCPI based sensors including temperature sensors * tag 'arm-scpi-for-v4.4' of git://git.kernel.org/pub/scm/linux/kernel/git/sudeep.holla/linux: hwmon: Support thermal zones registration for SCP temperature sensors hwmon: Support sensors exported via ARM SCP interface firmware: arm_scpi: Extend to support sensors Documentation: add DT bindings for ARM SCPI sensors cpufreq: arm_big_little: add SCPI interface driver clk: scpi: add support for cpufreq virtual device clk: add support for clocks provided by SCP(System Control Processor) firmware: add support for ARM System Control and Power Interface(SCPI) protocol Documentation: add DT binding for ARM System Control and Power Interface(SCPI) protocol
2015-10-14hwmon: (lm75) Add support for TMP75CBen Gardner
The TMP75C has a different control register layout and only supports 12-bit temperature samples (0.0625 deg C). The continuous sample rate is ~12 Hz. Signed-off-by: Ben Gardner <gardner.ben@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-10-14hwmon: Driver for Maxim MAX31790Il Han
The driver supports the Maxim MAX31790. Signed-off-by: Il Han <corone.il.han@gmail.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-10-09hwmon: Support sensors exported via ARM SCP interfacePunit Agrawal
Create a driver to add support for SoC sensors exported by the System Control Processor (SCP) via the System Control and Power Interface (SCPI). The supported sensor types is one of voltage, temperature, current, and power. The sensor labels and values provided by the SCP are exported via the hwmon sysfs interface. Signed-off-by: Punit Agrawal <punit.agrawal@arm.com> Acked-by: Guenter Roeck <linux@roeck-us.net> Cc: Sudeep Holla <sudeep.holla@arm.com>
2015-09-12hwmon: (nct6775) Add support for NCT6793DGuenter Roeck
NCT6793D is register compatible with NCT6792D. Also move nct6775_sio_names[] closer to enum kinds to simplify adding new chips. Tested-by: Grazvydas Ignotas <notasas@gmail.com> Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-08-27hwmon: (fam15h_power) Add documentation for new processors supportHuang Rui
This patch updates description of fam15h_power driver, its scope is extended to family 16h processsors. Signed-off-by: Huang Rui <ray.huang@amd.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-08-19hwmon: (ltc2978) Add support for LTM4675Guenter Roeck
LTM2975 is a dual 9A or single 18A μModule regulator. It is register compatible with LTM4676. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-08-17hwmon: (ltc2978) Add support for LTC3886Guenter Roeck
LTC3886 is a is a dual PolyPhase DC/DC synchronous step-down switching regulator controller. It is mostly command compatible to LTC3883, but supports two phases instead of one. Suggested-by: Michael Jones <mike@proclivis.com> Tested-by: Michael Jones <mike@proclivis.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-08-17hwmon: (ltc2978) Add support for LTC2980 and LTM2987Guenter Roeck
LTC2980 and LTM2987 are command compatible to LTC2977. They consist of two LTC2977 on a single die, and are instantiated as two separate chips, each supporting eight channels. Suggested-by: Michael Jones <mike@proclivis.com> Tested-by: Michael Jones <mike@proclivis.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-08-17hwmon: (ltc2978) Add support for LTC2975Guenter Roeck
LTC2975 is mostly compatible to LTC2974, but supports input current and power measurement. Tested-by: Michael Jones <mike@proclivis.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-08-12hwmon: (ltc2978) Add support for LTC3887Guenter Roeck
LTC3887 is an enhanced version of LTC3880 and supports the same commands. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-08-12hwmon: (ltc2978) Add support for LTC3882Guenter Roeck
LTC3882 is mostly compatible with LTC3880. Major differences are that it does not measure the input current, and it no longer supports LTC's legacy mechanism to identify the chip. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-08-10hwmon: (pmbus) Add device IDs for TPS544{B,C}2{0,5}Guenter Roeck
Add device IDs and references for Texas Instruments TPS544B20, TPS544B25, TPS544C20, and TPS544C25 to the generic PMBus driver. Reviewed-by: Jean Delvare <jdelvare@suse.de> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-08-09hwmon: (pmbus) Add support for MAX20751Guenter Roeck
MAX20751 is a multiphase power controller with internal buck converter. It uses VR12.0 to report the output voltage. This requires an explicit driver, since the VR version can not be auto-detected. The chip supports a manufacturer specific command to fine-tune the output voltage. This command is not currently supported. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-08-09hwmon: (it87) Add support for IT8732FJustin Maggard
Add support for the IT8732F. This chip is pretty similar to IT8721F, with the main difference being that the ADC LSB is 10.9 mV instead of 12 mV. Signed-off-by: Justin Maggard <jmaggard@netgear.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-08-09hwmon: (nct7802) Add auto_point attributesConstantine Shulyupin
Introduced REG_PWM, pwm[1..3]_auto_point[1..5]_temp, pwm[1..3]_auto_point[1..5]_pwm, nct7802_auto_point_attrs, nct7802_auto_point_group, updated nct7802_regmap_is_volatile Signed-off-by: Constantine Shulyupin <const@MakeLinux.com> Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-08-09hwmon: (adm1275) Add support for ADM1293 and ADM1294Guenter Roeck
ADM1293 and ADM1294 are mostly compatible with other chips of the same series, but have more configuration options. There are also some differences in register details. Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-07-29hwmon: (nct7904) Rename pwm attributes to match hwmon ABIGuenter Roeck
pwm attributes have well defined names, which should be used. Cc: Vadim V. Vlasov <vvlasov@dev.rtsoft.ru> Cc: stable@vger.kernel.org #v4.1+ Signed-off-by: Guenter Roeck <linux@roeck-us.net>
2015-07-03hwmon: Document which I2C addresses can be probedJean Delvare
Add an item to the checklist when submitting a new hwmon driver: only some I2C addresses can be probed, others should not for safety reasons. Signed-off-by: Jean Delvare <jdelvare@suse.de> Reviewed-by: Guenter Roeck <linux@roeck-us.net>
