path: root/Documentation/input
2008-03-14Input: add keyboard notifier documentationSamuel Thibault
Document the keyboard notifier. Signed-off-by: Samuel Thibault <samuel.thibault@ens-lyon.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz> SIgned-off-by: Dmitry Torokhov <dtor@mail.ru>
2008-01-21Input: fix bug in example codeSteven Whitehouse
The input example driver uses BTN_0 in the later stages of the example, so this changes the interrupt routine to match. Signed-off-by: Steven Whitehouse <swhiteho@redhat.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2007-10-20typo fixesMatt LaPlante
Most of these fixes were already submitted for old kernel versions, and were approved, but for some reason they never made it into the releases. Because this is a consolidation of a couple old missed patches, it touches both Kconfigs and documentation texts. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-20changed emailJohann Deneux
Changed email address of Johann Deneux (myself) Also removed CVS tags in comments (no longer using cvs) Signed-off-by: Johann Deneux <johann.deneux@gmail.com> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-19get rid of input BIT* duplicate definesJiri Slaby
get rid of input BIT* duplicate defines use newly global defined macros for input layer. Also remove includes of input.h from non-input sources only for BIT macro definiton. Define the macro temporarily in local manner, all those local definitons will be removed further in this patchset (to not break bisecting). BIT macro will be globally defined (1<<x) Signed-off-by: Jiri Slaby <jirislaby@gmail.com> Cc: <dtor@mail.ru> Acked-by: Jiri Kosina <jkosina@suse.cz> Cc: <lenb@kernel.org> Acked-by: Marcel Holtmann <marcel@holtmann.org> Cc: <perex@suse.cz> Acked-by: Mauro Carvalho Chehab <mchehab@infradead.org> Cc: <vernux@us.ibm.com> Cc: <malattia@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-09-20Fix CRLF line endings in Documentation/input/iforce-protocol.txtLinus Torvalds
Emil Medve points out that this documentation file uses CRLF line endings, which means that if you use [core] autocrlf=input (which makes sense if you ever develop under Windows, for example, or if you use other broken tools) in your git config, git will always complain about the file being dirty. This removes the bogus DOS line endings, and removes whitespace at the end of line. Cc: Emil Medve <Emilian.Medve@Freescale.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-09misc doc and kconfig typosMatt LaPlante
Fix various typos in kernel docs and Kconfigs, 2.6.21-rc4. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-29Input: update some documentationDmitry Torokhov
Input-programming.txt got out of sync with the latest changes in input core; let's refresh it. Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-11-30Fix typos in /Documentation : MiscMatt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some misc words. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-30Fix typos in /Documentation : 'U-Z'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some +words starting with the letters 'U-Z'. Looks like I made it through the alphabet...just in time to start over again +too! Maybe I can fit more profound fixes into the next round...? Time will +tell. :) Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-17USB: xpad: dance pad supportDominic Cerquetti
Adds support for dance pads to the xpad driver. Dance pads require the d-pad to be mapped to four buttons instead of two axes, so that combinations of up/down and left/right can be hit simultaneously. Known dance pads are detected, and there is a module parameter added to default unknown xpad devices to map the d-pad to buttons if this is desired. (dpad_to_buttons). Minor modifications were made to port the changes in the original patch to a newer kernel version. This patch was originally from Dominic Cerquetti originally written for kernel 2.6.11.4, with minor modifications (API changes for USB, spelling fixes to the documentation added in the original patch) made to apply to the current kernel. I have modified Dominic's original patch per some suggestions from Dmitry Torokhov. (There was nothing in the patch format description about multiple From: lines, so I haven't added myself.) [akpm@osdl.org: cleanups] Signed-off-by: Adam Buchbinder <adam.buchbinder@gmail.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-03Documentation: remove duplicated wordsPaolo Ornati
Remove many duplicated words under Documentation/ and do other small cleanups. Examples: "and and" --> "and" "in in" --> "in" "the the" --> "the" "the the" --> "to the" ... Signed-off-by: Paolo Ornati <ornati@fastwebnet.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'S'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letter 'S'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Alan Cox <alan@redhat.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'Q'-'R'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'Q'-'R'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'N'-'P'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'N'-'P'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'H'-'M'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'H'-'M'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'D'-'E'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'D'-'E'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'B'-'C'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'B'-'C'. There are also a few grammar fixes thrown in for Randy. ;) Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix some typos in Documentation/: 'A'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letter 'A'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03remove mentionings of devfs in documentationAdrian Bunk
Now that devfs is removed, there's no longer any need to document how to do this or that with devfs. This patch includes some improvements by Joe Perches. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03input: remove obsolete contact informationAdrian Bunk
This patch removes some obsolete contact information from Documentation/input/input.txt Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-19Merge rsync://rsync.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6Dmitry Torokhov
2006-08-23Input: remove dead URLs from Doclumentation/input/joystick.txtAlexey Dobriyan
Closes #2804. Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-07-19Input: update the force feedback documentationAnssi Hannula
Signed-off-by: Anssi Hannula <anssi.hannula@gmail.com> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-04-02Input: gamecon - add SNES mouse supportRaphael Assenat
SNES gamepads and mice share the same type of interface so they both can be connected to the parallel port using a simple interface. Adding mouse support to a gamepad driver may sound funny at first, but doing so in this case makes it possible to connect and SNES gamepads and mice at the same time, on the same port. Signed-off-by: Raphael Assenat <raph@raphnet.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2006-01-15Fix "stuct", "strut", "struc" typosAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-12-21Input: appletouch - add support for Geyser 2Michael Hanselmann
This patch adds support for the Geyser 2 touchpads used on post Oct 2005 Apple PowerBooks to the appletouch driver. Signed-off-by: Michael Hanselmann <linux-kernel@hansmi.ch> Acked-by: Rene Nussbaumer <linux-kernel@killerfox.forkbomb.ch> Acked-by: Johannes Berg <johannes@sipsolutions.net> Acked-by: Stelian Pop <stelian@popies.net> Signed-off-by: Dmitry Torokhov <dtor@mail.ru>
2005-10-28[PATCH] USB: Buffer overflow patch for Yealink driverHenk
Just a small patch that fixes a small parameter validation bug. drivers/usb/input/map_to_7segment.h: This patch fixes the broken parameter validation in the char to seg7 conversion. This could cause out-of-bounds memory references. MAINTAINERS: Yealink maintainer info now in sorted order. Documentation/input/yealink.txt: Added a Q&A section that answers some common questions. Signed-off-by: Henk <Henk.Vergonet@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> 006491df1a13f85ad245d1039dfdf20e49c394fd
2005-09-12[PATCH] USB: add apple usb touchpad driverStelian Pop
This is a driver for the USB touchpad which can be found on post-February 2005 Apple PowerBooks. This driver is derived from Johannes Berg's appletrackpad driver [1], but it has been improved in some areas: * appletouch is a full kernel driver, no userspace program is necessary * appletouch can be interfaced with the synaptics X11 driver[2], in order to have touchpad acceleration, scrolling, two/three finger tap, etc. This driver has been tested by the readers of the 'debian-powerpc' mailing list for a few weeks now and I believe it is now ready for inclusion into the mainline kernel. Credits go to Johannes Berg for reverse-engineering the touchpad protocol, Frank Arnold for further improvements, and Alex Harper for some additional information about the inner workings of the touchpad sensors. Signed-off-by: Stelian Pop <stelian@popies.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] USB: yealink: fix htons usage, documentation updatesHenk
Signed-off-by: Henk Vergonet <henk.vergonet@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2005-09-08[PATCH] input-driver-yealink-P1K-usb-phoneHenk
This patch aggregates all modifications in the -mm tree and adds complete ringtone support. The following features are supported: - keyboard full support - LCD full support - LED full support - dialtone full support - ringtone full support - audio playback via generic usb audio diver - audio record via generic usb audio diver For driver documentation see: Documentation/input/yealink.txt For vendor documentation see: http://yealink.com Signed-off-by: Henk <Henk.Vergonet@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
