path: root/Documentation/ioctl
2014-10-08cxl: Add documentation for userspace APIsIan Munsie
This documentation gives an overview of the hardware architecture, userspace APIs via /dev/cxl/afuM.N and the syfs files. It also adds a MAINTAINERS file entry for cxl. Signed-off-by: Ian Munsie <imunsie@au1.ibm.com> Signed-off-by: Michael Neuling <mikey@neuling.org> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2014-08-09Documentation: add How to avoid botching up ioctlsMichael Ellerman
I pointed some folks at this and they wondered why it wasn't in the kernel Documentation directory. So now it is. Signed-off-by: Daniel Vetter <daniel.vetter@ffwll.ch> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-06-20crypto: qat - Update to makefilesTadeusz Struk
Update to makefiles etc. Don't update the firmware/Makefile yet since there is no FW binary in the crypto repo yet. This will be added later. v3 - removed change to ./firmware/Makefile Reviewed-by: Bruce W. Allan <bruce.w.allan@intel.com> Signed-off-by: Tadeusz Struk <tadeusz.struk@intel.com> Signed-off-by: Herbert Xu <herbert@gondor.apana.org.au>
2014-01-24s390/hypfs: add interface for diagnose 0x304Martin Schwidefsky
To provide access to the set-partition-resource-parameter interface to user space add a new attribute to hypfs/debugfs: * s390_hypsfs/diag_304 The data for the query-partition-resource-parameters command can be access by a read on the attribute. All other diagnose 0x304 requests need to be submitted via ioctl with CAP_SYS_ADMIN rights. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-10-17ALSA: add DICE driverClemens Ladisch
As a start point for further development, this is an incomplete driver for DICE devices: - only playback (so no clock source except the bus clock) - only 44.1 kHz - no MIDI - recovery after bus reset is slow - hwdep device is created, but not actually implemented Contains compilation fixes by Stefan Richter. Signed-off-by: Clemens Ladisch <clemens@ladisch.de>
2013-06-26s390/sclp: Add SCLP character device driverMichael Holzheu
Add a character misc device "sclp_ctl" that allows to run SCCBs from user space using the SCLP_CTL_SCCB ioctl. Signed-off-by: Michael Holzheu <holzheu@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2013-03-25USB: cdc-wdm: implement IOCTL_WDM_MAX_COMMANDBjørn Mork
Userspace applications need to know the maximum supported message size. The cdc-wdm driver translates between a character device stream and a message based protocol. Each message is transported as a usb control message with no further encapsulation or syncronization. Each read or write on the character device should translate to exactly one usb control message to ensure that message boundaries are kept intact. That means that the userspace application must know the maximum message size supported by the device and driver, making this size a vital part of the cdc-wdm character device API. CDC WDM and CDC MBIM functions export the maximum supported message size through CDC functional descriptors. The cdc-wdm and cdc_mbim drivers will parse these descriptors and use the value chosen by the device. The only current way for a userspace application to retrive the value is by duplicating the descriptor parsing. This is an unnecessary complex task, and application writers are likely to postpone it, using a fixed value and adding a "todo" item. QMI functions have no way to tell the host what message size they support. The qmi_wwan driver use a fixed value based on protocol recommendations and observed device behaviour. Userspace applications must know and hard code the same value. This scheme will break if we ever encounter a QMI device needing a device specific message size quirk. We are currently unable to support such a device because using a non default size would break the implicit userspace API. The message size is currently a hidden attribute of the cdc-wdm userspace API. Retrieving it is unnecessarily complex, increasing the possibility of drivers and applications using different limits. The resulting errors are hard to debug, and can only be replicated on identical hardware. Exporting the maximum message size from the driver simplifies the task for the userspace application, and creates a unified information source independent of device and function class. It also serves to document that the message size is part of the cdc-wdm userspace API. This proposed API extension has been presented for the authors of userspace applications and libraries using the current API: libmbim, libqmi, uqmi, oFono and ModemManager. The replies were: Aleksander Morgado: "We do really need max message size for MBIM; and as you say, it may be good to have the max message size info also for QMI, so the new ioctl seems a good addition. So +1 from my side, for what it's worth." Dan Williams: "Yeah, +1 here. I'd prefer the sysfs file, but the fact that that doesn't work for fd passing pretty much kills it." No negative replies are so far received. Cc: Aleksander Morgado <aleksander@lanedo.com> Cc: Dan Williams <dcbw@redhat.com> Signed-off-by: Bjørn Mork <bjorn@mork.no> Acked-by: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-31wanrouter: completely decouple obsolete code from kernel.Paul Gortmaker
The original suggestion to delete wanrouter started earlier with the mainline commit f0d1b3c2bcc5de8a17af5f2274f7fcde8292b5fc ("net/wanrouter: Deprecate and schedule for removal") in May 2012. More importantly, Dan Carpenter found[1] that the driver had a fundamental breakage introduced back in 2008, with commit 7be6065b39c3 ("netdevice wanrouter: Convert directly reference of netdev->priv"). So we know with certainty that the code hasn't been used by anyone willing to at least take the effort to send an e-mail report of breakage for at least 4 years. This commit does a decouple of the wanrouter subsystem, by going after the Makefile/Kconfig and similar files, so that these mainline files that we are keeping do not have the big wanrouter file/driver deletion commit tied into their history. Once this commit is in place, we then can remove the obsolete cyclomx drivers and similar that have a dependency on CONFIG_WAN_ROUTER_DRIVERS. [1] http://www.spinics.net/lists/netdev/msg218670.html Originally-by: Joe Perches <joe@perches.com> Cc: Dan Carpenter <dan.carpenter@oracle.com> Cc: Arnaldo Carvalho de Melo <acme@redhat.com> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-08-14ioctl-number.txt: Remove legacy private ioctl's from media driversMauro Carvalho Chehab
None of those drivers use private ioctl's, as they all got converted to the standard V4L2 ones. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2012-07-31vfio: VFIO coreAlex Williamson
VFIO is a secure user level driver for use with both virtual machines and user level drivers. VFIO makes use of IOMMU groups to ensure the isolation of devices in use, allowing unprivileged user access. It's intended that VFIO will replace KVM device assignment and UIO drivers (in cases where the target platform includes a sufficiently capable IOMMU). New in this version of VFIO is support for IOMMU groups managed through the IOMMU core as well as a rework of the API, removing the group merge interface. We now go back to a model more similar to original VFIO with UIOMMU support where the file descriptor obtained from /dev/vfio/vfio allows access to the IOMMU, but only after a group is added, avoiding the previous privilege issues with this type of model. IOMMU support is also now fully modular as IOMMUs have vastly different interface requirements on different platforms. VFIO users are able to query and initialize the IOMMU model of their choice. Please see the follow-on Documentation commit for further description and usage example. Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
2012-05-09mei: update Documentation/ioctl/ioctl-number.txtTomas Winkler
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-04-02Merge branch 'for-next' of git://gitorious.org/kernel-hsi/kernel-hsiLinus Torvalds
Pull HSI (High Speed Synchronous Serial Interface) framework from Carlos Chinea: "The High Speed Synchronous Serial Interface (HSI) is a serial interface mainly used for connecting application engines (APE) with cellular modem engines (CMT) in cellular handsets. The framework is currently being used for some people and we would like to see it integrated into the kernel for 3.3. There is no HW controller drivers in this pull, but some people have already some of them pending which they would like to push as soon as this integrated. I am also working on the acceptance for an TI OMAP one, based on a compatible legacy version of the interface called SSI." Ok, so it didn't get into 3.3, but here it is pulled into 3.4. Several people piped up to say "yeah, we want this". * 'for-next' of git://gitorious.org/kernel-hsi/kernel-hsi: HSI: hsi_char: Update ioctl-number.txt HSI: Add HSI API documentation HSI: hsi_char: Add HSI char device kernel configuration HSI: hsi_char: Add HSI char device driver HSI: hsi: Introducing HSI framework
2012-03-21Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs Pull vfs pile 1 from Al Viro: "This is _not_ all; in particular, Miklos' and Jan's stuff is not there yet." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits) ext4: initialization of ext4_li_mtx needs to be done earlier debugfs-related mode_t whack-a-mole hfsplus: add an ioctl to bless files hfsplus: change finder_info to u32 hfsplus: initialise userflags qnx4: new helper - try_extent() qnx4: get rid of qnx4_bread/qnx4_getblk take removal of PF_FORKNOEXEC to flush_old_exec() trim includes in inode.c um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it um: embed ->stub_pages[] into mmu_context gadgetfs: list_for_each_safe() misuse ocfs2: fix leaks on failure exits in module_init ecryptfs: make register_filesystem() the last potential failure exit ntfs: forgets to unregister sysctls on register_filesystem() failure logfs: missing cleanup on register_filesystem() failure jfs: mising cleanup on register_filesystem() failure make configfs_pin_fs() return root dentry on success configfs: configfs_create_dir() has parent dentry in dentry->d_parent configfs: sanitize configfs_create() ...
2012-03-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial Pull trivial tree from Jiri Kosina: "It's indeed trivial -- mostly documentation updates and a bunch of typo fixes from Masanari. There are also several linux/version.h include removals from Jesper." * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (101 commits) kcore: fix spelling in read_kcore() comment constify struct pci_dev * in obvious cases Revert "char: Fix typo in viotape.c" init: fix wording error in mm_init comment usb: gadget: Kconfig: fix typo for 'different' Revert "power, max8998: Include linux/module.h just once in drivers/power/max8998_charger.c" writeback: fix fn name in writeback_inodes_sb_nr_if_idle() comment header writeback: fix typo in the writeback_control comment Documentation: Fix multiple typo in Documentation tpm_tis: fix tis_lock with respect to RCU Revert "media: Fix typo in mixer_drv.c and hdmi_drv.c" Doc: Update numastat.txt qla4xxx: Add missing spaces to error messages compiler.h: Fix typo security: struct security_operations kerneldoc fix Documentation: broken URL in libata.tmpl Documentation: broken URL in filesystems.tmpl mtd: simplify return logic in do_map_probe() mm: fix comment typo of truncate_inode_pages_range power: bq27x00: Fix typos in comment ...
2012-03-20Merge git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-nextLinus Torvalds
Pull networking merge from David Miller: "1) Move ixgbe driver over to purely page based buffering on receive. From Alexander Duyck. 2) Add receive packet steering support to e1000e, from Bruce Allan. 3) Convert TCP MD5 support over to RCU, from Eric Dumazet. 4) Reduce cpu usage in handling out-of-order TCP packets on modern systems, also from Eric Dumazet. 5) Support the IP{,V6}_UNICAST_IF socket options, making the wine folks happy, from Erich Hoover. 6) Support VLAN trunking from guests in hyperv driver, from Haiyang Zhang. 7) Support byte-queue-limtis in r8169, from Igor Maravic. 8) Outline code intended for IP_RECVTOS in IP_PKTOPTIONS existed but was never properly implemented, Jiri Benc fixed that. 9) 64-bit statistics support in r8169 and 8139too, from Junchang Wang. 10) Support kernel side dump filtering by ctmark in netfilter ctnetlink, from Pablo Neira Ayuso. 11) Support byte-queue-limits in gianfar driver, from Paul Gortmaker. 12) Add new peek socket options to assist with socket migration, from Pavel Emelyanov. 13) Add sch_plug packet scheduler whose queue is controlled by userland daemons using explicit freeze and release commands. From Shriram Rajagopalan. 14) Fix FCOE checksum offload handling on transmit, from Yi Zou." * git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1846 commits) Fix pppol2tp getsockname() Remove printk from rds_sendmsg ipv6: fix incorrent ipv6 ipsec packet fragment cpsw: Hook up default ndo_change_mtu. net: qmi_wwan: fix build error due to cdc-wdm dependecy netdev: driver: ethernet: Add TI CPSW driver netdev: driver: ethernet: add cpsw address lookup engine support phy: add am79c874 PHY support mlx4_core: fix race on comm channel bonding: send igmp report for its master fs_enet: Add MPC5125 FEC support and PHY interface selection net: bpf_jit: fix BPF_S_LDX_B_MSH compilation net: update the usage of CHECKSUM_UNNECESSARY fcoe: use CHECKSUM_UNNECESSARY instead of CHECKSUM_PARTIAL on tx net: do not do gso for CHECKSUM_UNNECESSARY in netif_needs_gso ixgbe: Fix issues with SR-IOV loopback when flow control is disabled net/hyperv: Fix the code handling tx busy ixgbe: fix namespace issues when FCoE/DCB is not enabled rtlwifi: Remove unused ETH_ADDR_LEN defines igbvf: Use ETH_ALEN ... Fix up fairly trivial conflicts in drivers/isdn/gigaset/interface.c and drivers/net/usb/{Kconfig,qmi_wwan.c} as per David.
2012-03-20hfsplus: add an ioctl to bless filesMatthew Garrett
Making an hfsplus partition bootable requires the ability to "bless" a file by putting its inode number in the volume header. Doing this from userspace on a mounted filesystem is impractical since the kernel will write back the original values on unmount. Add an ioctl to allow userspace to update the volume header information based on the target file. Signed-off-by: Matthew Garrett <mjg@redhat.com> Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-03-07Documentation: Fix multiple typo in DocumentationMasanari Iida
Signed-off-by: Masanari Iida <standby24x7@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-04ppp: Move ioctl definitions from if_ppp.h to new ppp-ioctl.hPaul Mackerras
This moves the definitions of the ioctls, constants and structures relating to the ppp_generic interface to userspace out from if_ppp.h to a new file, ppp-ioctl.h. The new file has my copyright since I designed and implemented the ppp_generic interface in the late 1990s. None of the contents of this file comes from the original if_ppp.h published by Carnegie Mellon University. Of the remainder of if_ppp.h, only the PPP_MTU definition was being used, and this replaces the uses of it with PPP_MRU (which is identical). Therefore, this replaces the entire file with the single line #include <linux/ppp-ioctl.h> which clearly doesn't contain any CMU code. Thus I have removed the CMU copyright notice with its problematic advertising clause, and in fact since it's only one trivial line I have not added any other copyright notice. Signed-off-by: Paul Mackerras <paulus@samba.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2012-02-15driver-core: documentation: fix up Greg's email addressGreg Kroah-Hartman
My old email address was used in a lot of documentation files, so fix this up to point to the correct one now. Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-01-05HSI: hsi_char: Update ioctl-number.txtAndras Domokos
Added ioctl range for HSI char devices to the documentation Signed-off-by: Andras Domokos <andras.domokos@nokia.com> Signed-off-by: Carlos Chinea <carlos.chinea@nokia.com>
2011-11-04NVMe: New driverMatthew Wilcox
This driver is for devices that follow the NVM Express standard Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
2011-09-12ioctl: register LTTng ioctlMathieu Desnoyers
The LTTng 2.0 kernel tracer (stand-alone module package, available at http://lttng.org) uses the 0xF6 ioctl range for tracer control and transport operations. Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-08-02Merge git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tileLinus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile: arch/tile/mm/init.c: trivial: use BUG_ON arch/tile: remove useless set_fixmap_nocache() macro arch/tile: add hypervisor-based character driver for SPI flash ROM ioctl-number.txt: add the tile hardwall ioctl range tile: use generic-y format for one-line asm-generic headers clocksource: tile: convert to use clocksource_register_hz
2011-07-08drivers/virt: introduce Freescale hypervisor management driverTimur Tabi
Add the drivers/virt directory, which houses drivers that support virtualization environments, and add the Freescale hypervisor management driver. The Freescale hypervisor management driver provides several services to drivers and applications related to the Freescale hypervisor: 1. An ioctl interface for querying and managing partitions 2. A file interface to reading incoming doorbells 3. An interrupt handler for shutting down the partition upon receiving the shutdown doorbell from a manager partition 4. A kernel interface for receiving callbacks when a managed partition shuts down. Signed-off-by: Timur Tabi <timur@freescale.com> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-06-10ioctl-number.txt: add the tile hardwall ioctl rangeChris Metcalf
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
2011-05-25Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (75 commits) mmc: core: eMMC bus width may not work on all platforms mmc: sdhci: Auto-CMD23 fixes. mmc: sdhci: Auto-CMD23 support. mmc: core: Block CMD23 support for UHS104/SDXC cards. mmc: sdhci: Implement MMC_CAP_CMD23 for SDHCI. mmc: core: Use CMD23 for multiblock transfers when we can. mmc: quirks: Add/remove quirks conditional support. mmc: Add new VUB300 USB-to-SD/SDIO/MMC driver mmc: sdhci-pxa: Add quirks for DMA/ADMA to match h/w mmc: core: duplicated trial with same freq in mmc_rescan_try_freq() mmc: core: add support for eMMC Dual Data Rate mmc: core: eMMC signal voltage does not use CMD11 mmc: sdhci-pxa: add platform code for UHS signaling mmc: sdhci: add hooks for setting UHS in platform specific code mmc: core: clear MMC_PM_KEEP_POWER flag on resume mmc: dw_mmc: fixed wrong regulator_enable in suspend/resume mmc: sdhi: allow powering down controller with no card inserted mmc: tmio: runtime suspend the controller, where possible mmc: sdhi: support up to 3 interrupt sources mmc: sdhi: print physical base address and clock rate ...
2011-05-24mmc: core: Add mmc CMD+ACMD passthrough ioctlJohn Calixto
Allows appropriately-privileged applications to send CMD (normal) and ACMD (application-specific; preceded with CMD55) commands to cards/devices on the mmc bus. This is primarily useful for enabling the security functionality built in to every SD card. It can also be used as a generic passthrough (e.g. to enable virtual machines to control mmc bus devices directly). However, this use case has not been tested rigorously. Generic passthrough testing was only conducted for a few non-security opcodes to prove the feasibility of the passthrough. Since any opcode can be sent using this passthrough, it is very possible to render the card/device unusable. Applications that use this ioctl must have CAP_SYS_RAWIO. Security commands tested on TI PCIxx12 (SDHCI), Sigma Designs SMP8652 SoC, TI OMAP3621/OMAP3630 SoC, Samsung S5PC110 SoC, Qualcomm MSM7200A SoC. Signed-off-by: John Calixto <john.calixto@modsystems.com> Reviewed-by: Andrei Warkentin <andreiw@motorola.com> Reviewed-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Chris Ball <cjb@laptop.org>
2011-05-20[media] uvcvideo: Make the API publicLaurent Pinchart
Move the public API definitions to include/linux/uvcvideo.h and bump the version number to 1.1.0. Compatibility with the old API is kept, application can still be compiled against the private header and will not break. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-03-24Merge branch 'v4l_for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6 * 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (442 commits) [media] videobuf2-dma-contig: make cookie() return a pointer to dma_addr_t [media] sh_mobile_ceu_camera: Do not call vb2's mem_ops directly [media] V4L: soc-camera: explicitly require V4L2_BUF_TYPE_VIDEO_CAPTURE [media] v4l: soc-camera: Store negotiated buffer settings [media] rc: interim support for 32-bit NEC-ish scancodes [media] mceusb: topseed 0x0011 needs gen3 init for tx to work [media] lirc_zilog: error out if buffer read bytes != chunk size [media] lirc: silence some compile warnings [media] hdpvr: use same polling interval as other OS [media] ir-kbd-i2c: pass device code w/key in hauppauge case [media] rc/keymaps: Remove the obsolete rc-rc5-tv keymap [media] remove the old RC_MAP_HAUPPAUGE_NEW RC map [media] rc/keymaps: Rename Hauppauge table as rc-hauppauge [media] rc-rc5-hauppauge-new: Fix Hauppauge Grey mapping [media] rc-rc5-hauppauge-new: Add support for the old Black RC [media] rc-rc5-hauppauge-new: Add the old control to the table [media] rc-winfast: Fix the keycode tables [media] a800: Fix a few wrong IR key assignments [media] opera1: Use multimedia keys instead of an app-specific mapping [media] dw2102: Use multimedia keys instead of an app-specific mapping ... Fix up trivial conflicts (remove/modify and some real conflicts) in: arch/arm/mach-omap2/devices.c drivers/staging/Kconfig drivers/staging/Makefile drivers/staging/dabusb/dabusb.c drivers/staging/dabusb/dabusb.h drivers/staging/easycap/easycap_ioctl.c drivers/staging/usbvideo/usbvideo.c drivers/staging/usbvideo/vicam.c
2011-03-22[media] media: Pick a free ioctls rangeLaurent Pinchart
Pick an unused range of ioctls in Documentation/ioctl/ioctl-number.txt and use it for the MEDIA_IOC_* ioctls. Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2011-02-03HID: roccat: Rename header roccat.h -> hid-roccat.hStefan Achatz
It was desired that the header roccat.h should be named hid-roccat.h Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-02-03HID: roccat: Add ioctl command to retreive report size from chardevStefan Achatz
Roccat chardev was reworked to support only a defined report size per device and this can be retreived by an ioctl now to enable future changes in report definitions. Header was moved/renamed from drivers/hid to include/linux for accessibility. Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-01-13pps: add kernel consumer supportAlexander Gordeev
Add an optional feature of PPSAPI, kernel consumer support, which uses the added hardpps() function. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-12-29[media] bt819: the ioctls in the header are internal to the kernelHans Verkuil
Remove bt819.h from ioctl-number.txt and make a note in the header that these ioctls are for internal use only. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] saa6588: rename rds.h to saa6588.hHans Verkuil
The naming of the media/rds.h header suggested that it was a generic RDS header, when in fact it is just a saa6588 module API that is internal to the kernel. Rename the header and the struct and defines in it to make this clear. Also removed the header include in radio-si470x.h (not used anymore) and from ioctl-number.txt (it's internal to the kernel and never called from userspace). Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-12-29[media] Documentation/ioctl/ioctl-number.txt: Remove some now freed ioctl rangesMauro Carvalho Chehab
The V4L1 removal patches removed a few ioctls. Update it at the docspace. Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-28Merge git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6Linus Torvalds
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (841 commits) Staging: brcm80211: fix usage of roundup in structures Staging: bcm: fix up network device reference counting Staging: keucr: fix up US_ macro change staging: brcm80211: brcmfmac: Removed codeversion from firmware filenames. staging: brcm80211: Remove unnecessary header files. staging: brcm80211: Remove unnecessary includes from bcmutils.c staging: brcm80211: Removed unnecessary pktsetprio() function. Staging: brcm80211: remove typedefs.h Staging: brcm80211: remove uintptr typedef usage Staging: hv: remove struct vmbus_channel_interface Staging: hv: remove Open from struct vmbus_channel_interface Staging: hv: storvsc: call vmbus_open directly Staging: hv: netvsc: call vmbus_open directly Staging: hv: channel: export vmbus_open to modules Staging: hv: remove Close from struct vmbus_channel_interface Staging: hv: netvsc: call vmbus_close directly Staging: hv: storvsc: call vmbus_close directly Staging: hv: channel: export vmbus_close to modules Staging: hv: remove SendPacket from struct vmbus_channel_interface Staging: hv: storvsc: call vmbus_sendpacket directly ... Fix up conflicts in drivers/staging/cx25821/cx25821-audio-upstream.c drivers/staging/cx25821/cx25821-audio.h due to warring whitespace cleanups (neither of which were all that great)
2010-10-21V4L/DVB: Documentation: update now that the vtx/videotext API has been removedHans Verkuil
Remove all references to /dev/vtx in the documentation, except for some historical comments in dev-teletext.xml. Documentation/devices.txt is not updated, this will go through Alan Cox who maintains this file. Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl> Signed-off-by: Mauro Carvalho Chehab <mchehab@redhat.com>
2010-10-05smbfs: move to drivers/stagingArnd Bergmann
smbfs has been scheduled for removal in 2.6.27, so maybe we can now move it to drivers/staging on the way out. smbfs still uses the big kernel lock and nobody is going to fix that, so we should be getting rid of it soon. This removes the 32 bit compat mount and ioctl handling code, which is implemented in common fs code, and moves all smbfs related files into drivers/staging/smbfs. Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Jeff Layton <jlayton@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6 * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: (82 commits) firewire: core: add forgotten dummy driver methods, remove unused ones firewire: add isochronous multichannel reception firewire: core: small clarifications in core-cdev firewire: core: remove unused code firewire: ohci: release channel in error path firewire: ohci: use memory barriers to order descriptor updates tools/firewire: nosy-dump: increment program version tools/firewire: nosy-dump: remove unused code tools/firewire: nosy-dump: use linux/firewire-constants.h tools/firewire: nosy-dump: break up a deeply nested function tools/firewire: nosy-dump: make some symbols static or const tools/firewire: nosy-dump: change to kernel coding style tools/firewire: nosy-dump: work around segfault in decode_fcp tools/firewire: nosy-dump: fix it on x86-64 tools/firewire: add userspace front-end of nosy firewire: nosy: note ioctls in ioctl-number.txt firewire: nosy: use generic printk macros firewire: nosy: endianess fixes and annotations firewire: nosy: annotate __user pointers and __iomem pointers firewire: nosy: fix device shutdown with active client ...
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-07-27firewire: nosy: note ioctls in ioctl-number.txtStefan Richter
These are the ioctls for the special-purpose misc device /dev/nosy, the interface to the IEEE 1394 packet sniffer/ protocol analyzer driver. Currently only the numbers 00...02 are in use; let's block a few more for unforeseen use cases. Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
2010-03-19Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (205 commits) ceph: update for write_inode API change ceph: reset osd after relevant messages timed out ceph: fix flush_dirty_caps race with caps migration ceph: include migrating caps in issued set ceph: fix osdmap decoding when pools include (removed) snaps ceph: return EBADF if waiting for caps on closed file ceph: set osd request message front length correctly ceph: reset front len on return to msgpool; BUG on mismatched front iov ceph: fix snaptrace decoding on cap migration between mds ceph: use single osd op reply msg ceph: reset bits on connection close ceph: remove bogus mds forward warning ceph: remove fragile __map_osds optimization ceph: fix connection fault STANDBY check ceph: invalidate_authorizer without con->mutex held ceph: don't clobber write return value when using O_SYNC ceph: fix client_request_forward decoding ceph: drop messages on unregistered mds sessions; cleanup ceph: fix comments, locking in destroy_inode ceph: move dereference after NULL test ... Fix trivial conflicts in Documentation/ioctl/ioctl-number.txt
2010-03-02USB: vstusb.c: removal of driver for Vernier Software & Technology, Inc., ↵Dennis O'Brien
devices and spectrometers This patch removes the vstusb driver and support from the Linux tree. This driver provided support for Vernier Software & Technology devices and spectrometers (Ocean Optics). This driver is being replaced by a user space - libusb - implementation. Signed-off-by: Jim Collar <jim.collar@eqware.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-01-11docs: large update to ioctl-number.txtRandy Dunlap
Add many ioctl definitions to ioctl-number.txt. Fix some whitespace/formatting. Correct some filenames/paths. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-06ceph: ioctlsSage Weil
A few Ceph ioctls for getting and setting file layout (striping) parameters, and learning the identity and network address of the OSD a given region of a file is stored on. Signed-off-by: Sage Weil <sage@newdream.net>
2009-09-24drivers/char/uv_mmtimer.c: add memory mapped RTC driver for UVDimitri Sivanich
This driver memory maps the UV Hub RTC. Signed-off-by: Dimitri Sivanich <sivanich@sgi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-14Merge branch 'kvm-updates/2.6.32' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
* 'kvm-updates/2.6.32' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (202 commits) MAINTAINERS: update KVM entry KVM: correct error-handling code KVM: fix compile warnings on s390 KVM: VMX: Check cpl before emulating debug register access KVM: fix misreporting of coalesced interrupts by kvm tracer KVM: x86: drop duplicate kvm_flush_remote_tlb calls KVM: VMX: call vmx_load_host_state() only if msr is cached KVM: VMX: Conditionally reload debug register 6 KVM: Use thread debug register storage instead of kvm specific data KVM guest: do not batch pte updates from interrupt context KVM: Fix coalesced interrupt reporting in IOAPIC KVM guest: fix bogus wallclock physical address calculation KVM: VMX: Fix cr8 exiting control clobbering by EPT KVM: Optimize kvm_mmu_unprotect_page_virt() for tdp KVM: Document KVM_CAP_IRQCHIP KVM: Protect update_cr8_intercept() when running without an apic KVM: VMX: Fix EPT with WP bit change during paging KVM: Use kvm_{read,write}_guest_virt() to read and write segment descriptors KVM: x86 emulator: Add adc and sbb missing decoder flags KVM: Add missing #include ...
2009-09-10Documentation: Update KVM list email addressAmit Shah
The KVM list moved to vger.kernel.org last year Signed-off-by: Amit Shah <amit.shah@redhat.com> Signed-off-by: Avi Kivity <avi@redhat.com>
2009-08-31x86, msr: Export the register-setting MSR functions via /dev/*/msrH. Peter Anvin
Make it possible to access the all-register-setting/getting MSR functions via the MSR driver. This is implemented as an ioctl() on the standard MSR device node. Signed-off-by: H. Peter Anvin <hpa@zytor.com> Cc: Borislav Petkov <petkovbb@gmail.com>
