Provide initial documentation for tegra
camera ioctls
Bug 1466413
Change-Id: I5d460ec3e98f10ea03f0f0a452d20e93d5c19c7a
Signed-off-by: Anton Kondratenko <akondratenko@nvidia.com>
Reviewed-on: http://git-master/r/390380
Reviewed-by: Thomas Cherry <tcherry@nvidia.com>
Userspace applications need to know the maximum supported message
size.
The cdc-wdm driver translates between a character device stream
and a message based protocol. Each message is transported as a
usb control message with no further encapsulation or syncronization.
Each read or write on the character device should translate to
exactly one usb control message to ensure that message boundaries
are kept intact. That means that the userspace application must
know the maximum message size supported by the device and driver,
making this size a vital part of the cdc-wdm character device API.
CDC WDM and CDC MBIM functions export the maximum supported
message size through CDC functional descriptors. The cdc-wdm and
cdc_mbim drivers will parse these descriptors and use the value
chosen by the device. The only current way for a userspace
application to retrive the value is by duplicating the descriptor
parsing. This is an unnecessary complex task, and application
writers are likely to postpone it, using a fixed value and adding
a "todo" item.
QMI functions have no way to tell the host what message size they
support. The qmi_wwan driver use a fixed value based on protocol
recommendations and observed device behaviour. Userspace
applications must know and hard code the same value. This scheme
will break if we ever encounter a QMI device needing a device
specific message size quirk. We are currently unable to support
such a device because using a non default size would break the
implicit userspace API.
The message size is currently a hidden attribute of the cdc-wdm
userspace API. Retrieving it is unnecessarily complex, increasing
the possibility of drivers and applications using different limits.
The resulting errors are hard to debug, and can only be replicated
on identical hardware.
Exporting the maximum message size from the driver simplifies the
task for the userspace application, and creates a unified
information source independent of device and function class. It also
serves to document that the message size is part of the cdc-wdm
userspace API.
This proposed API extension has been presented for the authors of
userspace applications and libraries using the current API: libmbim,
libqmi, uqmi, oFono and ModemManager. The replies were:
Aleksander Morgado:
"We do really need max message size for MBIM; and as you say, it may be
good to have the max message size info also for QMI, so the new ioctl
seems a good addition. So +1 from my side, for what it's worth."
Dan Williams:
"Yeah, +1 here. I'd prefer the sysfs file, but the fact that that
doesn't work for fd passing pretty much kills it."
No negative replies are so far received.
Cc: Aleksander Morgado <aleksander@lanedo.com>
Cc: Dan Williams <dcbw@redhat.com>
Signed-off-by: Bjørn Mork <bjorn@mork.no>
Acked-by: Oliver Neukum <oliver@neukum.org>
The original suggestion to delete wanrouter started earlier
with the mainline commit f0d1b3c2bcc5de8a17af5f2274f7fcde8292b5fc
("net/wanrouter: Deprecate and schedule for removal") in May 2012.
More importantly, Dan Carpenter found[1] that the driver had a
fundamental breakage introduced back in 2008, with commit
7be6065b39c3 ("netdevice wanrouter: Convert directly reference of
netdev->priv"). So we know with certainty that the code hasn't been
used by anyone willing to at least take the effort to send an e-mail
report of breakage for at least 4 years.
This commit does a decouple of the wanrouter subsystem, by going
after the Makefile/Kconfig and similar files, so that these mainline
files that we are keeping do not have the big wanrouter file/driver
deletion commit tied into their history.
Once this commit is in place, we then can remove the obsolete cyclomx
drivers and similar that have a dependency on CONFIG_WAN_ROUTER_DRIVERS.
[1] http://www.spinics.net/lists/netdev/msg218670.html
Originally-by: Joe Perches <joe@perches.com>
Cc: Dan Carpenter <dan.carpenter@oracle.com>
Cc: Arnaldo Carvalho de Melo <acme@redhat.com>
None of those drivers use private ioctl's, as they all got converted
to the standard V4L2 ones.
VFIO is a secure user level driver for use with both virtual machines
and user level drivers. VFIO makes use of IOMMU groups to ensure the
isolation of devices in use, allowing unprivileged user access. It's
intended that VFIO will replace KVM device assignment and UIO drivers
(in cases where the target platform includes a sufficiently capable
IOMMU).
New in this version of VFIO is support for IOMMU groups managed
through the IOMMU core as well as a rework of the API, removing the
group merge interface. We now go back to a model more similar to
original VFIO with UIOMMU support where the file descriptor obtained
from /dev/vfio/vfio allows access to the IOMMU, but only after a
group is added, avoiding the previous privilege issues with this type
of model. IOMMU support is also now fully modular as IOMMUs have
vastly different interface requirements on different platforms. VFIO
users are able to query and initialize the IOMMU model of their
choice.
Please see the follow-on Documentation commit for further description
and usage example.
Signed-off-by: Alex Williamson <alex.williamson@redhat.com>
Signed-off-by: Tomas Winkler <tomas.winkler@intel.com>
Pull HSI (High Speed Synchronous Serial Interface) framework from Carlos Chinea:
"The High Speed Synchronous Serial Interface (HSI) is a serial
interface mainly used for connecting application engines (APE) with
cellular modem engines (CMT) in cellular handsets.
The framework is currently being used for some people and we would
like to see it integrated into the kernel for 3.3. There is no HW
controller drivers in this pull, but some people have already some of
them pending which they would like to push as soon as this integrated.
I am also working on the acceptance for an TI OMAP one, based on a
compatible legacy version of the interface called SSI."
Ok, so it didn't get into 3.3, but here it is pulled into 3.4.
Several people piped up to say "yeah, we want this".
* 'for-next' of git://gitorious.org/kernel-hsi/kernel-hsi:
HSI: hsi_char: Update ioctl-number.txt
HSI: Add HSI API documentation
HSI: hsi_char: Add HSI char device kernel configuration
HSI: hsi_char: Add HSI char device driver
HSI: hsi: Introducing HSI framework
Pull vfs pile 1 from Al Viro:
"This is _not_ all; in particular, Miklos' and Jan's stuff is not there
yet."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/viro/vfs: (64 commits)
ext4: initialization of ext4_li_mtx needs to be done earlier
debugfs-related mode_t whack-a-mole
hfsplus: add an ioctl to bless files
hfsplus: change finder_info to u32
hfsplus: initialise userflags
qnx4: new helper - try_extent()
qnx4: get rid of qnx4_bread/qnx4_getblk
take removal of PF_FORKNOEXEC to flush_old_exec()
trim includes in inode.c
um: uml_dup_mmap() relies on ->mmap_sem being held, but activate_mm() doesn't hold it
um: embed ->stub_pages[] into mmu_context
gadgetfs: list_for_each_safe() misuse
ocfs2: fix leaks on failure exits in module_init
ecryptfs: make register_filesystem() the last potential failure exit
ntfs: forgets to unregister sysctls on register_filesystem() failure
logfs: missing cleanup on register_filesystem() failure
jfs: mising cleanup on register_filesystem() failure
make configfs_pin_fs() return root dentry on success
configfs: configfs_create_dir() has parent dentry in dentry->d_parent
configfs: sanitize configfs_create()
Pull trivial tree from Jiri Kosina:
"It's indeed trivial -- mostly documentation updates and a bunch of
typo fixes from Masanari.
There are also several linux/version.h include removals from Jesper."
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (101 commits)
kcore: fix spelling in read_kcore() comment
constify struct pci_dev * in obvious cases
Revert "char: Fix typo in viotape.c"
init: fix wording error in mm_init comment
usb: gadget: Kconfig: fix typo for 'different'
Revert "power, max8998: Include linux/module.h just once in drivers/power/max8998_charger.c"
writeback: fix fn name in writeback_inodes_sb_nr_if_idle() comment header
writeback: fix typo in the writeback_control comment
Documentation: Fix multiple typo in Documentation
tpm_tis: fix tis_lock with respect to RCU
Revert "media: Fix typo in mixer_drv.c and hdmi_drv.c"
Doc: Update numastat.txt
qla4xxx: Add missing spaces to error messages
compiler.h: Fix typo
security: struct security_operations kerneldoc fix
Documentation: broken URL in libata.tmpl
Documentation: broken URL in filesystems.tmpl
mtd: simplify return logic in do_map_probe()
mm: fix comment typo of truncate_inode_pages_range
power: bq27x00: Fix typos in comment
Pull networking merge from David Miller:
"1) Move ixgbe driver over to purely page based buffering on receive.
From Alexander Duyck.
2) Add receive packet steering support to e1000e, from Bruce Allan.
3) Convert TCP MD5 support over to RCU, from Eric Dumazet.
4) Reduce cpu usage in handling out-of-order TCP packets on modern
systems, also from Eric Dumazet.
5) Support the IP{,V6}_UNICAST_IF socket options, making the wine
folks happy, from Erich Hoover.
6) Support VLAN trunking from guests in hyperv driver, from Haiyang
Zhang.
7) Support byte-queue-limtis in r8169, from Igor Maravic.
8) Outline code intended for IP_RECVTOS in IP_PKTOPTIONS existed but
was never properly implemented, Jiri Benc fixed that.
9) 64-bit statistics support in r8169 and 8139too, from Junchang Wang.
10) Support kernel side dump filtering by ctmark in netfilter
ctnetlink, from Pablo Neira Ayuso.
11) Support byte-queue-limits in gianfar driver, from Paul Gortmaker.
12) Add new peek socket options to assist with socket migration, from
Pavel Emelyanov.
13) Add sch_plug packet scheduler whose queue is controlled by
userland daemons using explicit freeze and release commands. From
Shriram Rajagopalan.
14) Fix FCOE checksum offload handling on transmit, from Yi Zou."
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next: (1846 commits)
Fix pppol2tp getsockname()
Remove printk from rds_sendmsg
ipv6: fix incorrent ipv6 ipsec packet fragment
cpsw: Hook up default ndo_change_mtu.
net: qmi_wwan: fix build error due to cdc-wdm dependecy
netdev: driver: ethernet: Add TI CPSW driver
netdev: driver: ethernet: add cpsw address lookup engine support
phy: add am79c874 PHY support
mlx4_core: fix race on comm channel
bonding: send igmp report for its master
fs_enet: Add MPC5125 FEC support and PHY interface selection
net: bpf_jit: fix BPF_S_LDX_B_MSH compilation
net: update the usage of CHECKSUM_UNNECESSARY
fcoe: use CHECKSUM_UNNECESSARY instead of CHECKSUM_PARTIAL on tx
net: do not do gso for CHECKSUM_UNNECESSARY in netif_needs_gso
ixgbe: Fix issues with SR-IOV loopback when flow control is disabled
net/hyperv: Fix the code handling tx busy
ixgbe: fix namespace issues when FCoE/DCB is not enabled
rtlwifi: Remove unused ETH_ADDR_LEN defines
igbvf: Use ETH_ALEN
Fix up fairly trivial conflicts in drivers/isdn/gigaset/interface.c and
drivers/net/usb/{Kconfig,qmi_wwan.c} as per David.
Making an hfsplus partition bootable requires the ability to "bless" a
file by putting its inode number in the volume header. Doing this from
userspace on a mounted filesystem is impractical since the kernel will
write back the original values on unmount. Add an ioctl to allow userspace
to update the volume header information based on the target file.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
This moves the definitions of the ioctls, constants and structures
relating to the ppp_generic interface to userspace out from if_ppp.h
to a new file, ppp-ioctl.h. The new file has my copyright since I
designed and implemented the ppp_generic interface in the late 1990s.
None of the contents of this file comes from the original if_ppp.h
published by Carnegie Mellon University.
Of the remainder of if_ppp.h, only the PPP_MTU definition was being
used, and this replaces the uses of it with PPP_MRU (which is identical).
Therefore, this replaces the entire file with the single line
#include <linux/ppp-ioctl.h>
which clearly doesn't contain any CMU code. Thus I have removed the
CMU copyright notice with its problematic advertising clause, and in
fact since it's only one trivial line I have not added any other
copyright notice.
My old email address was used in a lot of documentation files, so fix
this up to point to the correct one now.
Added ioctl range for HSI char devices to the documentation
Signed-off-by: Andras Domokos <andras.domokos@nokia.com>
Signed-off-by: Carlos Chinea <carlos.chinea@nokia.com>
This driver is for devices that follow the NVM Express standard
Signed-off-by: Matthew Wilcox <matthew.r.wilcox@intel.com>
The LTTng 2.0 kernel tracer (stand-alone module package, available at
http://lttng.org) uses the 0xF6 ioctl range for tracer control and
transport operations.
Signed-off-by: Mathieu Desnoyers <mathieu.desnoyers@efficios.com>
* git://git.kernel.org/pub/scm/linux/kernel/git/cmetcalf/linux-tile:
arch/tile/mm/init.c: trivial: use BUG_ON
arch/tile: remove useless set_fixmap_nocache() macro
arch/tile: add hypervisor-based character driver for SPI flash ROM
ioctl-number.txt: add the tile hardwall ioctl range
tile: use generic-y format for one-line asm-generic headers
clocksource: tile: convert to use clocksource_register_hz
Add the drivers/virt directory, which houses drivers that support
virtualization environments, and add the Freescale hypervisor management
driver.
The Freescale hypervisor management driver provides several services to
drivers and applications related to the Freescale hypervisor:
1. An ioctl interface for querying and managing partitions
2. A file interface to reading incoming doorbells
3. An interrupt handler for shutting down the partition upon receiving the
shutdown doorbell from a manager partition
4. A kernel interface for receiving callbacks when a managed partition
shuts down.
Signed-off-by: Chris Metcalf <cmetcalf@tilera.com>
git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/cjb/mmc: (75 commits)
mmc: core: eMMC bus width may not work on all platforms
mmc: sdhci: Auto-CMD23 fixes.
mmc: sdhci: Auto-CMD23 support.
mmc: core: Block CMD23 support for UHS104/SDXC cards.
mmc: sdhci: Implement MMC_CAP_CMD23 for SDHCI.
mmc: core: Use CMD23 for multiblock transfers when we can.
mmc: quirks: Add/remove quirks conditional support.
mmc: Add new VUB300 USB-to-SD/SDIO/MMC driver
mmc: sdhci-pxa: Add quirks for DMA/ADMA to match h/w
mmc: core: duplicated trial with same freq in mmc_rescan_try_freq()
mmc: core: add support for eMMC Dual Data Rate
mmc: core: eMMC signal voltage does not use CMD11
mmc: sdhci-pxa: add platform code for UHS signaling
mmc: sdhci: add hooks for setting UHS in platform specific code
mmc: core: clear MMC_PM_KEEP_POWER flag on resume
mmc: dw_mmc: fixed wrong regulator_enable in suspend/resume
mmc: sdhi: allow powering down controller with no card inserted
mmc: tmio: runtime suspend the controller, where possible
mmc: sdhi: support up to 3 interrupt sources
mmc: sdhi: print physical base address and clock rate
Allows appropriately-privileged applications to send CMD (normal) and ACMD
(application-specific; preceded with CMD55) commands to cards/devices on
the mmc bus. This is primarily useful for enabling the security
functionality built in to every SD card.
It can also be used as a generic passthrough (e.g. to enable virtual
machines to control mmc bus devices directly). However, this use case has
not been tested rigorously. Generic passthrough testing was only conducted
for a few non-security opcodes to prove the feasibility of the passthrough.
Since any opcode can be sent using this passthrough, it is very possible to
render the card/device unusable. Applications that use this ioctl must
have CAP_SYS_RAWIO.
Security commands tested on TI PCIxx12 (SDHCI), Sigma Designs SMP8652 SoC,
TI OMAP3621/OMAP3630 SoC, Samsung S5PC110 SoC, Qualcomm MSM7200A SoC.
Signed-off-by: John Calixto <john.calixto@modsystems.com>
Reviewed-by: Andrei Warkentin <andreiw@motorola.com>
Reviewed-by: Arnd Bergmann <arnd@arndb.de>
Signed-off-by: Chris Ball <cjb@laptop.org>
Move the public API definitions to include/linux/uvcvideo.h and bump the
version number to 1.1.0. Compatibility with the old API is kept,
application can still be compiled against the private header and will
not break.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'v4l_for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (442 commits)
[media] videobuf2-dma-contig: make cookie() return a pointer to dma_addr_t
[media] sh_mobile_ceu_camera: Do not call vb2's mem_ops directly
[media] V4L: soc-camera: explicitly require V4L2_BUF_TYPE_VIDEO_CAPTURE
[media] v4l: soc-camera: Store negotiated buffer settings
[media] rc: interim support for 32-bit NEC-ish scancodes
[media] mceusb: topseed 0x0011 needs gen3 init for tx to work
[media] lirc_zilog: error out if buffer read bytes != chunk size
[media] lirc: silence some compile warnings
[media] hdpvr: use same polling interval as other OS
[media] ir-kbd-i2c: pass device code w/key in hauppauge case
[media] rc/keymaps: Remove the obsolete rc-rc5-tv keymap
[media] remove the old RC_MAP_HAUPPAUGE_NEW RC map
[media] rc/keymaps: Rename Hauppauge table as rc-hauppauge
[media] rc-rc5-hauppauge-new: Fix Hauppauge Grey mapping
[media] rc-rc5-hauppauge-new: Add support for the old Black RC
[media] rc-rc5-hauppauge-new: Add the old control to the table
[media] rc-winfast: Fix the keycode tables
[media] a800: Fix a few wrong IR key assignments
[media] opera1: Use multimedia keys instead of an app-specific mapping
[media] dw2102: Use multimedia keys instead of an app-specific mapping
Fix up trivial conflicts (remove/modify and some real conflicts) in:
arch/arm/mach-omap2/devices.c
drivers/staging/Kconfig
drivers/staging/Makefile
drivers/staging/dabusb/dabusb.c
drivers/staging/dabusb/dabusb.h
drivers/staging/easycap/easycap_ioctl.c
drivers/staging/usbvideo/usbvideo.c
drivers/staging/usbvideo/vicam.c
Pick an unused range of ioctls in Documentation/ioctl/ioctl-number.txt
and use it for the MEDIA_IOC_* ioctls.
It was desired that the header roccat.h should be named hid-roccat.h
Signed-off-by: Stefan Achatz <erazor_de@users.sourceforge.net>
Roccat chardev was reworked to support only a defined report size per
device and this can be retreived by an ioctl now to enable future changes
in report definitions.
Header was moved/renamed from drivers/hid to include/linux for accessibility.
Add an optional feature of PPSAPI, kernel consumer support, which uses the
added hardpps() function.
Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su>
Acked-by: Rodolfo Giometti <giometti@linux.it>
Remove bt819.h from ioctl-number.txt and make a note in the header
that these ioctls are for internal use only.
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
The naming of the media/rds.h header suggested that it was a generic
RDS header, when in fact it is just a saa6588 module API that is
internal to the kernel.
Rename the header and the struct and defines in it to make this clear.
Also removed the header include in radio-si470x.h (not used anymore)
and from ioctl-number.txt (it's internal to the kernel and never called
from userspace).
The V4L1 removal patches removed a few ioctls. Update it at the docspace.
* git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/staging-2.6: (841 commits)
Staging: brcm80211: fix usage of roundup in structures
Staging: bcm: fix up network device reference counting
Staging: keucr: fix up US_ macro change
staging: brcm80211: brcmfmac: Removed codeversion from firmware filenames.
staging: brcm80211: Remove unnecessary header files.
staging: brcm80211: Remove unnecessary includes from bcmutils.c
staging: brcm80211: Removed unnecessary pktsetprio() function.
Staging: brcm80211: remove typedefs.h
Staging: brcm80211: remove uintptr typedef usage
Staging: hv: remove struct vmbus_channel_interface
Staging: hv: remove Open from struct vmbus_channel_interface
Staging: hv: storvsc: call vmbus_open directly
Staging: hv: netvsc: call vmbus_open directly
Staging: hv: channel: export vmbus_open to modules
Staging: hv: remove Close from struct vmbus_channel_interface
Staging: hv: netvsc: call vmbus_close directly
Staging: hv: storvsc: call vmbus_close directly
Staging: hv: channel: export vmbus_close to modules
Staging: hv: remove SendPacket from struct vmbus_channel_interface
Staging: hv: storvsc: call vmbus_sendpacket directly
Fix up conflicts in
drivers/staging/cx25821/cx25821-audio-upstream.c
drivers/staging/cx25821/cx25821-audio.h
due to warring whitespace cleanups (neither of which were all that great)
Remove all references to /dev/vtx in the documentation, except for
some historical comments in dev-teletext.xml.
Documentation/devices.txt is not updated, this will go through Alan Cox
who maintains this file.
smbfs has been scheduled for removal in 2.6.27, so
maybe we can now move it to drivers/staging on the
way out.
smbfs still uses the big kernel lock and nobody
is going to fix that, so we should be getting
rid of it soon.
This removes the 32 bit compat mount and ioctl
handling code, which is implemented in common fs
code, and moves all smbfs related files into
drivers/staging/smbfs.
Acked-by: Jeff Layton <jlayton@redhat.com>
git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/ieee1394/linux1394-2.6: (82 commits)
firewire: core: add forgotten dummy driver methods, remove unused ones
firewire: add isochronous multichannel reception
firewire: core: small clarifications in core-cdev
firewire: core: remove unused code
firewire: ohci: release channel in error path
firewire: ohci: use memory barriers to order descriptor updates
tools/firewire: nosy-dump: increment program version
tools/firewire: nosy-dump: remove unused code
tools/firewire: nosy-dump: use linux/firewire-constants.h
tools/firewire: nosy-dump: break up a deeply nested function
tools/firewire: nosy-dump: make some symbols static or const
tools/firewire: nosy-dump: change to kernel coding style
tools/firewire: nosy-dump: work around segfault in decode_fcp
tools/firewire: nosy-dump: fix it on x86-64
tools/firewire: add userspace front-end of nosy
firewire: nosy: note ioctls in ioctl-number.txt
firewire: nosy: use generic printk macros
firewire: nosy: endianess fixes and annotations
firewire: nosy: annotate __user pointers and __iomem pointers
firewire: nosy: fix device shutdown with active client
Below you will find an updated version from the original series bunching all patches into one big patch
updating broken web addresses that are located in Documentation/*
Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult,
the best way to deal with these is to use web.archive.org to locate these addresses that are outdated.
Now there are also some addresses pointing to .spec files some are located, but some(after searching
on the companies site)where still no where to be found. In this case I just changed the address
to the company site this way the users can contact the company and they can locate them for the users.
Signed-off-by: Thomas Weber <weber@corscience.de>
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
Cc: Paulo Marques <pmarques@grupopie.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Michael Neuling <mikey@neuling.org>
These are the ioctls for the special-purpose misc device /dev/nosy, the
interface to the IEEE 1394 packet sniffer/ protocol analyzer driver.
Currently only the numbers 00...02 are in use; let's block a few more
for unforeseen use cases.
Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de>
git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/sage/ceph-client: (205 commits)
ceph: update for write_inode API change
ceph: reset osd after relevant messages timed out
ceph: fix flush_dirty_caps race with caps migration
ceph: include migrating caps in issued set
ceph: fix osdmap decoding when pools include (removed) snaps
ceph: return EBADF if waiting for caps on closed file
ceph: set osd request message front length correctly
ceph: reset front len on return to msgpool; BUG on mismatched front iov
ceph: fix snaptrace decoding on cap migration between mds
ceph: use single osd op reply msg
ceph: reset bits on connection close
ceph: remove bogus mds forward warning
ceph: remove fragile __map_osds optimization
ceph: fix connection fault STANDBY check
ceph: invalidate_authorizer without con->mutex held
ceph: don't clobber write return value when using O_SYNC
ceph: fix client_request_forward decoding
ceph: drop messages on unregistered mds sessions; cleanup
ceph: fix comments, locking in destroy_inode
ceph: move dereference after NULL test
Fix trivial conflicts in Documentation/ioctl/ioctl-number.txt
devices and spectrometers
This patch removes the vstusb driver and support from the Linux tree.
This driver provided support for Vernier Software & Technology devices
and spectrometers (Ocean Optics). This driver is being replaced by a
user space - libusb - implementation.
Signed-off-by: Jim Collar <jim.collar@eqware.net>
Add many ioctl definitions to ioctl-number.txt.
Fix some whitespace/formatting.
Correct some filenames/paths.
A few Ceph ioctls for getting and setting file layout (striping)
parameters, and learning the identity and network address of the OSD a
given region of a file is stored on.
Signed-off-by: Sage Weil <sage@newdream.net>
This driver memory maps the UV Hub RTC.
Signed-off-by: Dimitri Sivanich <sivanich@sgi.com>
* 'kvm-updates/2.6.32' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (202 commits)
MAINTAINERS: update KVM entry
KVM: correct error-handling code
KVM: fix compile warnings on s390
KVM: VMX: Check cpl before emulating debug register access
KVM: fix misreporting of coalesced interrupts by kvm tracer
KVM: x86: drop duplicate kvm_flush_remote_tlb calls
KVM: VMX: call vmx_load_host_state() only if msr is cached
KVM: VMX: Conditionally reload debug register 6
KVM: Use thread debug register storage instead of kvm specific data
KVM guest: do not batch pte updates from interrupt context
KVM: Fix coalesced interrupt reporting in IOAPIC
KVM guest: fix bogus wallclock physical address calculation
KVM: VMX: Fix cr8 exiting control clobbering by EPT
KVM: Optimize kvm_mmu_unprotect_page_virt() for tdp
KVM: Document KVM_CAP_IRQCHIP
KVM: Protect update_cr8_intercept() when running without an apic
KVM: VMX: Fix EPT with WP bit change during paging
KVM: Use kvm_{read,write}_guest_virt() to read and write segment descriptors
KVM: x86 emulator: Add adc and sbb missing decoder flags
KVM: Add missing #include
The KVM list moved to vger.kernel.org last year
Signed-off-by: Amit Shah <amit.shah@redhat.com>
Signed-off-by: Avi Kivity <avi@redhat.com>
Make it possible to access the all-register-setting/getting MSR
functions via the MSR driver. This is implemented as an ioctl() on
the standard MSR device node.
Signed-off-by: H. Peter Anvin <hpa@zytor.com>
Cc: Borislav Petkov <petkovbb@gmail.com>
This will register the ioctl range used by nilfs2 file system to the
table listed in Documentation/ioctl/ioctl-number.txt.
Signed-off-by: Ryusuke Konishi <konishi.ryusuke@lab.ntt.co.jp>
This patch adds the kernel side of the PPS support currently named
"LinuxPPS".
PPS means "pulse per second" and a PPS source is just a device which
provides a high precision signal each second so that an application can
use it to adjust system clock time.
Common use is the combination of the NTPD as userland program with a GPS
receiver as PPS source to obtain a wallclock-time with sub-millisecond
synchronisation to UTC.
To obtain this goal the userland programs shoud use the PPS API
specification (RFC 2783 - Pulse-Per-Second API for UNIX-like Operating
Systems, Version 1.0) which in part is implemented by this patch. It
provides a set of chars devices, one per PPS source, which can be used to
get the time signal. The RFC's functions can be implemented by accessing
to these char devices.
Signed-off-by: Rodolfo Giometti <giometti@linux.it>
Cc: Greg KH <greg@kroah.com>
Cc: Randy Dunlap <randy.dunlap@oracle.com>
Cc: Kay Sievers <kay.sievers@vrfy.org>
Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk>
Cc: Michael Kerrisk <mtk.manpages@googlemail.com>
Cc: Roman Zippel <zippel@linux-m68k.org>
changeset 04934e44e3784a1b969582e2d59afcec278470c6 removed the last implementation
that were still using the V4L1 obsoleted header.
Now, video_decoder.h is not used anymore by any driver.
Let's remove it and all references for it in Kernel.
include/linux/video_encoder.h is not used anymore by a v4l driver.
Let's remove it and its occurences.
Update several Documentation/ files and a few sub-dir files (only one
change in each) to reflect changed header files locations.
