path: root/Documentation/iostats.txt
2011-03-23Documentation/iostats.txt: bit-size reference etc.Randy Dunlap
- correction that disk stats values are native-word-sized 32-bit or 64-bit values, not always 32-bi values - drop "Last modified" entry; use git for that - fix a few typos - change "cpu" to "CPU" Reported-by: Linda Walsh <lkml@tlinx.org> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2011-01-03remove extraneous 'is' from Documentation/iostats.txtJim Cromie
fix "is increases", drop "is" Signed-off-by: Jim Cromie <jim.cromie@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-07-26Documentation cleanup: trivial misspelling, punctuation, and grammar ↵Matt LaPlante
corrections. Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-08Enhanced partition statistics: documentation updateJerome Marchand
Update the documentation to reflect the change in userspace interface. Signed-off-by: Jerome Marchand <jmarchan@redhat.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2007-07-24[BLOCK] Get rid of request_queue_t typedefJens Axboe
Some of the code has been gradually transitioned to using the proper struct request_queue, but there's lots left. So do a full sweet of the kernel and get rid of this typedef and replace its uses with the proper type. Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
