path: root/Documentation/ja_JP/SubmitChecklist
2011-06-23sched: Generalize sleep inside spinlock detectionFrederic Weisbecker
The sleeping inside spinlock detection is actually used for more general sleeping inside atomic sections debugging: preemption disabled, rcu read side critical sections, interrupts, interrupt disabled, etc... Change the name of the config and its help section to reflect its more general role. Signed-off-by: Frederic Weisbecker <fweisbec@gmail.com> Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Ingo Molnar <mingo@elte.hu>
2009-06-19block: rename CONFIG_LBD to CONFIG_LBDAFBartlomiej Zolnierkiewicz
Follow-up to "block: enable by default support for large devices and files on 32-bit archs". Rename CONFIG_LBD to CONFIG_LBDAF to: - allow update of existing [def]configs for "default y" change - reflect that it is used also for large files support nowadays Signed-off-by: Bartlomiej Zolnierkiewicz <bzolnier@gmail.com> Signed-off-by: Jens Axboe <jens.axboe@oracle.com>
2008-08-21Japanese translation of Documentation/SubmitChecklistTakenori Nagano
Hi, This patch adds SubmitChecklist translated into Japanese to Documentation/ja_JP directory. The translated SubmitChecklist has already been reviewed by JF project. SubmitChecklist is one of the important policy documents. So, I would like to merge into 2.6.27. Signed-off-by: Takenori Nagano <t-nagano@ah.jp.nec.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
