path: root/Documentation/kdump
2007-02-20[PATCH] PPC64 Kdump documentation updateSimon Horman
Patch from Mohan Kumar M to add the ppc64 portions of the kdump documentation. http://thread.gmane.org/gmane.linux.kernel/481689/focus=3375 Cc: Mohan Kumar M <mohan@in.ibm.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Simon Horman <horms@verge.net.au> Cc: Paul Mackerras <paulus@samba.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-12[PATCH] kexec: fix references to init in documentation for kexecHorms
I've noticed that the boot options are not correct for in the documentation for kdump. The "init" keyword is not necessary, and causes a kernel panic when booting with an initrd on Fedora 5. [horms@verge.net.au: put original comment with the latest version of the patch] Signed-off-by: Judith Lebzeelter <judith@osdl.org> Acked-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Simon Horman <horms@verge.net.au> Cc: "Eric W. Biederman" <ebiederm@xmission.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-23[PATCH] Kdump documentation update: ia64 portionHorms
this patch fills in the portions for ia64 kexec. Signed-off-by: Simon Horman <horms@verge.net.au> Cc: "Zou, Nanhai" <nanhai.zou@intel.com> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-23[PATCH] Kdump documentation update: kexec-tools updateHorms
Mohan Kumar suggested making kexec-tools-testing.tar.gz a link to the latest version. I have done this and this patch updates the documentation accordingly. Signed-off-by: Simon Horman <horms@verge.net.au> Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-11[PATCH] Kdump documentation updateVivek Goyal
o Kdump documentation update. - Update details for using relocatable kernel. - Start using kexec-tools-testing release as it is latest and old kexec-tools can't load relocatable bzImage file. - Also add kdump on ia64 specific details. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Cc: Horms <horms@verge.net.au> Cc: Mohan Kumar M <mohan@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Documentation: remove duplicated wordsPaolo Ornati
Remove many duplicated words under Documentation/ and do other small cleanups. Examples: "and and" --> "and" "in in" --> "in" "the the" --> "the" "the the" --> "to the" ... Signed-off-by: Paolo Ornati <ornati@fastwebnet.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-26fix paniced->panicked typosLee Revell
In a testament to the utter simplicity and logic of the English language ;-), I found a single correct use - in kernel/panic.c - and 10-15 incorrect ones. Signed-Off-By: Lee Revell <rlrevell@joe-job.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-06-25[PATCH] Updated kdump documentationDavid Wilder
Cc: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-11[PATCH] kdump: add dmesg gdbmacro into documentAkinobu Mita
Add gdb macro which print the kernel ring buffer into kdump docs Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-01-10[PATCH] Kdump documentation updateManeesh Soni
Update the kdump documentation to reflect the changes due to recent kernel config option changes for kexec and kdump. Signed-off-by: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] More documentation, minor cleanup in kdump.txtVivek Goyal
Added clarification on the root device format to be used for second kernel, as well as specifying initrd if drivers are built as modules. Signed-off-by: Kishore Sampathkumar <kishore.sampathkumar@hp.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-09[PATCH] Kdump: Documentation UpdateVivek Goyal
There are minor changes in command line options in kexec-tools for kdump. This patch updates the documentation to reflect those changes. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kdump documentation update to introduce use of irqpollVivek Goyal
o Specify "irqpoll" command line option which loading second kernel. This helps in reducing driver initialization failures in second kernel due to shared interrupts. o Enabled LAPIC/IOAPIC support for UP kernels in second kernel. This reduces the chances of devices sharing the irq and hence reduces the chances of driver initialization failures in second kernel. o Build a UP capture kernel and disabled SMP support. Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] kdump: Documentation for KdumpVivek Goyal
This patch contains the documentation for the kexec based crash dump tool. Quick kdump-howto ================================================================ 1) Download and build kexec-tools. 2) Download and build the latest kexec/kdump (-mm) kernel patchset. Two kernels need to be built in order to get this feature working. A) First kernel: a) Enable "kexec system call" feature: CONFIG_KEXEC=y b) Physical load address (use default): CONFIG_PHYSICAL_START=0x100000 c) Enable "sysfs file system support": CONFIG_SYSFS=y d) Boot into first kernel with the command line parameter "crashkernel=Y@X": For example: "crashkernel=64M@16M". B) Second kernel: a) Enable "kernel crash dumps" feature: CONFIG_CRASH_DUMP=y b) Physical load addreess, use same load address as X in "crashkernel" kernel parameter in d) above, e.g., 16 MB or 0x1000000. CONFIG_PHYSICAL_START=0x1000000 c) Enable "/proc/vmcore support" (Optional, in Pseudo filesystems). CONFIG_PROC_VMCORE=y 3) Boot into the first kernel. 4) Load the second kernel to be booted using: kexec -p <second-kernel> --crash-dump --args-linux --append="root=<root-dev> maxcpus=1 init 1" 5) System reboots into the second kernel when a panic occurs. A module can be written to force the panic, for testing purposes. 6) See Documentation/kdump.txt for how to read the first kernel's memory image and how to analyze it. Signed-off-by: Hariprasad Nellitheertha <hari@in.ibm.com> Signed-off-by: Eric Biederman <ebiederm@xmission.com> Signed-off-by: Vivek Goyal <vgoyal@in.ibm.com> Signed-off-by: randy_dunlap <rdunlap@xenotime.net> Signed-off-by: Maneesh Soni <maneesh@in.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
