path: root/Documentation/kernel-hacking
2017-07-03Merge tag 'docs-4.13' of git://git.lwn.net/linuxLinus Torvalds
Pull documentation updates from Jonathan Corbet: "There has been a fair amount of activity in the docs tree this time around. Highlights include: - Conversion of a bunch of security documentation into RST - The conversion of the remaining DocBook templates by The Amazing Mauro Machine. We can now drop the entire DocBook build chain. - The usual collection of fixes and minor updates" * tag 'docs-4.13' of git://git.lwn.net/linux: (90 commits) scripts/kernel-doc: handle DECLARE_HASHTABLE Documentation: atomic_ops.txt is core-api/atomic_ops.rst Docs: clean up some DocBook loose ends Make the main documentation title less Geocities Docs: Use kernel-figure in vidioc-g-selection.rst Docs: fix table problems in ras.rst Docs: Fix breakage with Sphinx 1.5 and upper Docs: Include the Latex "ifthen" package doc/kokr/howto: Only send regression fixes after -rc1 docs-rst: fix broken links to dynamic-debug-howto in kernel-parameters doc: Document suitability of IBM Verse for kernel development Doc: fix a markup error in coding-style.rst docs: driver-api: i2c: remove some outdated information Documentation: DMA API: fix a typo in a function name Docs: Insert missing space to separate link from text doc/ko_KR/memory-barriers: Update control-dependencies example Documentation, kbuild: fix typo "minimun" -> "minimum" docs: Fix some formatting issues in request-key.rst doc: ReSTify keys-trusted-encrypted.txt doc: ReSTify keys-request-key.txt ...
2017-05-16locking.rst: Update some ReST markupsMauro Carvalho Chehab
Correct a few minor issues with ReST notation used on this file (produced by an automatic tool). Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-05-16locking.rst: add captions to two tablesMauro Carvalho Chehab
Those tables have a "caption" at the end, but ReST actually expects it on a different way. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-05-16locking.rst: reformat locking tableMauro Carvalho Chehab
Use a different markup for this table, in order to make it smaller when seeing in text mode. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-05-16docs-rst: convert kernel-locking to ReSTMauro Carvalho Chehab
Use pandoc to convert documentation to ReST by calling Documentation/sphinx/tmplcvt script. - Manually adjust tables with got broken by conversion Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-05-16kernel-hacking: update documentMauro Carvalho Chehab
This document is fairly updated. Yet, some stuff moved to other kernel headers. So, update to point to the right places. While here, adjust some minor ReST markups. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
2017-05-16docs-rst: convert kernel-hacking to ReSTMauro Carvalho Chehab
Use pandoc to convert documentation to ReST by calling Documentation/sphinx/tmplcvt script. - Manually adjusted to use ..note and ..warning - Minor fixes for it to be parsed without errors - Use **bold** for emphasis. Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
