path: root/Documentation/kernel-parameters.txt
2017-01-26swiotlb: Add swiotlb=noforce debug optionGeert Uytterhoeven
commit fff5d99225107f5f13fe4a9805adc2a1c4b5fb00 upstream. On architectures like arm64, swiotlb is tied intimately to the core architecture DMA support. In addition, ZONE_DMA cannot be disabled. To aid debugging and catch devices not supporting DMA to memory outside the 32-bit address space, add a kernel command line option "swiotlb=noforce", which disables the use of bounce buffers. If specified, trying to map memory that cannot be used with DMA will fail, and a rate-limited warning will be printed. Note that io_tlb_nslabs is set to 1, which is the minimal supported value. Signed-off-by: Geert Uytterhoeven <geert+renesas@glider.be> Signed-off-by: Konrad Rzeszutek Wilk <konrad.wilk@oracle.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-10-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input Pull some more input subsystem updates from Dmitry Torokhov: "An update to the ALPS driver to support the V8 protocol with touchstick, a change for i8042 to skip selftest on many Asus laptops which helps to keep their touchpads working after resume, and a couple other driver fixes" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/dtor/input: Input: i8042 - skip selftest on ASUS laptops Input: melfas_mip4 - add ic_name sysfs attribute Input: melfas_mip4 - add maintainer information Input: melfas_mip4 - add devicetree binding documentations Input: elantech - add Fujitsu Lifebook E556 to force crc_enabled Input: synaptics-rmi4 - fix error handling in I2C transport driver Input: synaptics-rmi4 - fix error handling in SPI transport driver Input: ALPS - add V8 protocol documentation Input: ALPS - set DualPoint flag for 74 03 28 devices Input: ALPS - allow touchsticks to report pressure Input: ALPS - handle 0-pressure 1F events Input: ALPS - add touchstick support for SS5 hardware Input: elantech - force needed quirks on Fujitsu H760 Input: elantech - fix Lenovo version typo
2016-10-13Merge tag 'nfs-for-4.9-1' of git://git.linux-nfs.org/projects/anna/linux-nfsLinus Torvalds
Pull NFS client updates from Anna Schumaker: "Highlights include: Stable bugfixes: - sunrpc: fix writ espace race causing stalls - NFS: Fix inode corruption in nfs_prime_dcache() - NFSv4: Don't report revoked delegations as valid in nfs_have_delegation() - NFSv4: nfs4_copy_delegation_stateid() must fail if the delegation is invalid - NFSv4: Open state recovery must account for file permission changes - NFSv4.2: Fix a reference leak in nfs42_proc_layoutstats_generic Features: - Add support for tracking multiple layout types with an ordered list - Add support for using multiple backchannel threads on the client - Add support for pNFS file layout session trunking - Delay xprtrdma use of DMA API (for device driver removal) - Add support for xprtrdma remote invalidation - Add support for larger xprtrdma inline thresholds - Use a scatter/gather list for sending xprtrdma RPC calls - Add support for the CB_NOTIFY_LOCK callback - Improve hashing sunrpc auth_creds by using both uid and gid Bugfixes: - Fix xprtrdma use of DMA API - Validate filenames before adding to the dcache - Fix corruption of xdr->nwords in xdr_copy_to_scratch - Fix setting buffer length in xdr_set_next_buffer() - Don't deadlock the state manager on the SEQUENCE status flags - Various delegation and stateid related fixes - Retry operations if an interrupted slot receives EREMOTEIO - Make nfs boot time y2038 safe" * tag 'nfs-for-4.9-1' of git://git.linux-nfs.org/projects/anna/linux-nfs: (100 commits) NFSv4.2: Fix a reference leak in nfs42_proc_layoutstats_generic fs: nfs: Make nfs boot time y2038 safe sunrpc: replace generic auth_cred hash with auth-specific function sunrpc: add RPCSEC_GSS hash_cred() function sunrpc: add auth_unix hash_cred() function sunrpc: add generic_auth hash_cred() function sunrpc: add hash_cred() function to rpc_authops struct Retry operation on EREMOTEIO on an interrupted slot pNFS: Fix atime updates on pNFS clients sunrpc: queue work on system_power_efficient_wq NFSv4.1: Even if the stateid is OK, we may need to recover the open modes NFSv4: If recovery failed for a specific open stateid, then don't retry NFSv4: Fix retry issues with nfs41_test/free_stateid NFSv4: Open state recovery must account for file permission changes NFSv4: Mark the lock and open stateids as invalid after freeing them NFSv4: Don't test open_stateid unless it is set NFSv4: nfs4_do_handle_exception() handle revoke/expiry of a single stateid NFS: Always call nfs_inode_find_state_and_recover() when revoking a delegation NFSv4: Fix a race when updating an open_stateid NFSv4: Fix a race in nfs_inode_reclaim_delegation() ...
2016-10-11Input: i8042 - skip selftest on ASUS laptopsMarcos Paulo de Souza
On suspend/resume cycle, selftest is executed to reset i8042 controller. But when this is done in Asus devices, subsequent calls to detect/init functions to elantech driver fails. Skipping selftest fixes this problem. An easier step to reproduce this problem is adding i8042.reset=1 as a kernel parameter. On Asus laptops, it'll make the system to start with the touchpad already stuck, since psmouse_probe forcibly calls the selftest function. This patch was inspired by John Hiesey's change[1], but, since this problem affects a lot of models of Asus, let's avoid running selftests on them. All models affected by this problem: A455LD K401LB K501LB K501LX R409L V502LX X302LA X450LCP X450LD X455LAB X455LDB X455LF Z450LA [1]: https://marc.info/?l=linux-input&m=144312209020616&w=2 Fixes: "ETPS/2 Elantech Touchpad dies after resume from suspend" (https://bugzilla.kernel.org/show_bug.cgi?id=107971) Signed-off-by: Marcos Paulo de Souza <marcos.souza.org@gmail.com> Cc: stable@vger.kernel.org Signed-off-by: Dmitry Torokhov <dmitry.torokhov@gmail.com>
2016-10-11lib/bitmap.c: enhance bitmap syntaxNoam Camus
Today there are platforms with many CPUs (up to 4K). Trying to boot only part of the CPUs may result in too long string. For example lets take NPS platform that is part of arch/arc. This platform have SMP system with 256 cores each with 16 HW threads (SMT machine) where HW thread appears as CPU to the kernel. In this example there is total of 4K CPUs. When one tries to boot only part of the HW threads from each core the string representing the map may be long... For example if for sake of performance we decided to boot only first half of HW threads of each core the map will look like: 0-7,16-23,32-39,...,4080-4087 This patch introduce new syntax to accommodate with such use case. I added an optional postfix to a range of CPUs which will choose according to given modulo the desired range of reminders i.e.: <cpus range>:sed_size/group_size For example, above map can be described in new syntax like this: 0-4095:8/16 Note that this patch is backward compatible with current syntax. [akpm@linux-foundation.org: rework documentation] Link: http://lkml.kernel.org/r/1473579629-4283-1-git-send-email-noamca@mellanox.com Signed-off-by: Noam Camus <noamca@mellanox.com> Cc: David Decotigny <decot@googlers.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: David S. Miller <davem@davemloft.net> Cc: Pan Xinhui <xinhui@linux.vnet.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-10-10Merge branch 'mm-pkeys-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull protection keys syscall interface from Thomas Gleixner: "This is the final step of Protection Keys support which adds the syscalls so user space can actually allocate keys and protect memory areas with them. Details and usage examples can be found in the documentation. The mm side of this has been acked by Mel" * 'mm-pkeys-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: x86/pkeys: Update documentation x86/mm/pkeys: Do not skip PKRU register if debug registers are not used x86/pkeys: Fix pkeys build breakage for some non-x86 arches x86/pkeys: Add self-tests x86/pkeys: Allow configuration of init_pkru x86/pkeys: Default to a restrictive init PKRU pkeys: Add details of system call use to Documentation/ generic syscalls: Wire up memory protection keys syscalls x86: Wire up protection keys system calls x86/pkeys: Allocation/free syscalls x86/pkeys: Make mprotect_key() mask off additional vm_flags mm: Implement new pkey_mprotect() system call x86/pkeys: Add fault handling for PF_PK page fault bit
2016-10-06Merge tag 'kvm-4.9-1' of git://git.kernel.org/pub/scm/virt/kvm/kvmLinus Torvalds
Pull KVM updates from Radim Krčmář: "All architectures: - move `make kvmconfig` stubs from x86 - use 64 bits for debugfs stats ARM: - Important fixes for not using an in-kernel irqchip - handle SError exceptions and present them to guests if appropriate - proxying of GICV access at EL2 if guest mappings are unsafe - GICv3 on AArch32 on ARMv8 - preparations for GICv3 save/restore, including ABI docs - cleanups and a bit of optimizations MIPS: - A couple of fixes in preparation for supporting MIPS EVA host kernels - MIPS SMP host & TLB invalidation fixes PPC: - Fix the bug which caused guests to falsely report lockups - other minor fixes - a small optimization s390: - Lazy enablement of runtime instrumentation - up to 255 CPUs for nested guests - rework of machine check deliver - cleanups and fixes x86: - IOMMU part of AMD's AVIC for vmexit-less interrupt delivery - Hyper-V TSC page - per-vcpu tsc_offset in debugfs - accelerated INS/OUTS in nVMX - cleanups and fixes" * tag 'kvm-4.9-1' of git://git.kernel.org/pub/scm/virt/kvm/kvm: (140 commits) KVM: MIPS: Drop dubious EntryHi optimisation KVM: MIPS: Invalidate TLB by regenerating ASIDs KVM: MIPS: Split kernel/user ASID regeneration KVM: MIPS: Drop other CPU ASIDs on guest MMU changes KVM: arm/arm64: vgic: Don't flush/sync without a working vgic KVM: arm64: Require in-kernel irqchip for PMU support KVM: PPC: Book3s PR: Allow access to unprivileged MMCR2 register KVM: PPC: Book3S PR: Support 64kB page size on POWER8E and POWER8NVL KVM: PPC: Book3S: Remove duplicate setting of the B field in tlbie KVM: PPC: BookE: Fix a sanity check KVM: PPC: Book3S HV: Take out virtual core piggybacking code KVM: PPC: Book3S: Treat VTB as a per-subcore register, not per-thread ARM: gic-v3: Work around definition of gic_write_bpr1 KVM: nVMX: Fix the NMI IDT-vectoring handling KVM: VMX: Enable MSR-BASED TPR shadow even if APICv is inactive KVM: nVMX: Fix reload apic access page warning kvmconfig: add virtio-gpu to config fragment config: move x86 kvm_guest.config to a common location arm64: KVM: Remove duplicating init code for setting VMID ARM: KVM: Support vgic-v3 ...
2016-10-05Merge tag 'gpio-v4.9-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio Pull GPIO updates from Linus Walleij: "This is the bulk of GPIO changes for the v4.9 series: Subsystem improvements: - do away with the last users of the obsolete Kconfig options ARCH_REQUIRE_GPIOLIB and ARCH_WANT_OPTIONAL_GPIOLIB (the latter always sounded like an item on a wishlist to Santa Claus to me). We can now select GPIOLIB and be done with it, for all archs. After some struggle it even work on UM. Not that it has GPIO, but if it wants to, it can select the library. - continued efforts to make drivers properly either tristate or bool. - introduce a warning for drivers assigning default triggers to their irqchip lines when probed from device tree, so we find and fix these ambigous drivers. It is agreed that in the OF config path, the device tree defines trigger characteristics. - the same warning, mutatis mutandis, for ACPI-probed GPIO irqchips. - we introduce the ability to mark certain IRQ lines as "unusable" as they can be taken by BIOS/firmware, unrouted in silicon and generally nasty if you use them, and such things. This is put to good use in the STMPE driver and also in the Cherryview pin control driver. - a new "mockup" virtual GPIO device that can be used for testing. The plan is to add unit tests under tools/* for exercising this device and verify that the kernel code paths are working as they should. - make memory-mapped I/O-drivers depend on HAS_IOMEM. This was implicit all the time, but when people started building UM with allyesconfig or allmodconfig it exploded in their face. - move some stray bits of device tree and ACPI HW description callbacks down into their respective implementation silo. These were causing issues when compiling on !HAS_IOMEM as well, so now eventually UM compiles the GPIOLIB library if it wants to. New drivers: - new driver for the Aspeed GPIO front-end companion to the pin controller merged through the pin control tree. - new driver for the LP873x PMIC GPIO portions. - new driver for Technologic Systems' I2C FPGA GPIO such as TS4900, TS-7970, TS-7990 and TS-4100. - new driver for the Broadcom BCM63xx series including BCM6338 and BCM6345. - new driver for the Intel WhiskeyCove PMIC GPIO. - new driver for the Allwinner AXP209 PMIC GPIO portions. - new driver for Diamond Systems 48 line GPIO-MM, another of these port-mapped I/O expansion cards. - support the STMicroelectronics STMPE1600 variant in the STMPE driver. Driver improvements: - the STMPE driver now supports rising/falling edge detection properly for IRQs. - the PCA954x will now fetch and enable its VCC regulator properly. - major rework of the PCA953x driver with the goal of eventually switching it over to use regmap and thus modernize it even more. - switch the IOP driver to use the generic MMIO GPIO library. - move the ages old HTC EGPIO (extended GPIO) GPIO expander driver over to this subsystem from MFD, achieveing some separation of concerns" * tag 'gpio-v4.9-1' of git://git.kernel.org/pub/scm/linux/kernel/git/linusw/linux-gpio: (81 commits) gpio: add missing static inline gpio: OF: localize some gpiochip init functions gpio: acpi: separation of concerns gpio: OF: separation of concerns gpio: make memory-mapped drivers depend on HAS_IOMEM gpio: stmpe: use BIT() macro gpio: stmpe: forbid unused lines to be mapped as IRQs mfd/gpio: Move HTC GPIO driver to GPIO subsystem gpio: MAINTAINERS: Add an entry for GPIO mockup driver gpio/mockup: add virtual gpio device gpio: Added zynq specific check for special pins on bank zero gpio: axp209: Implement get_direction gpio: aspeed: remove redundant return value check gpio: loongson1: remove redundant return value check ARM: omap2: fix missing include gpio: tc3589x: fix up complaints on unsigned gpio: tc3589x: add .get_direction() and small cleanup gpio: f7188x: use gpiochip_get_data instead of container_of gpio: tps65218: use devm_gpiochip_add_data() for gpio registration gpio: aspeed: fix return value check in aspeed_gpio_probe() ...
2016-10-04Merge tag 'docs-4.9' of git://git.lwn.net/linuxLinus Torvalds
Pull documentation updates from Jonathan Corbet: "This is the documentation update pull for the 4.9 merge window. The Sphinx transition is still creating a fair amount of work. Here we have a number of fixes and, importantly, a proper PDF output solution, thanks to Jani Nikula, Mauro Carvalho Chehab and Markus Heiser. I've started a couple of new books: a driver API book (based on the old device-drivers.tmpl) and a development tools book. Both are meant to show how we can integrate together our existing documentation into a more coherent and accessible whole. It involves moving some stuff around and formatting changes, but, I think, the results are worth it. The good news is that most of our existing Documentation/*.txt files are *almost* in RST format already; the amount of messing around required is minimal. And, of course, there's the usual set of updates, typo fixes, and more" * tag 'docs-4.9' of git://git.lwn.net/linux: (120 commits) URL changed for Linux Foundation TAB dax : Fix documentation with respect to struct pages iio: Documentation: Correct the path used to create triggers. docs: Remove space-before-label guidance from CodingStyle docs-rst: add inter-document cross references Documentation/email-clients.txt: convert it to ReST markup Documentation/kernel-docs.txt: reorder based on timestamp Documentation/kernel-docs.txt: Add dates for online docs Documentation/kernel-docs.txt: get rid of broken docs Documentation/kernel-docs.txt: move in-kernel docs Documentation/kernel-docs.txt: remove more legacy references Documentation/kernel-docs.txt: add two published books Documentation/kernel-docs.txt: sort books per publication date Documentation/kernel-docs.txt: adjust LDD references Documentation/kernel-docs.txt: some improvements on the ReST output Documentation/kernel-docs.txt: Consistent indenting: 4 spaces Documentation/kernel-docs.txt: Add 4 paper/book references Documentation/kernel-docs.txt: Improve layouting of book list Documentation/kernel-docs.txt: Remove offline or outdated entries docs: Clean up bare :: lines ...
2016-10-03Merge tag 'usb-4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb Pull usb/phy/extcon updates from Greg KH: "Here is the big USB, and PHY, and extcon, patchsets for 4.9-rc1. Full details are in the shortlog, but generally a lot of new hardware support, usb gadget updates, and Wolfram's great cleanup of USB error message handling, making the kernel image a tad bit smaller. All of this has been in linux-next with no reported issues" * tag 'usb-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (343 commits) Revert "usbtmc: convert to devm_kzalloc" USB: serial: cp210x: Add ID for a Juniper console usb: Kconfig: using select for USB_COMMON dependency bluetooth: bcm203x: don't print error when allocating urb fails mmc: host: vub300: don't print error when allocating urb fails usb: hub: change CLEAR_FEATURE to SET_FEATURE usb: core: Introduce a USB port LED trigger USB: bcma: drop Northstar PHY 2.0 initialization code usb: core: hcd: add missing header dependencies usb: musb: da8xx: fix error handling message in probe usb: musb: Fix session based PM for first invalid VBUS usb: musb: Fix PM runtime for disconnect after unconfigure musb: Export musb_root_disconnect for use in modules usb: misc: legousbtower: Fix NULL pointer deference cdc-acm: hardening against malicious devices Revert "usb: gadget: NCM: Protect dev->port_usb using dev->lock" include: extcon: Fix compilation error caused because of incomplete merge MAINTAINERS: add tree entry for USB Serial phy-twl4030-usb: initialize charging-related stuff via pm_runtime phy-twl4030-usb: better handle musb_mailbox() failure ...
2016-10-03Merge tag 'tty-4.9-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty and serial updates from Greg KH: "Here is the big tty and serial patch set for 4.9-rc1. It also includes some drivers/dma/ changes, as those were needed by some serial drivers, and they were all acked by the DMA maintainer. Also in here is the long-suffering ACPI SPCR patchset, which was passed around from maintainer to maintainer like a hot-potato. Seems I was the sucker^Wlucky one. All of those patches have been acked by the various subsystem maintainers as well. All of this has been in linux-next with no reported issues" * tag 'tty-4.9-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (111 commits) Revert "serial: pl011: add console matching function" MAINTAINERS: update entry for atmel_serial driver serial: pl011: add console matching function ARM64: ACPI: enable ACPI_SPCR_TABLE ACPI: parse SPCR and enable matching console of/serial: move earlycon early_param handling to serial Revert "drivers/tty: Explicitly pass current to show_stack" tty: amba-pl011: Don't complain on -EPROBE_DEFER when no irq nios2: dts: 10m50: Add tx-threshold parameter serial: 8250: Set Altera 16550 TX FIFO Threshold serial: 8250: of: Load TX FIFO Threshold from DT Documentation: dt: serial: Add TX FIFO threshold parameter drivers/tty: Explicitly pass current to show_stack serial: imx: Fix DCD reading serial: stm32: mark symbols static where possible serial: xuartps: Add some register initialisation to cdns_early_console_setup() serial: xuartps: Removed unwanted checks while reading the error conditions serial: xuartps: Rewrite the interrupt handling logic serial: stm32: use mapbase instead of membase for DMA tty/serial: atmel: fix fractional baud rate computation ...
2016-10-03Merge tag 'arm64-upstream' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux Pull arm64 updates from Will Deacon: "It's a bit all over the place this time with no "killer feature" to speak of. Support for mismatched cache line sizes should help people seeing whacky JIT failures on some SoCs, and the big.LITTLE perf updates have been a long time coming, but a lot of the changes here are cleanups. We stray outside arch/arm64 in a few areas: the arch/arm/ arch_timer workaround is acked by Russell, the DT/OF bits are acked by Rob, the arch_timer clocksource changes acked by Marc, CPU hotplug by tglx and jump_label by Peter (all CC'd). Summary: - Support for execute-only page permissions - Support for hibernate and DEBUG_PAGEALLOC - Support for heterogeneous systems with mismatches cache line sizes - Errata workarounds (A53 843419 update and QorIQ A-008585 timer bug) - arm64 PMU perf updates, including cpumasks for heterogeneous systems - Set UTS_MACHINE for building rpm packages - Yet another head.S tidy-up - Some cleanups and refactoring, particularly in the NUMA code - Lots of random, non-critical fixes across the board" * tag 'arm64-upstream' of git://git.kernel.org/pub/scm/linux/kernel/git/arm64/linux: (100 commits) arm64: tlbflush.h: add __tlbi() macro arm64: Kconfig: remove SMP dependence for NUMA arm64: Kconfig: select OF/ACPI_NUMA under NUMA config arm64: fix dump_backtrace/unwind_frame with NULL tsk arm/arm64: arch_timer: Use archdata to indicate vdso suitability arm64: arch_timer: Work around QorIQ Erratum A-008585 arm64: arch_timer: Add device tree binding for A-008585 erratum arm64: Correctly bounds check virt_addr_valid arm64: migrate exception table users off module.h and onto extable.h arm64: pmu: Hoist pmu platform device name arm64: pmu: Probe default hw/cache counters arm64: pmu: add fallback probe table MAINTAINERS: Update ARM PMU PROFILING AND DEBUGGING entry arm64: Improve kprobes test for atomic sequence arm64/kvm: use alternative auto-nop arm64: use alternative auto-nop arm64: alternative: add auto-nop infrastructure arm64: lse: convert lse alternatives NOP padding to use __nops arm64: barriers: introduce nops and __nops macros for NOP sequences arm64: sysreg: replace open-coded mrs_s/msr_s with {read,write}_sysreg_s ...
2016-09-27serial: xuartps: Add some register initialisation to cdns_early_console_setup()Scott Telford
Add initialisation of control register and baud rate to cdns_early_console_setup(), required when running kernel standalone without a boot loader. Baud rate is only initialised when specified in earlycon command-line option, otherwise it is assumed this has been set by a boot loader. Updated Documentation/kernel-parameters.txt accordingly. Signed-off-by: Scott Telford <stelford@cadence.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-26gpio/mockup: add virtual gpio deviceBamvor Jian Zhang
This patch add basic structure of a virtual gpio device(gpio-mockup) for testing gpio subsystem. The tester could manipulate such device through userspace(sysfs or char device) and check the result from debugfs. Currently, it support one or more gpiochip(determined by module parameters with base,ngpio pair). One could test the overlap of different gpiochip and test the direction and/or output values of these chips. Signed-off-by: Kamlakant Patel <kamlakant.patel@broadcom.com> Signed-off-by: Bamvor Jian Zhang <bamvor.zhangjian@linaro.org> Signed-off-by: Linus Walleij <linus.walleij@linaro.org>
2016-09-23arm64: arch_timer: Work around QorIQ Erratum A-008585Scott Wood
Erratum A-008585 says that the ARM generic timer counter "has the potential to contain an erroneous value for a small number of core clock cycles every time the timer value changes". Accesses to TVAL (both read and write) are also affected due to the implicit counter read. Accesses to CVAL are not affected. The workaround is to reread TVAL and count registers until successive reads return the same value. Writes to TVAL are replaced with an equivalent write to CVAL. The workaround is to reread TVAL and count registers until successive reads return the same value, and when writing TVAL to retry until counter reads before and after the write return the same value. The workaround is enabled if the fsl,erratum-a008585 property is found in the timer node in the device tree. This can be overridden with the clocksource.arm_arch_timer.fsl-a008585 boot parameter, which allows KVM users to enable the workaround until a mechanism is implemented to automatically communicate this information. This erratum can be found on LS1043A and LS2080A. Acked-by: Marc Zyngier <marc.zyngier@arm.com> Signed-off-by: Scott Wood <oss@buserror.net> [will: renamed read macro to reflect that it's not usually unstable] Signed-off-by: Will Deacon <will.deacon@arm.com>
2016-09-19NFSv4.x: Add kernel parameter to control the callback serverTrond Myklebust
Add support for the kernel parameter nfs.callback_nr_threads to set the number of threads that will be assigned to the callback channel. Add support for the kernel parameter nfs.nfs.max_session_cb_slots to set the maximum size of the callback channel slot table. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: Anna Schumaker <Anna.Schumaker@Netapp.com>
2016-09-13scsi: introduce a quirk for false cache reportingOliver Neukum
Some SATA to USB bridges fail to cooperate with some drives resulting in no cache being present being reported to the host. That causes the host to skip sending a command to synchronize caches. That causes data loss when the drive is powered down. Signed-off-by: Oliver Neukum <oneukum@suse.com> Reviewed-by: Martin K. Petersen <martin.petersen@oracle.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2016-09-09x86/pkeys: Default to a restrictive init PKRUDave Hansen
PKRU is the register that lets you disallow writes or all access to a given protection key. The XSAVE hardware defines an "init state" of 0 for PKRU: its most permissive state, allowing access/writes to everything. Since we start off all new processes with the init state, we start all processes off with the most permissive possible PKRU. This is unfortunate. If a thread is clone()'d [1] before a program has time to set PKRU to a restrictive value, that thread will be able to write to all data, no matter what pkey is set on it. This weakens any integrity guarantees that we want pkeys to provide. To fix this, we define a very restrictive PKRU to override the XSAVE-provided value when we create a new FPU context. We choose a value that only allows access to pkey 0, which is as restrictive as we can practically make it. This does not cause any practical problems with applications using protection keys because we require them to specify initial permissions for each key when it is allocated, which override the restrictive default. In the end, this ensures that threads which do not know how to manage their own pkey rights can not do damage to data which is pkey-protected. I would have thought this was a pretty contrived scenario, except that I heard a bug report from an MPX user who was creating threads in some very early code before main(). It may be crazy, but folks evidently _do_ it. Signed-off-by: Dave Hansen <dave.hansen@linux.intel.com> Cc: linux-arch@vger.kernel.org Cc: Dave Hansen <dave@sr71.net> Cc: mgorman@techsingularity.net Cc: arnd@arndb.de Cc: linux-api@vger.kernel.org Cc: linux-mm@kvack.org Cc: luto@kernel.org Cc: akpm@linux-foundation.org Cc: torvalds@linux-foundation.org Link: http://lkml.kernel.org/r/20160729163021.F3C25D4A@viggo.jf.intel.com Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2016-09-06documentation/scsi: Remove nodisconnect parameterFinn Thain
The driver that used the 'nodisconnect' parameter was removed in commit 565bae6a4a8f ("[SCSI] 53c7xx: kill driver"). Related documentation was cleaned up in commit f37a7238d379 ("[SCSI] 53c7xx: fix removal fallout"), except for the remaining two mentions that are removed here. Signed-off-by: Finn Thain <fthain@telegraphics.com.au> Reviewed-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-09-05iommu/amd: Detect and enable guest vAPIC supportSuravee Suthikulpanit
This patch introduces a new IOMMU driver parameter, amd_iommu_guest_ir, which can be used to specify different interrupt remapping mode for passthrough devices to VM guest: * legacy: Legacy interrupt remapping (w/ 32-bit IRTE) * vapic : Guest vAPIC interrupt remapping (w/ GA mode 128-bit IRTE) Note that in vapic mode, it can also supports legacy interrupt remapping for non-passthrough devices with the 128-bit IRTE. Signed-off-by: Suravee Suthikulpanit <suravee.suthikulpanit@amd.com> Signed-off-by: Joerg Roedel <jroedel@suse.de>
2016-08-25docs: kernel-parameter: Improve the description of nr_cpus and maxcpusBaoquan He
From the old description people still can't get what's the exact difference between nr_cpus and maxcpus. Especially in kdump kernel nr_cpus is always suggested if it's implemented in the ARCH. The reason is nr_cpus is used to limit the max number of possible cpu in system, the sum of already plugged cpus and hot plug cpus can't exceed its value. However maxcpus is used to limit how many cpus are allowed to be brought up during bootup. Signed-off-by: Baoquan He <bhe@redhat.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-08-18Update the maximum depth of C-state from 6 to 9baolex.ni
Hi Jon, This patch is an old one, we have corrected some minor issues on the newer one. Please only review the newest version from my last mail with this subject "[PATCH] ACPI: Update the maximum depth of C-state from 6 to 9". And I also attached it to this mail. Thanks, Baole On 7/11/2016 6:37 AM, Jonathan Corbet wrote: > On Mon, 4 Jul 2016 09:55:10 +0800 > "baolex.ni" <baolex.ni@intel.com> wrote: > >> Currently, CPUIDLE_STATE_MAX has been defined as 10 in the cpuidle head file, >> and max_cstate = CPUIDLE_STATE_MAX – 1, so 9 is the right maximum depth of C-state. >> This change is reflected in one place of the kernel-param file, >> but not in the other place where I suggest changing. >> >> Signed-off-by: Chuansheng Liu <chuansheng.liu@intel.com> >> Signed-off-by: Baole Ni <baolex.ni@intel.com> > > So why are there two signoffs on a single-line patch? Which one of you > is the actual author? > > Thanks, > > jon > From cf5f8aa6885874f6490b11507d3c0c86fa0a11f4 Mon Sep 17 00:00:00 2001 From: Chuansheng Liu <chuansheng.liu@intel.com> Date: Mon, 4 Jul 2016 08:52:51 +0800 Subject: [PATCH] Update the maximum depth of C-state from 6 to 9 MIME-Version: 1.0 Content-Type: text/plain; charset=UTF-8 Content-Transfer-Encoding: 8bit Currently, CPUIDLE_STATE_MAX has been defined as 10 in the cpuidle head file, and max_cstate = CPUIDLE_STATE_MAX – 1, so 9 is the right maximum depth of C-state. This change is reflected in one place of the kernel-param file, but not in the other place where I suggest changing. Signed-off-by: Chuansheng Liu <chuansheng.liu@intel.com> Signed-off-by: Baole Ni <baolex.ni@intel.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-08-09PCI: Update "pci=resource_alignment" documentationMathias Koehrer
Some uio based PCI drivers, e.g., uio_cif, do not work if the assigned PCI memory resources are not page aligned. By using the kernel option "pci=resource_alignment=<align>@<bus>:<slot>.<func>" it is possible to request page alignment for memory resources of devices. However, this is cumbersome when using several devices, and the bus/slot/func addresses may change if devices are added to or removed from the system. Extend the "pci=resource_alignment" option so we can specify the relevant devices via PCI vendor, device, subvendor, and subdevice IDs. The specification of the devices via IDs is indicated by a leading string "pci:" as argument to "pci=resource_alignment". The format of the specification is pci:<vendor>:<device>[:<subvendor>:<subdevice>] Examples: pci=resource_alignment=4096@pci:8086:9c22:103c:198f pci=resource_alignment=pci:8086:9c22 # defaults to PAGE_SIZE align [bhelgaas: changelog, use actual vendor/device IDs in examples] Signed-off-by: Mathias Koehrer <mathias.koehrer@etas.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2016-08-07Merge tag 'doc-4.8-fixes' of git://git.lwn.net/linuxLinus Torvalds
Pull documentation fixes from Jonathan Corbet: "Three fixes for the docs build, including removing an annoying warning on 'make help' if sphinx isn't present" * tag 'doc-4.8-fixes' of git://git.lwn.net/linux: DocBook: use DOCBOOKS="" to ignore DocBooks instead of IGNORE_DOCBOOKS=1 Documenation: update cgroup's document path Documentation/sphinx: do not warn about missing tools in 'make help'
2016-08-04Merge tag 'nfsd-4.8' of git://linux-nfs.org/~bfields/linuxLinus Torvalds
Pull nfsd updates from Bruce Fields: "Highlights: - Trond made a change to the server's tcp logic that allows a fast client to better take advantage of high bandwidth networks, but may increase the risk that a single client could starve other clients; a new sunrpc.svc_rpc_per_connection_limit parameter should help mitigate this in the (hopefully unlikely) event this becomes a problem in practice. - Tom Haynes added a minimal flex-layout pnfs server, which is of no use in production for now--don't build it unless you're doing client testing or further server development" * tag 'nfsd-4.8' of git://linux-nfs.org/~bfields/linux: (32 commits) nfsd: remove some dead code in nfsd_create_locked() nfsd: drop unnecessary MAY_EXEC check from create nfsd: clean up bad-type check in nfsd_create_locked nfsd: remove unnecessary positive-dentry check nfsd: reorganize nfsd_create nfsd: check d_can_lookup in fh_verify of directories nfsd: remove redundant zero-length check from create nfsd: Make creates return EEXIST instead of EACCES SUNRPC: Detect immediate closure of accepted sockets SUNRPC: accept() may return sockets that are still in SYN_RECV nfsd: allow nfsd to advertise multiple layout types nfsd: Close race between nfsd4_release_lockowner and nfsd4_lock nfsd/blocklayout: Make sure calculate signature/designator length aligned xfs: abstract block export operations from nfsd layouts SUNRPC: Remove unused callback xpo_adjust_wspace() SUNRPC: Change TCP socket space reservation SUNRPC: Add a server side per-connection limit SUNRPC: Micro optimisation for svc_data_ready SUNRPC: Call the default socket callbacks instead of open coding SUNRPC: lock the socket while detaching it ...
2016-08-04Merge tag 'modules-next-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux Pull module updates from Rusty Russell: "The only interesting thing here is Jessica's patch to add ro_after_init support to modules. The rest are all trivia" * tag 'modules-next-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/rusty/linux: extable.h: add stddef.h so "NULL" definition is not implicit modules: add ro_after_init support jump_label: disable preemption around __module_text_address(). exceptions: fork exception table content from module.h into extable.h modules: Add kernel parameter to blacklist modules module: Do a WARN_ON_ONCE() for assert module mutex not held Documentation/module-signing.txt: Note need for version info if reusing a key module: Invalidate signatures on force-loaded modules module: Issue warnings when tainting kernel module: fix redundant test. module: fix noreturn attribute for __module_put_and_exit()
2016-08-04modules: Add kernel parameter to blacklist modulesPrarit Bhargava
Blacklisting a module in linux has long been a problem. The current procedure is to use rd.blacklist=module_name, however, that doesn't cover the case after the initramfs and before a boot prompt (where one is supposed to use /etc/modprobe.d/blacklist.conf to blacklist runtime loading). Using rd.shell to get an early prompt is hit-or-miss, and doesn't cover all situations AFAICT. This patch adds this functionality of permanently blacklisting a module by its name via the kernel parameter module_blacklist=module_name. [v2]: Rusty, use core_param() instead of __setup() which simplifies things. [v3]: Rusty, undo wreckage from strsep() [v4]: Rusty, simpler version of blacklisted() Signed-off-by: Prarit Bhargava <prarit@redhat.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Rusty Russell <rusty@rustcorp.com.au> Cc: linux-doc@vger.kernel.org Signed-off-by: Rusty Russell <rusty@rustcorp.com.au>
2016-08-03Documenation: update cgroup's document pathseokhoon.yoon
cgroup's document path is changed to "cgroup-v1". update it. Signed-off-by: seokhoon.yoon <iamyooon@gmail.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2016-08-02Merge branch 'akpm' (patches from Andrew)Linus Torvalds
Merge yet more updates from Andrew Morton: - the rest of ocfs2 - various hotfixes, mainly MM - quite a bit of misc stuff - drivers, fork, exec, signals, etc. - printk updates - firmware - checkpatch - nilfs2 - more kexec stuff than usual - rapidio updates - w1 things * emailed patches from Andrew Morton <akpm@linux-foundation.org>: (111 commits) ipc: delete "nr_ipc_ns" kcov: allow more fine-grained coverage instrumentation init/Kconfig: add clarification for out-of-tree modules config: add android config fragments init/Kconfig: ban CONFIG_LOCALVERSION_AUTO with allmodconfig relay: add global mode support for buffer-only channels init: allow blacklisting of module_init functions w1:omap_hdq: fix regression w1: add helper macro module_w1_family w1: remove need for ida and use PLATFORM_DEVID_AUTO rapidio/switches: add driver for IDT gen3 switches powerpc/fsl_rio: apply changes for RIO spec rev 3 rapidio: modify for rev.3 specification changes rapidio: change inbound window size type to u64 rapidio/idt_gen2: fix locking warning rapidio: fix error handling in mbox request/release functions rapidio/tsi721_dma: advance queue processing from transfer submit call rapidio/tsi721: add messaging mbox selector parameter rapidio/tsi721: add PCIe MRRS override parameter rapidio/tsi721_dma: add channel mask and queue size parameters ...
2016-08-02printk: add kernel parameter to control writes to /dev/kmsgBorislav Petkov
Add a "printk.devkmsg" kernel command line parameter which controls how userspace writes into /dev/kmsg. It has three options: * ratelimit - ratelimit logging from userspace. * on - unlimited logging from userspace * off - logging from userspace gets ignored The default setting is to ratelimit the messages written to it. This changes the kernel default setting of "on" to "ratelimit" and we do that because we want to keep userspace spamming /dev/kmsg to sane levels. This is especially moot when a small kernel log buffer wraps around and messages get lost. So the ratelimiting setting should be a sane setting where kernel messages should have a bit higher chance of survival from all the spamming. It additionally does not limit logging to /dev/kmsg while the system is booting if we haven't disabled it on the command line. Furthermore, we can control the logging from a lower priority sysctl interface - kernel.printk_devkmsg. That interface will succeed only if printk.devkmsg *hasn't* been supplied on the command line. If it has, then printk.devkmsg is a one-time setting which remains for the duration of the system lifetime. This "locking" of the setting is to prevent userspace from changing the logging on us through sysctl(2). This patch is based on previous patches from Linus and Steven. [bp@suse.de: fixes] Link: http://lkml.kernel.org/r/20160719072344.GC25563@nazgul.tnic Link: http://lkml.kernel.org/r/20160716061745.15795-3-bp@alien8.de Signed-off-by: Borislav Petkov <bp@suse.de> Cc: Dave Young <dyoung@redhat.com> Cc: Franck Bui <fbui@suse.com> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Ingo Molnar <mingo@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2016-08-02Merge tag 'pci-v4.8-changes' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci Pull PCI updates from Bjorn Helgaas: "Highlights: - ARM64 support for ACPI host bridges - new drivers for Axis ARTPEC-6 and Marvell Aardvark - new pci_alloc_irq_vectors() interface for MSI-X, MSI, legacy INTx - pci_resource_to_user() cleanup (more to come) Detailed summary: Enumeration: - Move ecam.h to linux/include/pci-ecam.h (Jayachandran C) - Add parent device field to ECAM struct pci_config_window (Jayachandran C) - Add generic MCFG table handling (Tomasz Nowicki) - Refactor pci_bus_assign_domain_nr() for CONFIG_PCI_DOMAINS_GENERIC (Tomasz Nowicki) - Factor DT-specific pci_bus_find_domain_nr() code out (Tomasz Nowicki) Resource management: - Add devm_request_pci_bus_resources() (Bjorn Helgaas) - Unify pci_resource_to_user() declarations (Bjorn Helgaas) - Implement pci_resource_to_user() with pcibios_resource_to_bus() (microblaze, powerpc, sparc) (Bjorn Helgaas) - Request host bridge window resources (designware, iproc, rcar, xgene, xilinx, xilinx-nwl) (Bjorn Helgaas) - Make PCI I/O space optional on ARM32 (Bjorn Helgaas) - Ignore write combining when mapping I/O port space (Bjorn Helgaas) - Claim bus resources on MIPS PCI_PROBE_ONLY set-ups (Bjorn Helgaas) - Remove unicore32 pci=firmware command line parameter handling (Bjorn Helgaas) - Support I/O resources when parsing host bridge resources (Jayachandran C) - Add helpers to request/release memory and I/O regions (Johannes Thumshirn) - Use pci_(request|release)_mem_regions (NVMe, lpfc, GenWQE, ethernet/intel, alx) (Johannes Thumshirn) - Extend pci=resource_alignment to specify device/vendor IDs (Koehrer Mathias (ETAS/ESW5)) - Add generic pci_bus_claim_resources() (Lorenzo Pieralisi) - Claim bus resources on ARM32 PCI_PROBE_ONLY set-ups (Lorenzo Pieralisi) - Remove ARM32 and ARM64 arch-specific pcibios_enable_device() (Lorenzo Pieralisi) - Add pci_unmap_iospace() to unmap I/O resources (Sinan Kaya) - Remove powerpc __pci_mmap_set_pgprot() (Yinghai Lu) PCI device hotplug: - Allow additional bus numbers for hotplug bridges (Keith Busch) - Ignore interrupts during D3cold (Lukas Wunner) Power management: - Enforce type casting for pci_power_t (Andy Shevchenko) - Don't clear d3cold_allowed for PCIe ports (Mika Westerberg) - Put PCIe ports into D3 during suspend (Mika Westerberg) - Power on bridges before scanning new devices (Mika Westerberg) - Runtime resume bridge before rescan (Mika Westerberg) - Add runtime PM support for PCIe ports (Mika Westerberg) - Remove redundant check of pcie_set_clkpm (Shawn Lin) Virtualization: - Add function 1 DMA alias quirk for Marvell 88SE9182 (Aaron Sierra) - Add DMA alias quirk for Adaptec 3805 (Alex Williamson) - Mark Atheros AR9485 and QCA9882 to avoid bus reset (Chris Blake) - Add ACS quirk for Solarflare SFC9220 (Edward Cree) MSI: - Fix PCI_MSI dependencies (Arnd Bergmann) - Add pci_msix_desc_addr() helper (Christoph Hellwig) - Switch msix_program_entries() to use pci_msix_desc_addr() (Christoph Hellwig) - Make the "entries" argument to pci_enable_msix() optional (Christoph Hellwig) - Provide sensible IRQ vector alloc/free routines (Christoph Hellwig) - Spread interrupt vectors in pci_alloc_irq_vectors() (Christoph Hellwig) Error Handling: - Bind DPC to Root Ports as well as Downstream Ports (Keith Busch) - Remove DPC tristate module option (Keith Busch) - Convert Downstream Port Containment driver to use devm_* functions (Mika Westerberg) Generic host bridge driver: - Select IRQ_DOMAIN (Arnd Bergmann) - Claim bus resources on PCI_PROBE_ONLY set-ups (Lorenzo Pieralisi) ACPI host bridge driver: - Add ARM64 acpi_pci_bus_find_domain_nr() (Tomasz Nowicki) - Add ARM64 ACPI support for legacy IRQs parsing and consolidation with DT code (Tomasz Nowicki) - Implement ARM64 AML accessors for PCI_Config region (Tomasz Nowicki) - Support ARM64 ACPI-based PCI host controller (Tomasz Nowicki) Altera host bridge driver: - Check link status before retrain link (Ley Foon Tan) - Poll for link up status after retraining the link (Ley Foon Tan) Axis ARTPEC-6 host bridge driver: - Add PCI_MSI_IRQ_DOMAIN dependency (Arnd Bergmann) - Add DT binding for Axis ARTPEC-6 PCIe controller (Niklas Cassel) - Add Axis ARTPEC-6 PCIe controller driver (Niklas Cassel) Intel VMD host bridge driver: - Use lock save/restore in interrupt enable path (Jon Derrick) - Select device dma ops to override (Keith Busch) - Initialize list item in IRQ disable (Keith Busch) - Use x86_vector_domain as parent domain (Keith Busch) - Separate MSI and MSI-X vector sharing (Keith Busch) Marvell Aardvark host bridge driver: - Add DT binding for the Aardvark PCIe controller (Thomas Petazzoni) - Add Aardvark PCI host controller driver (Thomas Petazzoni) - Add Aardvark PCIe support for Armada 3700 (Thomas Petazzoni) Microsoft Hyper-V host bridge driver: - Fix interrupt cleanup path (Cathy Avery) - Don't leak buffer in hv_pci_onchannelcallback() (Vitaly Kuznetsov) - Handle all pending messages in hv_pci_onchannelcallback() (Vitaly Kuznetsov) NVIDIA Tegra host bridge driver: - Program PADS_REFCLK_CFG* always, not just on legacy SoCs (Stephen Warren) - Program PADS_REFCLK_CFG* registers with per-SoC values (Stephen Warren) - Use lower-case hex consistently for register definitions (Thierry Reding) - Use generic pci_remap_iospace() rather than ARM32-specific one (Thierry Reding) - Stop setting pcibios_min_mem (Thierry Reding) Renesas R-Car host bridge driver: - Drop gen2 dummy I/O port region (Bjorn Helgaas) TI DRA7xx host bridge driver: - Fix return value in case of error (Christophe JAILLET) Xilinx AXI host bridge driver: - Fix return value in case of error (Christophe JAILLET) Miscellaneous: - Make bus_attr_resource_alignment static (Ben Dooks) - Include <asm/dma.h> for isa_dma_bridge_buggy (Ben Dooks) - MAINTAINERS: Add file patterns for PCI device tree bindings (Geert Uytterhoeven) - Make host bridge drivers explicitly non-modular (Paul Gortmaker)" * tag 'pci-v4.8-changes' of git://git.kernel.org/pub/scm/linux/kernel/git/helgaas/pci: (125 commits) PCI: xgene: Make explicitly non-modular PCI: thunder-pem: Make explicitly non-modular PCI: thunder-ecam: Make explicitly non-modular PCI: tegra: Make explicitly non-modular PCI: rcar-gen2: Make explicitly non-modular PCI: rcar: Make explicitly non-modular PCI: mvebu: Make explicitly non-modular PCI: layerscape: Make explicitly non-modular PCI: keystone: Make explicitly non-modular PCI: hisi: Make explicitly non-modular PCI: generic: Make explicitly non-modular PCI: designware-plat: Make it explicitly non-modular PCI: artpec6: Make explicitly non-modular PCI: armada8k: Make explicitly non-modular PCI: artpec: Add PCI_MSI_IRQ_DOMAIN dependency PCI: Add ACS quirk for Solarflare SFC9220 arm64: dts: marvell: Add Aardvark PCIe support for Armada 3700 PCI: aardvark: Add Aardvark PCI host controller driver dt-bindings: add DT binding for the Aardvark PCIe controller PCI: tegra: Program PADS_REFCLK_CFG* registers with per-SoC values ...
2016-08-01Merge branch 'pci/resource' into nextBjorn Helgaas
* pci/resource: unicore32/PCI: Remove pci=firmware command line parameter handling ARM/PCI: Remove arch-specific pcibios_enable_device() ARM64/PCI: Remove arch-specific pcibios_enable_device() MIPS/PCI: Claim bus resources on PCI_PROBE_ONLY set-ups ARM/PCI: Claim bus resources on PCI_PROBE_ONLY set-ups PCI: generic: Claim bus resources on PCI_PROBE_ONLY set-ups PCI: Add generic pci_bus_claim_resources() alx: Use pci_(request|release)_mem_regions ethernet/intel: Use pci_(request|release)_mem_regions GenWQE: Use pci_(request|release)_mem_regions lpfc: Use pci_(request|release)_mem_regions NVMe: Use pci_(request|release)_mem_regions PCI: Add helpers to request/release memory and I/O regions PCI: Extending pci=resource_alignment to specify device/vendor IDs sparc/PCI: Implement pci_resource_to_user() with pcibios_resource_to_bus() powerpc/pci: Implement pci_resource_to_user() with pcibios_resource_to_bus() microblaze/PCI: Implement pci_resource_to_user() with pcibios_resource_to_bus() PCI: Unify pci_resource_to_user() declarations microblaze/PCI: Remove useless __pci_mmap_set_pgprot() powerpc/pci: Remove __pci_mmap_set_pgprot() PCI: Ignore write combining when mapping I/O port space
2016-08-01Merge branches 'pci/aspm', 'pci/dpc', 'pci/hotplug', 'pci/misc', 'pci/msi', ↵Bjorn Helgaas
'pci/pm' and 'pci/virtualization' into next * pci/aspm: PCI/ASPM: Remove redundant check of pcie_set_clkpm * pci/dpc: PCI: Remove DPC tristate module option PCI: Bind DPC to Root Ports as well as Downstream Ports PCI: Fix whitespace in struct dpc_dev PCI: Convert Downstream Port Containment driver to use devm_* functions * pci/hotplug: PCI: Allow additional bus numbers for hotplug bridges * pci/misc: PCI: Include <asm/dma.h> for isa_dma_bridge_buggy PCI: Make bus_attr_resource_alignment static MAINTAINERS: Add file patterns for PCI device tree bindings PCI: Fix comment typo * pci/msi: PCI/MSI: irqchip: Fix PCI_MSI dependencies * pci/pm: PCI: pciehp: Ignore interrupts during D3cold PCI: Document connection between pci_power_t and hardware PM capability PCI: Add runtime PM support for PCIe ports ACPI / hotplug / PCI: Runtime resume bridge before rescan PCI: Power on bridges before scanning new devices PCI: Put PCIe ports into D3 during suspend PCI: Don't clear d3cold_allowed for PCIe ports PCI / PM: Enforce type casting for pci_power_t * pci/virtualization: PCI: Add ACS quirk for Solarflare SFC9220 PCI: Add DMA alias quirk for Adaptec 3805 PCI: Mark Atheros AR9485 and QCA9882 to avoid bus reset PCI: Add function 1 DMA alias quirk for Marvell 88SE9182
2016-07-30Merge tag 'powerpc-4.8-1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux Pull powerpc updates from Michael Ellerman: "Highlights: - PowerNV PCI hotplug support. - Lots more Power9 support. - eBPF JIT support on ppc64le. - Lots of cxl updates. - Boot code consolidation. Bug fixes: - Fix spin_unlock_wait() from Boqun Feng - Fix stack pointer corruption in __tm_recheckpoint() from Michael Neuling - Fix multiple bugs in memory_hotplug_max() from Bharata B Rao - mm: Ensure "special" zones are empty from Oliver O'Halloran - ftrace: Separate the heuristics for checking call sites from Michael Ellerman - modules: Never restore r2 for a mprofile-kernel style mcount() call from Michael Ellerman - Fix endianness when reading TCEs from Alexey Kardashevskiy - start rtasd before PCI probing from Greg Kurz - PCI: rpaphp: Fix slot registration for multiple slots under a PHB from Tyrel Datwyler - powerpc/mm: Add memory barrier in __hugepte_alloc() from Sukadev Bhattiprolu Cleanups & fixes: - Drop support for MPIC in pseries from Rashmica Gupta - Define and use PPC64_ELF_ABI_v2/v1 from Michael Ellerman - Remove unused symbols in asm-offsets.c from Rashmica Gupta - Fix SRIOV not building without EEH enabled from Russell Currey - Remove kretprobe_trampoline_holder from Thiago Jung Bauermann - Reduce log level of PCI I/O space warning from Benjamin Herrenschmidt - Add array bounds checking to crash_shutdown_handlers from Suraj Jitindar Singh - Avoid -maltivec when using clang integrated assembler from Anton Blanchard - Fix array overrun in ppc_rtas() syscall from Andrew Donnellan - Fix error return value in cmm_mem_going_offline() from Rasmus Villemoes - export cpu_to_core_id() from Mauricio Faria de Oliveira - Remove old symbols from defconfigs from Andrew Donnellan - Update obsolete comments in setup_32.c about entry conditions from Benjamin Herrenschmidt - Add comment explaining the purpose of setup_kdump_trampoline() from Benjamin Herrenschmidt - Merge the RELOCATABLE config entries for ppc32 and ppc64 from Kevin Hao - Remove RELOCATABLE_PPC32 from Kevin Hao - Fix .long's in tlb-radix.c to more meaningful from Balbir Singh Minor cleanups & fixes: - Andrew Donnellan, Anna-Maria Gleixner, Anton Blanchard, Benjamin Herrenschmidt, Bharata B Rao, Christophe Leroy, Colin Ian King, Geliang Tang, Greg Kurz, Madhavan Srinivasan, Michael Ellerman, Michael Ellerman, Stephen Rothwell, Stewart Smith. Freescale updates from Scott: - "Highlights include more 8xx optimizations, device tree updates, and MVME7100 support." PowerNV PCI hotplug from Gavin Shan: - PCI: Add pcibios_setup_bridge() - Override pcibios_setup_bridge() - Remove PCI_RESET_DELAY_US - Move pnv_pci_ioda_setup_opal_tce_kill() around - Increase PE# capacity - Allocate PE# in reverse order - Create PEs in pcibios_setup_bridge() - Setup PE for root bus - Extend PCI bridge resources - Make pnv_ioda_deconfigure_pe() visible - Dynamically release PE - Update bridge windows on PCI plug - Delay populating pdn - Support PCI slot ID - Use PCI slot reset infrastructure - Introduce pnv_pci_get_slot_id() - Functions to get/set PCI slot state - PCI/hotplug: PowerPC PowerNV PCI hotplug driver - Print correct PHB type names Power9 idle support from Shreyas B. Prabhu: - set power_save func after the idle states are initialized - Use PNV_THREAD_WINKLE macro while requesting for winkle - make hypervisor state restore a function - Rename idle_power7.S to idle_book3s.S - Rename reusable idle functions to hardware agnostic names - Make pnv_powersave_common more generic - abstraction for saving SPRs before entering deep idle states - Add platform support for stop instruction - cpuidle/powernv: Use CPUIDLE_STATE_MAX instead of MAX_POWERNV_IDLE_STATES - cpuidle/powernv: cleanup cpuidle-powernv.c - cpuidle/powernv: Add support for POWER ISA v3 idle states - Use deepest stop state when cpu is offlined Power9 PMU from Madhavan Srinivasan: - factor out power8 pmu macros and defines - factor out power8 pmu functions - factor out power8 __init_pmu code - Add power9 event list macros for generic and cache events - Power9 PMU support - Export Power9 generic and cache events to sysfs Power9 preliminary interrupt & PCI support from Benjamin Herrenschmidt: - Add XICS emulation APIs - Move a few exception common handlers to make room - Add support for HV virtualization interrupts - Add mechanism to force a replay of interrupts - Add ICP OPAL backend - Discover IODA3 PHBs - pci: Remove obsolete SW invalidate - opal: Add real mode call wrappers - Rename TCE invalidation calls - Remove SWINV constants and obsolete TCE code - Rework accessing the TCE invalidate register - Fallback to OPAL for TCE invalidations - Use the device-tree to get available range of M64's - Check status of a PHB before using it - pci: Don't try to allocate resources that will be reassigned Other Power9: - Send SIGBUS on unaligned copy and paste from Chris Smart - Large Decrementer support from Oliver O'Halloran - Load Monitor Register Support from Jack Miller Performance improvements from Anton Blanchard: - Avoid load hit store in __giveup_fpu() and __giveup_altivec() - Avoid load hit store in setup_sigcontext() - Remove assembly versions of strcpy, strcat, strlen and strcmp - Align hot loops of some string functions eBPF JIT from Naveen N. Rao: - Fix/enhance 32-bit Load Immediate implementation - Optimize 64-bit Immediate loads - Introduce rotate immediate instructions - A few cleanups - Isolate classic BPF JIT specifics into a separate header - Implement JIT compiler for extended BPF Operator Panel driver from Suraj Jitindar Singh: - devicetree/bindings: Add binding for operator panel on FSP machines - Add inline function to get rc from an ASYNC_COMP opal_msg - Add driver for operator panel on FSP machines Sparse fixes from Daniel Axtens: - make some things static - Introduce asm-prototypes.h - Include headers containing prototypes - Use #ifdef __BIG_ENDIAN__ #else for REG_BYTE - kvm: Clarify __user annotations - Pass endianness to sparse - Make ppc_md.{halt, restart} __noreturn MM fixes & cleanups from Aneesh Kumar K.V: - radix: Update LPCR HR bit as per ISA - use _raw variant of page table accessors - Compile out radix related functions if RADIX_MMU is disabled - Clear top 16 bits of va only on older cpus - Print formation regarding the the MMU mode - hash: Update SDR1 size encoding as documented in ISA 3.0 - radix: Update PID switch sequence - radix: Update machine call back to support new HCALL. - radix: Add LPID based tlb flush helpers - radix: Add a kernel command line to disable radix - Cleanup LPCR defines Boot code consolidation from Benjamin Herrenschmidt: - Move epapr_paravirt_early_init() to early_init_devtree() - cell: Don't use flat device-tree after boot - ge_imp3a: Don't use the flat device-tree after boot - mpc85xx_ds: Don't use the flat device-tree after boot - mpc85xx_rdb: Don't use the flat device-tree after boot - Don't test for machine type in rtas_initialize() - Don't test for machine type in smp_setup_cpu_maps() - dt: Add of_device_compatible_match() - Factor do_feature_fixup calls - Move 64-bit feature fixup earlier - Move 64-bit memory reserves to setup_arch() - Use a cachable DART - Move FW feature probing out of pseries probe() - Put exception configuration in a common place - Remove early allocation of the SMU command buffer - Move MMU backend selection out of platform code - pasemi: Remove IOBMAP allocation from platform probe() - mm/hash: Don't use machine_is() early during boot - Don't test for machine type to detect HEA special case - pmac: Remove spurrious machine type test - Move hash table ops to a separate structure - Ensure that ppc_md is empty before probing for machine type - Move 64-bit probe_machine() to later in the boot process - Move 32-bit probe() machine to later in the boot process - Get rid of ppc_md.init_early() - Move the boot time info banner to a separate function - Move setting of {i,d}cache_bsize to initialize_cache_info() - Move the content of setup_system() to setup_arch() - Move cache info inits to a separate function - Re-order the call to smp_setup_cpu_maps() - Re-order setup_panic() - Make a few boot functions __init - Merge 32-bit and 64-bit setup_arch() Other new features: - tty/hvc: Use IRQF_SHARED for OPAL hvc consoles from Sam Mendoza-Jonas - tty/hvc: Use opal irqchip interface if available from Sam Mendoza-Jonas - powerpc: Add module autoloading based on CPU features from Alastair D'Silva - crypto: vmx - Convert to CPU feature based module autoloading from Alastair D'Silva - Wake up kopald polling thread before waiting for events from Benjamin Herrenschmidt - xmon: Dump ISA 2.06 SPRs from Michael Ellerman - xmon: Dump ISA 2.07 SPRs from Michael Ellerman - Add a parameter to disable 1TB segs from Oliver O'Halloran - powerpc/boot: Add OPAL console to epapr wrappers from Oliver O'Halloran - Assign fixed PHB number based on device-tree properties from Guilherme G. Piccoli - pseries: Add pseries hotplug workqueue from John Allen - pseries: Add support for hotplug interrupt source from John Allen - pseries: Use kernel hotplug queue for PowerVM hotplug events from John Allen - pseries: Move property cloning into its own routine from Nathan Fontenot - pseries: Dynamic add entires to associativity lookup array from Nathan Fontenot - pseries: Auto-online hotplugged memory from Nathan Fontenot - pseries: Remove call to memblock_add() from Nathan Fontenot cxl: - Add set and get private data to context struct from Michael Neuling - make base more explicitly non-modular from Paul Gortmaker - Use for_each_compatible_node() macro from Wei Yongjun - Frederic Barrat - Abstract the differences between the PSL and XSL - Make vPHB device node match adapter's - Philippe Bergheaud - Add mechanism for delivering AFU driver specific events - Ignore CAPI adapters misplaced in switched slots - Refine slice error debug messages - Andrew Donnellan - static-ify variables to fix sparse warnings - PCI/hotplug: pnv_php: export symbols and move struct types needed by cxl - PCI/hotplug: pnv_php: handle OPAL_PCI_SLOT_OFFLINE power state - Add cxl_check_and_switch_mode() API to switch bi-modal cards - remove dead Kconfig options - fix potential NULL dereference in free_adapter() - Ian Munsie - Update process element after allocating interrupts - Add support for CAPP DMA mode - Fix allowing bogus AFU descriptors with 0 maximum processes - Fix allocating a minimum of 2 pages for the SPA - Fix bug where AFU disable operation had no effect - Workaround XSL bug that does not clear the RA bit after a reset - Fix NULL pointer dereference on kernel contexts with no AFU interrupts - powerpc/powernv: Split cxl code out into a separate file - Add cxl_slot_is_supported API - Enable bus mastering for devices using CAPP DMA mode - Move cxl_afu_get / cxl_afu_put to base - Allow a default context to be associated with an external pci_dev - Do not create vPHB if there are no AFU configuration records - powerpc/powernv: Add support for the cxl kernel api on the real phb - Add support for using the kernel API with a real PHB - Add kernel APIs to get & set the max irqs per context - Add preliminary workaround for CX4 interrupt limitation - Add support for interrupts on the Mellanox CX4 - Workaround PE=0 hardware limitation in Mellanox CX4 - powerpc/powernv: Fix pci-cxl.c build when CONFIG_MODULES=n selftests: - Test unaligned copy and paste from Chris Smart - Load Monitor Register Tests from Jack Miller - Cyril Bur - exec() with suspended transaction - Use signed long to read perf_event_paranoid - Fix usage message in context_switch - Fix generation of vector instructions/types in context_switch - Michael Ellerman - Use "Delta" rather than "Error" in normal output - Import Anton's mmap & futex micro benchmarks - Add a test for PROT_SAO" * tag 'powerpc-4.8-1' of git://git.kernel.org/pub/scm/linux/kernel/git/powerpc/linux: (263 commits) powerpc/mm: Parenthesise IS_ENABLED() in if condition tty/hvc: Use opal irqchip interface if available tty/hvc: Use IRQF_SHARED for OPAL hvc consoles selftests/powerpc: exec() with suspended transaction powerpc: Improve comment explaining why we modify VRSAVE powerpc/mm: Drop unused externs for hpte_init_beat[_v3]() powerpc/mm: Rename hpte_init_lpar() and move the fallback to a header powerpc/mm: Fix build break when PPC_NATIVE=n crypto: vmx - Convert to CPU feature based module autoloading powerpc: Add module autoloading based on CPU features powerpc/powernv/ioda: Fix endianness when reading TCEs powerpc/mm: Add memory barrier in __hugepte_alloc() powerpc/modules: Never restore r2 for a mprofile-kernel style mcount() call powerpc/ftrace: Separate the heuristics for checking call sites powerpc: Merge 32-bit and 64-bit setup_arch() powerpc/64: Make a few boot functions __init powerpc: Re-order setup_panic() powerpc: Re-order the call to smp_setup_cpu_maps() powerpc/32: Move cache info inits to a separate function powerpc/64: Move the content of setup_system() to setup_arch() ...
2016-07-26Merge tag 'acpi-4.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull ACPI updates from Rafael Wysocki: "The new feaures here are the support for ACPI overlays (allowing ACPI tables to be loaded at any time from EFI variables or via configfs) and the LPI (Low-Power Idle) support. Also notable is the ACPI-based NUMA support for ARM64. Apart from that we have two new drivers, for the DPTF (Dynamic Power and Thermal Framework) power participant device and for the Intel Broxton WhiskeyCove PMIC, some more PMIC-related changes, support for the Boot Error Record Table (BERT) in APEI and support for platform-initiated graceful shutdown. Plus two new pieces of documentation and usual assorted fixes and cleanups in quite a few places. Specifics: - Support for ACPI SSDT overlays allowing Secondary System Description Tables (SSDTs) to be loaded at any time from EFI variables or via configfs (Octavian Purdila, Mika Westerberg). - Support for the ACPI LPI (Low-Power Idle) feature introduced in ACPI 6.0 and allowing processor idle states to be represented in ACPI tables in a hierarchical way (with the help of Processor Container objects) and support for ACPI idle states management on ARM64, based on LPI (Sudeep Holla). - General improvements of ACPI support for NUMA and ARM64 support for ACPI-based NUMA (Hanjun Guo, David Daney, Robert Richter). - General improvements of the ACPI table upgrade mechanism and ARM64 support for that feature (Aleksey Makarov, Jon Masters). - Support for the Boot Error Record Table (BERT) in APEI and improvements of kernel messages printed by the error injection code (Huang Ying, Borislav Petkov). - New driver for the Intel Broxton WhiskeyCove PMIC operation region and support for the REGS operation region on Broxton, PMIC code cleanups (Bin Gao, Felipe Balbi, Paul Gortmaker). - New driver for the power participant device which is part of the Dynamic Power and Thermal Framework (DPTF) and DPTF-related code reorganization (Srinivas Pandruvada). - Support for the platform-initiated graceful shutdown feature introduced in ACPI 6.1 (Prashanth Prakash). - ACPI button driver update related to lid input events generated automatically on initialization and system resume that have been problematic for some time (Lv Zheng). - ACPI EC driver cleanups (Lv Zheng). - Documentation of the ACPICA release automation process and the in-kernel ACPI AML debugger (Lv Zheng). - New blacklist entry and two fixes for the ACPI backlight driver (Alex Hung, Arvind Yadav, Ralf Gerbig). - Cleanups of the ACPI pci_slot driver (Joe Perches, Paul Gortmaker). - ACPI CPPC code changes to make it more robust against possible defects in ACPI tables and new symbol definitions for PCC (Hoan Tran). - System reboot code modification to execute the ACPI _PTS (Prepare To Sleep) method in addition to _TTS (Ocean He). - ACPICA-related change to carry out lock ordering checks in ACPICA if ACPICA debug is enabled in the kernel (Lv Zheng). - Assorted minor fixes and cleanups (Andy Shevchenko, Baoquan He, Bhaktipriya Shridhar, Paul Gortmaker, Rafael Wysocki)" * tag 'acpi-4.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (71 commits) ACPI: enable ACPI_PROCESSOR_IDLE on ARM64 arm64: add support for ACPI Low Power Idle(LPI) drivers: firmware: psci: initialise idle states using ACPI LPI cpuidle: introduce CPU_PM_CPU_IDLE_ENTER macro for ARM{32, 64} arm64: cpuidle: drop __init section marker to arm_cpuidle_init ACPI / processor_idle: Add support for Low Power Idle(LPI) states ACPI / processor_idle: introduce ACPI_PROCESSOR_CSTATE ACPI / DPTF: move int340x_thermal.c to the DPTF folder ACPI / DPTF: Add DPTF power participant driver ACPI / lpat: make it explicitly non-modular ACPI / dock: make dock explicitly non-modular ACPI / PCI: make pci_slot explicitly non-modular ACPI / PMIC: remove modular references from non-modular code ACPICA: Linux: Enable ACPI_MUTEX_DEBUG for Linux kernel ACPI: Rename configfs.c to acpi_configfs.c to prevent link error ACPI / debugger: Add AML debugger documentation ACPI: Add documentation describing ACPICA release automation ACPI: add support for loading SSDTs via configfs ACPI: add support for configfs efi / ACPI: load SSTDs from EFI variables ...
2016-07-26Merge tag 'pm-4.8-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm Pull power management updates from Rafael Wysocki: "Again, the majority of changes go into the cpufreq subsystem, but there are no big features this time. The cpufreq changes that stand out somewhat are the governor interface rework and improvements related to the handling of frequency tables. Apart from those, there are fixes and new device/CPU IDs in drivers, cleanups and an improvement of the new schedutil governor. Next, there are some changes in the hibernation core, including a fix for a nasty problem related to the MONITOR/MWAIT usage by CPU offline during resume from hibernation, a few core improvements related to memory management during resume, a couple of additional debug features and cleanups. Finally, we have some fixes and cleanups in the devfreq subsystem, generic power domains framework improvements related to system suspend/resume, support for some new chips in intel_idle and in the power capping RAPL driver, a new version of the AnalyzeSuspend utility and some assorted fixes and cleanups. Specifics: - Rework the cpufreq governor interface to make it more straightforward and modify the conservative governor to avoid using transition notifications (Rafael Wysocki). - Rework the handling of frequency tables by the cpufreq core to make it more efficient (Viresh Kumar). - Modify the schedutil governor to reduce the number of wakeups it causes to occur in cases when the CPU frequency doesn't need to be changed (Steve Muckle, Viresh Kumar). - Fix some minor issues and clean up code in the cpufreq core and governors (Rafael Wysocki, Viresh Kumar). - Add Intel Broxton support to the intel_pstate driver (Srinivas Pandruvada). - Fix problems related to the config TDP feature and to the validity of the MSR_HWP_INTERRUPT register in intel_pstate (Jan Kiszka, Srinivas Pandruvada). - Make intel_pstate update the cpu_frequency tracepoint even if the frequency doesn't change to avoid confusing powertop (Rafael Wysocki). - Clean up the usage of __init/__initdata in intel_pstate, mark some of its internal variables as __read_mostly and drop an unused structure element from it (Jisheng Zhang, Carsten Emde). - Clean up the usage of some duplicate MSR symbols in intel_pstate and turbostat (Srinivas Pandruvada). - Update/fix the powernv, s3c24xx and mvebu cpufreq drivers (Akshay Adiga, Viresh Kumar, Ben Dooks). - Fix a regression (introduced during the 4.5 cycle) in the pcc-cpufreq driver by reverting the problematic commit (Andreas Herrmann). - Add support for Intel Denverton to intel_idle, clean up Broxton support in it and make it explicitly non-modular (Jacob Pan, Jan Beulich, Paul Gortmaker). - Add support for Denverton and Ivy Bridge server to the Intel RAPL power capping driver and make it more careful about the handing of MSRs that may not be present (Jacob Pan, Xiaolong Wang). - Fix resume from hibernation on x86-64 by making the CPU offline during resume avoid using MONITOR/MWAIT in the "play dead" loop which may lead to an inadvertent "revival" of a "dead" CPU and a page fault leading to a kernel crash from it (Rafael Wysocki). - Make memory management during resume from hibernation more straightforward (Rafael Wysocki). - Add debug features that should help to detect problems related to hibernation and resume from it (Rafael Wysocki, Chen Yu). - Clean up hibernation core somewhat (Rafael Wysocki). - Prevent KASAN from instrumenting the hibernation core which leads to large numbers of false-positives from it (James Morse). - Prevent PM (hibernate and suspend) notifiers from being called during the cleanup phase if they have not been called during the corresponding preparation phase which is possible if one of the other notifiers returns an error at that time (Lianwei Wang). - Improve suspend-related debug printout in the tasks freezer and clean up suspend-related console handling (Roger Lu, Borislav Petkov). - Update the AnalyzeSuspend script in the kernel sources to version 4.2 (Todd Brandt). - Modify the generic power domains framework to make it handle system suspend/resume better (Ulf Hansson). - Make the runtime PM framework avoid resuming devices synchronously when user space changes the runtime PM settings for them and improve its error reporting (Rafael Wysocki, Linus Walleij). - Fix error paths in devfreq drivers (exynos, exynos-ppmu, exynos-bus) and in the core, make some devfreq code explicitly non-modular and change some of it into tristate (Bartlomiej Zolnierkiewicz, Peter Chen, Paul Gortmaker). - Add DT support to the generic PM clocks management code and make it export some more symbols (Jon Hunter, Paul Gortmaker). - Make the PCI PM core code slightly more robust against possible driver errors (Andy Shevchenko). - Make it possible to change DESTDIR and PREFIX in turbostat (Andy Shevchenko)" * tag 'pm-4.8-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/rafael/linux-pm: (89 commits) Revert "cpufreq: pcc-cpufreq: update default value of cpuinfo_transition_latency" PM / hibernate: Introduce test_resume mode for hibernation cpufreq: export cpufreq_driver_resolve_freq() cpufreq: Disallow ->resolve_freq() for drivers providing ->target_index() PCI / PM: check all fields in pci_set_platform_pm() cpufreq: acpi-cpufreq: use cached frequency mapping when possible cpufreq: schedutil: map raw required frequency to driver frequency cpufreq: add cpufreq_driver_resolve_freq() cpufreq: intel_pstate: Check cpuid for MSR_HWP_INTERRUPT intel_pstate: Update cpu_frequency tracepoint every time cpufreq: intel_pstate: clean remnant struct element PM / tools: scripts: AnalyzeSuspend v4.2 x86 / hibernate: Use hlt_play_dead() when resuming from hibernation cpufreq: powernv: Replacing pstate_id with frequency table index intel_pstate: Fix MSR_CONFIG_TDP_x addressing in core_get_max_pstate() PM / hibernate: Image data protection during restoration PM / hibernate: Add missing braces in __register_nosave_region() PM / hibernate: Clean up comments in snapshot.c PM / hibernate: Clean up function headers in snapshot.c PM / hibernate: Add missing braces in hibernate_setup() ...
2016-07-26Merge tag 'docs-for-linus' of git://git.lwn.net/linuxLinus Torvalds
Pull documentation updates from Jonathan Corbet: "Some big changes this month, headlined by the addition of a new formatted documentation mechanism based on the Sphinx system. The objectives here are to make it easier to create better-integrated (and more attractive) documents while (eventually) dumping our one-of-a-kind, cobbled-together system for something that is widely used and maintained by others. There's a fair amount of information what's being done, why, and how to use it in: https://lwn.net/Articles/692704/ https://lwn.net/Articles/692705/ Closer to home, Documentation/kernel-documentation.rst describes how it works. For now, the new system exists alongside the old one; you should soon see the GPU documentation converted over in the DRM pull and some significant media conversion work as well. Once all the docs have been moved over and we're convinced that the rough edges (of which are are a few) have been smoothed over, the DocBook-based stuff should go away. Primary credit is to Jani Nikula for doing the heavy lifting to make this stuff actually work; there has also been notable effort from Markus Heiser, Daniel Vetter, and Mauro Carvalho Chehab. Expect a couple of conflicts on the new index.rst file over the course of the merge window; they are trivially resolvable. That file may be a bit of a conflict magnet in the short term, but I don't expect that situation to last for any real length of time. Beyond that, of course, we have the usual collection of tweaks, updates, and typo fixes" * tag 'docs-for-linus' of git://git.lwn.net/linux: (77 commits) doc-rst: kernel-doc: fix handling of address_space tags Revert "doc/sphinx: Enable keep_warnings" doc-rst: kernel-doc directive, fix state machine reporter docs: deprecate kernel-doc-nano-HOWTO.txt doc/sphinx: Enable keep_warnings Documentation: add watermark_scale_factor to the list of vm systcl file kernel-doc: Fix up warning output docs: Get rid of some kernel-documentation warnings doc-rst: add an option to ignore DocBooks when generating docs workqueue: Fix a typo in workqueue.txt Doc: ocfs: Fix typo in filesystems/ocfs2-online-filecheck.txt Documentation/sphinx: skip build if user requested specific DOCBOOKS Documentation: add cleanmediadocs to the documentation targets Add .pyc files to .gitignore Doc: PM: Fix a typo in intel_powerclamp.txt doc-rst: flat-table directive - initial implementation Documentation: add meta-documentation for Sphinx and kernel-doc Documentation: tiny typo fix in usb/gadget_multi.txt Documentation: fix wrong value in md.txt bcache: documentation formatting, edited for clarity, stripe alignment notes ...
2016-07-26Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux Pull s390 updates from Martin Schwidefsky: "There are a couple of new things for s390 with this merge request: - a new scheduling domain "drawer" is added to reflect the unusual topology found on z13 machines. Performance tests showed up to 8 percent gain with the additional domain. - the new crc-32 checksum crypto module uses the vector-galois-field multiply and sum SIMD instruction to speed up crc-32 and crc-32c. - proper __ro_after_init support, this requires RO_AFTER_INIT_DATA in the generic vmlinux.lds linker script definitions. - kcov instrumentation support. A prerequisite for that is the inline assembly basic block cleanup, which is the reason for the net/iucv/iucv.c change. - support for 2GB pages is added to the hugetlbfs backend. Then there are two removals: - the oprofile hardware sampling support is dead code and is removed. The oprofile user space uses the perf interface nowadays. - the ETR clock synchronization is removed, this has been superseeded be the STP clock synchronization. And it always has been "interesting" code.. And the usual bug fixes and cleanups" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/s390/linux: (82 commits) s390/pci: Delete an unnecessary check before the function call "pci_dev_put" s390/smp: clean up a condition s390/cio/chp : Remove deprecated create_singlethread_workqueue s390/chsc: improve channel path descriptor determination s390/chsc: sanitize fmt check for chp_desc determination s390/cio: make fmt1 channel path descriptor optional s390/chsc: fix ioctl CHSC_INFO_CU command s390/cio/device_ops: fix kernel doc s390/cio: allow to reset channel measurement block s390/console: Make preferred console handling more consistent s390/mm: fix gmap tlb flush issues s390/mm: add support for 2GB hugepages s390: have unique symbol for __switch_to address s390/cpuinfo: show maximum thread id s390/ptrace: clarify bits in the per_struct s390: stack address vs thread_info s390: remove pointless load within __switch_to s390: enable kcov support s390/cpumf: use basic block for ecctr inline assembly s390/hypfs: use basic block for diag inline assembly ...
2016-07-25Merge branch 'timers-core-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip Pull timer updates from Thomas Gleixner: "This update provides the following changes: - The rework of the timer wheel which addresses the shortcomings of the current wheel (cascading, slow search for next expiring timer, etc). That's the first major change of the wheel in almost 20 years since Finn implemted it. - A large overhaul of the clocksource drivers init functions to consolidate the Device Tree initialization - Some more Y2038 updates - A capability fix for timerfd - Yet another clock chip driver - The usual pile of updates, comment improvements all over the place" * 'timers-core-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/tip: (130 commits) tick/nohz: Optimize nohz idle enter clockevents: Make clockevents_subsys static clocksource/drivers/time-armada-370-xp: Fix return value check timers: Implement optimization for same expiry time in mod_timer() timers: Split out index calculation timers: Only wake softirq if necessary timers: Forward the wheel clock whenever possible timers/nohz: Remove pointless tick_nohz_kick_tick() function timers: Optimize collect_expired_timers() for NOHZ timers: Move __run_timers() function timers: Remove set_timer_slack() leftovers timers: Switch to a non-cascading wheel timers: Reduce the CPU index space to 256k timers: Give a few structs and members proper names hlist: Add hlist_is_singular_node() helper signals: Use hrtimer for sigtimedwait() timers: Remove the deprecated mod_timer_pinned() API timers, net/ipv4/inet: Initialize connection request timers as pinned timers, drivers/tty/mips_ejtag: Initialize the poll timer as pinned timers, drivers/tty/metag_da: Initialize the poll timer as pinned ...
2016-07-25PCI: Allow additional bus numbers for hotplug bridgesKeith Busch
A user may hot add a switch requiring more than one bus to enumerate. This previously required a system reboot if BIOS did not sufficiently pad the bus resource, which they frequently don't do. Add a kernel parameter so a user can specify the minimum number of bus numbers to reserve for a hotplug bridge's subordinate buses so rebooting won't be necessary. The default is 1, which is equivalent to previous behavior. Signed-off-by: Keith Busch <keith.busch@intel.com> Signed-off-by: Bjorn Helgaas <bhelgaas@google.com>
2016-07-25Merge branches 'acpi-processor', 'acpi-cppc', 'acpi-apei' and 'acpi-sleep'Rafael J. Wysocki
* acpi-processor: ACPI: enable ACPI_PROCESSOR_IDLE on ARM64 arm64: add support for ACPI Low Power Idle(LPI) drivers: firmware: psci: initialise idle states using ACPI LPI cpuidle: introduce CPU_PM_CPU_IDLE_ENTER macro for ARM{32, 64} arm64: cpuidle: drop __init section marker to arm_cpuidle_init ACPI / processor_idle: Add support for Low Power Idle(LPI) states ACPI / processor_idle: introduce ACPI_PROCESSOR_CSTATE * acpi-cppc: mailbox: pcc: Add PCC request and free channel declarations ACPI / CPPC: Prevent cpc_desc_ptr points to the invalid data ACPI: CPPC: Return error if _CPC is invalid on a CPU * acpi-apei: ACPI / APEI: Add Boot Error Record Table (BERT) support ACPI / einj: Make error paths more talkative ACPI / einj: Convert EINJ_PFX to proper pr_fmt * acpi-sleep: ACPI: Execute _PTS before system reboot
2016-07-17powerpc/mm/radix: Add a kernel command line to disable radixAneesh Kumar K.V
This patch adds the kernel command line disable_radix which disable the radix MMU mode even if firmware indicates radix support via ibm,pa-features device tree node. This helps in testing different MMU mode easily. Signed-off-by: Aneesh Kumar K.V <aneesh.kumar@linux.vnet.ibm.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2016-07-13SUNRPC: Add a server side per-connection limitTrond Myklebust
Allow the user to limit the number of requests serviced through a single connection, to help prevent faster clients from starving slower clients. Signed-off-by: Trond Myklebust <trond.myklebust@primarydata.com> Signed-off-by: J. Bruce Fields <bfields@redhat.com>
2016-07-10PM / hibernate: Image data protection during restorationRafael J. Wysocki
Make it possible to protect all pages holding image data during hibernate image restoration by setting them read-only (so as to catch attempts to write to those pages after image data have been stored in them). This adds overhead to image restoration code (it may cause large page mappings to be split as a result of page flags changes) and the errors it protects against should never happen in theory, so the feature is only active after passing hibernate=protect_image to the command line of the restore kernel. Also it only is built if CONFIG_DEBUG_RODATA is set. Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-07-08efi / ACPI: load SSTDs from EFI variablesOctavian Purdila
This patch allows SSDTs to be loaded from EFI variables. It works by specifying the EFI variable name containing the SSDT to be loaded. All variables with the same name (regardless of the vendor GUID) will be loaded. Note that we can't use acpi_install_table and we must rely on the dynamic ACPI table loading and bus re-scanning mechanisms. That is because I2C/SPI controllers are initialized earlier then the EFI subsystems and all I2C/SPI ACPI devices are enumerated when the I2C/SPI controllers are initialized. Signed-off-by: Octavian Purdila <octavian.purdila@intel.com> Reviewed-by: Matt Fleming <matt@codeblueprint.co.uk> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-07-05powerpc/mm: Add a parameter to disable 1TB segsOliver O'Halloran
This patch adds the kernel command line parameter "no_tb_segs" which forces the kernel to use 256MB rather than 1TB segments. Forcing the use of 256MB segments makes it considerably easier to test code that depends on an SLB miss occurring. Suggested-by: Michael Neuling <mikey@neuling.org> Suggested-by: Michael Ellerman <mpe@ellerman.id.au> Signed-off-by: Oliver O'Halloran <oohall@gmail.com> Signed-off-by: Michael Ellerman <mpe@ellerman.id.au>
2016-06-29ACPI / APEI: Add Boot Error Record Table (BERT) supportHuang Ying
ACPI/APEI is designed to verifiy/report H/W errors, like Corrected Error(CE) and Uncorrected Error(UC). It contains four tables: HEST, ERST, EINJ and BERT. The first three tables have been merged for a long time, but because of lacking BIOS support for BERT, the support for BERT is pending until now. Recently on ARM 64 platform it is has been supported. So here we come. Under normal circumstances, when a hardware error occurs, kernel will be notified via NMI, MCE or some other method, then kernel will process the error condition, report it, and recover it if possible. But sometime, the situation is so bad, so that firmware may choose to reset directly without notifying Linux kernel. Linux kernel can use the Boot Error Record Table (BERT) to get the un-notified hardware errors that occurred in a previous boot. In this patch, the error information is reported via printk. For more information about BERT, please refer to ACPI Specification version 6.0, section 18.3.1: http://www.uefi.org/sites/default/files/resources/ACPI_6.0.pdf The following log is a BERT record after system reboot because of hitting a fatal memory error: BERT: Error records from previous boot: [Hardware Error]: It has been corrected by h/w and requires no further action [Hardware Error]: event severity: corrected [Hardware Error]: Error 0, type: recoverable [Hardware Error]: section_type: memory error [Hardware Error]: error_status: 0x0000000000000400 [Hardware Error]: physical_address: 0xffffffffffffffff [Hardware Error]: card: 1 module: 2 bank: 3 row: 1 column: 2 bit_position: 5 [Hardware Error]: error_type: 2, single-bit ECC [Tomasz Nowicki: Clear error status at the end of error handling] [Tony: Applied some cleanups suggested by Fu Wei] [Fu Wei: delete EXPORT_SYMBOL_GPL(bert_disable), improve the code] Signed-off-by: Huang Ying <ying.huang@intel.com> Signed-off-by: Tomasz Nowicki <tomasz.nowicki@linaro.org> Signed-off-by: Chen, Gong <gong.chen@linux.intel.com> Tested-by: Jonathan (Zhixiong) Zhang <zjzhang@codeaurora.org> Signed-off-by: Fu Wei <fu.wei@linaro.org> Tested-by: Tyler Baicar <tbaicar@codeaurora.org> Reviewed-by: Borislav Petkov <bp@suse.de> Signed-off-by: Tony Luck <tony.luck@intel.com> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2016-06-28clocksource/drivers/arm_arch_timer: Control the evtstrm via the cmdlineWill Deacon
Disabling the eventstream can be useful for both remotely debugging a deployed production system and development of code using WFE-based polling loops. Whilst this can currently be controlled via a Kconfig option (CONFIG_ARM_ARCH_TIMER_EVTSTREAM), it's often desirable to toggle the feature on the command line, so this patch adds a new command-line option ("clocksource.arm_arch_timer.evtstrm") to do just that. The default behaviour is determined based on CONFIG_ARM_ARCH_TIMER_EVTSTREAM. Cc: Marc Zyngier <marc.zyngier@arm.com> Cc: Mark Rutland <mark.rutland@arm.com> Signed-off-by: Will Deacon <will.deacon@arm.com> Signed-off-by: Daniel Lezcano <daniel.lezcano@linaro.org>
2016-06-28s390/oprofile: remove hardware sampler supportHeiko Carstens
Remove hardware sampler support from oprofile module. The oprofile user space utilty has been switched to use the kernel perf interface, for which we also provide hardware sampling support. In addition the hardware sampling support is also slightly broken: it supports only 16 bits for the pid and therefore would generate wrong results on machines which have a pid >64k. Also the pt_regs structure which was passed to oprofile common code cannot necessarily be used to generate sane backtraces, since the task(s) in question may run while the samples are fed to oprofile. So the result would be more or less random. However given that the only user space tools switched to the perf interface already four years ago the hardware sampler code seems to be unused code, and therefore it should be reasonable to remove it. The timer based oprofile support continues to work. Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Acked-by: Andreas Arnez <arnez@linux.vnet.ibm.com> Acked-by: Andreas Krebbel <krebbel@linux.vnet.ibm.com> Acked-by: Robert Richter <rric@kernel.org> Reviewed-by: Hendrik Brueckner <brueckner@linux.vnet.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2016-06-26x86/KASLR, x86/power: Remove x86 hibernation restrictionsKees Cook
With the following fix: 70595b479ce1 ("x86/power/64: Fix crash whan the hibernation code passes control to the image kernel") ... there is no longer a problem with hibernation resuming a KASLR-booted kernel image, so remove the restriction. Signed-off-by: Kees Cook <keescook@chromium.org> Cc: Andy Lutomirski <luto@kernel.org> Cc: Baoquan He <bhe@redhat.com> Cc: Borislav Petkov <bp@alien8.de> Cc: Brian Gerst <brgerst@gmail.com> Cc: Denys Vlasenko <dvlasenk@redhat.com> Cc: H. Peter Anvin <hpa@zytor.com> Cc: Jonathan Corbet <corbet@lwn.net> Cc: Len Brown <len.brown@intel.com> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Linux PM list <linux-pm@vger.kernel.org> Cc: Logan Gunthorpe <logang@deltatee.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Peter Zijlstra <peterz@infradead.org> Cc: Stephen Smalley <sds@tycho.nsa.gov> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Yinghai Lu <yinghai@kernel.org> Cc: linux-doc@vger.kernel.org Link: http://lkml.kernel.org/r/20160613221002.GA29719@www.outflux.net Signed-off-by: Ingo Molnar <mingo@kernel.org>
