path: root/Documentation/laptops
2014-02-10Documentation/: update 00-INDEX filesHenrik Austad
Some of the 00-INDEX files are somewhat outdated and some folders does not contain 00-INDEX at all. Only outdated (with the notably exception of spi) indexes are touched here, the 169 folders without 00-INDEX has not been touched. New 00-INDEX - spi/* was added in a series of commits dating back to 2006 Added files (missing in (*/)00-INDEX) - dmatest.txt was added by commit 851b7e16a07d ("dmatest: run test via debugfs") - this_cpu_ops.txt was added by commit a1b2a555d637 ("percpu: add documentation on this_cpu operations") - ww-mutex-design.txt was added by commit 040a0a371005 ("mutex: Add support for wound/wait style locks") - bcache.txt was added by commit cafe56359144 ("bcache: A block layer cache") - kernel-per-CPU-kthreads.txt was added by commit 49717cb40410 ("kthread: Document ways of reducing OS jitter due to per-CPU kthreads") - phy.txt was added by commit ff764963479a ("drivers: phy: add generic PHY framework") - block/null_blk was added by commit 12f8f4fc0314 ("null_blk: documentation") - module-signing.txt was added by commit 3cafea307642 ("Add Documentation/module-signing.txt file") - assoc_array.txt was added by commit 3cb989501c26 ("Add a generic associative array implementation.") - arm/IXP4xx was part of the initial repo - arm/cluster-pm-race-avoidance.txt was added by commit 7fe31d28e839 ("ARM: mcpm: introduce helpers for platform coherency exit/setup") - arm/firmware.txt was added by commit 7366b92a77fc ("ARM: Add interface for registering and calling firmware-specific operations") - arm/kernel_mode_neon.txt was added by commit 2afd0a05241d ("ARM: 7825/1: document the use of NEON in kernel mode") - arm/tcm.txt was added by commit bc581770cfdd ("ARM: 5580/2: ARM TCM (Tightly-Coupled Memory) support v3") - arm/vlocks.txt was added by commit 9762f12d3e05 ("ARM: mcpm: Add baremetal voting mutexes") - blackfin/gptimers-example.c, Makefile was added by commit 4b60779d5ea7 ("Blackfin: add an example showing how to use the gptimers API") - devicetree/usage-model.txt was added by commit 31134efc681a ("dt: Linux DT usage model documentation") - fb/api.txt was added by commit fb21c2f42879 ("fbdev: Add FOURCC-based format configuration API") - fb/sm501.txt was added by commit e6a049807105 ("video, sm501: add edid and commandline support") - fb/udlfb.txt was added by commit 96f8d864afd6 ("fbdev: move udlfb out of staging.") - filesystems/Makefile was added by commit 1e0051ae48a2 ("Documentation/fs/: split txt and source files") - filesystems/nfs/nfsd-admin-interfaces.txt was added by commit 8a4c6e19cfed ("nfsd: document kernel interfaces for nfsd configuration") - ide/warm-plug-howto.txt was added by commit f74c91413ec6 ("ide: add warm-plug support for IDE devices (take 2)") - laptops/Makefile was added by commit d49129accc21 ("Documentation/laptop/: split txt and source files") - leds/leds-blinkm.txt was added by commit b54cf35a7f65 ("LEDS: add BlinkM RGB LED driver, documentation and update MAINTAINERS") - leds/ledtrig-oneshot.txt was added by commit 5e417281cde2 ("leds: add oneshot trigger") - leds/ledtrig-transient.txt was added by commit 44e1e9f8e705 ("leds: add new transient trigger for one shot timer activation") - m68k/README.buddha was part of the initial repo - networking/LICENSE.(qla3xxx|qlcnic|qlge) was added by commits 40839129f779, c4e84bde1d59, 5a4faa873782 - networking/Makefile was added by commit 3794f3e812ef ("docsrc: build Documentation/ sources") - networking/i40evf.txt was added by commit 105bf2fe6b32 ("i40evf: add driver to kernel build system") - networking/ipsec.txt was added by commit b3c6efbc36e2 ("xfrm: Add file to document IPsec corner case") - networking/mac80211-auth-assoc-deauth.txt was added by commit 3cd7920a2be8 ("mac80211: add auth/assoc/deauth flow diagram") - networking/netlink_mmap.txt was added by commit 5683264c3981 ("netlink: add documentation for memory mapped I/O") - networking/nf_conntrack-sysctl.txt was added by commit c9f9e0e1597f ("netfilter: doc: add nf_conntrack sysctl api documentation") lan) - networking/team.txt was added by commit 3d249d4ca7d0 ("net: introduce ethernet teaming device") - networking/vxlan.txt was added by commit d342894c5d2f ("vxlan: virtual extensible lan") - power/runtime_pm.txt was added by commit 5e928f77a09a ("PM: Introduce core framework for run-time PM of I/O devices (rev. 17)") - power/charger-manager.txt was added by commit 3bb3dbbd56ea ("power_supply: Add initial Charger-Manager driver") - RCU/lockdep-splat.txt was added by commit d7bd2d68aa2e ("rcu: Document interpretation of RCU-lockdep splats") - s390/kvm.txt was added by 5ecee4b (KVM: s390: API documentation) - s390/qeth.txt was added by commit b4d72c08b358 ("qeth: bridgeport support - basic control") - scheduler/sched-bwc.txt was added by commit 88ebc08ea9f7 ("sched: Add documentation for bandwidth control") - scsi/advansys.txt was added by commit 4bd6d7f35661 ("[SCSI] advansys: Move documentation to Documentation/scsi") - scsi/bfa.txt was added by commit 1ec90174bdb4 ("[SCSI] bfa: add readme file") - scsi/bnx2fc.txt was added by commit 12b8fc10eaf4 ("[SCSI] bnx2fc: Add driver documentation") - scsi/cxgb3i.txt was added by commit c3673464ebc0 ("[SCSI] cxgb3i: Add cxgb3i iSCSI driver.") - scsi/hpsa.txt was added by commit 992ebcf14f3c ("[SCSI] hpsa: Add hpsa.txt to Documentation/scsi") - scsi/link_power_management_policy.txt was added by commit ca77329fb713 ("[libata] Link power management infrastructure") - scsi/osd.txt was added by commit 78e0c621deca ("[SCSI] osd: Documentation for OSD library") - scsi/scsi-parameter.txt was created/moved by commit 163475fb111c ("Documentation: move SCSI parameters to their own text file") - serial/driver was part of the initial repo - serial/n_gsm.txt was added by commit 323e84122ec6 ("n_gsm: add a documentation") - timers/Makefile was added by commit 3794f3e812ef ("docsrc: build Documentation/ sources") - virt/kvm/s390.txt was added by commit d9101fca3d57 ("KVM: s390: diagnose call documentation") - vm/split_page_table_lock was added by commit 49076ec2ccaf ("mm: dynamically allocate page->ptl if it cannot be embedded to struct page") - w1/slaves/w1_ds28e04 was added by commit fbf7f7b4e2ae ("w1: Add 1-wire slave device driver for DS28E04-100") - w1/masters/omap-hdq was added by commit e0a29382c6f5 ("hdq: documentation for OMAP HDQ") - x86/early-microcode.txt was added by commit 0d91ea86a895 ("x86, doc: Documentation for early microcode loading") - x86/earlyprintk.txt was added by commit a1aade478862 ("x86/doc: mini-howto for using earlyprintk=dbgp") - x86/entry_64.txt was added by commit 8b4777a4b50c ("x86-64: Document some of entry_64.S") - x86/pat.txt was added by commit d27554d874c7 ("x86: PAT documentation") Moved files - arm/kernel_user_helpers.txt was moved out of arch/arm/kernel by commit 37b8304642c7 ("ARM: kuser: move interface documentation out of the source code") - efi-stub.txt was moved out of x86/ and down into Documentation/ in commit 4172fe2f8a47 ("EFI stub documentation updates") - laptops/hpfall.c was moved out of hwmon/ and into laptops/ in commit efcfed9bad88 ("Move hp_accel to drivers/platform/x86") - commit 5616c23ad9cd ("x86: doc: move x86-generic documentation from Doc/x86/i386"): * x86/usb-legacy-support.txt * x86/boot.txt * x86/zero_page.txt - power/video_extension.txt was moved to acpi in commit 70e66e4df191 ("ACPI / video: move video_extension.txt to Documentation/acpi") Removed files (left in 00-INDEX) - memory.txt was removed by commit 00ea8990aadf ("memory.txt: remove stray information") - gpio.txt was moved to gpio/ in commit fd8e198cfcaa ("Documentation: gpiolib: document new interface") - networking/DLINK.txt was removed by commit 168e06ae26dd ("drivers/net: delete old parallel port de600/de620 drivers") - serial/hayes-esp.txt was removed by commit f53a2ade0bb9 ("tty: esp: remove broken driver") - s390/TAPE was removed by commit 9e280f669308 ("[S390] remove tape block docu") - vm/locking was removed by commit 57ea8171d2bc ("mm: documentation: remove hopelessly out-of-date locking doc") - laptops/acer-wmi.txt was remvoed by commit 020036678e81 ("acer-wmi: Delete out-of-date documentation") Typos/misc issues - rpc-server-gss.txt was added as knfsd-rpcgss.txt in commit 030d794bf498 ("SUNRPC: Use gssproxy upcall for server RPCGSS authentication.") - commit b88cf73d9278 ("net: add missing entries to Documentation/networking/00-INDEX") * generic-hdlc.txt was added as generic_hdlc.txt * spider_net.txt was added as spider-net.txt - w1/master/mxc-w1 was added as mxc_w1 by commit a5fd9139f74c ("w1: add 1-wire master driver for i.MX27 / i.MX31") - s390/zfcpdump.txt was added as zfcpdump by commit 6920c12a407e ("[S390] Add Documentation/s390/00-INDEX.") Signed-off-by: Henrik Austad <henrik@austad.us> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> [rcu bits] Acked-by: Rob Landley <rob@landley.net> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <robh+dt@kernel.org> Cc: David S. Miller <davem@davemloft.net> Cc: Mark Brown <broonie@kernel.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Gleb Natapov <gleb@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Len Brown <len.brown@intel.com> Cc: James Bottomley <JBottomley@parallels.com> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-02Documentation: Fix size parameter for snprintfStefan Weil
cppcheck reports this error: Documentation/laptops/hpfall.c:33]: (error) Dangerous usage of 'devname' (strncpy doesn't always 0-terminate it) The terminating '\0' is needed for the global char array unload_heads_path, so never write the last array entry (which is initially '\0'). Signed-off-by: Stefan Weil <sw@weilnetz.de> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-10-17thinkpad-acpi: Add mute and mic-mute LED functionalityDavid Henningsson
The LEDs are currently not visible to userspace, for security reasons. They are exported through thinkpad_acpi.h for use by the snd-hda-intel driver. Thanks to Alex Hung <alex.hung@canonical.com> and Takashi Iwai <tiwai@suse.de> for writing parts of this patch. Signed-off-by: David Henningsson <david.henningsson@canonical.com> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Takashi Iwai <tiwai@suse.de>
2013-07-15platform / thinkpad: Remove deprecated hotkey_report_mode parameterThomas Renninger
It is somewhat strange that the default value to support the depracated interface is set (1). Anyway this has existed for years. The previous patch already removed the functionality to still export events through /proc. Now this param is useless and should vanish too. Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: Matthew Garrett <matthew.garrett@nebula.com> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-07-15ACPI: Remove the old /proc/acpi/event interfaceThomas Renninger
It is quite some time that this one has been deprecated. Get rid of it. Should some really important user be overseen, it may be reverted and the userspace program worked on first, but it is time to do something to get rid of this old stuff... Signed-off-by: Thomas Renninger <trenn@suse.de> Acked-by: Matthew Garrett <matthew.garrett@nebula.com> Acked-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Rafael J. Wysocki <rafael.j.wysocki@intel.com>
2013-05-28doc: fix misspellings with 'codespell' toolAnatol Pomozov
Signed-off-by: Anatol Pomozov <anatol.pomozov@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2013-01-21Documentation/laptops: remove depends on CONFIG_EXPERIMENTALKees Cook
The CONFIG_EXPERIMENTAL config item has not carried much meaning for a while now and is almost always enabled by default. As agreed during the Linux kernel summit, remove it from any "depends on" lines in Kconfigs. CC: Rob Landley <rob@landley.net> CC: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Kees Cook <keescook@chromium.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-04Documentation: fix the VM knobs descritpion WRT pdflushArtem Bityutskiy
The pdflush thread is long gone, however we still mention it incorrectly in the kernel documentation. This patch fixes the situation. Cc: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Artem Bityutskiy <artem.bityutskiy@linux.intel.com> Signed-off-by: Al Viro <viro@zeniv.linux.org.uk>
2012-06-28Documentation: asus-laptop.txt references an obsolete Kconfig itemPaul Gortmaker
The CONFIG_X86_UP_APIC option no longer exists. Delete the reference of it. Cc: trivial@kernel.org Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2012-03-30Documentation: remove references to /etc/modprobe.confLucas De Marchi
Usage of /etc/modprobe.conf file was deprecated by module-init-tools and is no longer parsed by new kmod tool. References to this file are replaced in Documentation, comments and Kconfig according to the context. There are also some references to the old /etc/modules.conf from 2.4 kernels that are being removed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-03-20platform/x86: drop deprecated asus_acpi driverCorentin Chary
asus_acpi only support old models, it has been deprecated since 2009 in favor of asus-laptop, it's not built by any (sane) distro, so it is time to say good bye. Thanks to Julien Lerouge and Karol Kozimor for the work they have done on it, I would never have wrote asus-laptop and other asus related drivers without asus_acpi. Signed-off-by: Corentin Chary <corentin.chary@gmail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2012-03-20to fix scancodes returned by sony-laptop driverJohn Hughes
Fix scancodes returned by driver to match scancodes used to remap keys. (Before the patch FN/E returned scancode 0x1B, but to remap scancode 0x14 had to be used). The scancodes returned by the sony-laptop driver for function keys did not match the scancodes used to remap keys. Also, since the scancode was sent to the input subsystem after the mapped keysym the /lib/udev/keymap utility was confused about which scancode to report for which keysym. This patch fixes the driver so the correct scancode is shown for each key. It also adds to the documentation a description of where to find the scancodes. Signed-off-by: John Hughes <john@calva.com> Acked-by: Dmitry Torokhov <dtor@mail.ru> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-11-04Documentation: thinkpad-acpi grammo fixesKumar Appaiah
This adds minor grammatical fixes to the description of the keys in the thinkpad-acpi documentation. Signed-off-by: Kumar Appaiah <a.kumar@alumni.iitm.ac.in> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-09-27doc: fix broken referencesPaul Bolle
There are numerous broken references to Documentation files (in other Documentation files, in comments, etc.). These broken references are caused by typo's in the references, and by renames or removals of the Documentation files. Some broken references are simply odd. Fix these broken references, sometimes by dropping the irrelevant text they were part of. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-07-07thinkpad-acpi: handle HKEY 0x4010, 0x4011 eventsHenrique de Moraes Holschuh
Handle events 0x4010 and 0x4011 so that we do not pester users about them. These events report when the thinkpad is docked/undocked to a native hotplug dock (i.e. one that does not need ACPI handling, nor is represented in the ACPI device tree). Such docks are based on USB 2.0/3.0, and also work as port replicators. We really want a proper dock class to report these, or at least new input EV_SW events. Since it is not clear which one to use yet, keep reporting them as vendor-specific ThinkPad events. WARNING: As defined by the thinkpad-acpi sysfs ABI rules of engagement, the vendor-specific events will be REMOVED as soon as generic events are made available (duplicate events are a big problem), with an appropriate update to the thinkpad-acpi sysfs/event ABI versioning. Userspace is already prepared to provide easy backwards compatibility for such changes when convenient to the distro (see acpi-fakekey). * Event 0x4010: docking to hotplug dock/port replicator * Event 0x4011: undocking from hotplug dock/port replicator Typical usecase would be to trigger display reconfiguration. Reports mention T410, T510, and series 3 docks/port replicators. Special thanks to Robert de Rooy for his extensive report and analysis of the situation. http://www.thinkwiki.org/wiki/ThinkPad_Port_Replicator_Series_3 http://www.thinkwiki.org/wiki/ThinkPad_Mini_Dock_Series_3 http://www.thinkwiki.org/wiki/ThinkPad_Mini_Dock_Plus_Series_3 http://www.thinkwiki.org/wiki/ThinkPad_Mini_Dock_Plus_Series_3_for_Mobile_Workstations http://lenovoblogs.com/insidethebox/?p=290 Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: Matthew Garrett <mjg59@srcf.ucam.org> Reported-by: Claudius Hubig <claudiushubig@chubig.net> Reported-by: Doctor Bill <docbill@gmail.com> Reported-by: Korte Noack <gbk.noack@gmx.de> Reported-by: Robert de Rooy <robert.de.rooy@gmail.com> Reported-by: Sebastian Will <swill@csail.mit.edu> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-07-07thinkpad-acpi: handle some new HKEY 0x60xx eventsHenrique de Moraes Holschuh
Handle some user interface events from the newer Lenovo models. We are likely to do something smart with these events in the future, for now, hide the ones we are already certain about from the user and userspace both. * Events 0x6000 and 0x6005 are key-related. 0x6005 is not properly identified yet. Ignore these events, and do not report them. * Event 0x6040 has not been properly identified yet, and we don't know if it is important (looks like it isn't, but still...). Keep reporting it. * Change the message the driver outputs on unknown 0x6xxx events, as all recent events are not related to thermal alarms. Degrade log level from ALERT to WARNING. Thanks to all users who reported these events or asked about them in a number of mailing lists. Your help is highly appreciated, even if I did took a lot of time to act on them. For that I apologise. I will list those that identified the reasons for the events as "reported-by", and I apologise in advance if I leave anyone out: it was not done on purpose, I made the mistake of not properly tagging all event report emails separately, and might have missed some. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Reported-by: Markus Malkusch <markus@malkusch.de> Reported-by: Peter Giles <g1l3sp@gmail.com> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-05-27acer-wmi: Delete out-of-date documentationCarlos Corbacho
The documentation file for acer-wmi is long out of date, and there's not much point in keeping it around either. Signed-off-by: Carlos Corbacho <carlos@strangeworlds.co.uk> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-04-04Documentation: fix minor typos/spellingSylvestre Ledru
Fix some minor typos: * informations => information * there own => their own * these => this Signed-off-by: Sylvestre Ledru <sylvestre.ledru@scilab.org> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-28sony-laptop: documentation updatesMattia Dongili
Signed-off-by: Mattia Dongili <malattia@linux.it> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2011-03-21Move hp_accel to drivers/platform/x86Jean Delvare
The hp_accel driver isn't a hardware monitoring driver, so it doesn't belong to drivers/hwmon. Move it to drivers/platform/x86, assuming HP doesn't ship non-x86 laptops. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Eric Piel <eric.piel@tremplin-utc.net> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Tested-by: Eric Piel <eric.piel@tremplin-utc.net> Tested-by: Takashi Iwai <tiwai@suse.de>
2010-08-16thinkpad-acpi: untangle ACPI/vendor backlight selectionHenrique de Moraes Holschuh
acpi_video_backlight_support() already tells us if ACPI is handling backlight control through the generic ACPI handle. It is better to just trust it. While at it, adjust down a printk priority, and test earlier for brightness_enable=0. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Matthew Garrett <mjg@redhat.com>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-08-03X86 platform drivers: Remove EC dump from thinkpad_acpiThomas Renninger
There is a general interface for that now (provided by other patches in this patch series): /sys/kernel/debug/ec/*/io Signed-off-by: Thomas Renninger <trenn@suse.de> CC: Alexey Starikovskiy <astarikovskiy@suse.de> CC: Len Brown <lenb@kernel.org> CC: linux-kernel@vger.kernel.org CC: linux-acpi@vger.kernel.org CC: platform-driver-x86@vger.kernel.org CC: Henrique de Moraes Holschuh <hmh@hmh.eng.br> CC: ibm-acpi-devel@lists.sourceforge.net Signed-off-by: Matthew Garrett <mjg@redhat.com>
2010-05-21Merge branch 'for_linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86 * 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mjg59/platform-drivers-x86: (32 commits) Move N014, N051 and CR620 dmi information to load scm dmi table drivers/platform/x86/eeepc-wmi.c: fix build warning X86 platfrom wmi: Add debug facility to dump WMI data in a readable way X86 platform wmi: Also log GUID string when an event happens and debug is set X86 platform wmi: Introduce debug param to log all WMI events Clean up all objects used by scm model when driver initial fail or exit msi-laptop: fix up some coding style issues found by checkpatch msi-laptop: Add i8042 filter to sync sw state with BIOS when function key pressed msi-laptop: Set rfkill init state when msi-laptop intiial msi-laptop: Add MSI CR620 notebook dmi information to scm models table msi-laptop: Add N014 N051 dmi information to scm models table drivers/platform/x86: Use kmemdup drivers/platform/x86: Use kzalloc drivers/platform/x86: Clarify the MRST IPC driver description slightly eeepc-wmi: depends on BACKLIGHT_CLASS_DEVICE IPC driver for Intel Mobile Internet Device (MID) platforms classmate-laptop: Add RFKILL support. thinkpad-acpi: document backlight level writeback at driver init thinkpad-acpi: clean up ACPI handles handling thinkpad-acpi: don't depend on led_path for led firmware type (v2) ...
2010-05-16thinkpad-acpi: update HKEY and hotkey subdriver documentation (v2)Henrique de Moraes Holschuh
Update the hotkey driver documentation to match the behaviour of the fixed NVRAM polling code. This also documents some HKEY events such as the alarms, which is very important information. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br>
2010-04-23Documentation/: it's -> its where appropriateFrancis Galiegue
Fix obvious cases of "it's" being used when "its" was meant. Signed-off-by: Francis Galiegue <fgaliegue@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-12Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (56 commits) doc: fix typo in comment explaining rb_tree usage Remove fs/ntfs/ChangeLog doc: fix console doc typo doc: cpuset: Update the cpuset flag file Fix of spelling in arch/sparc/kernel/leon_kernel.c no longer needed Remove drivers/parport/ChangeLog Remove drivers/char/ChangeLog doc: typo - Table 1-2 should refer to "status", not "statm" tree-wide: fix typos "ass?o[sc]iac?te" -> "associate" in comments No need to patch AMD-provided drivers/gpu/drm/radeon/atombios.h devres/irq: Fix devm_irq_match comment Remove reference to kthread_create_on_cpu tree-wide: Assorted spelling fixes tree-wide: fix 'lenght' typo in comments and code drm/kms: fix spelling in error message doc: capitalization and other minor fixes in pnp doc devres: typo fix s/dev/devm/ Remove redundant trailing semicolons from macros fix typo "definetly" -> "definitely" in comment tree-wide: s/widht/width/g typo in comments ... Fix trivial conflict in Documentation/laptops/00-INDEX
2010-03-12Documentation/laptop/: split txt and source filesRandy Dunlap
Documentation/laptops/laptop-mode.txt: Expose example and tool source files in the Documentation/ directory in their own files instead of being buried (almost hidden) in readme/txt files. This should help to prevent bitrot. This will make them more visible/usable to users who may need to use them, to developers who may need to test with them, and to anyone who would fix/update them if they were more visible. Also, if any of these possibly should not be in the kernel tree at all, it will be clearer that they are here and we can discuss if they should be removed. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-02-25thinkpad-acpi: lock down video output state accessHenrique de Moraes Holschuh
Given the right combination of ThinkPad and X.org, just reading the video output control state is enough to hard-crash X.org. Until the day I somehow find out a model or BIOS cut date to not provide this feature to ThinkPads that can do video switching through X RandR, change permissions so that only processes with CAP_SYS_ADMIN can access any sort of video output control state. This bug could be considered a local DoS I suppose, as it allows any non-privledged local user to cause some versions of X.org to hard-crash some ThinkPads. Reported-by: Jidanni <jidanni@jidanni.org> Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: stable@kernel.org
2010-02-05doc: update 00-INDEX for Documentation/laptops/Thadeu Lima de Souza Cascardo
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-26thinkpad-acpi: update volume subdriver documentationHenrique de Moraes Holschuh
Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-16thinkpad-acpi: bump version to 0.24Henrique de Moraes Holschuh
2009-12-15thinkpad-acpi: basic ALSA mixer support (v2)Henrique de Moraes Holschuh
Add the basic ALSA mixer functionality. The mixer is event-driven, and will work fine on IBM ThinkPads. I expect Lenovo ThinkPads will cause some trouble with the event interface. Heavily based on work by Lorne Applebaum <lorne.applebaum@gmail.com> and ideas from Matthew Garrett <mjg@redhat.com>. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: Lorne Applebaum <lorne.applebaum@gmail.com> Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15thinkpad-acpi: disable volume controlHenrique de Moraes Holschuh
Disable volume control by default. It can be enabled at module load time by a module parameter (volume_control=1). The audio control mixer that thinkpad-acpi interacts with is fully functional without any drivers, and operated by hotkeys. The idea behind the console audio control is that the human operator is the only one that can interact with it. The ThinkVantage suite in Windows does not allow any software-based overrides, and only does OSD (on-screen-display) functions. The Linux driver will, with the addition of the ALSA interface, try to follow and enforce the ThinkVantage UI design: The user is supposed to use the keyboard hotkeys to interact with the console audio control. The kernel and the desktop environment is supposed to cooperate to provide proper user feedback through on-screen-display functions. Distros are urged to not to enable volume control by default. Enabling this must be a local admin's decision. This is the reason why there is no Kconfig option. Keep in mind that all ThinkPads have a normal, main mixer (AC97 or HDA) for regular software-based audio control. We are not talking about that mixer here. Advanced users are, of course, free to enable volume control and do as they please. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: Lorne Applebaum <lorne.applebaum@gmail.com> Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15thinkpad-acpi: support MUTE-only ThinkPadsHenrique de Moraes Holschuh
Lenovo removed the extra mixer since the T61 and thereabouts. Newer Lenovo models only have the mute gate function, and leave the volume control to the HDA mixer. Until a way to automatically query the firmware about its audio control capabilities is discovered (there might not be any), use a white/black list. We will likely need to ask T60 (old and new model) and Z60/Z61 users whether they have volume control to populate the black/white list. Meanwhile, provide a volume_capabilities parameter that can be used to override the defaults. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: Lorne Applebaum <lorne.applebaum@gmail.com> Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-15thinkpad-acpi: volume subdriver rewriteHenrique de Moraes Holschuh
I don't trust the coupled EC writes and SMI calls the current volume control code does very much, although it is exactly what the IBM DSDTs seem to do (they never do more than a single step though). Change the driver to stop issuing SMIs, and just drive the EC directly to the desired level (DSDTs seem to confirm this will work even on very old models like the 570 and 600e/x). We checkpoint directly to NVRAM (this can be turned off) at suspend/shutdown/driver unload, which from what I can see in tbp, should also work on every ThinkPad. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: Lorne Applebaum <lorne.applebaum@gmail.com> Cc: Matthew Garrett <mjg@redhat.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-12-09thinkpad-acpi: issue backlight class eventsHenrique de Moraes Holschuh
Take advantage of the new events capabilities of the backlight class to notify userspace of backlight changes. This depends on "backlight: Allow drivers to update the core, and generate events on changes", by Matthew Garrett. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Cc: Matthew Garrett <mjg@redhat.com> Cc: Richard Purdie <rpurdie@linux.intel.com> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-26Merge branch 'thinkpad-2.6.32-part2' into releaseLen Brown
2009-09-20thinkpad-acpi: hotkey event driver updateHenrique de Moraes Holschuh
Update the HKEY event driver to: 1. Handle better the second-gen firmware, which has no HKEY mask support but does report FN+F3, FN+F4 and FN+F12 without the need for NVRAM polling. a) always make the mask-related attributes available in sysfs; b) use DMI quirks to detect the second-gen firmware; c) properly report that FN+F3, FN+F4 and FN+F12 are enabled, and available even on mask-less second-gen firmware; 2. Decouple the issuing of hotkey events towards userspace from their reception from the firmware. ALSA mixer and brightness event reporting support will need this feature. 3. Clean up the mess in the hotkey driver a great deal. It is still very convoluted, and wants a full refactoring into a proper event API interface, but that is not going to happen today. 4. Fully reset firmware interface on resume (restore hotkey mask and status). 5. Stop losing polled events for no good reason when changing the mask and poll frequencies. We will still lose them when the hotkey_source_mask is changed, as well as any that happened between driver suspend and driver resume. The hotkey subdriver now has the notion of user-space-visible hotkey event mask, as well as of the set of "hotkey" events the driver needs (because brightness/volume change reports are not just keypress reports in most ThinkPad models). With this rewrite, the ABI level is bumped to 0x020500 should userspace need to know it is dealing with the updated hotkey subdriver. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-20thinkpad-acpi: drop HKEY event 0x5010Henrique de Moraes Holschuh
HKEY event 0x5010 is useless to us: old ThinkPads don't issue it. Newer ThinkPads won't issue it anymore. And all ThinkPads issue 0x1010 and 0x1011 events. Just silently drop it instead of sending it to userspace. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-19Merge branch 'asus' into releaseLen Brown
2009-09-19thinkpad-acpi: Fix procfs hotkey reset commandHenrique de Moraes Holschuh
echo "reset" > /proc/acpi/ibm/hotkey should do something non-useless, so instead of setting it to Fn+F2, Fn+F3, Fn+F5, set it to hotkey_recommended_mask. It is not like it will survive for much longer, anyway. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2009-09-19thinkpad-acpi: deprecate hotkey_bios_maskHenrique de Moraes Holschuh
Some analysis of the ACPI DSDTs shows that the HKEY pre-enabled mask is always 0x80c (FN+F3,FN+F4 and FN+F12), which are the hotkeys that the second gen of HKEY firmware supported (the first gen didn't report any hotkeys, the second reported these tree hotkeys but had no mask support, and the third added mask support). So, this is probably some sort of backwards compatibility with older versions of the IBM ThinkVantage suite. We have no use for that, and I know of exactly ZERO users of that attribute, anyway. Start the process of getting rid of it. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-28asus-laptop: document the moduleCorentin Chary
Signed-off-by: Corentin Chary <corentincj@iksaif.net> Signed-off-by: Len Brown <len.brown@intel.com>
2009-08-01thinkpad-acpi: remove dock and bay subdriversHenrique de Moraes Holschuh
The standard ACPI dock driver can handle the hotplug bays and docks of the ThinkPads just fine (including batteries) as of 2.6.27, and the code in thinkpad-acpi for the dock and bay subdrivers is currently broken anyway... Userspace needs some love to support the two-stage ejection nicely, but it is simple enough to do through udev rules (you don't even need HAL) so this wouldn't justify fixing the dock and bay subdrivers, either. That leaves warm-swap bays (_EJ3) support for thinkpad-acpi, as well as support for the weird dock of the model 570, but since such support has never left the "experimental" stage, it is also not a strong enough reason to find a way to fix this code. Users of ThinkPads with warm-swap bays are urged to request that _EJ3 support be added to the regular ACPI dock driver, if such feature is indeed useful for them. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-24Merge branches 'acerhdf', 'acpi-pci-bind', 'bjorn-pci-root', ↵Len Brown
'bugzilla-12904', 'bugzilla-13121', 'bugzilla-13396', 'bugzilla-13533', 'bugzilla-13612', 'c3_lock', 'hid-cleanups', 'misc-2.6.31', 'pdc-leak-fix', 'pnpacpi', 'power_nocheck', 'thinkpad_acpi', 'video' and 'wmi' into release
2009-06-18thinkpad-acpi: support the second fan on the X61Henrique de Moraes Holschuh
Support reading the tachometer of the auxiliary fan of a X60/X61. It was found out by sheer luck, that bit 0 of EC register 0x31 (formely HBRV) selects which fan is active for tachometer readings through EC 0x84/0x085: 0 for fan1, 1 for fan2. Many thanks to Christoph Kl??nter, to Whoopie, and to weasel, who helped confirm that behaviour. Fan control through EC HFSP applies to both fans equally, regardless of the state of bit 0 of EC 0x31. That matches the way the DSDT uses HFSP. In order to better support the secondary fan, export a second tachometer over hwmon, and add defensive measures to make sure we are reading the correct tachometer. Support for the second fan is whitelist-based, as I have not found anything obvious to look for in the DSDT to detect the presence of the second fan. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
2009-06-18thinkpad-acpi: forbid the use of HBRV on Lenovo ThinkPadsHenrique de Moraes Holschuh
Forcing thinkpad-acpi to do EC-based brightness control (HBRV) on a X61 has very... interesting effects, instead of doing nothing (since it doesn't have EC-based backlight control), it causes "weirdness" in the fan tachometer readings, for example. This means the EC register that used to be HBRV has been reused by Lenovo for something else, but they didn't remove it from the DSDT. Make sure the documentation reflects this data, and forbid the user from forcing the driver to access HBRV on Lenovo ThinkPads. Signed-off-by: Henrique de Moraes Holschuh <hmh@hmh.eng.br> Signed-off-by: Len Brown <len.brown@intel.com>
