All those files are under GFDL 1.1 or later, with no invariant sections.
Tag them as such.
Signed-off-by: Mauro Carvalho Chehab <mchehab+samsung@kernel.org>
This is not needed there. Also, the same UTF-8 encoding should
be used on all documents.
The previous patch renamed several files that are cross-referenced
along the Kernel documentation. Adjust the links to point to
the right places.
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
Shorten the tables by removing row numbers in comments, allowing for
later insertion of rows with minimal diffs.
All changes have been generated by the following script.
import io
import re
import sys
def process_table(fname, data):
if fname.endswith('hist-v4l2.rst'):
data = re.sub(u'\n{1,2}\t( ?) -( ?) ?', u'\n\t\\1 -\\2', data, flags = re.MULTILINE)
data = re.sub(u'\n(\t| )- \.\. row [0-9]+\n\t ?-( ?) ?', u'\\1* -\\2', data, flags = re.MULTILINE)
else:
data = re.sub(u'\n{1,2} -( ?) ?', u'\n -\\1', data, flags = re.MULTILINE)
data = re.sub(u'(\n?)(\n\n - \.\. row 1\n)', u'\n\\2', data, flags = re.MULTILINE)
data = re.sub(u'\n - \.\. row [0-9]+\n -( ?) ?', u' * -\\1', data, flags = re.MULTILINE)
data = re.sub(u'\n - \.\. row [0-9]+\n \.\. (_[A-Z0-9_`-]*:)', u'\n - .. \\1', data, flags = re.MULTILINE)
data = re.sub(u'\n - \.\. (_[A-Z0-9_`-]*:)\n -', u' * .. \\1\n\n -', data, flags = re.MULTILINE)
data = re.sub(u'^ - ', u' -', data, flags = re.MULTILINE)
data = re.sub(u'^(\t{1,2}) ', u'\\1', data, flags = re.MULTILINE)
return data
def process_file(fname, data):
buf = io.StringIO(data)
output = ''
in_table = False
table_separator = 0
for line in buf.readlines():
if line.find('.. flat-table::') != -1:
in_table = True
table = ''
elif in_table and not re.match('^[\t\n]|( )', line):
in_table = False
output += process_table(fname, table)
if in_table:
table += line
else:
output += line
if in_table:
in_table = False
return output
fname = sys.argv[1]
data = file(fname, 'rb').read().decode('utf-8')
data = process_file(fname, data)
file(fname, 'wb').write(data.encode('utf-8'))
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
The V4L version 1 structures had long gone from the Linux Kernel.
It doesn't make sense to use cross-references for them, as they
won't be found.
So, get rid of them.
instead of declaring the uAPI structs using usual refs, e. g.:
.. _foo-struct:
Use the C domain way:
.. c:type:: foo_struct
This way, the kAPI documentation can use cross-references to
point to the uAPI symbols.
That solves about ~100 undefined warnings like:
WARNING: c:type reference target not found: foo_struct
This table has several troubles:
- a duplicated "struct" on its name;
- a reference to a V4L version 1 struct that will never
point to something (as we got rid of V4L1 API a long
time ago);
- misses hints for LaTeX output (column size and longtable
style).
Fix them.
It should be noticed that the first column of this table is
not aligned with the rest. I suspect that this is a bug at
the flat-table extension.
According with ReST spec, footnotes should be like:
[#name], and not [name]. So, change them.
The name of the subsystem is "media", and not "linux_tv". Also,
as we plan to add other stuff there in the future, let's
rename also the media uAPI book to media_uapi, to make it
clearer.
No functional changes.
