path: root/Documentation/misc-devices
2011-03-22ST SPEAr: PCIE gadget suppportPratyush Anand
This is a configurable gadget. can be configured by configfs interface. Any IP available at PCIE bus can be programmed to be used by host controller.It supoorts both INTX and MSI. By default, the gadget is configured for INTX and SYSRAM1 is mapped to BAR0 with size 0x1000 Signed-off-by: Pratyush Anand <pratyush.anand@st.com> Cc: Randy Dunlap <randy.dunlap@oracle.com> Cc: Jesse Barnes <jbarnes@virtuousgeek.org> Cc: Viresh Kumar <viresh.kumar@st.com> Cc: Shiraz Hashim <shiraz.hashim@st.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-21Move lis3lv02d drivers to drivers/miscJean Delvare
The lis3lv02d drivers aren't hardware monitoring drivers, so the don't belong to drivers/hwmon. Move them to drivers/misc, short of a better home. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Guenter Roeck <guenter.roeck@ericsson.com> Acked-by: Eric Piel <eric.piel@tremplin-utc.net> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Tested-by: Eric Piel <eric.piel@tremplin-utc.net> Tested-by: Takashi Iwai <tiwai@suse.de>
2010-10-26Documentation: short descriptions for bh1770glc and apds990x driversSamu Onkalo
Add short documentation for two ALS / proximity chip drivers. Signed-off-by: Samu Onkalo <samu.p.onkalo@nokia.com> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-15ad525x_dpot: new driver for AD525x digital potentiometersMichael Hennerich
This driver supports the non-volatile digital potentiometers via I2C: AD5258, AD5259, AD5251, AD5252, AD5253, AD5254, and AD5255 It provides a sysfs interface to each device for reading/writing which is documented in Documentation/misc-devices/ad525x_dpot.txt. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Chris Verges <chrisv@cyberswitching.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-09Doc: use misc-devices/ dir for driversJean Delvare
We have a directory for misc drivers documentation, let's use it. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: "Darrick J. Wong" <djwong@us.ibm.com> Cc: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-10-04max6875: Discard obsolete detect methodJean Delvare
There is no point in implementing a detect callback for the MAX6875, as this device can't be detected. It was there solely to handle "force" module parameters to instantiate devices, but now we have a better sysfs interface that can do the same. So we can get rid of the ugly module parameters and the detect callback. This basically divides the binary module size by 2. Signed-off-by: Jean Delvare <khali@linux-fr.org> Acked-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Ben Gardner <gardner.ben@gmail.com>
2009-10-04i2c: Move misc devices documentationJean Delvare
Some times ago the eeprom and max6875 drivers moved to drivers/misc/eeprom, but their documentation did not follow. It's finally time to get rid of Documentation/i2c/chips. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Ben Gardner <gardner.ben@gmail.com> Acked-by: Wolfram Sang <w.sang@pengutronix.de>
2009-04-01drivers/misc/isl29003.c: driver for the ISL29003 ambient light sensorDaniel Mack
Add a driver for Intersil's ISL29003 ambient light sensor device plus some documentation. Inspired by tsl2550.c, a driver for a similar device. It is put in drivers/misc for now until the industrial I/O framework gets merged. Signed-off-by: Daniel Mack <daniel@caiaq.de> Acked-by: Jonathan Cameron <jic23@cam.ac.uk> Cc: Jean Delvare <khali@linux-fr.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
