path: root/Documentation/networking/bonding.txt
2011-08-07bonding: document two undocumented options.Nicolas de Pesloüan
Commit 655f8919d549ad1872e24d826b6ce42530516d2e bonding: add min links parameter to 802.3ad and commit ebd8e4977a87cb81d93c62a9bff0102a9713722f bonding: add all_slaves_active parameter introduced new options to bonding, but didn't provide the documentation for those options. V2: add the default value for both options. V3: document the exact behavior of min_links default value. Signed-off-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-08-01Documentation/bonding.txt: Update to 3.x version numbersJesper Juhl
Signed-off-by: Jesper Juhl <jj@chaosbits.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-05-25bonding: documentation and code cleanup for resend_igmpFlavio Leitner
Improves the documentation about how IGMP resend parameter works, fix two missing checks and coding style issues. Signed-off-by: Flavio Leitner <fbl@redhat.com> Acked-by: Rick Jones <rick.jones2@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-04-29ipv4, ipv6, bonding: Restore control over number of peer notificationsBen Hutchings
For backward compatibility, we should retain the module parameters and sysfs attributes to control the number of peer notifications (gratuitous ARPs and unsolicited NAs) sent after bonding failover. Also, it is possible for failover to take place even though the new active slave does not have link up, and in that case the peer notification should be deferred until it does. Change ipv4 and ipv6 so they do not automatically send peer notifications on bonding failover. Change the bonding driver to send separate NETDEV_NOTIFY_PEERS notifications when the link is up, as many times as requested. Since it does not directly control which protocols send notifications, make num_grat_arp and num_unsol_na aliases for a single parameter. Bump the bonding version number and update its documentation. Signed-off-by: Ben Hutchings <bhutchings@solarflare.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Acked-by: Brian Haley <brian.haley@hp.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-03-14bonding: documentation update: mailing lists.Nicolas de Pesloüan
In commit a6c36ee677607b02d8ecc88e8a12785418b88107 ("bonding: change list contact to netdev@vger.kernel.org"), the mailing list for bonding developpement was changed from bonding-devel to netdev. Update the bonding documentation to reflect this change: - bonding-devel is used for usage discussions (despite the name). - netdev is used for developpement discussions. Also remove the reference to the sourceforge bonding page, which is deprecated. Signed-off-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2011-01-25bonding: update documentation - alternate configuration.Nicolas de Pesloüan
The bonding documentation used to provide configuration details and examples for initscripts and sysconfig only. This patch describe the third possible configuration: /etc/network/interfaces. Signed-off-by: Nicolas de Pesloüan <nicolas.2p.debian@free.fr> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-10-05bonding: add retransmit membership reports tunableFlavio Leitner
Allow sysadmins to configure the number of multicast membership report sent on a link failure event. Signed-off-by: Flavio Leitner <fleitner@redhat.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2010-08-04Merge branch 'for-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits) Documentation: update broken web addresses. fix comment typo "choosed" -> "chosen" hostap:hostap_hw.c Fix typo in comment Fix spelling contorller -> controller in comments Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault fs/Kconfig: Fix typo Userpace -> Userspace Removing dead MACH_U300_BS26 drivers/infiniband: Remove unnecessary casts of private_data fs/ocfs2: Remove unnecessary casts of private_data libfc: use ARRAY_SIZE scsi: bfa: use ARRAY_SIZE drm: i915: use ARRAY_SIZE drm: drm_edid: use ARRAY_SIZE synclink: use ARRAY_SIZE block: cciss: use ARRAY_SIZE comment typo fixes: charater => character fix comment typos concerning "challenge" arm: plat-spear: fix typo in kerneldoc reiserfs: typo comment fix update email address ...
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-06-05bonding: allow user-controlled output slave selectionAndy Gospodarek
v2: changed bonding module version, modified to apply on top of changes from previous patch in series, and updated documentation to elaborate on multiqueue awareness that now exists in bonding driver. This patch give the user the ability to control the output slave for round-robin and active-backup bonding. Similar functionality was discussed in the past, but Jay Vosburgh indicated he would rather see a feature like this added to existing modes rather than creating a completely new mode. Jay's thoughts as well as Neil's input surrounding some of the issues with the first implementation pushed us toward a design that relied on the queue_mapping rather than skb marks. Round-robin and active-backup modes were chosen as the first users of this slave selection as they seemed like the most logical choices when considering a multi-switch environment. Round-robin mode works without any modification, but active-backup does require inclusion of the first patch in this series and setting the 'all_slaves_active' flag. This will allow reception of unicast traffic on any of the backup interfaces. This was tested with IPv4-based filters as well as VLAN-based filters with good results. More information as well as a configuration example is available in the patch to Documentation/networking/bonding.txt. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Neil Horman <nhorman@tuxdriver.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-10-07bonding: introduce primary_reselect optionJiri Pirko
In some cases there is not desirable to switch back to primary interface when it's link recovers and rather stay with currently active one. We need to avoid packetloss as much as we can in some cases. This is solved by introducing primary_reselect option. Note that enslaved primary slave is set as current active no matter what. Patch modified by Jay Vosburgh as follows: fixed bug in action after change of option setting via sysfs, revised the documentation update, and bumped the bonding version number. Signed-off-by: Jiri Pirko <jpirko@redhat.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2009-06-12trivial: Miscellaneous documentation typo fixesMatt LaPlante
Fix various typos in documentation txts. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-04-13Bonding: fix zero address hole bug in arp_ip_target listBrian Haley
Fix a zero address hole bug in the bonding arp_ip_target list that was causing the bond to ignore ARP replies (bugz 13006). Instead of just setting the array entry to zero, we now copy any additional entries down one slot, putting the zero entry at the end. With this change we can now have all the loops that walk the array stop when they hit a zero since there will be no addresses after it. Changes are based in part on code fragment provided in kernel: bugzilla 13006: http://bugzilla.kernel.org/show_bug.cgi?id=13006 by Steve Howard <steve@astutenetworks.com> Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-06bonding: alternate agg selection policies for 802.3adJay Vosburgh
This patch implements alternative aggregator selection policies for 802.3ad. The existing policy, now termed "stable," selects the active aggregator by greatest bandwidth, and only reselects a new aggregator if the active aggregator is entirely disabled (no more ports or all ports down). This patch adds two new policies: bandwidth and count, selecting the active aggregator by total bandwidth (like the stable policy) or by the number of ports in the aggregator, respectively. These two policies also differ from the stable policy in that they will reselect the active aggregator when availability-related changes occur in the bond (e.g., link state change). This permits "gang failover" within 802.3ad, allowing redundant aggregators along parallel paths to always maintain the "best" aggregator as the active aggregator (rather than having to wait for the active to entirely fail). This patch also updates the driver version to 3.5.0. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-11-06bonding: send IPv6 neighbor advertisement on failoverBrian Haley
This patch adds better IPv6 failover support for bonding devices, especially when in active-backup mode and there are only IPv6 addresses configured, as reported by Alex Sidorenko. - Creates a new file, net/drivers/bonding/bond_ipv6.c, for the IPv6-specific routines. Both regular bonds and VLANs over bonds are supported. - Adds a new tunable, num_unsol_na, to limit the number of unsolicited IPv6 Neighbor Advertisements that are sent on a failover event. Default is 1. - Creates two new IPv6 neighbor discovery functions: ndisc_build_skb() ndisc_send_skb() These were required to support VLANs since we have to be able to add the VLAN id to the skb since ndisc_send_na() and friends shouldn't be asked to do this. These two routines are basically __ndisc_send() split into two pieces, in a slightly different order. - Updates Documentation/networking/bonding.txt and bumps the rev of bond support to 3.4.0. On failover, this new code will generate one packet: - An unsolicited IPv6 Neighbor Advertisement, which helps the switch learn that the address has moved to the new slave. Testing has shown that sending just the NA results in pretty good behavior when in active-back mode, I saw no lost ping packets for example. Signed-off-by: Brian Haley <brian.haley@hp.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-11-02bonding: update docs to correctly reflect arp_ip_target behaviorAndy Gospodarek
This documentation patch hopes to clarify that the '+' was only needed for Fedora 7 and Red Hat Enterprise Linux 5.0 and 5.1. After that the IP addreses could be added as a comma separated list just like the module option. Signed-off-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-07-26Documentation cleanup: trivial misspelling, punctuation, and grammar ↵Matt LaPlante
corrections. Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-06-18bonding: Allow setting max_bonds to zeroJay Vosburgh
Permit bonding to function rationally if max_bonds is set to zero. This will load the module, but create no master devices (which can be created via sysfs). Requires some change to bond_create_sysfs; currently, the netdev sysfs directory is determined from the first bonding device created, but this is no longer possible. Instead, an interface from net/core is created to create and destroy files in net_class. Based on a patch submitted by Phil Oester <kernel@linuxaces.com>. Modified by Jay Vosburgh to fix the sysfs issue mentioned above and to update the documentation. Signed-off-by: Phil Oester <kernel@linuxace.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-06-18bonding: Rework / fix multiple gratuitous ARP supportJay Vosburgh
Support for sending multiple gratuitous ARPs during failovers was added by commit: commit 7893b2491a2d5f716540ac5643d78d37a7f6628b Author: Moni Shoua <monis@voltaire.com> Date: Sat May 17 21:10:12 2008 -0700 bonding: Send more than one gratuitous ARP when slave takes over This change modifies that support to remove duplicated code, add support for ARP monitor (the original only supported miimon), clear the grat ARP counter in bond_close (lest a later "ifconfig up" immediately start spewing ARPs), and add documentation for the module parameter. Also updated driver version to 3.3.0. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-05-22bonding: Add "follow" option to fail_over_macJay Vosburgh
Add a "follow" selection for fail_over_mac. This option causes the MAC address to move from slave to slave as the active slave changes. This is in addition to the existing fail_over_mac option that causes the bond's MAC address to change during failover. This new option is useful for devices that cannot tolerate multiple ports using the same MAC address simultaneously, either because it confuses them or incurs a performance penalty (as is the case with some LPAR-aware multiport devices). Because the MAC of the bond itself does not change, the "follow" option is slightly more reliable during failover and doesn't change the MAC of the bond during operation. This patch requires a previous ARP monitor change to properly handle RTNL during failovers. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2008-01-28[BONDING]: Documentation updateJay Vosburgh
Update the bonding documentation: more discussion on initialization and configuration, changes to discussion of packet reordering in balance-rr, update some out of date information. Based in part on input from Rick Jones <rick.jones2@hp.com> and Andy Gospodarek <andy@greyhouse.net>. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Acked-by: Andy Gospodarek <andy@greyhouse.net> Signed-off-by: David S. Miller <davem@davemloft.net>
2007-12-07bonding: Add new layer2+3 hash for xor/802.3ad modesJay Vosburgh
Add new hash for balance-xor and 802.3ad modes. Originally submitted by "Glenn Griffin" <ggriffin.kernel@gmail.com>; modified by Jay Vosburgh to move setting of hash policy out of line, tweak the documentation update and add version update to 3.2.2. Glenn's original comment follows: Included is a patch for a new xmit_hash_policy for the bonding driver that selects slaves based on MAC and IP information. This is a middle ground between what currently exists in the layer2 only policy and the layer3+4 policy. This policy strives to be fully 802.3ad compliant by transmitting every packet of any particular flow over the same link. As documented the layer3+4 policy is not fully compliant for extreme cases such as ip fragmentation, so this policy is a nice compromise for environments that require full compliance but desire more than the layer2 only policy. Signed-off-by: "Glenn Griffin" <ggriffin.kernel@gmail.com> Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-10-15net/bonding: Optionally allow ethernet slaves to keep own MACJay Vosburgh
Update the "don't change MAC of slaves" functionality added in previous changes to be a generic option, rather than something tied to IB devices, as it's occasionally useful for regular ethernet devices as well. Adds "fail_over_mac" option (which is automatically enabled for IB slaves), applicable only to active-backup mode. Includes documentation update. Updates bonding driver version to 3.2.0. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2007-04-26[NET]: bonding documentation fix for multiple bonding interfacesAlexandra N. Kossovsky
Fix bonding driver documentation for the case of multiple bonding interfaces. Signed-off-by: "Alexandra N. Kossovsky" <Alexandra.Kossovsky@oktetlabs.ru> Acked-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: David S. Miller <davem@davemloft.net>
2006-10-03Documentation: remove duplicated wordsPaolo Ornati
Remove many duplicated words under Documentation/ and do other small cleanups. Examples: "and and" --> "and" "in in" --> "in" "the the" --> "the" "the the" --> "to the" ... Signed-off-by: Paolo Ornati <ornati@fastwebnet.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-25[PATCH] bonding: Validate probe replies in ARP monitorJay Vosburgh
Add logic to check ARP request / reply packets used for ARP monitor link integrity checking. The current method simply examines the slave device to see if it has sent and received traffic; this can be fooled by extraneous traffic. For example, if multiple hosts running bonding are behind a common switch, the probe traffic from the multiple instances of bonding will update the tx/rx times on each other's slave devices. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2006-06-08[DOC] Update bonding documentation with sysfs infoAuke Kok
Bonding documentation needed an update to include sysfs specific information. This patch adds information on how to change bonding parameters at runtime using the sysfs interface. Signed-off-by: Mitch Williams <mitch.a.williams@intel.com> Signed-off-by: Auke Kok <auke-jan.h.kok@intel.com>
2006-01-09[PATCH] update bonding.txt to not show ip address on slavesEric Paris
ifenslave, as of abi version 2, does not set the ip address on the slave interfaces. The documentation example however still shows that the ensalved interfaces should have the same IP as the master. The patch simply removes the lines from the example which should no longer appear. Signed-off-by: Eric Paris <eparis@redhat.com> bonding.txt | 2 -- 1 files changed, 2 deletions(-) Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-10-18[PATCH] bonding: fix typos in bonding documentationJohn W. Linville
Fix some simple typos in the bonding.txt file. The typos are in areas relating to loading the bonding driver multiple times. Signed-off-by: John W. Linville <linville@tuxdriver.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
2005-09-10[PATCH] Spelling fixes for Documentation/Tobias Klauser
The attached patch fixes the following spelling errors in Documentation/ - double "the" - Several misspellings of function/functionality - infomation - memeory - Recieved - wether and possibly others which I forgot ;-) Trailing whitespaces on the same line as the typo are also deleted. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-31[PATCH] bonding: documentation updateJay Vosburgh
Contains general updates (additional configuration info, hopefully better examples, updated some out of date info, and a bonus pass through ispell to banish the "paramters.") and info specific to gratuitous ARP and xmit policy functionality already in 2.6.13-rc2. Signed-off-by: Jay Vosburgh <fubar@us.ibm.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
