path: root/Documentation/networking/phy.txt
2010-10-24phylib: make local function staticstephen hemminger
The following functions are not used directly by any drivers: phy_attach_direct phy_device_create phy_prepare_link genphy_config_advert genphy_setup_forced phy_config_interrupt phy_clear_interrypt phy_sanitize_settings phy_enable_interrupts phy_disable_interrupts Signed-off-by: Stephen Hemminger <shemminger@vyatta.com> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-11-19phylib: fix phy name example in documentationPaulius Zaleckas
All MDIO bus drivers currently name bus with "%x" format. There is one exception where mv643xx_eth driver is using "%d". Phy address on the bus uses format "%02x". Fixing phy name example to match all real life MDIO drivers. Signed-off-by: Paulius Zaleckas <paulius.zaleckas@teltonika.lt> Signed-off-by: David S. Miller <davem@davemloft.net>
2008-04-25phylib: Add support for board-level PHY fixupsAndy Fleming
Sometimes the specific interaction between the platform and the PHY requires special handling. For instance, to change where the PHY's clock input is, or to add a delay to account for latency issues in the data path. We add a mechanism for registering a callback with the PHY Lib to be called on matching PHYs when they are brought up, or reset. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@redhat.com>
2006-12-02[PATCH] PHY: Add support for configuring the PHY connection interfaceAndy Fleming
Most PHYs connect to an ethernet controller over a GMII or MII interface. However, a growing number are connected over different interfaces, such as RGMII or SGMII. The ethernet driver will tell the PHY what type of connection it is by setting it manually, or passing it in through phy_connect (or phy_attach). Changes include: * Updates to documentation * Updates to PHY Lib consumers * Changes to PHY Lib to add interface support * Some minor changes to whitespace in phy.h * gianfar driver now detects interface and passes appropriate value to PHY Lib Signed-off-by: Andrew Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jeff@garzik.org>
2005-07-30This patch adds a PHY Abstraction Layer to the Linux Kernel, enablingAndy Fleming
ethernet drivers to remain as ignorant as is reasonable of the connected PHY's design and operation details. Signed-off-by: Andy Fleming <afleming@freescale.com> Signed-off-by: Jeff Garzik <jgarzik@pobox.com>
