Update Intel Wired LAN ixgbevf documentation.
Update Intel Wired LAN ixgbe documentation.
Update Intel Wired LAN igbvf documentation.
Update Intel Wired LAN igb documentation.
v2- Updated the ethtool support link, removed the LRO section and
anti-spoofing sections.
Update Intel Wired LAN e1000e documentation.
Update Intel Wired LAN e1000 documentation.
drivers/net/wireless/ath/ath9k/ar9003_eeprom.c
net/llc/af_llc.c
This patch adds a generic infrastructure for policy-based dequeueing of
TX packets and provides two policies:
* a simple FIFO policy (which is the default) and
* a priority based policy (set via socket options).
Both policies honour the tx_qlen sysctl for the maximum size of the write
queue (can be overridden via socket options).
The priority policy uses skb->priority internally to assign an u32 priority
identifier, using the same ranking as SO_PRIORITY. The skb->priority field
is set to 0 when the packet leaves DCCP. The priority is supplied as ancillary
data using cmsg(3), the patch also provides the requisite parsing routines.
Signed-off-by: Tomasz Grobelny <tomasz@grobelny.oswiecenia.net>
Signed-off-by: Gerrit Renker <gerrit@erg.abdn.ac.uk>
Signed-off-by: Sritej Velaga <sritej.velaga@qlogic.com>
Signed-off-by: Anirban Chakraborty <anirban.chakraborty@qlogic.com>
tcp_win_from_space() does the following:
if (sysctl_tcp_adv_win_scale <= 0)
return space >> (-sysctl_tcp_adv_win_scale);
else
return space - (space >> sysctl_tcp_adv_win_scale);
"space" is int.
As per C99 6.5.7 (3) shifting int for 32 or more bits is
undefined behaviour.
Indeed, if sysctl_tcp_adv_win_scale is exactly 32,
space >> 32 equals space and function returns 0.
Which means we busyloop in tcp_fixup_rcvbuf().
Restrict net.ipv4.tcp_adv_win_scale to [-31, 31].
Fix https://bugzilla.kernel.org/show_bug.cgi?id=20312
Steps to reproduce:
echo 32 >/proc/sys/net/ipv4/tcp_adv_win_scale
wget www.kernel.org
[softlockup]
This patch helps clarify documentation for
net.ipv4.igmp_max_memberships by providing a formula for
calculating the maximum number of multicast groups that can be
subscribed to, plus defining the theoretical limit.
Signed-off-by: Jiri Pirko <jpirko@redhat.com>
Signed-off-by: Jeremy Eder <jeder@redhat.com>
Some of the documentation refers to web pages under
the domain `osdl.org'. However, `osdl.org' now
redirects to `linuxfoundation.org'.
Rather than rely on redirections, this patch updates
the addresses appropriately; for the most part, only
documentation that is meant to be current has been
updated.
The patch should be pretty quick to scan and check;
each new web-page url was gotten by trying out the
original URL in a browser and then simply copying the
the redirected URL (formatting as necessary).
There is some conflict as to which one of these domain
names is preferred:
linuxfoundation.org
linux-foundation.org
So, I wrote:
info@linuxfoundation.org
and got this reply:
Message-ID: <4CE17EE6.9040807@linuxfoundation.org>
Date: Mon, 15 Nov 2010 10:41:42 -0800
linuxfoundation.org is preferred. The canonical name for our web site is
www.linuxfoundation.org. Our list site is actually
lists.linux-foundation.org.
Regarding email linuxfoundation.org is preferred there are a few people
who choose to use linux-foundation.org for their own reasons.
Consequently, I used `linuxfoundation.org' for web pages and
`lists.linux-foundation.org' for mailing-list web pages and email addresses;
the only personal email address I updated from `@osdl.org' was that of
Andrew Morton, who prefers `linux-foundation.org' according `git log'.
Signed-off-by: Michael Witten <mfwitten@gmail.com>
Signed-off-by: Ben Greear <greearb@candelatech.com>
Signed-off-by: Giuseppe Cavallaro <peppe.cavallaro@st.com>
"gadget", "through", "command", "maintain", "maintain", "controller", "address",
"between", "initiali[zs]e", "instead", "function", "select", "already",
"equal", "access", "management", "hierarchy", "registration", "interest",
"relative", "memory", "offset", "already",
The following functions are not used directly by any drivers:
phy_attach_direct
phy_device_create
phy_prepare_link
genphy_config_advert
genphy_setup_forced
phy_config_interrupt
phy_clear_interrypt
phy_sanitize_settings
phy_enable_interrupts
phy_disable_interrupts
CAN has no addressing scheme. It is currently impossible for userspace
to tell is a received CAN frame comes from another process on the local
host, or from a remote CAN device.
This patch add support for userspace applications to distinguish between
'own', 'local' and 'remote' CAN traffic. The distinction is made by returning
flags in msg->msg_flags in the call to recvmsg().
The added documentation explains the introduced flags.
Signed-off-by: Kurt Van Dijck <kurt.van.dijck@eia.be>
Signed-off-by: Oliver Hartkopp <socketcan@hartkopp.net>
Updates to Phonet doc for Pipe controller 'connect' socket
implementation and changes related to socket options.
Signed-off-by: Kumar Sanghvi <kumar.sanghvi@stericsson.com>
The current code works like this:
int garbage, status;
socklen_t len = sizeof(status);
/* enable pipe */
setsockopt(fd, SOL_PNPIPE, PNPIPE_ENABLE, &garbage, sizeof(garbage));
/* disable pipe */
setsockopt(fd, SOL_PNPIPE, PNPIPE_DISABLE, &garbage, sizeof(garbage));
/* get status */
getsockopt(fd, SOL_PNPIPE, PNPIPE_INQ, &status, &len);
...which does not follow the usual socket option pattern. This patch
merges all three "options" into a single gettable&settable option,
before Linux 2.6.37 gets out:
int status;
/* enable pipe */
status = 1;
setsockopt(fd, SOL_PNPIPE, PNPIPE_ENABLE, &status, sizeof(status));
/* disable pipe */
status = 0;
/* get status */
getsockopt(fd, SOL_PNPIPE, PNPIPE_ENABLE, &status, &len);
This also fixes the error code from EFAULT to ENOTCONN.
Signed-off-by: Rémi Denis-Courmont <remi.denis-courmont@nokia.com>
Cc: Kumar Sanghvi <kumar.sanghvi@stericsson.com>
drivers/net/pcmcia/pcnet_cs.c
net/caif/caif_socket.c
Allow sysadmins to configure the number of multicast
membership report sent on a link failure event.
Signed-off-by: Flavio Leitner <fleitner@redhat.com>
Adds documentation for the e1000e networking driver.
Updated the e1000 networking driver documentation.
Update the documentation for the ixgbevf (ixgbe virtual
function driver).
Updates the Phonet document with description related to Pipe controller
implementation
Acked-by: Linus Walleij <linus.walleij@stericsson.com>
forwarding
Documentation for recent changes to the tunables accept_ra and
forwarding.
Signed-off-by: Thomas Graf <tgraf@infradead.org>
This makes RTAX_RTO_MIN also available to CCID-3, replacing the compile-time
RTO lower bound with a per-route tunable value.
The original Kconfig option solved the problem that a very low RTT (in the
order of HZ) can trigger too frequent and unnecessary reductions of the
sending rate.
This tunable does not affect the initial RTO value of 2 seconds specified in
RFC 5348, section 4.2 and Appendix B. But like the hardcoded Kconfig value,
it allows to adapt to network conditions.
The same effect as the original Kconfig option of 100ms is now achieved by
> ip route replace to unicast 192.168.0.0/24 rto_min 100j dev eth0
(assuming HZ=1000).
Using a fixed RTO_MIN of 0.2 seconds was found to cause problems for CCID-2
over 802.11g: at least once per session there was a spurious timeout. It
helped to then increase the the value of RTO_MIN over this link.
Since the problem is the same as in TCP, this patch makes the solution from
commit "05bb1fad1cde025a864a90cfeb98dcbefe78a44a"
"[TCP]: Allow minimum RTO to be configurable via routing metrics."
available to DCCP.
This avoids reinventing the wheel, so that e.g. the following works in the
expected way now also for CCID-2:
> ip route change 10.0.0.2 rto_min 800 dev ath0
Luckily this useful rto_min function was recently moved to net/tcp.h,
which simplifies sharing code originating from TCP.
Documentation also updated (plus minor whitespace fixes).
This patch removes the abstraction introduced by the union skb_shared_tx in
the shared skb data.
The access of the different union elements at several places led to some
confusion about accessing the shared tx_flags e.g. in skb_orphan_try().
http://marc.info/?l=linux-netdev&m=128084897415886&w=2
Commit 1d794e3b353b ("Staging: wavelan: delete the driver") removed the
source, so remove the documentation as well.
Cc: Jean Tourrilhes <jt@hpl.hp.com>
Acked-by: Randy Dunlap <rdunlap@xenotime.net>
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-2.6: (59 commits)
igbvf.txt: Add igbvf Documentation
igb.txt: Add igb documentation
e100/e1000*/igb*/ixgb*: Add missing read memory barrier
ixgbe: fix build error with FCOE_CONFIG without DCB_CONFIG
netxen: protect tx timeout recovery by rtnl lock
isdn: gigaset: use after free
isdn: gigaset: add missing unlock
solos-pci: Fix race condition in tasklet RX handling
pkt_sched: Fix sch_sfq vs tcf_bind_filter oops
net: disable preemption before call smp_processor_id()
tcp: no md5sig option size check bug
iwlwifi: fix locking assertions
iwlwifi: fix TX tracer
isdn: fix information leak
net: Fix napi_gro_frags vs netpoll path
usbnet: remove noisy and hardly useful printk
rtl8180: avoid potential NULL deref in rtl8180_beacon_work
ath9k: Remove myself from the MAINTAINERS list
libertas: scan before assocation if no BSSID was given
libertas: fix association with some APs by using extended rates
Adds documentation for the igbvf (igb virtual function driver).
v2:
- Removed trailing white space
- Removed Ethtool version info
Tested-by: Jeff Pieper <jeffrey.e.pieper@intel.com>
Add documentation for the igb networking driver.
v2:
- Removed LRO kernel version info
Fixes for the DNS query module, including:
(1) Use 'negative' instead of '-ve' in the documentation.
(2) Mark the kdoc comment with '/**' on dns_query().
Reported-by: Randy Dunlap <randy.dunlap@oracle.com>
Signed-off-by: Steve French <sfrench@us.ibm.com>
Separate out the DNS resolver key type from the CIFS filesystem into its own
module so that it can be made available for general use, including the AFS
filesystem module.
This facility makes it possible for the kernel to upcall to userspace to have
it issue DNS requests, package up the replies and present them to the kernel
in a useful form. The kernel is then able to cache the DNS replies as keys
can be retained in keyrings.
Resolver keys are of type "dns_resolver" and have a case-insensitive
description that is of the form "[<type>:]<domain_name>". The optional <type>
indicates the particular DNS lookup and packaging that's required. The
<domain_name> is the query to be made.
If <type> isn't given, a basic hostname to IP address lookup is made, and the
result is stored in the key in the form of a printable string consisting of a
comma-separated list of IPv4 and IPv6 addresses.
This key type is supported by userspace helpers driven from /sbin/request-key
and configured through /etc/request-key.conf. The cifs.upcall utility is
invoked for UNC path server name to IP address resolution.
The CIFS functionality is encapsulated by the dns_resolve_unc_to_ip() function,
which is used to resolve a UNC path to an IP address for CIFS filesystem. This
part remains in the CIFS module for now.
See the added Documentation/networking/dns_resolver.txt for more information.
Signed-off-by: Wang Lei <wang840925@gmail.com>
Acked-by: Jeff Layton <jlayton@redhat.com>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits)
Documentation: update broken web addresses.
fix comment typo "choosed" -> "chosen"
hostap:hostap_hw.c Fix typo in comment
Fix spelling contorller -> controller in comments
Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault
fs/Kconfig: Fix typo Userpace -> Userspace
Removing dead MACH_U300_BS26
drivers/infiniband: Remove unnecessary casts of private_data
fs/ocfs2: Remove unnecessary casts of private_data
libfc: use ARRAY_SIZE
scsi: bfa: use ARRAY_SIZE
drm: i915: use ARRAY_SIZE
drm: drm_edid: use ARRAY_SIZE
synclink: use ARRAY_SIZE
block: cciss: use ARRAY_SIZE
comment typo fixes: charater => character
fix comment typos concerning "challenge"
arm: plat-spear: fix typo in kerneldoc
reiserfs: typo comment fix
update email address
Below you will find an updated version from the original series bunching all patches into one big patch
updating broken web addresses that are located in Documentation/*
Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult,
the best way to deal with these is to use web.archive.org to locate these addresses that are outdated.
Now there are also some addresses pointing to .spec files some are located, but some(after searching
on the companies site)where still no where to be found. In this case I just changed the address
to the company site this way the users can contact the company and they can locate them for the users.
Signed-off-by: Thomas Weber <weber@corscience.de>
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
Cc: Paulo Marques <pmarques@grupopie.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Michael Neuling <mikey@neuling.org>
This patch introduces the CAIF SPI Protocol Driver for
CAIF Link Layer.
This driver implements a platform driver to accommodate for a
platform specific SPI device. A general platform driver is not
possible as there are no SPI Slave side Kernel API defined.
A sample CAIF SPI Platform device can be found in
.../Documentation/networking/caif/spi_porting.txt
Signed-off-by: Sjur Braendeland <sjur.brandeland@stericsson.com>
git://git.kernel.org/pub/scm/linux/kernel/git/linville/wireless-next-2.6
BugLink: http://bugs.launchpad.net/bugs/21367
Enable LED by default and update the MODULE_PARM_DESC. The original
reason for defaulting to disabled was documented in 2005 and noted, "The
LED code has been reported to hang some systems when running ifconfig
and is therefore disabled by default." This no longer appears
applicable and users have been requesting this be enabled for several
years.
Signed-off-by: TJ <ubuntu@tjworld.net>
Signed-off-by: Tim Gardner <tim.gardner@canonical.com>
Signed-off-by: Andy Whitcroft <apw@canonical.com>
Acked-by: Stefan Bader <stefan.bader@canonical.com>
Signed-off-by: Leann Ogasawara <leann.ogasawara@canonical.com>
This patch increases the granularity of the rate generated by pktgen.
The previous version of pktgen uses micro seconds (udelay) resolution when it
was delayed causing gaps in the rates. It is changed to nanosecond (ndelay).
Now any rate is possible.
Also it allows to set, the desired rate in Mb/s or packets per second.
The documentation has been updated.
Signed-off-by: Daniel Turull <daniel.turull@gmail.com>
Signed-off-by: Robert Olsson <robert.olsson@its.uu.se>
v2: changed bonding module version, modified to apply on top of changes
from previous patch in series, and updated documentation to elaborate on
multiqueue awareness that now exists in bonding driver.
This patch give the user the ability to control the output slave for
round-robin and active-backup bonding. Similar functionality was
discussed in the past, but Jay Vosburgh indicated he would rather see a
feature like this added to existing modes rather than creating a
completely new mode. Jay's thoughts as well as Neil's input surrounding
some of the issues with the first implementation pushed us toward a
design that relied on the queue_mapping rather than skb marks.
Round-robin and active-backup modes were chosen as the first users of
this slave selection as they seemed like the most logical choices when
considering a multi-switch environment.
Round-robin mode works without any modification, but active-backup does
require inclusion of the first patch in this series and setting
the 'all_slaves_active' flag. This will allow reception of unicast traffic on
any of the backup interfaces.
This was tested with IPv4-based filters as well as VLAN-based filters
with good results.
More information as well as a configuration example is available in the
patch to Documentation/networking/bonding.txt.
Signed-off-by: Andy Gospodarek <andy@greyhouse.net>
Signed-off-by: Neil Horman <nhorman@tuxdriver.com>
This patch adds a setting, PACKET_TIMESTAMP, to specify the packet
timestamp source that is exported to capture utilities like tcpdump by
packet_mmap.
PACKET_TIMESTAMP accepts the same integer bit field as
SO_TIMESTAMPING. However, only the SOF_TIMESTAMPING_SYS_HARDWARE and
SOF_TIMESTAMPING_RAW_HARDWARE values are currently recognized by
PACKET_TIMESTAMP. SOF_TIMESTAMPING_SYS_HARDWARE takes precedence over
SOF_TIMESTAMPING_RAW_HARDWARE if both bits are set.
If PACKET_TIMESTAMP is not set, a software timestamp generated inside
the networking stack is used (the behavior before this setting was
added).
Signed-off-by: Scott McMillan <scott.a.mcmillan@intel.com>
is enabled
This option causes a gratuitous ARP request, not a reply as the documentation
currently suggests.
Signed-off-by: Ian Campbell <ian.campbell@citrix.com>
Cc: Stephen Hemminger <shemminger@linux-foundation.org>
Cc: netdev@vger.kernel.org
* git://git.kernel.org/pub/scm/linux/kernel/git/davem/net-next-2.6: (1674 commits)
qlcnic: adding co maintainer
ixgbe: add support for active DA cables
ixgbe: dcb, do not tag tc_prio_control frames
ixgbe: fix ixgbe_tx_is_paused logic
ixgbe: always enable vlan strip/insert when DCB is enabled
ixgbe: remove some redundant code in setting FCoE FIP filter
ixgbe: fix wrong offset to fc_frame_header in ixgbe_fcoe_ddp
ixgbe: fix header len when unsplit packet overflows to data buffer
ipv6: Never schedule DAD timer on dead address
ipv6: Use POSTDAD state
ipv6: Use state_lock to protect ifa state
ipv6: Replace inet6_ifaddr->dead with state
cxgb4: notify upper drivers if the device is already up when they load
cxgb4: keep interrupts available when the ports are brought down
cxgb4: fix initial addition of MAC address
cnic: Return SPQ credit to bnx2x after ring setup and shutdown.
cnic: Convert cnic_local_flags to atomic ops.
can: Fix SJA1000 command register writes on SMP systems
bridge: fix build for CONFIG_SYSFS disabled
ARCNET: Limit com20020 PCI ID matches for SOHARD cards
Fix up various conflicts with pcmcia tree drivers/net/
{pcmcia/3c589_cs.c, wireless/orinoco/orinoco_cs.c and
wireless/orinoco/spectrum_cs.c} and feature removal
(Documentation/feature-removal-schedule.txt).
Also fix a non-content conflict due to pm_qos_requirement getting
renamed in the PM tree (now pm_qos_request) in net/mac80211/scan.c
(Dropped the infiniband part, because Tetsuo modified the related code,
I will send a separate patch for it once this is accepted.)
This patch introduces /proc/sys/net/ipv4/ip_local_reserved_ports which
allows users to reserve ports for third-party applications.
The reserved ports will not be used by automatic port assignments
(e.g. when calling connect() or bind() with port number 0). Explicit
port allocation behavior is unchanged.
Signed-off-by: Octavian Purdila <opurdila@ixiacom.com>
Signed-off-by: WANG Cong <amwang@redhat.com>
Cc: Neil Horman <nhorman@tuxdriver.com>
Cc: Eric W. Biederman <ebiederm@xmission.com>
Fix obvious cases of "it's" being used when "its" was meant.
Signed-off-by: Francis Galiegue <fgaliegue@gmail.com>
