path: root/Documentation/oops-tracing.txt
2008-04-29Taint kernel after WARN_ON(condition)Nur Hussein
The kernel is sent to tainted within the warn_on_slowpath() function, and whenever a warning occurs the new taint flag 'W' is set. This is useful to know if a warning occurred before a BUG by preserving the warning as a flag in the taint state. This does not work on architectures where WARN_ON has its own definition. These archs are: 1. s390 2. superh 3. avr32 4. parisc The maintainers of these architectures have been added in the Cc: list in this email to alert them to the situation. The documentation in oops-tracing.txt has been updated to include the new flag. Signed-off-by: Nur Hussein <nurhussein@gmail.com> Cc: Arjan van de Ven <arjan@infradead.org> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Cc: Ingo Molnar <mingo@elte.hu> Cc: Peter Zijlstra <a.p.zijlstra@chello.nl> Cc: Kyle McMartin <kyle@mcmartin.ca> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: Paul Mundt <lethal@linux-sh.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17Report that kernel is tainted if there was an OOPSPavel Emelianov
If the kernel OOPSed or BUGed then it probably should be considered as tainted. Thus, all subsequent OOPSes and SysRq dumps will report the tainted kernel. This saves a lot of time explaining oddities in the calltraces. Signed-off-by: Pavel Emelianov <xemul@openvz.org> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: <linux-arch@vger.kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> [ Added parisc patch from Matthew Wilson -Linus ] Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-16doc/oops-tracing: add Code: decode infoRandy Dunlap
Add info that the Code: bytes line contains <xy> or (wxyz) in some architecture oops reports and what that means. Add a script by Andi Kleen that reads the Code: line from an Oops report file and generates assembly code from the hex bytes. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Andi Kleen <ak@suse.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08doc: fix oops-tracing duplicateMichal Piotrowski
Remove duplicate 'U' entry -- fix mis-merge. Signed-off-by: Michal Piotrowski <michal.k.k.piotrowski@gmail.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-20[PATCH] update Doc/oops-tracing.txt for TAINT_USERRandy Dunlap
Add TAINT_USER description to Tainted flags in oops-tracing.txt. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: "Theodore Ts'o" <tytso@mit.edu> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-01-11[PATCH] doc: refer to kdump in oops-tracing.txtAkinobu Mita
Kdump has been merged and supported on several architectures. It is better to encourage to use kdump rather than non standard kernel crash dump patches. Signed-off-by: Akinobu Mita <mita@miraclelinux.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-15[PATCH] oops-tracing: mention extended VGADave Jones
Something I've found handy countless times when users do this.. Signed-off-by: Dave Jones <davej@redhat.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-13[PATCH] oops-tracing: mention digital photosDiego Calleja
2005-11-07[PATCH] ksymoops related docs updateJesper Juhl
Update ksymoops related documentation to reflect current 2.6 reality. Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-13[PATCH] Doc: update oops-tracing.txt (Tainted flags)Randy Dunlap
Update Documentation/oops-tracing.txt: - add descriptions of 3 more "Tainted" flags; - fix some typos; Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
