path: root/Documentation/parport-lowlevel.txt
2007-11-26plip: fix parport_register_device name parameterMikulas Patocka
Plip passes a string "name" that is allocated on stack to parport_register_device. parport_register_device holds the pointer to "name" and when the registering function exits, it points nowhere. On some machine, this bug causes bad names to appear in /proc, such as /proc/sys/dev/parport/parport0/devices/T^/�X^/�, on others, the plip proc node is completely missing. The patch also fixes documentation to note this requirement. Signed-off-by: Mikulas Patocka <mikulas@artax.karlin.mff.cuni.cz> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-18sysctl: parport remove binary pathsEric W. Biederman
The sysctl binary paths don't look as if they even code work, .data is not filled in, and all of the proc_handlers look at extra1 and there is not strategy routine. So just kill the binary paths. In addition this patch removes the setting of extra1 on directories. It doesn't look like the parport code ever examines it, and it's bad sysctl form. [bunk@kernel.org: remove parport_device_num()] Signed-off-by: Eric W. Biederman <ebiederm@xmission.com> Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-02-03[PATCH] parport: fix documentationArnaud Giersch
Fix documentation to actually match the code. Signed-off-by: Arnaud Giersch <arnaud.giersch@free.fr> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
