path: root/Documentation/power/opp.txt
2011-07-15PM / OPP: Introduce function to free cpufreq tableNishanth Menon
cpufreq table allocated by opp_init_cpufreq_table is better freed by OPP layer itself. This allows future modifications to the table handling to be transparent to the users. Signed-off-by: Nishanth Menon <nm@ti.com> Acked-by: Kevin Hilman <khilman@ti.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-11-11PM / OPP: Hide OPP configuration when SoCs do not provide an implementationMark Brown
Since the OPP API is only useful with an appropraite SoC-specific implementation there is no point in offering the ability to enable the API on general systems. Provide an ARCH_HAS OPP Kconfig symbol which masks out the option unless selected by an implementation. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Nishanth Menon <nm@ti.com> Acked-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-10-17PM: Introduce library for device-specific OPPs (v7)Nishanth Menon
SoCs have a standard set of tuples consisting of frequency and voltage pairs that the device will support per voltage domain. These are called Operating Performance Points or OPPs. The actual definitions of OPP varies over silicon versions. For a specific domain, we can have a set of {frequency, voltage} pairs. As the kernel boots and more information is available, a default set of these are activated based on the precise nature of device. Further on operation, based on conditions prevailing in the system (such as temperature), some OPP availability may be temporarily controlled by the SoC frameworks. To implement an OPP, some sort of power management support is necessary hence this library depends on CONFIG_PM. Contributions include: Sanjeev Premi for the initial concept: http://patchwork.kernel.org/patch/50998/ Kevin Hilman for converting original design to device-based. Kevin Hilman and Paul Walmsey for cleaning up many of the function abstractions, improvements and data structure handling. Romit Dasgupta for using enums instead of opp pointers. Thara Gopinath, Eduardo Valentin and Vishwanath BS for fixes and cleanups. Linus Walleij for recommending this layer be made generic for usage in other architectures beyond OMAP and ARM. Mark Brown, Andrew Morton, Rafael J. Wysocki, Paul E. McKenney for valuable improvements. Discussions and comments from: http://marc.info/?l=linux-omap&m=126033945313269&w=2 http://marc.info/?l=linux-omap&m=125482970102327&w=2 http://marc.info/?t=125809247500002&r=1&w=2 http://marc.info/?l=linux-omap&m=126025973426007&w=2 http://marc.info/?t=128152609200064&r=1&w=2 http://marc.info/?t=128468723000002&r=1&w=2 incorporated. v1: http://marc.info/?t=128468723000002&r=1&w=2 Signed-off-by: Nishanth Menon <nm@ti.com> Signed-off-by: Kevin Hilman <khilman@deeprootsystems.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
