path: root/Documentation/power
2010-05-21Merge branch 'linux-next' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6 * 'linux-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jbarnes/pci-2.6: (36 commits) PCI: hotplug: pciehp: Removed check for hotplug of display devices PCI: read memory ranges out of Broadcom CNB20LE host bridge PCI: Allow manual resource allocation for PCI hotplug bridges x86/PCI: make ACPI MCFG reserved error messages ACPI specific PCI hotplug: Use kmemdup PM/PCI: Update PCI power management documentation PCI: output FW warning in pci_read/write_vpd PCI: fix typos pci_device_dis/enable to pci_dis/enable_device in comments PCI quirks: disable msi on AMD rs4xx internal gfx bridges PCI: Disable MSI for MCP55 on P5N32-E SLI x86/PCI: irq and pci_ids patch for additional Intel Cougar Point DeviceIDs PCI: aerdrv: trivial cleanup for aerdrv_core.c PCI: aerdrv: trivial cleanup for aerdrv.c PCI: aerdrv: introduce default_downstream_reset_link PCI: aerdrv: rework find_aer_service PCI: aerdrv: remove is_downstream PCI: aerdrv: remove magical ROOT_ERR_STATUS_MASKS PCI: aerdrv: redefine PCI_ERR_ROOT_*_SRC PCI: aerdrv: rework do_recovery PCI: aerdrv: rework get_e_source() ...
2010-05-20Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (44 commits) vlynq: make whole Kconfig-menu dependant on architecture add descriptive comment for TIF_MEMDIE task flag declaration. EEPROM: max6875: Header file cleanup EEPROM: 93cx6: Header file cleanup EEPROM: Header file cleanup agp: use NULL instead of 0 when pointer is needed rtc-v3020: make bitfield unsigned PCI: make bitfield unsigned jbd2: use NULL instead of 0 when pointer is needed cciss: fix shadows sparse warning doc: inode uses a mutex instead of a semaphore. uml: i386: Avoid redefinition of NR_syscalls fix "seperate" typos in comments cocbalt_lcdfb: correct sections doc: Change urls for sparse Powerpc: wii: Fix typo in comment i2o: cleanup some exit paths Documentation/: it's -> its where appropriate UML: Fix compiler warning due to missing task_struct declaration UML: add kernel.h include to signal.c ...
2010-05-18PM/PCI: Update PCI power management documentationRafael J. Wysocki
I power management document, Documentation/power/pci.txt, is outdated and partially inaccurate. It also is missing some important information about the power management of PCI device. Rewrite it to make it more up to date and more complete. Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-05-10PM QOS updateMark Gross
This patch changes the string based list management to a handle base implementation to help with the hot path use of pm-qos, it also renames much of the API to use "request" as opposed to "requirement" that was used in the initial implementation. I did this because request more accurately represents what it actually does. Also, I added a string based ABI for users wanting to use a string interface. So if the user writes 0xDDDDDDDD formatted hex it will be accepted by the interface. (someone asked me for it and I don't think it hurts anything.) This patch updates some documentation input I got from Randy. Signed-off-by: markgross <mgross@linux.intel.com> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-05-10PM / Hibernate: document open(/dev/snapshot) side effectsPavel Machek
Opening and closing /dev/snapshot causes the kernel to carry out some hibernate preparations that should be documented. [rjw: Added the changelog.] Signed-off-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-05-10PM: Improve device power management documentAlan Stern
Improve the device power management document after it's been updated by the previous patch. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-05-10PM: Update device power management documentRafael J. Wysocki
The device PM document, Documentation/power/devices.txt, is badly outdated and requires total rework to fit the current design of the PM framework. Make it more up to date. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reviewed-by: Randy Dunlap <randy.dunlap@oracle.com>
2010-04-23Documentation/: it's -> its where appropriateFrancis Galiegue
Fix obvious cases of "it's" being used when "its" was meant. Signed-off-by: Francis Galiegue <fgaliegue@gmail.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-08Merge branch 'for-next' into for-linusJiri Kosina
Conflicts: Documentation/filesystems/proc.txt arch/arm/mach-u300/include/mach/debug-macro.S drivers/net/qlge/qlge_ethtool.c drivers/net/qlge/qlge_main.c drivers/net/typhoon.c
2010-03-06PM: Provide generic subsystem-level callbacksRafael J. Wysocki
There are subsystems whose power management callbacks only need to invoke the callbacks provided by device drivers. Still, their system sleep PM callbacks should play well with the runtime PM callbacks, so that devices suspended at run time can be left in that state for a system sleep transition. Provide a set of generic PM callbacks for such subsystems and define convenience macros for populating dev_pm_ops structures. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-03-06PM / Runtime: Document power.runtime_auto and related functionsRafael J. Wysocki
The power.runtime_auto device flag and the helper functions pm_runtime_allow() and pm_runtime_forbid() used to modify it are a part of the run-time power management framework and therefore they should be described in Documentation/power/runtime_pm.txt. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2010-02-05doc: fix leve -> level typo in pm-runtime docThadeu Lima de Souza Cascardo
Signed-off-by: Thadeu Lima de Souza Cascardo <cascardo@holoscopio.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-12-22PM: Runtime PM documentation updateAlan Stern
This patch (as1318) updates the runtime PM documentation, adding a section discussing the interaction between runtime PM and system sleep. [rjw: Rebased and made it agree with the other updates better.] Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-12-22PM / Runtime: Use device type and device class callbacksRafael J. Wysocki
The power management of some devices is handled through device types and device classes rather than through bus types. Since these devices may also benefit from using the run-time power management core, extend it so that the device type and device class run-time PM callbacks can be taken into consideration by it if the bus type callback is not defined. Update the run-time PM core documentation to reflect this change. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-12-09Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (42 commits) tree-wide: fix misspelling of "definition" in comments reiserfs: fix misspelling of "journaled" doc: Fix a typo in slub.txt. inotify: remove superfluous return code check hdlc: spelling fix in find_pvc() comment doc: fix regulator docs cut-and-pasteism mtd: Fix comment in Kconfig doc: Fix IRQ chip docs tree-wide: fix assorted typos all over the place drivers/ata/libata-sff.c: comment spelling fixes fix typos/grammos in Documentation/edac.txt sysctl: add missing comments fs/debugfs/inode.c: fix comment typos sgivwfb: Make use of ARRAY_SIZE. sky2: fix sky2_link_down copy/paste comment error tree-wide: fix typos "couter" -> "counter" tree-wide: fix typos "offest" -> "offset" fix kerneldoc for set_irq_msi() spidev: fix double "of of" in comment comment typo fix: sybsystem -> subsystem ...
2009-12-06PM: Add flag for devices capable of generating run-time wake-up eventsRafael J. Wysocki
Apparently, there are devices that can wake up the system from sleep states and yet are incapable of generating wake-up events at run time. Thus, introduce a flag indicating if given device is capable of generating run-time wake-up events. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-12-06PM / Runtime: Make documentation of runtime_idle() agree with the codeRafael J. Wysocki
Currently the ->runtime_idle() callback is documented as having no return value, but in fact it returns int. Although its return value is ignored at the PM core level, it may be used by bus type routines executing the drivers' ->runtime_idle() callbacks. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Reported-by: Alan Stern <stern@rowland.harvard.edu>
2009-12-04doc: fix regulator docs cut-and-pasteismDr. David Alan Gilbert
Minor copy-and-pasteism in the regulator docs (against git from today): Signed-off-by: Dave Gilbert <linux@treblig.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-23Merge git://git.infradead.org/battery-2.6Linus Torvalds
* git://git.infradead.org/battery-2.6: power_supply: Add driver for the PMU on WM831x PMICs ds2760_battery: Fix integer overflow for time_to_empty_now wm97xx_battery: Convert to dev_pm_ops wm97xx_battery: Use irq to detect charger state wm97xx_battery: Use platform_data wm97xx-core: Pass platform_data to battery ds2760_battery: implement set_charged() feature power_supply: get_by_name and set_charged functionality power_supply: EXPORT_SYMBOL cleanups ds2760_battery: add current_accum module parameter ds2760_battery: handle full_active_uAh == 0 case correctly ds2760_battery: add rated_capacity module parameter ds2760_battery: export more features ds2760_battery: delay power supply registration wm8350_power: Implement charge type property power_supply: Add a charge_type property, and use it for olpc driver olpc_battery: Add an 'error' sysfs device that displays raw errors Revert "power: remove POWER_SUPPLY_PROP_CAPACITY_LEVEL"
2009-09-23Merge branch 'master' of ↵Anton Vorontsov
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 Conflicts: drivers/power/wm97xx_battery.c
2009-09-22regulator: Add some brief design documentationMark Brown
Provide some brief documentation of some of the design decisions that are made by the regulator API. Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-09-22regulator: fix typosWolfram Sang
Fix a couple of typos I found while working with this subsystem. Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-09-22regulator: update a filename in documentationWolfram Sang
Signed-off-by: Wolfram Sang <w.sang@pengutronix.de> Cc: Liam Girdwood <lrg@slimlogic.co.uk> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-09-22Fix some regulator documentationLinus Walleij
This fixes a spelling error and an API function signature mismatch in the regulator documentation. Signed-off-by: Linus Walleij <linus.walleij@stericsson.com> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2009-08-23PM: Introduce core framework for run-time PM of I/O devices (rev. 17)Rafael J. Wysocki
Introduce a core framework for run-time power management of I/O devices. Add device run-time PM fields to 'struct dev_pm_info' and device run-time PM callbacks to 'struct dev_pm_ops'. Introduce a run-time PM workqueue and define some device run-time PM helper functions at the core level. Document all these things. Special thanks to Alan Stern for his help with the design and multiple detailed reviews of the pereceding versions of this patch and to Magnus Damm for testing feedback. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Magnus Damm <damm@igel.co.jp>
2009-07-02power_supply: Add a charge_type property, and use it for olpc driverAndres Salomon
This adds a new sysfs file called 'charge_type' which displays the type of charging (unknown, n/a, trickle charge, or fast charging). This allows things like battery diagnostics to determine what the battery/EC is doing without resorting to changing the 'status' sysfs output. Signed-off-by: Andres Salomon <dilinger@collabora.co.uk> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2009-07-01Revert "power: remove POWER_SUPPLY_PROP_CAPACITY_LEVEL"Andres Salomon
This reverts commit 8efe444038a205e79b38b7ad03878824901849a8 and 4cbc76eadf56399cd11fb736b33c53aec9caab8c. Richard@laptop.org was apparently using CAPACITY_LEVEL for debugging battery/EC problems, and was upset that it was removed. This readds it. Conflicts: Documentation/power_supply_class.txt Signed-off-by: Andres Salomon <dilinger@collabora.co.uk> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2009-06-14Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (31 commits) trivial: remove the trivial patch monkey's name from SubmittingPatches trivial: Fix a typo in comment of addrconf_dad_start() trivial: usb: fix missing space typo in doc trivial: pci hotplug: adding __init/__exit macros to sgi_hotplug trivial: Remove the hyphen from git commands trivial: fix ETIMEOUT -> ETIMEDOUT typos trivial: Kconfig: .ko is normally not included in module names trivial: SubmittingPatches: fix typo trivial: Documentation/dell_rbu.txt: fix typos trivial: Fix Pavel's address in MAINTAINERS trivial: ftrace:fix description of trace directory trivial: unnecessary (void*) cast removal in sound/oss/msnd.c trivial: input/misc: Fix typo in Kconfig trivial: fix grammo in bus_for_each_dev() kerneldoc trivial: rbtree.txt: fix rb_entry() parameters in sample code trivial: spelling fix in ppc code comments trivial: fix typo in bio_alloc kernel doc trivial: Documentation/rbtree.txt: cleanup kerneldoc of rbtree.txt trivial: Miscellaneous documentation typo fixes trivial: fix typo milisecond/millisecond for documentation and source comments. ...
2009-06-12PM: Remove bus_type suspend_late()/resume_early() V2Magnus Damm
Remove the ->suspend_late() and ->resume_early() callbacks from struct bus_type V2. These callbacks are legacy stuff at this point and since there seem to be no in-tree users we may as well remove them. New users should use dev_pm_ops. Signed-off-by: Magnus Damm <damm@igel.co.jp> Acked-by: Pavel Machek <pavel@ucw.cz> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl>
2009-06-12trivial: Miscellaneous documentation typo fixesMatt LaPlante
Fix various typos in documentation txts. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-10-16pm: document use of RTC in pm_traceFrans Pop
As pm_trace uses the system's hardware clock to save its magic value, users of that option should be warned that using this debug option will result in an incorrect system time after resume. Signed-off-by: Frans Pop <elendil@planet.nl> Acked-by: Pavel Machek <pavel@suse.cz> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-13regulator: core - Rework machine API to remove string based functions.Liam Girdwood
This improves the machine level API in order to configure regulator constraints and consumers as platform data and removes the old string based API that required several calls to set up each regulator. The intention is to create a struct regulator_init_data, populate it's fields with constraints, consumers devices, etc and then register the regulator device from board.c in the standard Linux way. e.g. regulator LDO2 (supplying codec and sim) platform data. /* regulator LDO2 consumer devices */ static struct regulator_consumer_supply ldo2_consumers[] = { { .dev = &platform_audio_device.dev, .supply = "codec_avdd", }, { .dev = &platform_sim_device.dev, .supply = "sim_vcc", } }; /* regulator LDO2 constraints */ static struct regulator_init_data ldo2_data = { .constraints = { .min_uV = 3300000, .max_uV = 3300000, .valid_modes_mask = REGULATOR_MODE_NORMAL, .apply_uV = 1, }, .num_consumer_supplies = ARRAY_SIZE(ldo2_consumers), .consumer_supplies = ldo2_consumers, }; /* machine regulator devices with thier consumers and constraints */ static struct platform_device wm8350_regulator_devices[] = { { .name = "wm8350-regulator", .id = WM8350_LDO_2, .dev = { .platform_data = &ldo2_data, }, }, }; Changes in detail:- o Removed all const char* regulator config functions in machine API. o Created new struct regulator_init_data to contain regulator machine configuration constraints and consmuers. o Changed set_supply(), set_machine_constraints(), set_consumer_device_supply() to remove their string identifier parameters. Also made them static and moved functions nearer top of core.c. o Removed no longer used inline func to_rdev() o Added regulator_get_init_drvdata() to retrieve init data. o Added struct device* as parameter to regulator_register(). o Changed my email address. Signed-off-by: Eric Miao <eric.miao@marvell.com> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Liam Girdwood <lrg@slimlogic.co.uk>
2008-08-05pm_qos: spelling fixesRichard Hughes
A documentation cleanup patch. With a minor tweak to clarify units for kbs. [akpm@linux-foundation.org: coding-style fixes] Signed-off-by: mark gross <mgross@linux.intel.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-01Merge branch 'reg-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6 * 'reg-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/lrg/voltage-2.6: regulator: TI bq24022 Li-Ion Charger driver regulator: maintainers - add maintainers for regulator framework. regulator: documentation - ABI regulator: documentation - machine regulator: documentation - regulator driver regulator: documentation - consumer interface regulator: documentation - overview regulator: core kbuild files regulator: regulator test harness regulator: add support for fixed regulators. regulator: regulator framework core regulator: fixed regulator interface regulator: machine driver interface regulator: regulator driver interface regulator: consumer device interface
2008-07-30regulator: documentation - machineLiam Girdwood
This adds documenation describing the regulator machine interface. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com>
2008-07-30regulator: documentation - regulator driverLiam Girdwood
This adds documentation describing the regulator driver interface. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com>
2008-07-30regulator: documentation - consumer interfaceLiam Girdwood
This adds documentation describing the consumer device interface. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com>
2008-07-30regulator: documentation - overviewLiam Girdwood
This adds overview documentation describing the regulator framework and nomenclature used in the interface specific documentation and code. Signed-off-by: Liam Girdwood <lg@opensource.wolfsonmicro.com>
2008-07-30Merge branch 'master' of /home/cbou/linux-2.6Anton Vorontsov
Conflicts: drivers/power/Kconfig drivers/power/Makefile
2008-07-24pm: remove obsolete piece of PM documentationRafael J. Wysocki
Remove some obsolete PM documentation. The majority of contents of Documentation/power/pm.txt are outdated. Remove the outdated parts of this file and move the rest to Documentation/power/apm-acpi.txt . Update the index in Documentation/power/ as appropriate. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-05-13power_supply: add CHARGE_COUNTER property and olpc_battery support for itAndres Salomon
This adds PROP_CHARGE_COUNTER to the power supply class (documenting it as well). The OLPC battery driver uses this for spitting out its ACR values (in uAh). We have some rounding errors (the data sheet claims 416.7, the math actually works out to 416.666667, so we're forced to choose between overflows or precision loss. I chose precision loss, and stuck w/ data sheet values), but I don't think anyone will care that much. Signed-off-by: Andres Salomon <dilinger@debian.org> Signed-off-by: Anton Vorontsov <cbouatmailru@gmail.com>
2008-04-19PM: Handle device registrations during suspend/resumeRafael J. Wysocki
Modify the PM core to protect its data structures, specifically the dpm_active list, from being corrupted if a child of the currently suspending device is registered concurrently with its ->suspend() callback. In that case, since the new device (the child) is added to dpm_active after its parent, the PM core will attempt to suspend it after the parent, which is wrong. Introduce a new member of struct dev_pm_info, called 'sleeping', and use it to check if the parent of the device being added to dpm_active has been suspended, in which case the device registration fails. Also, use 'sleeping' for checking if the ordering of devices on dpm_active is correct. Introduce variable 'all_sleeping' that will be set to 'true' once all devices have been suspended and make new device registrations fail until 'all_sleeping' is reset to 'false', in order to avoid having unsuspended devices around while the system is going into a sleep state. Remove pm_sleep_rwsem which is not necessary any more. Special thanks to Alan Stern for discussions and suggestions that lead to the creation of this patch. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-12documentation: Move power-related files to Documentation/power/Randy Dunlap
Move 00-INDEX entries to power/00-INDEX (and add entry for pm_qos_interface.txt). Update references to moved filenames. Fix some trailing whitespace. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-23PM: Introduce PM_EVENT_HIBERNATE callback stateRafael J. Wysocki
During the last step of hibernation in the "platform" mode (with the help of ACPI) we use the suspend code, including the devices' ->suspend() methods, to prepare the system for entering the ACPI S4 system sleep state. But at least for some devices the operations performed by the ->suspend() callback in that case must be different from its operations during regular suspend. For this reason, introduce the new PM event type PM_EVENT_HIBERNATE and pass it to the device drivers' ->suspend() methods during the last phase of hibernation, so that they can distinguish this case and handle it as appropriate. Modify the drivers that handle PM_EVENT_SUSPEND in a special way and need to handle PM_EVENT_HIBERNATE in the same way. These changes are necessary to fix a hibernation regression related to the i915 driver (ref. http://lkml.org/lkml/2008/2/22/488). Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Tested-by: Jeff Chua <jeff.chua.linux@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-07PM: documentation cleanupsPavel Machek
Signed-off-by: Pavel Machek <pavel@suse.cz> Acked-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01PM: Remove obsolete /sys/devices/.../power/state docsDavid Brownell
The /sys/devices/.../power/state files have been gone for a while now, but I just noticed some documentation that still refers to them. (Fortunately described as DEPRECATED and WILL REMOVE). Time to remove that obsolete documentation too ... Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01PM: Suspend/hibernation debug documentation update (rev. 2)Rafael J. Wysocki
Update the suspend/hibernation debugging and testing documentation to describe the newly introduced testing facilities. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Hibernation: Add PM_RESTORE_PREPARE and PM_POST_RESTORE notifiers (rev. 2)Alan Stern
Add PM_RESTORE_PREPARE and PM_POST_RESTORE notifiers to the PM core, to be used in analogy with the existing PM_HIBERNATION_PREPARE and PM_POST_HIBERNATION notifiers. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: "Rafael J. Wysocki" <rjw@sisk.pl> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Hibernation: Introduce exportable suspend ioctls header (rev. 2)Rafael J. Wysocki
Move the definitions of hibernation ioctls to a separate header file in include/linux, which can be exported to the user space. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
2008-02-01Hibernation: Correct definitions of some ioctls (rev. 2)Rafael J. Wysocki
Three ioctl numbers belonging to the hibernation userland interface, SNAPSHOT_ATOMIC_SNAPSHOT, SNAPSHOT_AVAIL_SWAP, SNAPSHOT_GET_SWAP_PAGE, are defined in a wrong way (eg. not portable). Provide new ioctl numbers for these ioctls and mark the existing ones as deprecated. Signed-off-by: Rafael J. Wysocki <rjw@sisk.pl> Acked-by: Pavel Machek <pavel@ucw.cz> Signed-off-by: Len Brown <len.brown@intel.com>
