path: root/Documentation/ramdisk.txt
2007-10-17Remove final traces of long-deprecated "ramdisk" kernel parmRobert P. J. Day
Since the "ramdisk" kernel parameter has been officially deprecated since at least 2.6.18, might as well finally get rid of it. Signed-off-by: Robert P. J. Day <rpjday@mindspring.com> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-17docs: ramdisk/initrd/initramfs correctionsRandy Dunlap
initrd/initramfs/ramdisk docs: - fix typos/spellos/grammar - clarify RAM disk config location - correct cpio option Acked-by: Bryan O'Sullivan <bos@serpentine.com> Acked-by: Rob Landley <rob@landley.net> Cc: Werner Almesberger <werner@almesberger.net> Cc: H. Peter Anvin <hpa@zytor.com> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-07-14[PATCH] Update ramdisk documentationNathan Scott
The default ramdisk blocksize is actually 1024, not 512 bytes. Also fixes up some trailing whitespace issues. Signed-off-by: Nathan Scott <nathans@sgi.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
