path: root/Documentation/rbtree.txt
2010-11-11Documentation: remove anticipatory scheduler infoRandy Dunlap
Remove anticipatory block I/O scheduler info from Documentation/ since the code has been deleted. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Reported-by: "Robert P. J. Day" <rpjday@crashcourse.ca> Cc: Jens Axboe <axboe@kernel.dk> Signed-off-by: Jens Axboe <jaxboe@fusionio.com>
2010-02-18rbtree: Add support for augmented rbtreesPallipadi, Venkatesh
Add support for augmented rbtrees in core rbtree code. This will be used in subsequent patches, in x86 PAT code, which needs interval trees to efficiently keep track of PAT ranges. Signed-off-by: Venkatesh Pallipadi <venkatesh.pallipadi@intel.com> LKML-Reference: <20100210232343.GA11465@linux-os.sc.intel.com> Signed-off-by: Suresh Siddha <suresh.b.siddha@intel.com> Signed-off-by: H. Peter Anvin <hpa@zytor.com>
2009-06-12trivial: rbtree.txt: fix rb_entry() parameters in sample codeWang Tinggong
Reviewed-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-12trivial: Documentation/rbtree.txt: cleanup kerneldoc of rbtree.txtfigo.zhang
The first formal parameter of the rb_link_node() is a pointer, and the "node" is define a data struct (pls see line 67 and line 73 in the doc), so the actual parameter should use "&data->node". Signed-off-by: Figo.zhang <figo.zhang@kolorific.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2007-02-11[PATCH] Documentation/rbtree.txtRob Landley
Documentation for lib/rbtree.c. Signed-off-by: Rob Landley <rob@landley.net> Cc: "Randy.Dunlap" <rdunlap@xenotime.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
