path: root/Documentation/rtc.txt
2012-10-06rtc-proc: permit the /proc/driver/rtc device to use other devicesKim, Milo
To get time information via /proc/driver/rtc, only the first device (rtc0) is used. If the rtcN (eg. rtc1 or rtc2) is used for the system clock, there is no way to get information of rtcN via /proc/driver/rtc. With this patch, the time data can be retrieved from the system clock RTC. If the RTC_HCTOSYS_DEVICE is not defined, then rtc0 is used by default. Signed-off-by: Milo(Woogyom) Kim <milo.kim@ti.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-03-09RTC: Fix up rtc.txt documentation to reflect changes to generic rtc layerJohn Stultz
Now that the genric RTC layer handles much of the RTC functionality, the rtc.txt documentation needs to be updated to remove outdated information. CC: Thomas Gleixner <tglx@linutronix.de> CC: Alessandro Zummo <a.zummo@towertech.it> CC: Marcelo Roberto Jimenez <mroberto@cpti.cetuc.puc-rio.br> CC: rtc-linux@googlegroups.com Signed-off-by: John Stultz <john.stultz@linaro.org>
2009-09-23rtc: add boot_timesource sysfs attributeMatthew Garrett
CONFIG_RTC_HCTOSYS allows the kernel to read the system time from the RTC at boot and resume, avoiding the need for userspace to do so. Unfortunately userspace currently has no way to know whether this configuration option is enabled and thus cannot sensibly choose whether to run hwclock itself or not. Add a hctosys sysfs attribute which indicates whether a given RTC set the system clock. Signed-off-by: Matthew Garrett <mjg@redhat.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23rtc: document the sysfs interfaceMatthew Garrett
The sysfs interface to the RTC class drivers is currently undocumented. Add some basic documentation defining the semantics of the fields. Signed-off-by: Matthew Garrett <mjg@redhat.com> Cc: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23rtc: update documentation wrt RTC_PIE/irq_set_stateMike Frysinger
Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc: cleanup example codeMike Frysinger
No functional changes here, just tighten up style/whitespace. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-02-06rtc: update documentation wrt irq_set_freqMike Frysinger
Document the proper use of the irq_set_freq function. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-11-14rtc: tweak driver documentation for rtc periodicMike Frysinger
The max_user_freq member is not really meant for RTC drivers to modify, so update the rtc documentation so drivers writers know what is expected of them when handling periodic events. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-17rtc: make example code jump to done instead of return when ioctl not supportedHans-Christian Egtvedt
Signed-off-by: Hans-Christian Egtvedt <hcegtvedt@atmel.com> Cc: Haavard Skinnemoen <hskinnemoen@atmel.com> Cc: David Brownell <david-b@pacbell.net> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-05-08rtc: remove "RTC_ALM_SET mode" bugsDavid Brownell
This fixes a common glitch in how RTC drivers handle two "set alarm" modes, by getting rid of the surprising/hidden one that was rarely implemented correctly (and which could expose nonportable hardware-specific behavior). The glitch comes from the /dev/rtcX logic implementing the legacy RTC_ALM_SET (limited to 24 hours, needing RTC_AIE_ON) ioctl on top of the RTC driver call providing access to the newer RTC_WKALM_SET (without those limitations) by initializing the day/month/year fields to be invalid ... that second mode. Now, since few RTC drivers check those fields, and most hardware misbehaves when faced with invalid date fields, many RTC drivers will set bogus alarm times on those RTC_ALM_SET code paths. (Several in-tree drivers have that issue, and I also noticed it with code reviews on several new RTC drivers.) This patch ensures that RTC drivers never see such invalid alarm fields, by moving some logic out of rtc-omap into the RTC_ALM_SET code and adding an explicit check (which will prevent the issue on other code paths). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Scott Wood <scottwood@freescale.com> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-02-11[PATCH] some rtc documentation updatesMike Frysinger
Fix typo when describing RTC_WKALM. Add some helpful pointers to people developing their own RTC driver. Change a bunch of the error messages in the test program to be a bit more helpful. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-11-25[PATCH] Documentation/rtc.txt updates (for rtc class)David Brownell
This updates the RTC documentation to summarize the two APIs now available: the old PC/AT one, and the new RTC class drivers. It also updates the included "rtctest.c" file to better meet Linux style guidelines, and to work with the new RTC drivers. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-06-25[PATCH] rtc: small documentation updateJean Delvare
Rtc driver documentation update * Mention the max-user-freq control file. * Add missing header in example code. Signed-off-by: Jean Delvare <khali@linux-fr.org> Cc: Alessandro Zummo <a.zummo@towertech.it> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
