path: root/Documentation/s390/cds.txt
2009-01-06documentation: update s390 header file pathsRandy Dunlap
Update Documentation/s390/ files to reflect changed header files locations. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-01-24Documentation: Replace obsolete "driverfs" with "sysfs".Robert P. J. Day
2007-10-12[S390] cio: Documentation update.Cornelia Huck
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-05-21[S390] cio: Update documentation.Cornelia Huck
- read_dev_chars()/read_conf_data() are deprecated. Don't document them, but advise to issue the channel program from the driver itself. - Remove some really obsolete and incorrect stuff. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] Some documentation typos.Nicolas Kaiser
Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-10-18[S390] cio: update documentation.Cornelia Huck
2006-10-03Fix typos in Documentation/: 'Q'-'R'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'Q'-'R'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix "can not" in Documentation and KconfigMatt LaPlante
Randy brought it to my attention that in proper english "can not" should always be written "cannot". I donot see any reason to argue, even if I mightnot understand why this rule exists. This patch fixes "can not" in several Documentation files as well as three Kconfigs. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'N'-'P'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'N'-'P'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'H'-'M'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'H'-'M'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'D'-'E'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'D'-'E'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix some typos in Documentation/: 'A'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letter 'A'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2005-05-01[PATCH] s390: cio documentationCornelia Huck
Synchronize documentation with current interface. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
