path: root/Documentation/s390
2007-05-21[S390] cio: Update documentation.Cornelia Huck
- read_dev_chars()/read_conf_data() are deprecated. Don't document them, but advise to issue the channel program from the driver itself. - Remove some really obsolete and incorrect stuff. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-05-09documentation: convert the Documentation directory to UTF-8John Anthony Kazos Jr
Convert files within the Documentation directory to UTF-8. Adrian Bunk: small additional fixes Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-04-27[S390] crypto: cleanup.Jan Glauber
Cleanup code and remove obsolete documentation. Signed-off-by: Jan Glauber <jan.glauber@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2007-04-27[S390] zfcpdump support.Michael Holzheu
s390 machines provide hardware support for creating Linux dumps on SCSI disks. For creating a dump a special purpose dump Linux is used. The first 32 MB of memory are saved by the hardware before the dump Linux is booted. Via an SCLP interface, the saved memory can be accessed from Linux. This patch exports memory and registers of the crashed Linux to userspace via a debugfs file. For more information refer to Documentation/s390/zfcpdump.txt, which is included in this patch. Signed-off-by: Michael Holzheu <holzheu@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com>
2007-02-05[S390] Fix register usage description.Heiko Carstens
Fix description of register usage as pointed out by Andreas Krebbel. Since this document is completely outdated and would need a lot of fixing, it might be worth considering to get rid of it... Signed-off-by: Heiko Carstens <heiko.carstens@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-08[S390] Update documentation for dynamic subchannel mapping.Cornelia Huck
Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-12-04[S390] Some documentation typos.Nicolas Kaiser
Signed-off-by: Nicolas Kaiser <nikai@nikai.net> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com>
2006-11-30Fix typos in /Documentation : 'T''Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some +words starting with the letter 'T'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-18[S390] cio: update documentation.Cornelia Huck
2006-10-03Documentation: remove duplicated wordsPaolo Ornati
Remove many duplicated words under Documentation/ and do other small cleanups. Examples: "and and" --> "and" "in in" --> "in" "the the" --> "the" "the the" --> "to the" ... Signed-off-by: Paolo Ornati <ornati@fastwebnet.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'S'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letter 'S'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Alan Cox <alan@redhat.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'Q'-'R'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'Q'-'R'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix "can not" in Documentation and KconfigMatt LaPlante
Randy brought it to my attention that in proper english "can not" should always be written "cannot". I donot see any reason to argue, even if I mightnot understand why this rule exists. This patch fixes "can not" in several Documentation files as well as three Kconfigs. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'N'-'P'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'N'-'P'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'H'-'M'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'H'-'M'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'F'-'G'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'F'-'G'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'D'-'E'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'D'-'E'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'B'-'C'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'B'-'C'. There are also a few grammar fixes thrown in for Randy. ;) Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix some typos in Documentation/: 'A'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letter 'A'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03remove mentionings of devfs in documentationAdrian Bunk
Now that devfs is removed, there's no longer any need to document how to do this or that with devfs. This patch includes some improvements by Joe Perches. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-03-24[PATCH] s390: cio documentation updateCornelia Huck
Update documentation of the common I/O layer: - Add MSS-specific example. - Add more information on ccwgroup devices. - Add channel path type attribute. - Fix typo. Signed-off-by: Cornelia Huck <cornelia.huck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-09[PATCH] s390: "extern inline" -> "static inline"Adrian Bunk
"extern inline" -> "static inline" Signed-off-by: Adrian Bunk <bunk@stusta.de> Cc: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-11-07[PATCH] s390: documentation updateCornelia Huck
Fix typos and add a section about cpus in the driver-model documentation. Signed-off-by: Cornelia Huck <cohuck@de.ibm.com> Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-09-10[PATCH] Spelling fixes for Documentation/Tobias Klauser
The attached patch fixes the following spelling errors in Documentation/ - double "the" - Several misspellings of function/functionality - infomation - memeory - Recieved - wether and possibly others which I forgot ;-) Trailing whitespaces on the same line as the typo are also deleted. Signed-off-by: Tobias Klauser <tklauser@nuerscht.ch> Signed-off-by: Domen Puncer <domen@coderock.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-25[PATCH] s390: debug feature changesMichael Holzheu
This patch changes the memory allocation method for the s390 debug feature. Trace buffers had been allocated using the get_free_pages() function before. Therefore it was not possible to get big memory areas in a running system due to memory fragmentation. Now the trace buffers are subdivided into several subbuffers with pagesize. Therefore it is now possible to allocate more memory for the trace buffers and more trace records can be written. In addition to that, dynamic specification of the size of the trace buffers is implemented. It is now possible to change the size of a trace buffer using a new debugfs file instance. When writing a number into this file, the trace buffer size is changed to 'number * pagesize'. In the past all the traces could be obtained from userspace by accessing files in the "proc" filesystem. Now with debugfs we have a new filesystem which should be used for debugging purposes. This patch moves the debug feature from procfs to debugfs. Since the interface of debug_register() changed, all device drivers, which use the debug feature had to be adjusted. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-06-21[PATCH] s390: cio documentationCornelia Huck
Some clarifications in the cio documentation. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-05-01[PATCH] s390: cio documentationCornelia Huck
Synchronize documentation with current interface. Signed-off-by: Martin Schwidefsky <schwidefsky@de.ibm.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
