path: root/Documentation/scsi/00-INDEX
2008-01-11[SCSI] 53c7xx: fix removal falloutAdrian Bunk
This patch does some additional cleanups after the 53c7xx removal. Signed-off-by: Adrian Bunk <bunk@kernel.org> Acked-by: Geert Uytterhoeven <geert@linux-m68k.org> Signed-off-by: James Bottomley <James.Bottomley@HansenPartnership.com>
2007-10-12[SCSI] Update Documentation/scsi/00-INDEXRob Landley
Update Documentation/scsi/00-INDEX to match current files. Signed-off-by: Rob Landley <rob@landley.net> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2006-06-10[SCSI] scsi: remove Documentation/scsi/cpqfc.txtArthur Othieno
cpqfc driver flushed out with: [SCSI] remove broken driver cpqfc (commit ca61f10ab2b874b889e89d14ea09fae2dcccdca6) but somehow Documentation/scsi/cpqfc.txt managed to survive the blast. Signed-off-by: Arthur Othieno <apgo@patchbomb.org> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-11-06[SCSI] remove the obsolete SCSI qlogicisp driverAdrian Bunk
The SCSI qlogicisp driver is both marked BROKEN and superseded by the qla1280 driver. Signed-off-by: Adrian Bunk <bunk@stusta.de> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
2005-09-10[SCSI] scsi: Error handler description documentTejun Heo
This patch adds Documentation/scsi/scs_eh.txt. I've chosen plain text over DocBook as most other scsi docs are in plain text and it's more accessible. Signed-off-by: Tejun Heo <htejun@gmail.com> Signed-off-by: James Bottomley <James.Bottomley@SteelEye.com>
