path: root/Documentation/serial
2010-03-12ldisc: new dcd_change() method for line disciplinesRodolfo Giometti
Signed-off-by: Rodolfo Giometti <giometti@linux.it> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Greg KH <greg@kroah.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Alexander Gordeev <lasaine@lvk.cs.msu.su> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-11tty: docs: serial/tty, add to ldisc methodsTilman Schmidt
A small addition to the ldisc method descriptions. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11tty: esp: remove broken driverAlan Cox
The ESP driver has been marked broken for years. It's an old ISA device that clearly nobody cares about any more. Remove it Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-14Create/use more directory structure in the Documentation/ tree.Randy Dunlap
Create Documentation/blockdev/ sub-directory and populate it. Populate the Documentation/serial/ sub-directory. Move MSI-HOWTO.txt to Documentation/PCI/. Move ioctl-number.txt to Documentation/ioctl/. Update all relevant 00-INDEX files. Update all relevant Kconfig files and source files. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com>
2008-07-20Subject: [PATCH 1/2] serial: Add flush_buffer() operation to uart_opsHaavard Skinnemoen
Serial drivers using DMA (like the atmel_serial driver) tend to get very confused when the xmit buffer is flushed and nobody told them. They also tend to spew a lot of garbage since the DMA engine keeps running after the buffer is flushed and possibly refilled with unrelated data. This patch adds a new flush_buffer operation to the uart_ops struct, along with a call to it from uart_flush_buffer() right after the xmit buffer has been cleared. The driver can implement this in order to syncronize its internal DMA state with the xmit buffer when the buffer is flushed. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-02[SERIAL] Update parity handling documentationPeter Korsgaard
Update documentation to match reality. INPCK controls whether input parity checking is enabled. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-15[SERIAL] Update serial driver documentationRussell King
Improve serial driver documentation: - Remove CVS id. - Update pointer to reference driver documentation. - Add comments about new uart_write_console function. - Add TIOCM_LOOP modem control bit description. - Add commentry about enable_ms method being called multiple times. - Add commentry about startup/shutdown method calling. - Mention that dereferencing port->info after shutdown is invalid. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-31[SERIAL] Update serial_core documentationRussell King
2005-08-31[SERIAL] Clean up and fix tty transmission start/stopingRussell King
The start_tx and stop_tx methods were passed a flag to indicate whether the start/stop was from the tty start/stop callbacks, and some drivers used this flag to decide whether to ask the UART to immediately stop transmission (where the UART supports such a feature.) There are other cases when we wish this to occur - when CTS is lowered, or if we change from soft to hard flow control and CTS is inactive. In these cases, this flag was false, and we would allow the transmitter to drain before stopping. There is really only one case where we want to let the transmitter drain before disabling, and that's when we run out of characters to send. Hence, re-jig the start_tx and stop_tx methods to eliminate this flag, and introduce new functions for the special "disable and allow transmitter to drain" case. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-29[PATCH] Serial: Adjust serial lockingRussell King
This patch changes the way serial ports are locked when getting modem status. This change is necessary because we will need to atomically read the modem status and take action depending on the CTS status. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
