path: root/Documentation/serial
2015-06-12Doc: serial-rs485.txt: update RS485 driver interfaceBaruch Siach
Since commit a5f276f10ff7 (serial_core: Handle TIOC[GS]RS485 ioctls., 2014-11-06) serial_core handles RS485 ioctls. Drivers only need to implement the rs485_config callback. Update serial-rs485.txt to reflect these changes. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-06-12Doc: tty.txt: remove mention of the BKLBaruch Siach
The BKL is long gone, no need to kill the dead. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2015-05-10pty: Fix input race when closingPeter Hurley
A read() from a pty master may mistakenly indicate EOF (errno == -EIO) after the pty slave has closed, even though input data remains to be read. For example, pty slave | input worker | pty master | | | | n_tty_read() pty_write() | | input avail? no add data | | sleep schedule worker --->| | . |---> flush_to_ldisc() | . pty_close() | fill read buffer | . wait for worker | wakeup reader --->| . | read buffer full? |---> input avail ? yes |<--- yes - exit worker | copy 4096 bytes to user TTY_OTHER_CLOSED <---| |<--- kick worker | | **** New read() before worker starts **** | | n_tty_read() | | input avail? no | | TTY_OTHER_CLOSED? yes | | return -EIO Several conditions are required to trigger this race: 1. the ldisc read buffer must become full so the input worker exits 2. the read() count parameter must be >= 4096 so the ldisc read buffer is empty 3. the subsequent read() occurs before the kicked worker has processed more input However, the underlying cause of the race is that data is pipelined, while tty state is not; ie., data already written by the pty slave end is not yet visible to the pty master end, but state changes by the pty slave end are visible to the pty master end immediately. Pipeline the TTY_OTHER_CLOSED state through input worker to the reader. 1. Introduce TTY_OTHER_DONE which is set by the input worker when TTY_OTHER_CLOSED is set and either the input buffers are flushed or input processing has completed. Readers/polls are woken when TTY_OTHER_DONE is set. 2. Reader/poll checks TTY_OTHER_DONE instead of TTY_OTHER_CLOSED. 3. A new input worker is started from pty_close() after setting TTY_OTHER_CLOSED, which ensures the TTY_OTHER_DONE state will be set if the last input worker is already finished (or just about to exit). Remove tty_flush_to_ldisc(); no in-tree callers. Fixes: 52bce7f8d4fc ("pty, n_tty: Simplify input processing on final close") Bugzilla: https://bugzilla.kernel.org/show_bug.cgi?id=96311 BugLink: http://bugs.launchpad.net/bugs/1429756 Cc: <stable@vger.kernel.org> # 3.19+ Reported-by: Andy Whitcroft <apw@canonical.com> Reported-by: H.J. Lu <hjl.tools@gmail.com> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-11-05serial: Fix locking for uart driver set_termios() methodPeter Hurley
The low-level uart driver may modify termios settings to override settings that are not compatible with the uart, such as CRTSCTS. Thus, callers of the low-level uart driver's set_termios() method must hold termios_rwsem write lock to prevent concurrent access to termios, in case such override occurs. The termios_rwsem lock requirement does not extend to console setup (ie., uart_set_options), as console setup cannot race with tty operations. Nor does this lock requirement extend to functions which cannot be concurrent with tty ioctls (ie., uart_port_startup() and uart_resume_port()). Further, always claim the port mutex to protect hardware re-reprogramming in the set_termios() uart driver method. Note this is unnecessary for console initialization in uart_set_options() which cannot be concurrent with other uart operations. Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-10-08Merge tag 'tty-3.18-rc1' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty Pull tty/serial driver updates from Greg KH: "Here's the big tty/serial driver patchset for 3.18-rc1. Lots of little things in here, some good work from Peter Hurley on the tty core, and in lots of drivers. There are also lots of other driver updates in here as well, full details in the changelogs. All have been in the linux-next tree for a while" * tag 'tty-3.18-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/tty: (99 commits) Revert "serial/core: Initialize the console pm state" tty: serial: 8250: use 32bit variable for rpm_tx_active tty: serial: msm: Add earlycon support serial/core: Initialize the console pm state serial: asc: Conditionally use readl_relaxed (COMPILE_TEST) serial: of-serial: add PM suspend/resume support m68k: AMIGA_BUILTIN_SERIAL should depend on TTY asm/uapi: Add definition of TIOC[SG]RS485 tty/metag_da: Add console_poll module parameter serial: 8250_pci: remove rts_n override from Baytrail quirk serial: cadence: Add generic earlycon support serial: imx: change the wait even to interruptiable serial: imx: terminate the RX DMA when the UART is suspending serial: imx: fix throttle/unthrottle callbacks for hardware assisted flow control serial: 8250: Add Quark X1000 to 8250_pci.c tty: omap-serial: pull out calculation from baud_is_mode16 tty: omap-serial: fix division by zero xen_hvc: no reason to write the type key on xenstore tty: serial: 8250_core: remove UART_IER_RDI in serial8250_stop_rx() tty: serial: 8250_core: use the ->line argument as a hint in serial8250_find_match_or_unused() ...
2014-09-08serial: Fix send_xchar() handlersPeter Hurley
START_CHAR() & STOP_CHAR() can be disabled if set to '\0' (__DISABLED_CHAR). UART drivers which define a send_xchar() handler must not transmit __DISABLED_CHAR. Document requirement. Affected drivers: sunsab sunhv cc: David S. Miller <davem@davemloft.net> cc: <sparclinux@vger.kernel.org> Signed-off-by: Peter Hurley <peter@hurleysoftware.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-08Documentation: serial: fix header pathYegor Yefremov
RS485 related structure will be defined in user space API header. Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-09-04tty: doc: Fix grammar in serial/ttyRichard Genoud
Correct spelling typos in serial/tty Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Acked-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-08-26Documentation: serial: fix header pathYegor Yefremov
RS485 related structure will be defined in user space API header. Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-05-28tty/serial: Add GPIOLIB helpers for controlling modem linesRichard Genoud
This patch add some helpers to control modem lines (CTS/RTS/DSR...) via GPIO. This will be useful for many boards which have a serial controller that only handle CTS/RTS pins (or even just RX/TX). Signed-off-by: Richard Genoud <richard.genoud@gmail.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Tested-by: Yegor Yefremov <yegorslists@googlemail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-16Documentation/serial: Delete obsolete driver documentationJean Delvare
These serial drivers were removed in kernel v3.1, so we can drop their documentation files and references to their magic numbers and parameters. There are still references to these old drivers in Documentation/devices.txt but I'm afraid they can't be removed. Signed-off-by: Jean Delvare <jdelvare@suse.de> Cc: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Cc: Jiri Slaby <jslaby@suse.cz> Cc: Rob Landley <rob@landley.net> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-02-10Documentation/: update 00-INDEX filesHenrik Austad
Some of the 00-INDEX files are somewhat outdated and some folders does not contain 00-INDEX at all. Only outdated (with the notably exception of spi) indexes are touched here, the 169 folders without 00-INDEX has not been touched. New 00-INDEX - spi/* was added in a series of commits dating back to 2006 Added files (missing in (*/)00-INDEX) - dmatest.txt was added by commit 851b7e16a07d ("dmatest: run test via debugfs") - this_cpu_ops.txt was added by commit a1b2a555d637 ("percpu: add documentation on this_cpu operations") - ww-mutex-design.txt was added by commit 040a0a371005 ("mutex: Add support for wound/wait style locks") - bcache.txt was added by commit cafe56359144 ("bcache: A block layer cache") - kernel-per-CPU-kthreads.txt was added by commit 49717cb40410 ("kthread: Document ways of reducing OS jitter due to per-CPU kthreads") - phy.txt was added by commit ff764963479a ("drivers: phy: add generic PHY framework") - block/null_blk was added by commit 12f8f4fc0314 ("null_blk: documentation") - module-signing.txt was added by commit 3cafea307642 ("Add Documentation/module-signing.txt file") - assoc_array.txt was added by commit 3cb989501c26 ("Add a generic associative array implementation.") - arm/IXP4xx was part of the initial repo - arm/cluster-pm-race-avoidance.txt was added by commit 7fe31d28e839 ("ARM: mcpm: introduce helpers for platform coherency exit/setup") - arm/firmware.txt was added by commit 7366b92a77fc ("ARM: Add interface for registering and calling firmware-specific operations") - arm/kernel_mode_neon.txt was added by commit 2afd0a05241d ("ARM: 7825/1: document the use of NEON in kernel mode") - arm/tcm.txt was added by commit bc581770cfdd ("ARM: 5580/2: ARM TCM (Tightly-Coupled Memory) support v3") - arm/vlocks.txt was added by commit 9762f12d3e05 ("ARM: mcpm: Add baremetal voting mutexes") - blackfin/gptimers-example.c, Makefile was added by commit 4b60779d5ea7 ("Blackfin: add an example showing how to use the gptimers API") - devicetree/usage-model.txt was added by commit 31134efc681a ("dt: Linux DT usage model documentation") - fb/api.txt was added by commit fb21c2f42879 ("fbdev: Add FOURCC-based format configuration API") - fb/sm501.txt was added by commit e6a049807105 ("video, sm501: add edid and commandline support") - fb/udlfb.txt was added by commit 96f8d864afd6 ("fbdev: move udlfb out of staging.") - filesystems/Makefile was added by commit 1e0051ae48a2 ("Documentation/fs/: split txt and source files") - filesystems/nfs/nfsd-admin-interfaces.txt was added by commit 8a4c6e19cfed ("nfsd: document kernel interfaces for nfsd configuration") - ide/warm-plug-howto.txt was added by commit f74c91413ec6 ("ide: add warm-plug support for IDE devices (take 2)") - laptops/Makefile was added by commit d49129accc21 ("Documentation/laptop/: split txt and source files") - leds/leds-blinkm.txt was added by commit b54cf35a7f65 ("LEDS: add BlinkM RGB LED driver, documentation and update MAINTAINERS") - leds/ledtrig-oneshot.txt was added by commit 5e417281cde2 ("leds: add oneshot trigger") - leds/ledtrig-transient.txt was added by commit 44e1e9f8e705 ("leds: add new transient trigger for one shot timer activation") - m68k/README.buddha was part of the initial repo - networking/LICENSE.(qla3xxx|qlcnic|qlge) was added by commits 40839129f779, c4e84bde1d59, 5a4faa873782 - networking/Makefile was added by commit 3794f3e812ef ("docsrc: build Documentation/ sources") - networking/i40evf.txt was added by commit 105bf2fe6b32 ("i40evf: add driver to kernel build system") - networking/ipsec.txt was added by commit b3c6efbc36e2 ("xfrm: Add file to document IPsec corner case") - networking/mac80211-auth-assoc-deauth.txt was added by commit 3cd7920a2be8 ("mac80211: add auth/assoc/deauth flow diagram") - networking/netlink_mmap.txt was added by commit 5683264c3981 ("netlink: add documentation for memory mapped I/O") - networking/nf_conntrack-sysctl.txt was added by commit c9f9e0e1597f ("netfilter: doc: add nf_conntrack sysctl api documentation") lan) - networking/team.txt was added by commit 3d249d4ca7d0 ("net: introduce ethernet teaming device") - networking/vxlan.txt was added by commit d342894c5d2f ("vxlan: virtual extensible lan") - power/runtime_pm.txt was added by commit 5e928f77a09a ("PM: Introduce core framework for run-time PM of I/O devices (rev. 17)") - power/charger-manager.txt was added by commit 3bb3dbbd56ea ("power_supply: Add initial Charger-Manager driver") - RCU/lockdep-splat.txt was added by commit d7bd2d68aa2e ("rcu: Document interpretation of RCU-lockdep splats") - s390/kvm.txt was added by 5ecee4b (KVM: s390: API documentation) - s390/qeth.txt was added by commit b4d72c08b358 ("qeth: bridgeport support - basic control") - scheduler/sched-bwc.txt was added by commit 88ebc08ea9f7 ("sched: Add documentation for bandwidth control") - scsi/advansys.txt was added by commit 4bd6d7f35661 ("[SCSI] advansys: Move documentation to Documentation/scsi") - scsi/bfa.txt was added by commit 1ec90174bdb4 ("[SCSI] bfa: add readme file") - scsi/bnx2fc.txt was added by commit 12b8fc10eaf4 ("[SCSI] bnx2fc: Add driver documentation") - scsi/cxgb3i.txt was added by commit c3673464ebc0 ("[SCSI] cxgb3i: Add cxgb3i iSCSI driver.") - scsi/hpsa.txt was added by commit 992ebcf14f3c ("[SCSI] hpsa: Add hpsa.txt to Documentation/scsi") - scsi/link_power_management_policy.txt was added by commit ca77329fb713 ("[libata] Link power management infrastructure") - scsi/osd.txt was added by commit 78e0c621deca ("[SCSI] osd: Documentation for OSD library") - scsi/scsi-parameter.txt was created/moved by commit 163475fb111c ("Documentation: move SCSI parameters to their own text file") - serial/driver was part of the initial repo - serial/n_gsm.txt was added by commit 323e84122ec6 ("n_gsm: add a documentation") - timers/Makefile was added by commit 3794f3e812ef ("docsrc: build Documentation/ sources") - virt/kvm/s390.txt was added by commit d9101fca3d57 ("KVM: s390: diagnose call documentation") - vm/split_page_table_lock was added by commit 49076ec2ccaf ("mm: dynamically allocate page->ptl if it cannot be embedded to struct page") - w1/slaves/w1_ds28e04 was added by commit fbf7f7b4e2ae ("w1: Add 1-wire slave device driver for DS28E04-100") - w1/masters/omap-hdq was added by commit e0a29382c6f5 ("hdq: documentation for OMAP HDQ") - x86/early-microcode.txt was added by commit 0d91ea86a895 ("x86, doc: Documentation for early microcode loading") - x86/earlyprintk.txt was added by commit a1aade478862 ("x86/doc: mini-howto for using earlyprintk=dbgp") - x86/entry_64.txt was added by commit 8b4777a4b50c ("x86-64: Document some of entry_64.S") - x86/pat.txt was added by commit d27554d874c7 ("x86: PAT documentation") Moved files - arm/kernel_user_helpers.txt was moved out of arch/arm/kernel by commit 37b8304642c7 ("ARM: kuser: move interface documentation out of the source code") - efi-stub.txt was moved out of x86/ and down into Documentation/ in commit 4172fe2f8a47 ("EFI stub documentation updates") - laptops/hpfall.c was moved out of hwmon/ and into laptops/ in commit efcfed9bad88 ("Move hp_accel to drivers/platform/x86") - commit 5616c23ad9cd ("x86: doc: move x86-generic documentation from Doc/x86/i386"): * x86/usb-legacy-support.txt * x86/boot.txt * x86/zero_page.txt - power/video_extension.txt was moved to acpi in commit 70e66e4df191 ("ACPI / video: move video_extension.txt to Documentation/acpi") Removed files (left in 00-INDEX) - memory.txt was removed by commit 00ea8990aadf ("memory.txt: remove stray information") - gpio.txt was moved to gpio/ in commit fd8e198cfcaa ("Documentation: gpiolib: document new interface") - networking/DLINK.txt was removed by commit 168e06ae26dd ("drivers/net: delete old parallel port de600/de620 drivers") - serial/hayes-esp.txt was removed by commit f53a2ade0bb9 ("tty: esp: remove broken driver") - s390/TAPE was removed by commit 9e280f669308 ("[S390] remove tape block docu") - vm/locking was removed by commit 57ea8171d2bc ("mm: documentation: remove hopelessly out-of-date locking doc") - laptops/acer-wmi.txt was remvoed by commit 020036678e81 ("acer-wmi: Delete out-of-date documentation") Typos/misc issues - rpc-server-gss.txt was added as knfsd-rpcgss.txt in commit 030d794bf498 ("SUNRPC: Use gssproxy upcall for server RPCGSS authentication.") - commit b88cf73d9278 ("net: add missing entries to Documentation/networking/00-INDEX") * generic-hdlc.txt was added as generic_hdlc.txt * spider_net.txt was added as spider-net.txt - w1/master/mxc-w1 was added as mxc_w1 by commit a5fd9139f74c ("w1: add 1-wire master driver for i.MX27 / i.MX31") - s390/zfcpdump.txt was added as zfcpdump by commit 6920c12a407e ("[S390] Add Documentation/s390/00-INDEX.") Signed-off-by: Henrik Austad <henrik@austad.us> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> [rcu bits] Acked-by: Rob Landley <rob@landley.net> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <robh+dt@kernel.org> Cc: David S. Miller <davem@davemloft.net> Cc: Mark Brown <broonie@kernel.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Gleb Natapov <gleb@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Len Brown <len.brown@intel.com> Cc: James Bottomley <JBottomley@parallels.com> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2013-10-16serial: core: delete .set_wake() callbackLinus Walleij
This deletes the .set_wake() callback in the struct uart_ops. Apparently this has been unused since pre-git times. In the old-2.6-bkcvs it is deleted as part of a changeset removing the PM_SET_WAKEUP from pm_request_t which is since also deleted from the kernel. The apropriate way to set wakeups in the kernel is to have a code snippet like this in .suspend() or .runtime_suspend() callbacks: static int foo_suspend(struct device *dev) { if (device_may_wakeup(dev)) { /* Enable wakeups, set internal states */ } } This specific callback is not coming back. Cc: Rafael J. Wysocki <rjw@sisk.pl> Cc: Len Brown <len.brown@intel.com> Cc: Pavel Machek <pavel@ucw.cz> Cc: Kevin Hilman <khilman@deeprootsystems.com> Cc: Dmitry Artamonow <mad_soft@inbox.ru> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-06-03stallion: final cleanupPaul Bolle
Support for the Stallion multiport serial drivers was removed in v3.1. Clean up their last references in the tree: mainly an outdated Kconfig entry and unneeded documentation. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Acked-by: Arnd Bergmann <arnd@arndb.de> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15tty: Update serial core API documentationKevin Cernekee
Signed-off-by: Kevin Cernekee <cernekee@gmail.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2013-01-15tty: serial core: decouple pm states from ACPILinus Walleij
The serial core is using power states lifted from ACPI for no good reason. Remove this reference from the documentation and alter all users to use an enum specific to the serial core instead, and define it in <linux/serial_core.h>. Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Acked-by: Alan Cox <alan@linux.intel.com> Reviewed-by: Daniel Lezcano <daniel.lezcano@linaro.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-08-16firmware: remove computone driver firmware and documentationTim Gardner
The only Computone support left in the kernel is in drivers/tty/serial/8250/8250_pci.c. CONFIG_COMPUTONE is no longer a valid option. Therefore, remove firmware, documentation, and the last vestiges of this driver. Cc: Rob Landley <rob@landley.net> Cc: Paul Gortmaker <paul.gortmaker@windriver.com> Cc: Ben Hutchings <ben@decadent.org.uk> Cc: James Bottomley <JBottomley@Parallels.com> Cc: Dan Williams <dan.j.williams@intel.com> Signed-off-by: Tim Gardner <tim.gardner@canonical.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-05-17serial: delete the MCA specific 8250 support.Paul Gortmaker
The support for CONFIG_MCA is being removed, since the 20 year old hardware simply isn't capable of meeting today's software demands on CPU and memory resources. This commit removes the MCA specific 8250 UART code. Cc: Alan Cox <alan@linux.intel.com> Cc: linux-serial@vger.kernel.org Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Signed-off-by: Paul Gortmaker <paul.gortmaker@windriver.com>
2012-03-30Documentation: remove references to /etc/modprobe.confLucas De Marchi
Usage of /etc/modprobe.conf file was deprecated by module-init-tools and is no longer parsed by new kmod tool. References to this file are replaced in Documentation, comments and Kconfig according to the context. There are also some references to the old /etc/modules.conf from 2.4 kernels that are being removed. Signed-off-by: Lucas De Marchi <lucas.demarchi@profusion.mobi> Acked-by: Takashi Iwai <tiwai@suse.de> Acked-by: Mauro Carvalho Chehab <mchehab@redhat.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2012-01-04serial/documentation: fix documented name of DCD cpp symbolUwe Kleine-König
Signed-off-by: Uwe Kleine-König <u.kleine-koenig@pengutronix.de> Acked-by: Alan Cox <alan@linux.intel.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-15RS485: fix inconsistencies in the meaning of some variablesClaudio Scordino
The crisv10.c and the atmel_serial.c serial drivers intepret the fields of the serial_rs485 structure in a different way. In particular, crisv10.c uses SER_RS485_RTS_AFTER_SEND and SER_RS485_RTS_ON_SEND for the voltage of the RTS pin; atmel_serial.c, instead, uses these values to know if a delay must be set before and after sending. This patch makes the usage of these variables consistent across all drivers and fixes the Documentation as well. From now on, SER_RS485_RTS_AFTER_SEND and SER_RS485_RTS_ON_SEND will be used to set the voltage of the RTS pin (as in the crisv10.c driver); the delay will be understood by looking only at the value of delay_rts_before_send and delay_rts_after_send. Signed-off-by: Claudio Scordino <claudio@evidence.eu.com> Signed-off-by: Darron Black <darron@griffin.net> Acked-by: Jesper Nilsson <jesper.nilsson@axis.com> Acked-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-11-04Documentation: Computone ip2 is orphanedMarcos Paulo Souza
Removed the email for support and fixes for orphaned ip2 driver. Signed-off-by: Marcos Paulo de Souza <marcos.mage@gmail.com> Signed-off-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-10-18tty/serial: RS485 bindings for device treeNicolas Ferre
Generic bindings for RS485 feature included in some UARTs. Those bindings have to be used withing an UART device tree node. Documentation updated to link to the bindings definition. Signed-off-by: Nicolas Ferre <nicolas.ferre@atmel.com> Acked-by: Grant Likely <grant.likely@secretlab.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-08-24atmel_serial: RS485: receiving enabled when sending dataBernhard Roth
By default the atmel_serial driver in RS485 mode disables receiving data until all data in the send buffer has been sent. This flag allows to receive data even whilst sending data. Signed-off-by: Bernhard Roth <br@pwrnet.de> Signed-off-by: Claudio Scordino <claudio@evidence.eu.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-06-13doc: fix wrong arch/i386 referencesWanlong Gao
Change all "arch/i386" to "arch/x86" in Documentaion/, since the directory has changed. Also update the files which have changed their filename in the meantime accordingly. Signed-off-by: Wanlong Gao <wanlong.gao@gmail.com> [jkosina@suse.cz: reword changelog] Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-03-09n_gsm: add a documentationEric Bénard
* this documentation gives some details on how to get the n_gsm line discipline to work with modems supporting 07.10 basic option. * it was tested on Telit and Simcom modems. Signed-off-by: Eric Bénard <eric@eukrea.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2011-01-13pps: timestamp is always passed to dcd_change()Alexander Gordeev
Remove the code that gatheres timestamp in pps_tty_dcd_change() in case passed ts parameter is NULL because it never happens in the current code. Fix comments as well. Signed-off-by: Alexander Gordeev <lasaine@lvk.cs.msu.su> Acked-by: Rodolfo Giometti <giometti@linux.it> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2010-11-30RS485 documentation: add 16C950 UART descriptionYegor Yefremov
Add a notion about 16C950 UART, that is using DTR signal for RS485 mode. Signed-off-by: Yegor Yefremov <yegorslists@googlemail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-11-11serial: add Documentation about RS485 serial communicationsClaudio Scordino
Documentation about RS485 serial communications Signed-off-by: Claudio Scordino <claudio@evidence.eu.com> Acked-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Russell King <linux@arm.linux.org.uk> Acked-by: Grant Edwards <grant.b.edwards@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2010-08-04Documentation: update broken web addresses.Justin P. Mattock
Below you will find an updated version from the original series bunching all patches into one big patch updating broken web addresses that are located in Documentation/* Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult, the best way to deal with these is to use web.archive.org to locate these addresses that are outdated. Now there are also some addresses pointing to .spec files some are located, but some(after searching on the companies site)where still no where to be found. In this case I just changed the address to the company site this way the users can contact the company and they can locate them for the users. Signed-off-by: Justin P. Mattock <justinmattock@gmail.com> Signed-off-by: Thomas Weber <weber@corscience.de> Signed-off-by: Mike Frysinger <vapier.adi@gmail.com> Cc: Paulo Marques <pmarques@grupopie.com> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Michael Neuling <mikey@neuling.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2010-03-12ldisc: new dcd_change() method for line disciplinesRodolfo Giometti
Signed-off-by: Rodolfo Giometti <giometti@linux.it> Cc: David Woodhouse <dwmw2@infradead.org> Cc: Greg KH <greg@kroah.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Alexander Gordeev <lasaine@lvk.cs.msu.su> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-12-11tty: docs: serial/tty, add to ldisc methodsTilman Schmidt
A small addition to the ldisc method descriptions. Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-12-11tty: esp: remove broken driverAlan Cox
The ESP driver has been marked broken for years. It's an old ISA device that clearly nobody cares about any more. Remove it Signed-off-by: Alan Cox <alan@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-14Create/use more directory structure in the Documentation/ tree.Randy Dunlap
Create Documentation/blockdev/ sub-directory and populate it. Populate the Documentation/serial/ sub-directory. Move MSI-HOWTO.txt to Documentation/PCI/. Move ioctl-number.txt to Documentation/ioctl/. Update all relevant 00-INDEX files. Update all relevant Kconfig files and source files. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com>
2008-07-20Subject: [PATCH 1/2] serial: Add flush_buffer() operation to uart_opsHaavard Skinnemoen
Serial drivers using DMA (like the atmel_serial driver) tend to get very confused when the xmit buffer is flushed and nobody told them. They also tend to spew a lot of garbage since the DMA engine keeps running after the buffer is flushed and possibly refilled with unrelated data. This patch adds a new flush_buffer operation to the uart_ops struct, along with a call to it from uart_flush_buffer() right after the xmit buffer has been cleared. The driver can implement this in order to syncronize its internal DMA state with the xmit buffer when the buffer is flushed. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Acked-by: Alan Cox <alan@redhat.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-06-02[SERIAL] Update parity handling documentationPeter Korsgaard
Update documentation to match reality. INPCK controls whether input parity checking is enabled. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-04-15[SERIAL] Update serial driver documentationRussell King
Improve serial driver documentation: - Remove CVS id. - Update pointer to reference driver documentation. - Add comments about new uart_write_console function. - Add TIOCM_LOOP modem control bit description. - Add commentry about enable_ms method being called multiple times. - Add commentry about startup/shutdown method calling. - Mention that dereferencing port->info after shutdown is invalid. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-10-31[SERIAL] Update serial_core documentationRussell King
2005-08-31[SERIAL] Clean up and fix tty transmission start/stopingRussell King
The start_tx and stop_tx methods were passed a flag to indicate whether the start/stop was from the tty start/stop callbacks, and some drivers used this flag to decide whether to ask the UART to immediately stop transmission (where the UART supports such a feature.) There are other cases when we wish this to occur - when CTS is lowered, or if we change from soft to hard flow control and CTS is inactive. In these cases, this flag was false, and we would allow the transmitter to drain before stopping. There is really only one case where we want to let the transmitter drain before disabling, and that's when we run out of characters to send. Hence, re-jig the start_tx and stop_tx methods to eliminate this flag, and introduce new functions for the special "disable and allow transmitter to drain" case. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2005-06-29[PATCH] Serial: Adjust serial lockingRussell King
This patch changes the way serial ports are locked when getting modem status. This change is necessary because we will need to atomically read the modem status and take action depending on the CTS status. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
