path: root/Documentation/spi/pxa2xx
2011-06-18spi/pxa2xx: Remove unavailable ssp_type from documentationStefan Schmidt
Since commit commit 2f1a74e5a2de0459139b85af95e901448726c375 Author: eric miao <eric.miao@marvell.com> Date: Wed Nov 21 18:50:53 2007 +0800 [ARM] pxa: make pxa2xx_spi driver use ssp_request()/ssp_free() the ssp_type field in struct pxa2xx_spi_master is no longer available. Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-01arm/pxa2xx: reorgazine SSP and SPI header filesSebastian Andrzej Siewior
The PXA-SPI driver relies on some files / defines which are arm specific and are within the ARM tree. The CE4100 SoC which is x86 has also the SPI core. This patch moves the ssp and spi files from arm/mach-pxa and plat-pxa to include/linux where the CE4100 can access them. This move got verified by building the following defconfigs: cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig raumfeld_defconfig magician_defconfig Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
2008-10-16pxa2xx_spi: fix chip_info defaults and documentation.Vernon Sauder
Make the chip info structure data optional by providing reasonable defaults. Improve corresponding documentation, and highlight the drawback of not providing explicit chipselect control. DMA can determine appropriate dma_burst_size and thresholds automatically so use DMA even if dma_burst_size is not specified. Signed-off-by: Vernon Sauder <VernonInHand@gmail.com> Reviewed-by: Ned Forrester <nforrester@whoi.edu> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-04-21[ARM] 4304/1: removes the unnecessary bit number from CKENnn_XXXXEric Miao
This patch removes the unnecessary bit number from CKENnn_XXXX definitions for PXA, so that CKEN0_PWM0 --> CKEN_PWM0 CKEN1_PWM1 --> CKEN_PWM1 ... CKEN24_CAMERA --> CKEN_CAMERA The reasons for the change of these defitions are: 1. they do not scale - they are currently valid for pxa2xx, but definitely not valid for pxa3xx, e.g., pxa3xx has bit 3 for camera instead of bit 24 2. they are unnecessary - the peripheral name within the definition has already announced its usage, we don't need those bit numbers to know which peripheral we are going to enable/disable clock for 3. they are inconvenient - think about this: a driver programmer for pxa has to remember which bit in the CKEN register to turn on/off Another change in the patch is to make the definitions equal to its clock bit index, so that #define CKEN_CAMERA (24) instead of #define CKEN_CAMERA (1 << 24) this change, however, will add a run-time bit shift operation in pxa_set_cken(), but the benefit of this change is that it scales when bit index exceeds 32, e.g., pxa3xx has two registers CKENA and CKENB, totally 64 bit for this, suppose CAMERA clock enabling bit is CKENB:10, one can simply define CKEN_CAMERA to be (32 + 10) and so that pxa_set_cken() need minimum change to adapt to that. Signed-off-by: eric miao <eric.y.miao@gmail.com> Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2006-12-10[PATCH] spi: stabilize PIO mode transfers on PXA2xx systemsStephen Street
Stabilize PIO mode transfers against a range of word sizes and FIFO thresholds and fixes word size setup/override issues. 1) 16 and 32 bit DMA/PIO transfers broken due to timing differences. 2) Potential for bad transfer counts due to transfer size assumptions. 3) Setup function broken is multiple ways. 4) Per transfer bit_per_word changes break DMA setup in pump_tranfers. 5) False positive timeout are not errors. 6) Changes in pxa2xx_spi_chip not effective in calls to setup. 7) Timeout scaling wrong for PXA255 NSSP. 8) Driver leaks memory while busy during unloading. Known issues: SPI_CS_HIGH and SPI_LSB_FIRST settings in struct spi_device are not handled. Testing: This patch has been test against the "random length, random bits/word, random data (verified on loopback) and stepped baud rate by octaves (3.6MHz to 115kHz)" test. It is robust in PIO mode, using any combination of tx and rx thresholds, and also in DMA mode (which internally computes the thresholds). Much thanks to Ned Forrester for exhaustive reviews, fixes and testing. The driver is substantially better for his efforts. Signed-off-by: Stephen Street <stephen@streetfiresound.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2006-10-03Documentation: remove duplicated wordsPaolo Ornati
Remove many duplicated words under Documentation/ and do other small cleanups. Examples: "and and" --> "and" "in in" --> "in" "the the" --> "the" "the the" --> "to the" ... Signed-off-by: Paolo Ornati <ornati@fastwebnet.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-05-16[PATCH] SPI: add PXA2xx SSP SPI DriverStephen Street
This driver turns a PXA2xx synchronous serial port (SSP) into a SPI master controller (see Documentation/spi/spi_summary). The driver has the following features: - Support for any PXA2xx SSP - SSP PIO and SSP DMA data transfers. - External and Internal (SSPFRM) chip selects. - Per slave device (chip) configuration. - Full suspend, freeze, resume support. Signed-off-by: Stephen Street <stephen@streetfiresound.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
