path: root/Documentation/spi
2015-04-17Documentation/spi/spidev_test.c: fix warningAndrew Morton
Documentation/spi/spidev_test.c:83:5: warning: no previous prototype for 'unespcape' [-Wmissing-prototypes] fix spelling too. Acked-by: Mark Brown <broonie@kernel.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2015-04-11Merge remote-tracking branches 'spi/topic/spidev' and ↵Mark Brown
'spi/topic/spidev-test' into spi-next
2015-03-10spi: spidev_test: Added input buffer from the terminalAdrian Remonda
Signed-off-by: Adrian Remonda <adrianremonda@gmail.com> Signed-off-by: Mark Brown <broonie@kernel.org>
2015-03-10spi: spidev_test: Added verbose outputAdrian Remonda
2015-03-10spi: spidev_test: Cleaned hexadecimal dumpAdrian Remonda
2015-03-08spi: Use PM ops instead of legacy suspend/resumeLars-Peter Clausen
New drivers should use PM ops instead of the legacy suspend/resume callbacks. Update the SPI device driver guide to reflect this. Signed-off-by: Lars-Peter Clausen <lars@metafoo.de> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-10-07Merge branch 'for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/doc Pull documentation updates from Jiri Kosina: "Updates to kernel documentation. I took this over (hopefully temporarily) from Randy who was not willing to maintain it any longer. This pile mostly is a relay of queue that Randy already had in his tree" * 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/doc: Documentation: fix broken v4l-utils URL Documentation: update include path for mpssd Documentation: correct parameter error for dma_mapping_error MAINTAINERS: update location of linux-doc tree Documentation: remove networking/.gitignore tools: add more endian.h macros Make Documenation depend on headers_install Docs: this_cpu_ops: remove redundant add forms Documentation: disable vdso_test to avoid breakage with old glibc Documentation: update vDSO makefile to build portable examples Documentation: update .gitignore files Documentation: support glibc versions without htole macros v4l2-pci-skeleton: Only build if PCI is available Documentation: fix misc. warnings Documentation: make functions static to avoid prototype warnings Documentation: add makefiles for more targets Documentation: use subdir-y to avoid unnecessary built-in.o files
2014-09-26Documentation: use subdir-y to avoid unnecessary built-in.o filesPeter Foley
Change the Documentation makefiles from obj-m to subdir-y to avoid generating unnecessary built-in.o files since nothing in Documentation/ is ever linked in to vmlinux. Signed-off-by: Peter Foley <pefoley2@pefoley.com> Acked-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Randy Dunlap <rdunlap@infradead.org> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2014-09-16spi-summary: documentation mistakeOscar Utbult
Contributors are not listed in alphabetical order as claimed by documentation. Signed-off-by: Oscar Utbult <oscar@oscr.io> Signed-off-by: Mark Brown <broonie@kernel.org>
2014-03-30Merge remote-tracking branches 'spi/topic/s3c64xx', 'spi/topic/sc18is602', ↵Mark Brown
'spi/topic/sh-hspi', 'spi/topic/sh-msiof', 'spi/topic/sh-sci', 'spi/topic/sirf' and 'spi/topic/spidev' into spi-next
2014-02-27spi: spidev_fdx: Add support for Dual/Quad SPI TransfersGeert Uytterhoeven
Use SPI_IOC_RD_MODE32 to print the full SPI mode, now in hex. Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-27spi: spidev_test: Add support for Dual/Quad SPI TransfersGeert Uytterhoeven
2014-02-27spi: spidev: Add support for Dual/Quad SPI TransfersGeert Uytterhoeven
Add support for Dual/Quad SPI Transfers to the spidev API. As this uses SPI mode bits that don't fit in a single byte, two new ioctls (SPI_IOC_RD_MODE32 and SPI_IOC_WR_MODE32) are introduced. Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-22spi/spidev_test: Document -N/--no-cs and -R/--readyGeert Uytterhoeven
commit b55f627feeb9d48fdbde3835e18afbc76712e49b ("spi: new spi->mode bits") added two new command line options without adding the respective help texts. Signed-off-by: Geert Uytterhoeven <geert+renesas@linux-m68k.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-02-12Merge tag 'spi-v3.14-rc2' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi Pull spi fixes from Mark Brown: "A few driver and documentation fixes, plus a fix for double error handling which had crept in due to the confusing documentation - it wasn't clear if the core or the driver was responsible for cleanup in error cases so both tried to do it with unfortunate results" * tag 'spi-v3.14-rc2' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/spi: spi: nuc900: Set SPI_LSB_FIRST for master->mode_bits if hw->pdata->lsb is true spi: rspi: Document support for Renesas QSPI in Kconfig spi: Fix crash with double message finalisation on error handling spi: correct the transfer_one_message documentation wording spi: document the transfer_one spi_master callback spi: spi.h: clarify the documentation of transfer_one
2014-02-10Documentation/: update 00-INDEX filesHenrik Austad
Some of the 00-INDEX files are somewhat outdated and some folders does not contain 00-INDEX at all. Only outdated (with the notably exception of spi) indexes are touched here, the 169 folders without 00-INDEX has not been touched. New 00-INDEX - spi/* was added in a series of commits dating back to 2006 Added files (missing in (*/)00-INDEX) - dmatest.txt was added by commit 851b7e16a07d ("dmatest: run test via debugfs") - this_cpu_ops.txt was added by commit a1b2a555d637 ("percpu: add documentation on this_cpu operations") - ww-mutex-design.txt was added by commit 040a0a371005 ("mutex: Add support for wound/wait style locks") - bcache.txt was added by commit cafe56359144 ("bcache: A block layer cache") - kernel-per-CPU-kthreads.txt was added by commit 49717cb40410 ("kthread: Document ways of reducing OS jitter due to per-CPU kthreads") - phy.txt was added by commit ff764963479a ("drivers: phy: add generic PHY framework") - block/null_blk was added by commit 12f8f4fc0314 ("null_blk: documentation") - module-signing.txt was added by commit 3cafea307642 ("Add Documentation/module-signing.txt file") - assoc_array.txt was added by commit 3cb989501c26 ("Add a generic associative array implementation.") - arm/IXP4xx was part of the initial repo - arm/cluster-pm-race-avoidance.txt was added by commit 7fe31d28e839 ("ARM: mcpm: introduce helpers for platform coherency exit/setup") - arm/firmware.txt was added by commit 7366b92a77fc ("ARM: Add interface for registering and calling firmware-specific operations") - arm/kernel_mode_neon.txt was added by commit 2afd0a05241d ("ARM: 7825/1: document the use of NEON in kernel mode") - arm/tcm.txt was added by commit bc581770cfdd ("ARM: 5580/2: ARM TCM (Tightly-Coupled Memory) support v3") - arm/vlocks.txt was added by commit 9762f12d3e05 ("ARM: mcpm: Add baremetal voting mutexes") - blackfin/gptimers-example.c, Makefile was added by commit 4b60779d5ea7 ("Blackfin: add an example showing how to use the gptimers API") - devicetree/usage-model.txt was added by commit 31134efc681a ("dt: Linux DT usage model documentation") - fb/api.txt was added by commit fb21c2f42879 ("fbdev: Add FOURCC-based format configuration API") - fb/sm501.txt was added by commit e6a049807105 ("video, sm501: add edid and commandline support") - fb/udlfb.txt was added by commit 96f8d864afd6 ("fbdev: move udlfb out of staging.") - filesystems/Makefile was added by commit 1e0051ae48a2 ("Documentation/fs/: split txt and source files") - filesystems/nfs/nfsd-admin-interfaces.txt was added by commit 8a4c6e19cfed ("nfsd: document kernel interfaces for nfsd configuration") - ide/warm-plug-howto.txt was added by commit f74c91413ec6 ("ide: add warm-plug support for IDE devices (take 2)") - laptops/Makefile was added by commit d49129accc21 ("Documentation/laptop/: split txt and source files") - leds/leds-blinkm.txt was added by commit b54cf35a7f65 ("LEDS: add BlinkM RGB LED driver, documentation and update MAINTAINERS") - leds/ledtrig-oneshot.txt was added by commit 5e417281cde2 ("leds: add oneshot trigger") - leds/ledtrig-transient.txt was added by commit 44e1e9f8e705 ("leds: add new transient trigger for one shot timer activation") - m68k/README.buddha was part of the initial repo - networking/LICENSE.(qla3xxx|qlcnic|qlge) was added by commits 40839129f779, c4e84bde1d59, 5a4faa873782 - networking/Makefile was added by commit 3794f3e812ef ("docsrc: build Documentation/ sources") - networking/i40evf.txt was added by commit 105bf2fe6b32 ("i40evf: add driver to kernel build system") - networking/ipsec.txt was added by commit b3c6efbc36e2 ("xfrm: Add file to document IPsec corner case") - networking/mac80211-auth-assoc-deauth.txt was added by commit 3cd7920a2be8 ("mac80211: add auth/assoc/deauth flow diagram") - networking/netlink_mmap.txt was added by commit 5683264c3981 ("netlink: add documentation for memory mapped I/O") - networking/nf_conntrack-sysctl.txt was added by commit c9f9e0e1597f ("netfilter: doc: add nf_conntrack sysctl api documentation") lan) - networking/team.txt was added by commit 3d249d4ca7d0 ("net: introduce ethernet teaming device") - networking/vxlan.txt was added by commit d342894c5d2f ("vxlan: virtual extensible lan") - power/runtime_pm.txt was added by commit 5e928f77a09a ("PM: Introduce core framework for run-time PM of I/O devices (rev. 17)") - power/charger-manager.txt was added by commit 3bb3dbbd56ea ("power_supply: Add initial Charger-Manager driver") - RCU/lockdep-splat.txt was added by commit d7bd2d68aa2e ("rcu: Document interpretation of RCU-lockdep splats") - s390/kvm.txt was added by 5ecee4b (KVM: s390: API documentation) - s390/qeth.txt was added by commit b4d72c08b358 ("qeth: bridgeport support - basic control") - scheduler/sched-bwc.txt was added by commit 88ebc08ea9f7 ("sched: Add documentation for bandwidth control") - scsi/advansys.txt was added by commit 4bd6d7f35661 ("[SCSI] advansys: Move documentation to Documentation/scsi") - scsi/bfa.txt was added by commit 1ec90174bdb4 ("[SCSI] bfa: add readme file") - scsi/bnx2fc.txt was added by commit 12b8fc10eaf4 ("[SCSI] bnx2fc: Add driver documentation") - scsi/cxgb3i.txt was added by commit c3673464ebc0 ("[SCSI] cxgb3i: Add cxgb3i iSCSI driver.") - scsi/hpsa.txt was added by commit 992ebcf14f3c ("[SCSI] hpsa: Add hpsa.txt to Documentation/scsi") - scsi/link_power_management_policy.txt was added by commit ca77329fb713 ("[libata] Link power management infrastructure") - scsi/osd.txt was added by commit 78e0c621deca ("[SCSI] osd: Documentation for OSD library") - scsi/scsi-parameter.txt was created/moved by commit 163475fb111c ("Documentation: move SCSI parameters to their own text file") - serial/driver was part of the initial repo - serial/n_gsm.txt was added by commit 323e84122ec6 ("n_gsm: add a documentation") - timers/Makefile was added by commit 3794f3e812ef ("docsrc: build Documentation/ sources") - virt/kvm/s390.txt was added by commit d9101fca3d57 ("KVM: s390: diagnose call documentation") - vm/split_page_table_lock was added by commit 49076ec2ccaf ("mm: dynamically allocate page->ptl if it cannot be embedded to struct page") - w1/slaves/w1_ds28e04 was added by commit fbf7f7b4e2ae ("w1: Add 1-wire slave device driver for DS28E04-100") - w1/masters/omap-hdq was added by commit e0a29382c6f5 ("hdq: documentation for OMAP HDQ") - x86/early-microcode.txt was added by commit 0d91ea86a895 ("x86, doc: Documentation for early microcode loading") - x86/earlyprintk.txt was added by commit a1aade478862 ("x86/doc: mini-howto for using earlyprintk=dbgp") - x86/entry_64.txt was added by commit 8b4777a4b50c ("x86-64: Document some of entry_64.S") - x86/pat.txt was added by commit d27554d874c7 ("x86: PAT documentation") Moved files - arm/kernel_user_helpers.txt was moved out of arch/arm/kernel by commit 37b8304642c7 ("ARM: kuser: move interface documentation out of the source code") - efi-stub.txt was moved out of x86/ and down into Documentation/ in commit 4172fe2f8a47 ("EFI stub documentation updates") - laptops/hpfall.c was moved out of hwmon/ and into laptops/ in commit efcfed9bad88 ("Move hp_accel to drivers/platform/x86") - commit 5616c23ad9cd ("x86: doc: move x86-generic documentation from Doc/x86/i386"): * x86/usb-legacy-support.txt * x86/boot.txt * x86/zero_page.txt - power/video_extension.txt was moved to acpi in commit 70e66e4df191 ("ACPI / video: move video_extension.txt to Documentation/acpi") Removed files (left in 00-INDEX) - memory.txt was removed by commit 00ea8990aadf ("memory.txt: remove stray information") - gpio.txt was moved to gpio/ in commit fd8e198cfcaa ("Documentation: gpiolib: document new interface") - networking/DLINK.txt was removed by commit 168e06ae26dd ("drivers/net: delete old parallel port de600/de620 drivers") - serial/hayes-esp.txt was removed by commit f53a2ade0bb9 ("tty: esp: remove broken driver") - s390/TAPE was removed by commit 9e280f669308 ("[S390] remove tape block docu") - vm/locking was removed by commit 57ea8171d2bc ("mm: documentation: remove hopelessly out-of-date locking doc") - laptops/acer-wmi.txt was remvoed by commit 020036678e81 ("acer-wmi: Delete out-of-date documentation") Typos/misc issues - rpc-server-gss.txt was added as knfsd-rpcgss.txt in commit 030d794bf498 ("SUNRPC: Use gssproxy upcall for server RPCGSS authentication.") - commit b88cf73d9278 ("net: add missing entries to Documentation/networking/00-INDEX") * generic-hdlc.txt was added as generic_hdlc.txt * spider_net.txt was added as spider-net.txt - w1/master/mxc-w1 was added as mxc_w1 by commit a5fd9139f74c ("w1: add 1-wire master driver for i.MX27 / i.MX31") - s390/zfcpdump.txt was added as zfcpdump by commit 6920c12a407e ("[S390] Add Documentation/s390/00-INDEX.") Signed-off-by: Henrik Austad <henrik@austad.us> Reviewed-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> [rcu bits] Acked-by: Rob Landley <rob@landley.net> Cc: Jiri Kosina <jkosina@suse.cz> Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Rob Herring <robh+dt@kernel.org> Cc: David S. Miller <davem@davemloft.net> Cc: Mark Brown <broonie@kernel.org> Cc: "H. Peter Anvin" <hpa@zytor.com> Cc: Ingo Molnar <mingo@elte.hu> Cc: Gleb Natapov <gleb@kernel.org> Cc: Linus Torvalds <torvalds@linux-foundation.org> Cc: Len Brown <len.brown@intel.com> Cc: James Bottomley <JBottomley@parallels.com> Cc: Jean-Christophe Plagniol-Villard <plagnioj@jcrosoft.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2014-01-27spi: correct the transfer_one_message documentation wordingBaruch Siach
The transfer_one_message callback handles messages, not transfers. Signed-off-by: Baruch Siach <baruch@tkos.co.il> Signed-off-by: Mark Brown <broonie@linaro.org>
2014-01-27spi: document the transfer_one spi_master callbackBaruch Siach
2013-12-09spi: Correction to typos in Documentation/spi/spi-summaryJohn Whitmore
Just a few simple typo corrections. Signed-off-by: John Whitmore <johnfwhitmore@gmail.com> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-08-08spi/documentation: Fix usage of __initdataSachin Kamat
__initdata should be placed between the variable name and equal sign for the variable to be placed in the intended section. Fix the example code. Signed-off-by: Sachin Kamat <sachin.kamat@linaro.org> Signed-off-by: Mark Brown <broonie@linaro.org>
2013-01-03Documentation: remove __dev* attributes.Greg Kroah-Hartman
CONFIG_HOTPLUG is going away as an option. As a result, the __dev* markings need to be removed. This change removes the use of __devinit, __devexit_p, __devinitdata, __devinitconst, and __devexit from the kernel documentation. Based on patches originally written by Bill Pemberton, but redone by me in order to handle some of the coding style issues better, by hand. Cc: Bill Pemberton <wfp5p@virginia.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2012-10-02Merge tag 'spi-3.7' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/broonie/misc Pull spi updates from Mark Brown: "No framework work here, only a bunch of driver updates of varying sizes: - Factoring out of the core hardware support from the MXS MMC driver by Marek Vasut to allow the hardware to also be used for SPI. - Lots of error handling cleanups from Guenter Roeck - Removal of the existing Tegra driver which is quite comprehensively broken as detailed in the changelog for the removal. - DT suppport for the PL022 and GPIO drivers. - pinctrl support for OMAP and PL022." Pulling from Mark Brown as Grant Likely is still busy moving. * tag 'spi-3.7' of git://git.kernel.org/pub/scm/linux/kernel/git/broonie/misc: (53 commits) spi: remove completely broken Tegra driver spi/imx: set the inactive state of the clock according to the clock polarity spi/pl022: get/put resources on suspend/resume spi/pl022: use more managed resources spi/pl022: Devicetree support w/o platform data spi/s3c64xx: Don't free controller_data on non-dt platforms spi: omap2-mcspi: add pinctrl support spi/pl022: adopt pinctrl support spi: omap2-mcspi: Cleanup the omap2_mcspi_txrx_dma function spi/gpio: Fix stub for spi_gpio_probe_dt() spi/mxs: Make the SPI block clock speed configurable via DT spi: spi-sh-hspi: drop frees of devm_ alloc'd data spi/pl022: Fix chipselects pointer computation spi: spi-tle62x0: Use module_spi_driver macro mxs/spi: Rework the mxs_ssp_timeout to be more readable mxs/spi: Decrement the DMA/PIO border mxs/spi: Increment the transfer length only if transfer succeeded mxs/spi: Fix issues when doing long continuous transfer spi: spi-gpio: Add DT bindings spi: spi-gpio: store chipselect information in private structure ...
2012-09-14ARM: ep93xx: move platform_data definitionsArnd Bergmann
Platform data for device drivers should be defined in include/linux/platform_data/*.h, not in the architecture and platform specific directories. This moves such data out of the ep93xx include directories Signed-off-by: Arnd Bergmann <arnd@arndb.de> Acked-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org> Acked-by: Nicolas Pitre <nico@linaro.org> Acked-by: Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Ryan Mallon <rmallon@gmail.com> Acked-by: Vinod Koul <vinod.koul@linux.intel.com> Cc: Grant Likely <grant.likely@secretlab.ca> Cc: Jeff Garzik <jgarzik@pobox.com> Cc: Dan Williams <djbw@fb.com> Cc: Dmitry Torokhov <dmitry.torokhov@gmail.com> Cc: Florian Tobias Schandinat <FlorianSchandinat@gmx.de> Cc: Liam Girdwood <lrg@ti.com> Cc: Jaroslav Kysela <perex@perex.cz> Cc: Takashi Iwai <tiwai@suse.de> Cc: Mika Westerberg <mika.westerberg@iki.fi> Cc: Axel Lin <axel.lin@gmail.com>
2012-08-22spi: Master driver for NXP SC18IS602/603Guenter Roeck
This driver adds support for NXP SC18IS602/603 I2C to SPI bus bridge. Signed-off-by: Guenter Roeck <linux@roeck-us.net> Signed-off-by: Mark Brown <broonie@opensource.wolfsonmicro.com>
2012-03-07spi: create a message queueing infrastructureLinus Walleij
This rips the message queue in the PL022 driver out and pushes it into (optional) common infrastructure. Drivers that want to use the message pumping thread will need to define the new per-messags transfer methods and leave the deprecated transfer() method as NULL. Most of the design is described in the documentation changes that are included in this patch. Since there is a queue that need to be stopped when the system is suspending/resuming, two new calls are implemented for the device drivers to call in their suspend()/resume() functions: spi_master_suspend() and spi_master_resume(). ChangeLog v1->v2: - Remove Kconfig entry and do not make the queue support optional at all, instead be more agressive and have it as part of the compulsory infrastructure. - If the .transfer() method is implemented, delete print a small deprecation notice and do not start the transfer pump. - Fix a bitrotted comment. ChangeLog v2->v3: - Fix up a problematic sequence courtesy of Chris Blair. - Stop rather than destroy the queue on suspend() courtesy of Chris Blair. Signed-off-by: Chris Blair <chris.blair@stericsson.com> Signed-off-by: Linus Walleij <linus.walleij@linaro.org> Tested-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Reviewed-by: Mark Brown <broonie@opensource.wolfsonmicro.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-09-27doc: fix broken referencesPaul Bolle
There are numerous broken references to Documentation files (in other Documentation files, in comments, etc.). These broken references are caused by typo's in the references, and by renames or removals of the Documentation files. Some broken references are simply odd. Fix these broken references, sometimes by dropping the irrelevant text they were part of. Signed-off-by: Paul Bolle <pebolle@tiscali.nl> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-06-18spi/pxa2xx: Remove unavailable ssp_type from documentationStefan Schmidt
Since commit commit 2f1a74e5a2de0459139b85af95e901448726c375 Author: eric miao <eric.miao@marvell.com> Date: Wed Nov 21 18:50:53 2007 +0800 [ARM] pxa: make pxa2xx_spi driver use ssp_request()/ssp_free() the ssp_type field in struct pxa2xx_spi_master is no longer available. Signed-off-by: Stefan Schmidt <stefan@datenfreihafen.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2011-06-08spi/ep93xx: add DMA supportMika Westerberg
This patch adds DMA support for the EP93xx SPI driver. By default the DMA is not enabled but it can be enabled by setting ep93xx_spi_info.use_dma to true in board configuration file. Note that the SPI driver still uses PIO for small transfers (<= 8 bytes) for performance reasons. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: Vinod Koul <vinod.koul@intel.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-12-01arm/pxa2xx: reorgazine SSP and SPI header filesSebastian Andrzej Siewior
The PXA-SPI driver relies on some files / defines which are arm specific and are within the ARM tree. The CE4100 SoC which is x86 has also the SPI core. This patch moves the ssp and spi files from arm/mach-pxa and plat-pxa to include/linux where the CE4100 can access them. This move got verified by building the following defconfigs: cm_x2xx_defconfig corgi_defconfig em_x270_defconfig ezx_defconfig imote2_defconfig pxa3xx_defconfig spitz_defconfig zeus_defconfig raumfeld_defconfig magician_defconfig Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Dirk Brandewie <dirk.brandewie@gmail.com>
2010-05-25spi/ep93xx: implemented driver for Cirrus EP93xx SPI controllerMika Westerberg
This patch adds an SPI master driver for the Cirrus EP93xx SPI controller found in EP93xx chips. Signed-off-by: Mika Westerberg <mika.westerberg@iki.fi> Signed-off-by: H Hartley Sweeten <hsweeten@visionengravers.com> Acked-by: H Hartley Sweeten <hsweeten@visionengravers.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-05-25Documentation/spi/* compile warning fixPrarit Bhargava
Fix this warning: Documentation/spi/spidev_fdx.c: In function `do_msg': Documentation/spi/spidev_fdx.c:61: warning: cast from pointer to integer of different size Documentation/spi/spidev_fdx.c:64: warning: cast from pointer to integer of different size buf should be unsigned long to match native arch on 32-bit x86 compile. Signed-off-by: Prarit Bhargava <prarit@redhat.com> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2010-04-29spi: spidev_test gives error upon 1-byte transferHector Palacios
The sample application spidev_test.c is using SPI_IOC_MESSAGE ioctl to do an SPI transfer. This ioctl returns the number of bytes successfully transmitted or a negative error code upon erroneous completion. The application however is returning an error if the result of the ioclt if the return value is 1. This makes the application to fail upon 1-byte length transfers. Signed-off-by: Hector Palacios <hector.palacios@digi.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2009-12-04tree-wide: fix assorted typos all over the placeAndré Goddard Rosa
That is "success", "unknown", "through", "performance", "[re|un]mapping" , "access", "default", "reasonable", "[con]currently", "temperature" , "channel", "[un]used", "application", "example","hierarchy", "therefore" , "[over|under]flow", "contiguous", "threshold", "enough" and others. Signed-off-by: André Goddard Rosa <andre.goddard@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-09-23spi: fix spelling of `automatically' in documentationBen Dooks
Fix spelling of `automatically' in Documentation/spi/spi-summary. Signed-off-by: Ben Dooks <ben@simtec.co.uk> Cc: David Brownell <david-b@pacbell.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-09-23Documentation/: fix warnings from -Wmissing-prototypes in HOSTCFLAGSLadinu Chandrasinghe
Fix up -Wmissing-prototypes in compileable userspace code, mainly under Documentation/. Signed-off-by: Ladinu Chandrasinghe <ladinu.pub@gmail.com> Signed-off-by: Trevor Keith <tsrk@tsrk.net> Cc: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-06-30spi: new spi->mode bitsDavid Brownell
Add two new spi_device.mode bits to accomodate more protocol options, and pass them through to usermode drivers: * SPI_NO_CS ... a second 3-wire variant, where the chipselect line is removed instead of a data line; transfers are still full duplex. This obviously has STRONG protocol implications since the chipselect transitions can't be used to synchronize state transitions with the SPI master. * SPI_READY ... defines open drain signal that's pulled low to pause the clock. This defines a 5-wire variant (normal 4-wire SPI plus READY) and two 4-wire variants (READY plus each of the 3-wire flavors). Such hardware flow control can be a big win. There are ADC converters and flash chips that expose READY signals, but not many host controllers support it today. The spi_bitbang code should be changed to use SPI_NO_CS instead of its current nonportable hack. That's a mode most hardware can easily support (unlike SPI_READY). Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: "Paulraj, Sandeep" <s-paulraj@ti.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-04-21spi: documentation: emphasise spi_master.setup() semanticsDavid Brownell
This is a doc-only patch which I hope will reduce the number of spi_master controller driver patches starting out with a common implementation bug. (As in: almost every spi_master driver I see starts out with its version of this bug. Sigh.) It just re-emphasizes that the setup() method may be called for one device while a transfer is active on another ... which means that most driver implementations shouldn't touch any registers. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07hwmon: (lm70) Code streamlining and cleanupKaiwan N Billimoria
This fixes a byteswap bug in the LM70 temperature sensor driver, which was previously covered up by a converse bug in the driver for the LM70EVAL-LLP board (which is also fixed). Other fixes: doc updates, remove an annoying msleep(), and improve three-wire protocol handling. Signed-off-by: Kaiwan N Billimoria <kaiwan@designergraphix.com> [ dbrownell@users.sourceforge.net: doc and whitespace tweaks ] Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Jean Delvare <khali@linux-fr.org>
2008-12-01spi documentation: use __initdata on structroel kluin
Use __initdata for data, not __init. Signed-off-by: Roel Kluin <roel.kluin@gmail.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-30.gitignore updatesAlexey Dobriyan
Signed-off-by: Alexey Dobriyan <adobriyan@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-10-16pxa2xx_spi: fix chip_info defaults and documentation.Vernon Sauder
Make the chip info structure data optional by providing reasonable defaults. Improve corresponding documentation, and highlight the drawback of not providing explicit chipselect control. DMA can determine appropriate dma_burst_size and thresholds automatically so use DMA even if dma_burst_size is not specified. Signed-off-by: Vernon Sauder <VernonInHand@gmail.com> Reviewed-by: Ned Forrester <nforrester@whoi.edu> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-12docsrc: build Documentation/ sourcesRandy Dunlap
Currently source files in the Documentation/ sub-dir can easily bit-rot since they are not generally buildable, either because they are hidden in text files or because there are no Makefile rules for them. This needs to be fixed so that the source files remain usable and good examples of code instead of bad examples. Add the ability to build source files that are in the Documentation/ dir. Add to Kconfig as "BUILD_DOCSRC" config symbol. Use "CONFIG_BUILD_DOCSRC=1 make ..." to build objects from the Documentation/ sources. Or enable BUILD_DOCSRC in the *config system. However, this symbol depends on HEADERS_CHECK since the header files need to be installed (for userspace builds). Built (using cross-tools) for x86-64, i386, alpha, ia64, sparc32, sparc64, powerpc, sh, m68k, & mips. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Reviewed-by: Sam Ravnborg <sam@ravnborg.org> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-08-07[ARM] Move include/asm-arm/arch-* to arch/arm/*/include/machRussell King
This just leaves include/asm-arm/plat-* to deal with. Signed-off-by: Russell King <rmk+kernel@arm.linux.org.uk>
2008-04-28documentation: move spidev_fdx example to its own source fileRandy Dunlap
Move sample source code to its own source file so that it can be used easier and build-tested/check/maintained by anyone. (Makefile changes are in a separate patch for all of Documentation/.) Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-08spi: documentation tweaksDavid Brownell
Update SPI documentation to clarify some areas of recent confusion: clock polarity takes effect when chipselect goes active; and zero length buffers are OK in certain cases. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-19Convert files to UTF-8 and some cleanupsJan Engelhardt
* Convert files to UTF-8. * Also correct some people's names (one example is Eißfeldt, which was found in a source file. Given that the author used an ß at all in a source file indicates that the real name has in fact a 'ß' and not an 'ss', which is commonly used as a substitute for 'ß' when limited to 7bit.) * Correct town names (Goettingen -> Göttingen) * Update Eberhard Mönkeberg's address (http://lkml.org/lkml/2007/1/8/313) Signed-off-by: Jan Engelhardt <jengelh@gmx.de> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-16spi doesn't need class_deviceTony Jones
Make the SPI framework and drivers stop using class_device. Update docs accordingly ... highlighting just which sysfs paths should be "safe"/stable. Signed-off-by: Tony Jones <tonyj@suse.de> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Greg KH <greg@kroah.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-10-16Documentation/spi/spidev_test.c: constify some variablesWANG Cong
Constify two char pointers and a struct in Documentation/spi/spidev_test.c. Acked-by: David Brownell <dbrownell@users.sourceforge.net> Cc: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: WANG Cong <xiyou.wangcong@gmail.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-07-31spidev_test utilityAnton Vorontsov
This is a simple utility used to test SPI functionality. It could stand growing options to support using other test data patterns; this initial version only issues full duplex transfers, which rules out 3WIRE or Microwire links. Signed-off-by: Anton Vorontsov <avorontsov@ru.mvista.com> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
