path: root/Documentation/spinlocks.txt
2013-06-19sched: Rename sched.c as sched/core.c in comments and DocumentationViresh Kumar
Most of the stuff from kernel/sched.c was moved to kernel/sched/core.c long time back and the comments/Documentation never got updated. I figured it out when I was going through sched-domains.txt and so thought of fixing it globally. I haven't crossed check if the stuff that is referenced in sched/core.c by all these files is still present and hasn't changed as that wasn't the motive behind this patch. Signed-off-by: Viresh Kumar <viresh.kumar@linaro.org> Signed-off-by: Peter Zijlstra <peterz@infradead.org> Link: http://lkml.kernel.org/r/cdff76a265326ab8d71922a1db5be599f20aad45.1370329560.git.viresh.kumar@linaro.org Signed-off-by: Ingo Molnar <mingo@kernel.org>
2011-07-11Documentation/spinlocks.txt: Remove reference to sti()/cli()Muthu Kumar
Since we removed sti()/cli() and related, how about removing it from Documentation/spinlocks.txt? Signed-off-by: Muthukumar R <muthur@gmail.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2011-01-27locking: Remove deprecated lock initializersThomas Gleixner
Last users are gone. Remove the left overs. Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
2009-12-14Documentation: rw_lock lessons learnedWilliam Allen Simpson
In recent months, two different network projects erroneously strayed down the rw_lock path. Update the Documentation based upon comments by Eric Dumazet and Paul E. McKenney in those threads. Further updates await somebody else with more expertise. Changes: - Merged with extensive content by Stephen Hemminger. - Fix one of the comments by Linus Torvalds. Signed-off-by: William.Allen.Simpson@gmail.com Acked-by: Paul E. McKenney <paulmck@linux.vnet.ibm.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-04-11Add additional examples in Documentation/spinlocks.txtMark Fasheh
Checkpatch will throw an error if code doesn't use the correct initializers for static spinlocks: ERROR: Use of SPIN_LOCK_UNLOCKED is deprecated: see Documentation/spinlocks.txt This is fine, but Documentation/spinlocks.txt isn't very clear on how to _use_ the new initializers for static variables. To save people time in the future, I added two small examples of how to fix old-style static initializers to be more lockdep friendly. Signed-off-by: Mark Fasheh <mfasheh@suse.com> Signed-off-by: Jonathan Corbet <corbet@lwn.net>
2007-07-16docs: static initialization of spinlocks is OKEd L. Cashin
Static initialization of spinlocks is preferable to dynamic initialization when it is practical. This patch updates documentation for consistency with comments in spinlock_types.h. Signed-off-by: Ed L. Cashin <ecashin@coraid.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2006-03-22fix rwlock usage exampleLucas Correia Villa Real
This is a trivial patch which fixes a typo on rwlock usage under Documentation/spinlocks.txt. Signed-Off-By: Lucas Correia Villa Real <lucasvr@gobolinux.org> Signed-off-by: Adrian Bunk <bunk@stusta.de>
