path: root/Documentation/stable_kernel_rules.txt
2008-10-29Update stable tree documentationJosh Boyer
Update the documentation for the stable tree rules to reflect that device IDs and quirks are also suitable for -stable kernels. Signed-off-by: Josh Boyer <jwboyer@linux.vnet.ibm.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-21stable_kernel_rules: fix must already be in mainlineStefan Richter
stable_kernel_rules: fix must already be in mainline Signed-off-by: Stefan Richter <stefanr@s5r6.in-berlin.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-11-30Fix typos in /Documentation : MiscMatt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some misc words. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix "can not" in Documentation and KconfigMatt LaPlante
Randy brought it to my attention that in proper english "can not" should always be written "cannot". I donot see any reason to argue, even if I mightnot understand why this rule exists. This patch fixes "can not" in several Documentation files as well as three Kconfigs. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-01-10[PATCH] Docs update: small fixes to stable_kernel_rules.txtJesper Juhl
Small spelling, formating & similar fixes to stable_kernel_rules.txt Signed-off-by: Jesper Juhl <jesper.juhl@gmail.com> Signed-off-by: Andrew Morton <akpm@osdl.org> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
2005-07-29[PATCH] Add the rules about the -stable kernel releases to the Documentation ↵Greg KH
directory This was the last agreed upon set of rules, it's probably time we actually add them to the kernel tree to make them "official". Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> Signed-off-by: Linus Torvalds <torvalds@osdl.org>
