path: root/Documentation/target
2012-09-17target: Simplify fabric sense data length handlingRoland Dreier
Every fabric driver has to supply a se_tfo->set_fabric_sense_len() method, just so iSCSI can return an offset of 2. However, every fabric driver is already allocating a sense buffer and passing it into the target core, either via transport_init_se_cmd() or target_submit_cmd(). So instead of having iSCSI pass the start of its sense buffer into the core and then later tell the core to skip the first 2 bytes, it seems easier for iSCSI just to do the offset of 2 when it passes the sense buffer into the core. Then we can drop the se_tfo->set_fabric_sense_len() everywhere, and just add a couple of lines of code to iSCSI to set the sense data length to the beginning of the buffer right before it sends it over the network. (nab: Remove .set_fabric_sense_len usage from tcm_qla2xxx_npiv_ops + change transport_get_sense_buffer to follow v3.6-rc6 code w/o ->set_fabric_sense_len usage) Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-09-17target: Remove unused target_core_fabric_ops.get_fabric_sense_len methodRoland Dreier
There are no callers of se_tfo->get_fabric_sense_len(), so we should stop having every fabric driver implement it. Signed-off-by: Roland Dreier <roland@purestorage.com> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2012-02-10Documentation: Fix typo in tcm_mod_builder.pyMasanari Iida
Correct spelling "alocate" to "allocate" in Documentation/target/tcm_mod_builder.py Signed-off-by: Masanari Iida <standby24x7@gmail.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2011-12-14target: tcm_mod_builder: small fixupsSebastian Andrzej Siewior
This includes: - remove on _ in "__NAMELEN" in $fabric _make_tport - target_fabric_configfs_init() returns an error pointer and not NULL anymore. Consider that. - replace (!(var_name)) with (!var_name). The extra () are not required - remove #ifdef MODULE. If the code is builtin it needs an init function or the code is useless - put exit/clean functions into __exit Signed-off-by: Sebastian Andrzej Siewior <bigeasy@linutronix.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2011-12-14Documentation/target: Fix tcm_mod_builder.py build breakageNicholas Bellinger
This patch fixes TFO->release_cmd() and removes legacy pack_lun() usage and new_cmd_failure when generating new TCM fabric skeleton from the tcm_mod_builder.py script. Reported-by: Stefan Bergstrand <stefan.bergstrand@sdsab.se> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2011-12-14target: header reshuffle, part2Christoph Hellwig
This reorganized the headers under include/target into: - target_core_base.h stays as is with all target-wide data stuctures and defines - target_core_backend.h contains the whole interface to I/O backends - target_core_fabric.h contains the whole interface to fabric modules Except for those only the various configfs macro headers stay around. Signed-off-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas Bellinger <nab@linux-iscsi.org>
2011-03-23[SCSI] tcm_mod_builder.py: Fix generated *_drop_nodeacl() handlerFubo Chen
This patch adds the missing core_tpg_del_initiator_node_acl() call required by fabric modules for struct se_node_acl->acl_group context shutdown via target_core_fabric_configfs.c:target_fabric_nacl_base_release() -> struct target_core_fabric_ops->fabric_drop_nodeacl() for tcm_mod_builder.py generated $FABRIC_MOD_configfs.c skeleton code. Signed-off-by: Fubo Chen <fubo.chen@gmail.com> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-03-23[SCSI] target: tcm_mod_builder.py generated Makefile cleanupsNicholas Bellinger
This patch converts the tcm_mod_builder.py generation script to create a new drivers/target/$TCM_FABRIC_MOD/Makefile and update drivers/target/Makefile, instead of creating+updating a 'Kbuild' filename. It also removes the remaining EXTRA_CFLAGS includes from tcm_mod_build_kbuild(), and converts fabric module generated .c code to us ""-style includes for $FABRIC_MOD_[base,fabric].h Reported-by: Christoph Hellwig <hch@lst.de> Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
2011-01-14[SCSI] target: Add LIO target core v4.0.0-rc6Nicholas Bellinger
LIO target is a full featured in-kernel target framework with the following feature set: High-performance, non-blocking, multithreaded architecture with SIMD support. Advanced SCSI feature set: * Persistent Reservations (PRs) * Asymmetric Logical Unit Assignment (ALUA) * Protocol and intra-nexus multiplexing, load-balancing and failover (MC/S) * Full Error Recovery (ERL=0,1,2) * Active/active task migration and session continuation (ERL=2) * Thin LUN provisioning (UNMAP and WRITE_SAMExx) Multiprotocol target plugins Storage media independence: * Virtualization of all storage media; transparent mapping of IO to LUNs * No hard limits on number of LUNs per Target; maximum LUN size ~750 TB * Backstores: SATA, SAS, SCSI, BluRay, DVD, FLASH, USB, ramdisk, etc. Standards compliance: * Full compliance with IETF (RFC 3720) * Full implementation of SPC-4 PRs and ALUA Significant code cleanups done by Christoph Hellwig. [jejb: fix up for new block bdev exclusive interface. Minor fixes from Randy Dunlap and Dan Carpenter.] Signed-off-by: Nicholas A. Bellinger <nab@linux-iscsi.org> Signed-off-by: James Bottomley <James.Bottomley@suse.de>
