path: root/Documentation/timers/hpet.txt
2010-03-12Documentation/timers/: split txt and source filesRandy Dunlap
Documentation/timers/hpet.txt: Expose example and tool source files in the Documentation/timers/ directory in their own files instead of being buried (almost hidden) in readme/txt files. This should help to prevent bitrot. This will make them more visible/usable to users who may need to use them, to developers who may need to test with them, and to anyone who would fix/update them if they were more visible. Also, if any of these possibly should not be in the kernel tree at all, it will be clearer that they are here and we can discuss if they should be removed. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: Thomas Gleixner <tglx@linutronix.de> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-11-09fix URL in hpet.txtAmerigo Wang
That URL is out of date. Update it. Cc: Thomas Gleixner <tglx@linutronix.de> Cc: Randy Dunlap <rdunlap@xenotime.net> Cc: Matt LaPlante <kernel1@cyberdogtech.com> Cc: Jiri Kosina <jkosina@suse.cz> Signed-off-by: WANG Cong <amwang@redhat.com> Acked-by: Matt LaPlante <kernel@cyberdogtech.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-12trivial: Miscellaneous documentation typo fixesMatt LaPlante
Fix various typos in documentation txts. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2008-07-31hpet: /dev/hpet - fixes and cleanupDavid Brownell
Minor /dev/hpet updates and bugfixes: * Remove dead code, mostly remnants of an incomplete/unusable kernel interface ... noted when addressing "sparse" warnings: + hpet_unregister() and a routine it calls + hpet_task and all references, including hpet_task_lock + hpet_data.hd_flags (and HPET_DATA_PLATFORM) * Correct and improve boot message: + displays *counter* (shared between comparators) bit width, not *timer* bit widths (which are often mixed) + relabel "timers" as "comparators"; this is less confusing, they are not independent like normal timers are (sigh) + display MHz not Hz; it's never less than 10 MHz. * Tighten and correct the userspace interface code + don't accidentally program comparators in 64-bit mode using 32-bit values ... always force comparators into 32-bit mode + provide the correct bit definition flagging comparators with periodic capability ... the ABI is unchanged * Update Documentation/hpet.txt + be more correct and current + expand description a bit + don't mention that now-gone kernel interface Plus, add a FIXME comment for something that could cause big trouble on systems with more capable HPETs than at least Intel seems to ship. It seems that few folk use this userspace interface; it's not very usable given the general lack of HPET IRQ routing. I'm told that the only real point of it any more is to mmap for fast timestamps; IMO that's handled better through the gettimeofday() vsyscall. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Acked-by: Clemens Ladisch <clemens@ladisch.de> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2008-07-24documentation: move hpet.txt to timers/ subdirectoryRandy Dunlap
Move hpet.txt to Documentation/timers/ subdirectory. Add 00-INDEX to Documentation/timers/ subdirectory. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Cc: tglx <tglx@linutronix.de> Signed-off-by: Thomas Gleixner <tglx@linutronix.de>
