path: root/Documentation/trace/ftrace.txt
2009-06-15debugfs: Fix terminology inconsistency of dir name to mount debugfs filesystem.GeunSik Lim
Many developers use "/debug/" or "/debugfs/" or "/sys/kernel/debug/" directory name to mount debugfs filesystem for ftrace according to ./Documentation/tracers/ftrace.txt file. And, three directory names(ex:/debug/, /debugfs/, /sys/kernel/debug/) is existed in kernel source like ftrace, DRM, Wireless, Documentation, Network[sky2]files to mount debugfs filesystem. debugfs means debug filesystem for debugging easy to use by greg kroah hartman. "/sys/kernel/debug/" name is suitable as directory name of debugfs filesystem. - debugfs related reference: http://lwn.net/Articles/334546/ Fix inconsistency of directory name to mount debugfs filesystem. * From Steven Rostedt - find_debugfs() and tracing_files() in this patch. Signed-off-by: GeunSik Lim <geunsik.lim@samsung.com> Acked-by : Inaky Perez-Gonzalez <inaky@linux.intel.com> Reviewed-by : Steven Rostedt <rostedt@goodmis.org> Reviewed-by : James Smart <james.smart@emulex.com> CC: Jiri Kosina <trivial@kernel.org> CC: David Airlie <airlied@linux.ie> CC: Peter Osterlund <petero2@telia.com> CC: Ananth N Mavinakayanahalli <ananth@in.ibm.com> CC: Anil S Keshavamurthy <anil.s.keshavamurthy@intel.com> CC: Masami Hiramatsu <mhiramat@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-12trivial: ftrace:fix description of trace directoryGeunSik Lim
Fix trace source directory from kernel/tracing/ to kernel/trace/. Signed-off-by: GeunSik Lim <geunsik.lim@samsung.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-10Merge branch 'tracing-for-linus' of ↵Linus Torvalds
git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip * 'tracing-for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/tip/linux-2.6-tip: (244 commits) Revert "x86, bts: reenable ptrace branch trace support" tracing: do not translate event helper macros in print format ftrace/documentation: fix typo in function grapher name tracing/events: convert block trace points to TRACE_EVENT(), fix !CONFIG_BLOCK tracing: add protection around module events unload tracing: add trace_seq_vprint interface tracing: fix the block trace points print size tracing/events: convert block trace points to TRACE_EVENT() ring-buffer: fix ret in rb_add_time_stamp ring-buffer: pass in lockdep class key for reader_lock tracing: add annotation to what type of stack trace is recorded tracing: fix multiple use of __print_flags and __print_symbolic tracing/events: fix output format of user stack tracing/events: fix output format of kernel stack tracing/trace_stack: fix the number of entries in the header ring-buffer: discard timestamps that are at the start of the buffer ring-buffer: try to discard unneeded timestamps ring-buffer: fix bug in ring_buffer_discard_commit ftrace: do not profile functions when disabled tracing: make trace pipe recognize latency format flag ...
2009-06-10ftrace/documentation: fix typo in function grapher nameMike Frysinger
The function graph tracer is called just "function_graph" (no trailing "_tracer" needed). Signed-off-by: Mike Frysinger <vapier@gentoo.org> LKML-Reference: <1244623722-6325-1-git-send-email-vapier@gentoo.org> Signed-off-by: Steven Rostedt <rostedt@goodmis.org>
2009-05-29ftrace: fix typo about map of kernel priority in ftrace.txt file.GeunSik Lim
Fix typo about chart to map the kernel priority to user land priorities. * About sched_setscheduler(2) Processes scheduled under SCHED_FIFO or SCHED_RR can have a (user-space) static priority in the range 1 to 99. (reference: http://www.kernel.org/doc/man-pages/online/pages/ man2/sched_setscheduler.2.html) * From: Steven Rostedt 0 to 98 - maps to RT tasks 99 to 1 (SCHED_RR or SCHED_FIFO) 99 - maps to internal kernel threads that want to be lower than RT tasks but higher than SCHED_OTHER tasks. Although I'm not sure if any kernel thread actually uses this. I'm not even sure how this can be set, because the internal sched_setscheduler function does not allow for it. 100 to 139 - maps nice levels -20 to 19. These are not set via sched_setscheduler, but are set via the nice system call. 140 - reserved for idle tasks. Signed-off-by: GeunSik Lim <geunsik.lim@samsung.com> Acked-by: Steven Rostedt <rostedt@goodmis.org> Signed-off-by: Peter Zijlstra <a.p.zijlstra@chello.nl> LKML-Reference: <new-submission> Signed-off-by: Ingo Molnar <mingo@elte.hu>
2009-04-09tracing: consolidate documentsLi Zefan
Move kmemtrace.txt, tracepoints.txt, ftrace.txt and mmiotrace.txt to the new trace/ directory. I didnt find any references to those documents in both source files and documents, so no extra work needs to be done. Signed-off-by: Li Zefan <lizf@cn.fujitsu.com> Acked-by: Pekka Paalanen <pq@iki.fi> Cc: Steven Rostedt <rostedt@goodmis.org> Cc: Frederic Weisbecker <fweisbec@gmail.com> Cc: Mathieu Desnoyers <mathieu.desnoyers@polymtl.ca> LKML-Reference: <49DD6E2B.6090200@cn.fujitsu.com> Signed-off-by: Ingo Molnar <mingo@elte.hu>
