This commit applies memory-barriers.txt part of upstream change, commit
706eeb3e9c6f ("Documentation/locking/atomic: Add documents for new
atomic_t APIs") to Korean translation.
Signed-off-by: SeongJae Park <sj38.park@gmail.com>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
This commit applies upstream change, commit 66ce3a4dcb9f ("doc: Update
memory-barriers.txt for read-to-write dependencies") to Korean
translation.
mm/page_alloc.c
Now that there are no users of smp_mb__before_spinlock() left, remove
it entirely.
After removal of DocBook, those targets are bogus.
Reported-by: Jim Davis <jim.epost@gmail.com>
Signed-off-by: Mauro Carvalho Chehab <mchehab@s-opensource.com>
Obsolete links to atomic_ops.txt exist in ko_KR/memory-barriers.txt
though the file has moved to core-api/atomic_ops.rst. This commit fixes
the obsolete links.
This commit applies commit 388f9b20f98d ("Documentation/process/howto:
Only send regression fixes after -rc1") to Korean translation.
Korean translation, there should be a space terminating the link.
Acked-by: SeongJae Park <sj38.park@gmail.com>
This commit applies upstream change, commit b26cfc48e3e0 ("doc: Update
control-dependencies section of memory-barriers.txt"), to Korean
translation.
DocBook is mentioned several times at the documentation. Update
the obsolete references from it at the DocBook.
While converting the deviceiobook from DocBook to RST, dangling
references were left behind. This commit updates all remaining
references to the new location. SeongJae Park improved the ko_KR
translation.
Fixes: 8a8a602fdb83 ("docs: Convert the deviceio template to RST")
Signed-off-by: Helmut Grohne <h.grohne@intenta.de>
This commit adds Japanese translation of HOWTO document into rst based
documentation build system with updates.
Signed-off-by: Tsugikazu Shibata <tshibata@ab.jp.nec.com>
Documentation/sparse.txt has been moved to
Documentation/dev-tools/sparse.rst
Signed-off-by: Cao jin <caoj.fnst@cn.fujitsu.com>
This commit applies upstream change, commit c8241f8553e8 ("doc: Update
translation.
A Japanese translation file contained the incorrect email address for
the linux-api list.
Signed-off-by: Tyler Hicks <tyhicks@canonical.com>
An extra space in the wrong place made Sphinx unhappy; take it out.
Tested by the command:
make htmldocs
During the compiling process, zh_CN/coding-style.rst has no errors and
warnings generated, the generated html document has been checked.
Signed-off-by: Andy Deng <theandy.deng@gmail.com>
This commit applies all changes from the English version, and should
be able to work with the documentation build system.
Some of the sentences in Chapters 19 and 20 are re-translated:
- Fixed translation errors in Section 2 of Chapter 19 to prevent
misleading readers;
- Retranslate some sentences to make the translation more clear and
accurate.
It's no longer used.
Signed-off-by: Michael S. Tsirkin <mst@redhat.com>
Having the kernel-documentation at the topmost level doesn't
allow generating a separate PDF file for it. Also, makes harder
to add extra contents. So, place it on a sub-dir.
This commit adds Korean translation of HOWTO document into rst based
