path: root/Documentation/usb/chipidea.txt
2019-02-12MLK-9618-1 doc: usb: chipidea: select gadget drivers for otg compliance testLi Jun
This patch adds guide for selecting available gadget drivers for otg and EH compliance tests. Acked-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Li Jun <b47624@freescale.com> (cherry picked from commit 520cac9e4fe938887dd45b5b4df6c8e35e125a59) (cherry picked from commit 6534fab0bd77be544629ac04d4b8bb677d0a3aec)
2019-02-12MLK-11340-34 Documentation: usb: chipidea: Update test procedure for HNP ↵Li Jun
polling support Update HNP test procedure as HNP polling is supported. Signed-off-by: Li Jun <b47624@freescale.com> (cherry picked from commit 4aac546c4338246b1e55647796badedf6e80bfbe)
2016-05-04doc: usb: chipidea: update the doc for OTG FSMPeter Chen
Since we have added otg version and HNP polling support, update related documentation. Signed-off-by: Peter Chen <peter.chen@nxp.com>
2016-03-04Documentation: usb: chipidea: Update test procedure for HNP pollingLi Jun
Update HNP test procedure as HNP polling is supported. Acked-by: Peter Chen <peter.chen@nxp.com> Signed-off-by: Li Jun <jun.li@nxp.com> Signed-off-by: Felipe Balbi <balbi@kernel.org>
2015-12-24usb: chipidea: clean up CONFIG_USB_CHIPIDEA_DEBUG referencePeter Chen
Since this configuration option has deleted, cleans up all its references. Signed-off-by: Peter Chen <peter.chen@freescale.com> Reported-by: Valentin Rothberg <valentinrothberg@gmail.com>
2015-03-18doc: usb: chipidea: add usb wakeup enable examplePeter Chen
Add the example for how to enable USB as system wakeup source. Signed-off-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-05-23Doc: usb: chipidea: need to build both kernel Image and modulesPeter Chen
When tried to enable OTG FSM, we need to rebuild both kernel Image and modules, since there are some codes at gadget modules which are controlled by related configurations. Signed-off-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
2014-04-24Documentation: usb: add chipidea.txt for how to demo usb OTG HNP and SRPLi Jun
This patch adds a file chipidea.txt for how to demo chipidea usb OTG HNP and SRP functions via sysfs input files, any other possible information should be documented for chipidea usb driver in future can be added into this file. Signed-off-by: Peter Chen <peter.chen@freescale.com> Signed-off-by: Li Jun <b47624@freescale.com> Signed-off-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
