commit f811a38300be3cdb603171aea5ad3fb42b71ca53 upstream.
testusb.c at http://www.linux-usb.org/usbtest/ is out of date,
using the one at the kernel source folder.
Signed-off-by: Peter Chen <peter.chen@freescale.com>
Signed-off-by: Felipe Balbi <balbi@ti.com>
git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb
Pull USB updates from Greg KH:
"Here's the big USB patchset for 4.2-rc1. As is normal these days, the
majority of changes are in the gadget drivers, with a bunch of other
small driver changes.
All of these have been in linux-next with no reported issues"
* tag 'usb-4.2-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (175 commits)
usb: dwc3: Use ASCII space in Kconfig
usb: chipidea: add work-around for Marvell HSIC PHY startup
usb: chipidea: allow multiple instances to use default ci_default_pdata
dt-bindings: Consolidate ChipIdea USB ci13xxx bindings
phy: add Marvell HSIC 28nm PHY
phy: Add Marvell USB 2.0 OTG 28nm PHY
dt-bindings: Add Marvell PXA1928 USB and HSIC PHY bindings
USB: ssb: use devm_kzalloc
USB: ssb: fix error handling in ssb_hcd_create_pdev()
usb: isp1760: check for null return from kzalloc
cdc-acm: Add support of ATOL FPrint fiscal printers
usb: chipidea: usbmisc_imx: Remove unneeded semicolon
USB: usbtmc: add device quirk for Rigol DS6104
USB: serial: mos7840: Use setup_timer
phy: twl4030-usb: add ABI documentation
phy: twl4030-usb: remove incorrect pm_runtime_get_sync() in probe function.
phy: twl4030-usb: remove pointless 'suspended' test in 'suspend' callback.
phy: twl4030-usb: make runtime pm more reliable.
drivers:usb:fsl: Fix compilation error for fsl ehci drv
usb: renesas_usbhs: Don't disable the pipe if Control write status stage
RNDIS function has a limitation on the number of allowed instances.
So far it has been RNDIS_MAX_CONFIGS, which happens to be one.
In order to eliminate this kind of arbitrary limitation we should not
preallocate a predefined (RNDIS_MAX_CONFIGS) array of struct rndis_params
instances but instead allow allocating them on demand.
This patch allocates struct rndis_params on demand in rndis_register().
Coversly, the structure is free()'d in rndis_deregister().
If CONFIG_USB_GADGET_DEBUG_FILES is set, the proc files are created which
is the same behaviour as before, but the moment of creation is delayed
until struct rndis_params is actually allocated.
rnids_init() and rndis_exit() have nothing to do, so they are eliminated.
Signed-off-by: Andrzej Pietrasiewicz <andrzej.p@samsung.com>
While trying to test a Cinterion GSM/GPS/3G module I had reconfigured
the USB interface by mistake and therefore needed to run a different
USB driver than CDC-ACM. It turned out that I need the "usbserial" driver.
This file is an official description how to use it:
Documentation/usb/usb-serial.txt
But it is outdated. The parameters vendor= and product= have been
superseded by a /sys interface.
Here was the solution:
https://bbs.archlinux.org/viewtopic.php?id=175499
insmod usbserial vendor=0x#### product=0x####
becomes (first #### is vendor, second is product)
modprobe usbserial
echo #### #### >/sys/bus/usb-serial/drivers/generic/new_id
This patch changes the documentation file to describe the modern variant.
Please note that the old one still works (if compiled as module).
Signed-off-by: H. Nikolaus Schaller <hns@goldelico.com>
Signed-off-by: Marek Belisko <marek@goldelico.com>
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
Fix the UAC2 parameter capture channel mask
git://git.kernel.org/pub/scm/linux/kernel/git/balbi/usb into usb-next
Felipe writes:
usb: patches for v4.1 merge window
As usual, a big pile of commits. This time a total
of 111 non-merge commits.
Other than the usual set of cleanups and non-critical
fixes, we have some interesting work for AM335x's MUSB
babble recovery. Now that takes a lot less time and we
don't have to Reset MUSB all the time.
The printer gadget has been converted to configfs interface
and the atmel udc has learned suspend/resume with wakeup.
Add the example for how to enable USB as system wakeup source.
Add support for configfs interface so that f_printer can be used as a
component of usb gadgets composed with it.
Felipe writes:
usb: patches for v3.20 merge window
Here's the big pull request for Gadgets and PHYs. It's
a total of 217 non-merge commits with pretty much everything
being touched.
The most important bits are a ton of new documentation for
almost all usb gadget functions, a new isp1760 UDC driver,
several improvements to the old net2280 UDC driver, and
some minor tracepoint improvements to dwc3.
Other than that, a big list of minor cleanups, smaller bugfixes
and new features all over the place.
Summary of how to test UVC function of USB gadget.
Summary of how to test UAC2 function of USB gadget.
Summary of how to test UAC1 function of USB gadget.
Summary of how to test SOURCESINK function of USB gadget.
Summary of how to test SERIAL function of USB gadget.
Summary of how to test RNDIS function of USB gadget.
Summary of how to test PHONET function of USB gadget.
Summary of how to test OBEX function of USB gadget.
Summary of how to test NCM function of USB gadget.
Summary of how to test MIDI function of USB gadget.
Summary of how to test MASS STORAGE function of USB gadget.
Summary of how to test LOOPBACK function of USB gadget.
Summary of how to test HID function of USB gadget.
Summary of how to test FFS (FunctionFS) function of USB gadget.
Summary of how to test EEM function of USB gadget.
Summary of how to test ECM subset function of USB gadget.
Summary of how to test ECM function of USB gadget.
The newly added file will be used to provide descriptions of how to test
the functions of USB gadgets.
Using module parameters to specify accepted Vendor ID, Product ID is
considered legacy now. Update the documentation to reflect it.
Signed-off-by: Jeremiah Mahler <jmmahler@gmail.com>
The usbmon documentation uses "be reading until" which is an unusual
wording. Change it to "read until it" which is more clear.
"Here's the big set of USB and PHY patches for 3.19-rc1.
The normal churn in the USB gadget area is in here, as well as xhci
and other individual USB driver updates. The PHY tree is also in
here, as there were dependancies on the USB tree.
All of these have been in linux-next"
* tag 'usb-3.19-rc1' of git://git.kernel.org/pub/scm/linux/kernel/git/gregkh/usb: (351 commits)
arm: omap3: twl: remove usb phy init data
usbip: fix error handling in stub_probe()
usb: gadget: udc: missing curly braces
USB: mos7720: delete some unneeded code
wusb: replace memset by memzero_explicit
usbip: remove unneeded structure
usb: xhci: fix comment for PORT_DEV_REMOVE
xhci: don't use the same variable for stopped and halted rings current TD
xhci: clear extra bits from slot context when setting max exit latency
xhci: cleanup finish_td function
USB: adutux: NULL dereferences on disconnect
usb: chipidea: fix platform_no_drv_owner.cocci warnings
usb: chipidea: Fixed a few typos in comments
Documentation: bindings: add doc for the USB2 ChipIdea USB driver
usb: chipidea: add a usb2 driver for ci13xxx
usb: chipidea: fix phy handling
usb: chipidea: remove duplicate dev_set_drvdata for host_start
usb: chipidea: parameter 'mode' isn't needed for hw_device_reset
usb: chipidea: add controller reset API
usb: chipidea: remove flag CI_HDRC_REQUIRE_TRANSCEIVER
Pull trivial tree update from Jiri Kosina:
"Usual stuff: documentation updates, printk() fixes, etc"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (24 commits)
intel_ips: fix a type in error message
cpufreq: cpufreq-dt: Move newline to end of error message
ps3rom: fix error return code
treewide: fix typo in printk and Kconfig
ARM: dts: bcm63138: change "interupts" to "interrupts"
Replace mentions of "list_struct" to "list_head"
kernel: trace: fix printk message
scsi: mpt2sas: fix ioctl in comment
zbud, zswap: change module author email
clocksource: Fix 'clcoksource' typo in comment
arm: fix wording of "Crotex" in CONFIG_ARCH_EXYNOS3 help
gpio: msm-v1: make boolean argument more obvious
usb: Fix typo in usb-serial-simple.c
PCI: Fix comment typo 'COMFIG_PM_OPS'
powerpc: Fix comment typo 'CONIFG_8xx'
powerpc: Fix comment typos 'CONFiG_ALTIVEC'
clk: st: Spelling s/stucture/structure/
isci: Spelling s/stucture/structure/
usb: gadget: zero: Spelling s/infrastucture/infrastructure/
treewide: Fix company name in module descriptions
After commit b2b49ccbdd54 (PM: Kconfig: Set PM_RUNTIME if PM_SLEEP is
selected) PM_RUNTIME is always set if PM is set, so quite a few
depend on CONFIG_PM (or even dropped in some cases).
Replace CONFIG_PM_RUNTIME with CONFIG_PM in the USB core code
and documentation.
Acked-by: Alan Stern <stern@rowland.harvard.edu>
Acked-by: Greg Kroah-Hartman <gregkh@linuxfoundation.org>
git://git.kernel.org/pub/scm/linux/kernel/git/johan/usb-serial into usb-next
Johan writes:
USB-serial updates for v3.19-rc1
These changes add a new "simple" driver for Google USB-serial
devices and add support for Huawei Gobi modems to qcserial.
Included are also some removals of unnecessary atomic allocations and
a few spelling fixes.
Signed-off-by: Johan Hovold <johan@kernel.org>
current trivial.git base
Make the hid function available for gadgets composed with configfs.
Signed-off-by: Frans Klaver <frans.klaver@xsens.com>
Entrega is misspelled as Entregra or Entrgra, so fix that.
Signed-off-by: Mark Knibbs <markk@clara.co.uk>
USB hub has started to use a workqueue instead of kthread. Let's update
the documentation and comments here and there.
This patch mostly just replaces "khubd" with "hub_wq". There are only few
exceptions where the whole sentence was updated. These more complicated
changes can be found in the following files:
Documentation/usb/hotplug.txt
drivers/net/usb/usbnet.c
drivers/usb/core/hcd.c
drivers/usb/host/ohci-hcd.c
drivers/usb/host/xhci.c
Signed-off-by: Petr Mladek <pmladek@suse.cz>
The existing UWB documentation states that UWB devices show up in
/sys/class/uwb and /sys/bus/uwb/devices. Up until the most recent
changes to add uwb devices to their own bus, neither of these statements
were actually true. Now, UWB devices do show up in /sys/bus/uwb/devices
so the documentation has been updated to reflect that and removed
references to /sys/class/uwb.
The existing documentation also states that local UWB radio controller
(RC) devices also show up as UWB devices along with their wireless peer
UWB devices under /sys/class/uwb. This is not true so that statement
has been removed.
Signed-off-by: Thomas Pugliese <thomas.pugliese@gmail.com>
Fixed several typos in the code examples given in
Documentation/usb/hotplug.txt.
- missing [] with array of struct usb_device_id
- checkpatch.pl warning: space between function name and parenthesis
- missing terminating ';'
describe the mechanisms for controlling port power policy and
discovering the port power state.
[oliver]: fixes, clarification of wakeup vs port-power-control
[sarah]: wordsmithing
[djbw]: updates for peer port changes
[alan]: review and fixes
Cc: Oliver Neukum <oneukum@suse.de>
Signed-off-by: Lan Tianyu <tianyu.lan@intel.com>
git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial into next
Pull trivial tree changes from Jiri Kosina:
"Usual pile of patches from trivial tree that make the world go round"
* 'for-linus' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (23 commits)
staging: go7007: remove reference to CONFIG_KMOD
aic7xxx: Remove obsolete preprocessor define
of: dma: doc fixes
doc: fix incorrect formula to calculate CommitLimit value
doc: Note need of bc in the kernel build from 3.10 onwards
mm: Fix printk typo in dmapool.c
modpost: Fix comment typo "Modules.symvers"
Kconfig.debug: Grammar s/addition/additional/
wimax: Spelling s/than/that/, wording s/destinatary/recipient/
aic7xxx: Spelling s/termnation/termination/
arm64: mm: Remove superfluous "the" in comment
of: Spelling s/anonymouns/anonymous/
dma: imx-sdma: Spelling s/determnine/determine/
ath10k: Improve grammar in comments
ath6kl: Spelling s/determnine/determine/
of: Improve grammar for of_alias_get_id() documentation
drm/exynos: Spelling s/contro/control/
radio-bcm2048.c: fix wrong overflow check
doc: printk-formats: do not mention casts for u64/s64
doc: spelling error changes
When tried to enable OTG FSM, we need to rebuild both kernel Image
and modules, since there are some codes at gadget modules which are
controlled by related configurations.
Fixed multiple spelling errors.
Acked-by: Randy Dunlap <rdunlap@infradead.org>
Signed-off-by: Carlos E. Garcia <carlos@cgarcia.org>
This patch adds a file chipidea.txt for how to demo chipidea usb OTG HNP and SRP
functions via sysfs input files, any other possible information should be
documented for chipidea usb driver in future can be added into this file.
Signed-off-by: Li Jun <b47624@freescale.com>
Fix double words "the the" in various files
within Documentations.
Signed-off-by: Masanari Iida <standby24x7@gmail.com>
Changed from "Please not that" to "Please note that"
Signed-off-by: David E. Narvaez <david.narvaez@computer.org>
Acked-by: Felipe Balbi <balbi@ti.com>
Correct spelling typo in Documentation/usb/gadget_configs.txt
The config descriptors as read from /proc/bus/usb/BBB/DDD are in *bus* endian
format. Correct proc_usb_info.txt to correctly reflect that.
