path: root/Documentation/usb
2011-05-09USB: teach "devices" file about Wireless and SuperSpeed USBAlan Stern
commit 834e2312e7a384877a876b0d34dffc3046c96bcb upstream. USB: teach "devices" file about Wireless and SuperSpeed USB The /sys/kernel/debug/usb/devices file doesn't know about Wireless or SuperSpeed USB. This patch (as1416b) teaches it, and updates the Documentation/usb/proc_sub_info.txt file accordingly. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> CC: David Vrabel <david.vrabel@csr.com> CC: Sarah Sharp <sarah.a.sharp@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de> [Julien Blache: The original commit also added the correct speed for USB_SPEED_WIRELESS, I removed it as it's not supported in 2.6.32.] Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23USB: Fix sysfs paths in documentationJean Delvare
Neither /sys/usb/devices nor /sys/bus/devices exist. The correct path is /sys/bus/usb/devices. Signed-off-by: Jean Delvare <khali@linux-fr.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23USB: fix paths in usbmon documentationRogério Brito
Hi there. On Aug 21 2009, Alan Stern wrote: > On Thu, 20 Aug 2009, Rogério Brito wrote: > > Again, just reiterating, what I said before, even though I am not sure > > if I can reproduce it, I will try to. > > A usbmon trace showing what happens when you plug in the drive and > when you run smartctl would help. The documentation for usbmon in the kernel 2.6.31-rc7 kernel doesn't match what the kernel exposes in the debug fs tree. This patch fixes it. Signed-off-by: Rogério Brito <rbrito@ime.usp.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-09-23USB: usbmon: touch up the documentationPete Zaitcev
I think this sentence was confusing regarding the possible size of the data area. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-06-12trivial: usb: fix missing space typo in docNémeth Márton
Signed-off-by: Márton Németh <nm127@freemail.hu> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-06-12trivial: Miscellaneous documentation typo fixesMatt LaPlante
Fix various typos in documentation txts. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Jiri Kosina <jkosina@suse.cz>
2009-03-24USB: usbmon: Add binary API v1Pete Zaitcev
This patch adds an extension to the binary API so it reaches parity with existing text API (so-called "1u"). The extension delivers additional data, such as ISO descriptors and the interrupt interval. Signed-Off-By: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-29Documentation: move DMA-mapping.txt to Doc/PCI/Randy Dunlap
Move DMA-mapping.txt to Documentation/PCI/. DMA-mapping.txt was supposed to be moved from Documentation/ to Documentation/PCI/. The 00-INDEX files in those two directories were updated, along with a few other text files, but the file itself somehow escaped being moved, so move it and update more text files and source files with its new location. Signed-off-by: Randy Dunlap <randy.dunlap@oracle.com> Acked-by: Greg Kroah-Hartman <gregkh@suse.de> cc: Jesse Barnes <jbarnes@virtuousgeek.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2009-01-07USB: add asynchronous autosuspend/autoresume supportAlan Stern
This patch (as1160b) adds support routines for asynchronous autosuspend and autoresume, with accompanying documentation updates. There already are several potential users of this interface, and others are likely to arise as autosuspend support becomes more widespread. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2009-01-02Merge branch 'master' of ↵David Vrabel
git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux-2.6 into for-upstream Conflicts: drivers/uwb/wlp/eda.c
2008-12-17USB: fix comment about endianness of descriptorsPhil Endecott
This patch fixes a comment and clarifies the documentation about the endianness of descriptors. The current policy is that descriptors will be little-endian at the API even on big-endian systems; however the /proc/bus/usb API predates this policy and presents descriptors with some multibyte fields byte-swapped. Signed-off-by: Phil Endecott <usb_endian_patch@chezphil.org> Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-17USB: Documentation/usb/gadget_serial.txt: update to match driver use_acm ↵Peter Korsgaard
behaviour Commit 7bb5ea54 (usb gadget serial: use composite gadget framework) changed the default for the use_acm parameter from 0 to 1. Update the documentation to match. Signed-off-by: Peter Korsgaard <jacmet@sunsite.dk> Acked-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-12-17usbmon: drop bogus 0t from usbmon.txtPete Zaitcev
The example is incorrect: there is no 0t socket (the '1t' format has no bus number in it). Also, correct the broken sentence for USB Tag. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-11-19uwb: add basic radio managerDavid Vrabel
The UWB radio manager coordinates the use of the radio between the PALs that may be using it. PALs request use of the radio with uwb_radio_start() and the radio manager will start beaconing if its not already doing so. When the last PAL has called uwb_radio_stop() beaconing will be stopped. In the future, the radio manager will have a more sophisticated channel selection algorithm, probably following the Channel Selection Policy from the WiMedia Alliance when it is finalized. For now, channel 9 (BG1, TFC1) is selected. The user may override the channel selected by the radio manager and may force the radio to stop beaconing. The WUSB Host Controller PAL makes use of this and there are two new debug PAL commands that can be used for testing. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-10-20Merge branch 'master' into for-upstreamDavid Vrabel
Conflicts: Documentation/ABI/testing/sysfs-bus-usb drivers/Makefile
2008-10-17USB: Fix doc for usb_autopm_enableGeoff Levand
Correct errors in the descriptions for usb_autopm_enable and usb_autopm_disable in the USB PM doc. Signed-off-by: Geoff Levand <geoff@infradead.org> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: Documentation/usb/anchors.txt #2Oliver Neukum
This adds Documentation for the extensions of the anchor API. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-17USB: Added driver for a Delcom USB 7-segment LED DisplayHarrison Metzger
Added basic support for a Delcom USB 7-segment LED Display Signed-off by: Harrison Metzger <harrisonmetz@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-10-10Merge branch 'for-upstream' of ↵David Vrabel
git://git.kernel.org/pub/scm/linux/kernel/git/dvrabel/uwb into for-upstream
2008-09-23USB: update of Documentation/usb/anchors.txtOliver Neukum
The extended anchor API is documented Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-09-17wusb: wusb-cbaf (CBA driver) sysfs ABI simplificationFelipe Zimmerle
Simplify the sysfs ABI of the wusb-cbaf (Cable Based Association) driver: use one value per file and cause the write of the CHID to fetch the CDID (instead of requiring a separate read). Update the example wusb-cbaf script to work with this revised ABI. Signed-off-by: Felipe Zimmerle <felipe.zimmerle@indt.org.br> Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-09-17uwb: add initial documentationInaky Perez-Gonzalez
Documentation (and example utilities) for the UWB (and WUSB) stacks. Some of the documentation may be out-of-date. Signed-off-by: David Vrabel <david.vrabel@csr.com>
2008-08-13USB: update to DocumentationOliver Neukum
this mentions a new deadlock due to advanced power management. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-13usb: auerswald: remove driver (obsolete)Wolfgang Mües
This patch removes the auerswald USB driver from the linux kernel 2.6.26. This driver was included into the kernel mainly to connect to the ISDN framework. This was done in linux 2.4.x. For 2.6.x, due to the fragile and moving ISDN support, this connection was never realized, and the only use of this driver was for device configuration. In the age of DSL, the demand of ISDN support is getting very low. Meanwhile, with the advent of libusb, an userspace driver was done for the device configuration which works fine for linux and mac. (Thanks to the libusb developers!). The userspace driver is downloadable from the auerswald web site. So this driver is obsolete now and has to be removed. Many thanks to all developers which helped me to bring this driver up and working. Signed-off-by: Wolfgang Muees <wolfgang@iksw-muees.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-26Documentation cleanup: trivial misspelling, punctuation, and grammar ↵Matt LaPlante
corrections. Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21USB: use reset_resume when normal resume failsAlan Stern
This patch (as1109b) makes USB-Persist more resilient to errors. With the current code, if a normal resume fails, it's an unrecoverable error. With the patch, if a normal resume fails (and if the device is enabled for USB-Persist) then a reset-resume is tried. This fixes the problem reported in Bugzilla #10977. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21usb gadget: use new serial coreDavid Brownell
Teach "gadget serial" to use the new abstracted (and bugfixed) TTY glue, and remove all the orignal tangled-up code. Update the documentation accordingly. This is a net object code shrink and cleanup; it should make it a lot easier to see how the TTY glue should accomodate updates to the TTY layer, be bugfixed, etc. Notable behavior changes include: it can now support getty even when there's no USB connection; it fits properly into the mdev/udev world; and RX handling is better (throttling works, and low latency). Configurations with scripts setting up the /dev/ttygserial device node (with "experimental" major number) may want to change that to be a symlink pointing to the /dev/ttyGS0 file, as a migration aid; else, just switch entirely over to mdev/udev. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21USB: remove Documentation/usb/uhci.txtAdrian Bunk
The driver was removed before kernel 2.6.0 Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: add documentation about callbacksOliver Neukum
Add Documentation about callbacks in USB. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: add Documentation about usb_anchorOliver Neukum
This adds documentation about the new usb anchor infrastructure. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: serial: Remove obsolete contact addressesMatti Linnanvuori
Remove obsolete contact addresses. Signed-off-by: Matti Linnanvuori <mattilinnanvuori@yahoo.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: check serial-number string after device resetAlan Stern
This patch (as1048) extends the descriptor checking after a device is reset. Now the SerialNumber string descriptor is compared to its old value, in addition to the device and configuration descriptors. As a consequence, the kmalloc() call in usb_string() is now on the error-handling pathway for usb-storage. Hence its allocation type is changed to GFO_NOIO. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: remove CONFIG_USB_PERSIST settingAlan Stern
This patch (as1047) removes the USB_PERSIST Kconfig option, enabling it permanently. It also prevents the power/persist attribute from being created for hub devices; there's no point in having it since USB-PERSIST is always turned on for hubs. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-10USB:Update mailing list information in documentationRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: add Printer Gadget DriverCraig W. Nadler
G_PRINTER: Adds a USB printer gadget driver for use in printer firmware. This adds a USB printer gadget driver for use in printer firmware. The printer gadget channels data between the USB host and a userspace program driving the print engine. The user space program reads and writes the device file /dev/g_printer to receive or send printer data. It can use ioctl calls to the device file to get or set printer status. Signed-off-by: Craig W. Nadler <craig@nadler.us> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: add iuu_phoenix driverAlain Degreffe
Signed-off-by: Alain Degreffe <eczema@ecze.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-28USB: power-management documenation updateAlan Stern
This patch (as1014) was partly written by Tilman Schmidt. It clarifies the USB power-management documentation by explaining that when a disconnect occurs, a suspend method call might not be followed by either a resume or a reset_resume call. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-20spelling fixes: Documentation/Simon Arlott
Spelling fixes in Documentation/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-12USB: documentation for USB power managementAlan Stern
This patch (as998) adds documentation on how USB power management works and how to use it. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: Driver for CH341 USB-serial adaptorFrank A Kingswood
This patch implements a USB serial port driver for the Winchiphead CH341 USB-RS232 Converter. This chip also implements an IEEE 1284 parallel port, I2C and SPI, but that is not supported by the driver. Signed-off-by: Frank A Kingswood <frank@kingswood-consulting.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: usbmon doc update - mention new wildcard ('0') busPaolo 'Blaisorblade' Giarrusso
Update usbmon documentation, mentioning the "zero" (wildcard) bus. Possibly, in my first hunk, the 'either ... or ...' should be rephrased a bit to be expressed better. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12usb: document device authorizationInaky Perez-Gonzalez
Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: usb/dma doc updatesDavid Brownell
This patch updates some of the documentation about DMA buffer management for USB, and ways to avoid extra copying. Our understanding of the issues has improved over time. - Most drivers should *avoid* the dma-coherent allocators. There are a few exceptions (like the HID driver). - Some methods are currently commented out; it seems folk writing USB drivers aren't doing performance tuning at that level yet. - Just avoid highmem; there's no good way to pass an "I can do highmem DMA" capability through a driver stack. This is easy, everything already avoids highmem. But it'd be nice if x86_32 systems with much physical memory could use it directly with network adapters and mass storage devices. (Patch, anyone?) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: add power/persist device attributeAlan Stern
This patch (as920) adds an extra level of protection to the USB-Persist facility. Now it will apply by default only to hubs; for all other devices the user must enable it explicitly by setting the power/persist device attribute. The disconnect_all_children() routine in hub.c has been removed and its code placed inline. This is the way it was originally as part of hub_pre_reset(); the revised usage in hub_reset_resume() is sufficiently different that the code can no longer be shared. Likewise, mark_children_for_reset() is now inline as part of hub_reset_resume(). The end result looks much cleaner than before. The sysfs interface is updated to add the new attribute file, and there are corresponding documentation updates. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: add USB-Persist facilityAlan Stern
This patch (as886) adds the controversial USB-persist facility, allowing USB devices to persist across a power loss during system suspend. The facility is controlled by a new Kconfig option (with appropriate warnings about the potential dangers); when the option is off the behavior will remain the same as it is now. But when the option is on, people will be able to use suspend-to-disk and keep their USB filesystems intact -- something particularly valuable for small machines where the root filesystem is on a USB device! Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-09documentation: convert the Documentation directory to UTF-8John Anthony Kazos Jr
Convert files within the Documentation directory to UTF-8. Adrian Bunk: small additional fixes Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-04MAINTAINER change for Connect Tech IncStuart MacDonald
I am no longer with CTI. The Support Department will handle all inquiries regarding the WH. Signed-off-by: Stuart MacDonald <stuartm@connecttech.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-27usbmon: Extended text APIPete Zaitcev
This patch adds a new text API, codenamed '1u', which captures more URB fields than old '1t' interface did. Also the '1u' text API is compatible with the future "bus zero" extension. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07USB: add binary API to usbmonPete Zaitcev
This patch adds a new, "binary" API in addition to the old, text API usbmon had before. The new API allows for less CPU use, and it allows to capture all data from a packet where old API only captured 32 bytes at most. There are some limitations and conditions to this, e.g. in case someone constructs a URB with 1GB of data, it's not likely to be captured, because even the huge buffers of the new reader are finite. Nonetheless, I expect this new capability to capture all data for all real life scenarios. The downside is, a special user mode application is required where cat(1) worked before. I have sample code at http://people.redhat.com/zaitcev/linux/ and Paolo Abeni is working on patching libpcap. This patch was initially written by Paolo and later I tweaked it, and we had a little back-and-forth. So this is a jointly authored patch, but I am submitting this I am responsible for the bugs. Signed-off-by: Paolo Abeni <paolo.abeni@email.it> Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07USB: indicate active altsetting in proc/bus/usb/devices fileDavid Brownell
Update /proc/bus/usb/devices output to report active altsettings. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
