path: root/Documentation/usb
2008-09-23USB: update of Documentation/usb/anchors.txtOliver Neukum
The extended anchor API is documented Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-13USB: update to DocumentationOliver Neukum
this mentions a new deadlock due to advanced power management. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-08-13usb: auerswald: remove driver (obsolete)Wolfgang Mües
This patch removes the auerswald USB driver from the linux kernel 2.6.26. This driver was included into the kernel mainly to connect to the ISDN framework. This was done in linux 2.4.x. For 2.6.x, due to the fragile and moving ISDN support, this connection was never realized, and the only use of this driver was for device configuration. In the age of DSL, the demand of ISDN support is getting very low. Meanwhile, with the advent of libusb, an userspace driver was done for the device configuration which works fine for linux and mac. (Thanks to the libusb developers!). The userspace driver is downloadable from the auerswald web site. So this driver is obsolete now and has to be removed. Many thanks to all developers which helped me to bring this driver up and working. Signed-off-by: Wolfgang Muees <wolfgang@iksw-muees.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-26Documentation cleanup: trivial misspelling, punctuation, and grammar ↵Matt LaPlante
corrections. Cc: Randy Dunlap <randy.dunlap@oracle.com> Signed-off-by: Andrew Morton <akpm@linux-foundation.org> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2008-07-21USB: use reset_resume when normal resume failsAlan Stern
This patch (as1109b) makes USB-Persist more resilient to errors. With the current code, if a normal resume fails, it's an unrecoverable error. With the patch, if a normal resume fails (and if the device is enabled for USB-Persist) then a reset-resume is tried. This fixes the problem reported in Bugzilla #10977. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21usb gadget: use new serial coreDavid Brownell
Teach "gadget serial" to use the new abstracted (and bugfixed) TTY glue, and remove all the orignal tangled-up code. Update the documentation accordingly. This is a net object code shrink and cleanup; it should make it a lot easier to see how the TTY glue should accomodate updates to the TTY layer, be bugfixed, etc. Notable behavior changes include: it can now support getty even when there's no USB connection; it fits properly into the mdev/udev world; and RX handling is better (throttling works, and low latency). Configurations with scripts setting up the /dev/ttygserial device node (with "experimental" major number) may want to change that to be a symlink pointing to the /dev/ttyGS0 file, as a migration aid; else, just switch entirely over to mdev/udev. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-07-21USB: remove Documentation/usb/uhci.txtAdrian Bunk
The driver was removed before kernel 2.6.0 Signed-off-by: Adrian Bunk <bunk@kernel.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: add documentation about callbacksOliver Neukum
Add Documentation about callbacks in USB. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: add Documentation about usb_anchorOliver Neukum
This adds documentation about the new usb anchor infrastructure. Signed-off-by: Oliver Neukum <oneukum@suse.de> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: serial: Remove obsolete contact addressesMatti Linnanvuori
Remove obsolete contact addresses. Signed-off-by: Matti Linnanvuori <mattilinnanvuori@yahoo.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: check serial-number string after device resetAlan Stern
This patch (as1048) extends the descriptor checking after a device is reset. Now the SerialNumber string descriptor is compared to its old value, in addition to the device and configuration descriptors. As a consequence, the kmalloc() call in usb_string() is now on the error-handling pathway for usb-storage. Hence its allocation type is changed to GFO_NOIO. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-04-24USB: remove CONFIG_USB_PERSIST settingAlan Stern
This patch (as1047) removes the USB_PERSIST Kconfig option, enabling it permanently. It also prevents the power/persist attribute from being created for hub devices; there's no point in having it since USB-PERSIST is always turned on for hubs. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-03-10USB:Update mailing list information in documentationRobert P. J. Day
Signed-off-by: Robert P. J. Day <rpjday@crashcourse.ca> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: add Printer Gadget DriverCraig W. Nadler
G_PRINTER: Adds a USB printer gadget driver for use in printer firmware. This adds a USB printer gadget driver for use in printer firmware. The printer gadget channels data between the USB host and a userspace program driving the print engine. The user space program reads and writes the device file /dev/g_printer to receive or send printer data. It can use ioctl calls to the device file to get or set printer status. Signed-off-by: Craig W. Nadler <craig@nadler.us> Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2008-02-01USB: add iuu_phoenix driverAlain Degreffe
Signed-off-by: Alain Degreffe <eczema@ecze.com> Cc: Alan Cox <alan@lxorguk.ukuu.org.uk> Cc: Oliver Neukum <oliver@neukum.org> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-11-28USB: power-management documenation updateAlan Stern
This patch (as1014) was partly written by Tilman Schmidt. It clarifies the USB power-management documentation by explaining that when a disconnect occurs, a suspend method call might not be followed by either a resume or a reset_resume call. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Tilman Schmidt <tilman@imap.cc> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-20spelling fixes: Documentation/Simon Arlott
Spelling fixes in Documentation/. Signed-off-by: Simon Arlott <simon@fire.lp0.eu> Signed-off-by: Adrian Bunk <bunk@kernel.org>
2007-10-12USB: documentation for USB power managementAlan Stern
This patch (as998) adds documentation on how USB power management works and how to use it. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: Driver for CH341 USB-serial adaptorFrank A Kingswood
This patch implements a USB serial port driver for the Winchiphead CH341 USB-RS232 Converter. This chip also implements an IEEE 1284 parallel port, I2C and SPI, but that is not supported by the driver. Signed-off-by: Frank A Kingswood <frank@kingswood-consulting.co.uk> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12USB: usbmon doc update - mention new wildcard ('0') busPaolo 'Blaisorblade' Giarrusso
Update usbmon documentation, mentioning the "zero" (wildcard) bus. Possibly, in my first hunk, the 'either ... or ...' should be rephrased a bit to be expressed better. Signed-off-by: Paolo 'Blaisorblade' Giarrusso <blaisorblade@yahoo.it> Cc: Pete Zaitcev <zaitcev@redhat.com> Cc: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-10-12usb: document device authorizationInaky Perez-Gonzalez
Signed-off-by: Inaky Perez-Gonzalez <inaky@linux.intel.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: usb/dma doc updatesDavid Brownell
This patch updates some of the documentation about DMA buffer management for USB, and ways to avoid extra copying. Our understanding of the issues has improved over time. - Most drivers should *avoid* the dma-coherent allocators. There are a few exceptions (like the HID driver). - Some methods are currently commented out; it seems folk writing USB drivers aren't doing performance tuning at that level yet. - Just avoid highmem; there's no good way to pass an "I can do highmem DMA" capability through a driver stack. This is easy, everything already avoids highmem. But it'd be nice if x86_32 systems with much physical memory could use it directly with network adapters and mass storage devices. (Patch, anyone?) Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: add power/persist device attributeAlan Stern
This patch (as920) adds an extra level of protection to the USB-Persist facility. Now it will apply by default only to hubs; for all other devices the user must enable it explicitly by setting the power/persist device attribute. The disconnect_all_children() routine in hub.c has been removed and its code placed inline. This is the way it was originally as part of hub_pre_reset(); the revised usage in hub_reset_resume() is sufficiently different that the code can no longer be shared. Likewise, mark_children_for_reset() is now inline as part of hub_reset_resume(). The end result looks much cleaner than before. The sysfs interface is updated to add the new attribute file, and there are corresponding documentation updates. Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-07-12USB: add USB-Persist facilityAlan Stern
This patch (as886) adds the controversial USB-persist facility, allowing USB devices to persist across a power loss during system suspend. The facility is controlled by a new Kconfig option (with appropriate warnings about the potential dangers); when the option is off the behavior will remain the same as it is now. But when the option is on, people will be able to use suspend-to-disk and keep their USB filesystems intact -- something particularly valuable for small machines where the root filesystem is on a USB device! Signed-off-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-05-09documentation: convert the Documentation directory to UTF-8John Anthony Kazos Jr
Convert files within the Documentation directory to UTF-8. Adrian Bunk: small additional fixes Signed-off-by: John Anthony Kazos Jr. <jakj@j-a-k-j.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2007-05-04MAINTAINER change for Connect Tech IncStuart MacDonald
I am no longer with CTI. The Support Department will handle all inquiries regarding the WH. Signed-off-by: Stuart MacDonald <stuartm@connecttech.com> Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-04-27usbmon: Extended text APIPete Zaitcev
This patch adds a new text API, codenamed '1u', which captures more URB fields than old '1t' interface did. Also the '1u' text API is compatible with the future "bus zero" extension. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Acked-by: Alan Stern <stern@rowland.harvard.edu> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07USB: add binary API to usbmonPete Zaitcev
This patch adds a new, "binary" API in addition to the old, text API usbmon had before. The new API allows for less CPU use, and it allows to capture all data from a packet where old API only captured 32 bytes at most. There are some limitations and conditions to this, e.g. in case someone constructs a URB with 1GB of data, it's not likely to be captured, because even the huge buffers of the new reader are finite. Nonetheless, I expect this new capability to capture all data for all real life scenarios. The downside is, a special user mode application is required where cat(1) worked before. I have sample code at http://people.redhat.com/zaitcev/linux/ and Paolo Abeni is working on patching libpcap. This patch was initially written by Paolo and later I tweaked it, and we had a little back-and-forth. So this is a jointly authored patch, but I am submitting this I am responsible for the bugs. Signed-off-by: Paolo Abeni <paolo.abeni@email.it> Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-02-07USB: indicate active altsetting in proc/bus/usb/devices fileDavid Brownell
Update /proc/bus/usb/devices output to report active altsettings. Signed-off-by: David Brownell <dbrownell@users.sourceforge.net> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2007-01-23Change Linus' email address tooLinus Torvalds
This changes a few mentions of my email address to point to the new one, leaving things like old copyright messages alone. Signed-off-by: Linus Torvalds <torvalds@linux-foundation.org>
2007-01-05USB: small update to Documentation/usb/acm.txtOliver Neukum
this docu update mentions that cell phones also use cdc-acm. Signed-off-by: Oliver Neukum <oliver@neukum.name>
2006-11-30Fix typos in /Documentation : MiscMatt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some misc words. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-30Fix typos in /Documentation : 'T''Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some +words starting with the letter 'T'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-11-03USB: HID: add blacklist AIRcable USB, little beautificationNaranjo Manuel Francisco
This patch add AIRcable USBto USB-HID blacklist, makes some little changes things in the Kconfig to make AIRcable USB look as all the rest of drivers. And it removes the readme part that was on Documentation/usb/usb-serial.txt because it is not needed anymore. Signed-off-by: Naranjo Manuel Francisco <naranjo.manuel@gmail.com Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-10-03Documentation: remove duplicated wordsPaolo Ornati
Remove many duplicated words under Documentation/ and do other small cleanups. Examples: "and and" --> "and" "in in" --> "in" "the the" --> "the" "the the" --> "to the" ... Signed-off-by: Paolo Ornati <ornati@fastwebnet.it> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'S'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letter 'S'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Alan Cox <alan@redhat.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'N'-'P'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'N'-'P'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'H'-'M'Matt LaPlante
This patch fixes typos in various Documentation txts. The patch addresses some words starting with the letters 'H'-'M'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Acked-by: Randy Dunlap <rdunlap@xenotime.net> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03Fix typos in Documentation/: 'D'-'E'Matt LaPlante
This patch fixes typos in various Documentation txts. This patch addresses some words starting with the letters 'D'-'E'. Signed-off-by: Matt LaPlante <kernel1@cyberdogtech.com> Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-10-03remove mentionings of devfs in documentationAdrian Bunk
Now that devfs is removed, there's no longer any need to document how to do this or that with devfs. This patch includes some improvements by Joe Perches. Signed-off-by: Adrian Bunk <bunk@stusta.de>
2006-09-27USB: Dealias -110 code (more complete)Pete Zaitcev
The purpose of this patch is to split off the case when a device does not reply on the lower level (which is reported by HC hardware), and a case when the device accepted the request, but does not reply at upper level. This redefinition allows to diagnose issues easier, without asking the user if the -110 happened "immediately". The usbmon splits such cases already thanks to its timestamp, but it's not always available. I adjusted all drivers which I found affected (by searching for "urb"). Out of tree drivers may suffer a little bit, but I do not expect much breakage. At worst they may print a few messages. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-09-27Add AIRcable USB Bluetooth Dongle DriverManuel Francisco Naranjo
Add driver for AIRcable USB Bluetooth dongle. Signed-off-by: Naranjo, Manuel Francisco <naranjo.manuel@gmail.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-02USB: doc: fixes devio.c location in proc_usb_info.txt.Luiz Fernando N. Capitulino
Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-08-02USB: doc: usb-help.txt update.Luiz Fernando N. Capitulino
http://www.suse.cz/development/linux-usb/ doesn't exist anymore. Signed-off-by: Luiz Fernando N. Capitulino <lcapitulino@mandriva.com.br> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-07-12[PATCH] USB: Addition of vendor/product id pair for pl2303 driverPeter Moulder
Text from the back of the box, for your information/amusement: USB DATA CABLE FOR K700 Series The USB Cable is an ideal link between your mobile phone and PC. Employing the user-friendiy [sic] USB standard,its capacity for rapid data transfer enables functions such as synchronization of phone book and calendar,as well as Internet browsing via a modem-enabled phone.Autual [sic] connection speed is dependent on phone capacity. MADE IN CHINA From: Peter Moulder <Peter.Moulder@infotech.monash.edu.au> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-06-21[PATCH] USB: update usbmon.txtPete Zaitcev
Fix up the documentation. Apparently, I left unedited copy-paste results in examples. Also, Alan helped me to improve the most confusing parts. Signed-off-by: Pete Zaitcev <zaitcev@redhat.com> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-04-02V4L/DVB (3653h): Move usb v4l docs into Documentation/video4linuxMichael Krufky
- Move documentation for usb v4l devices from Documentation/usb to Documentation/video4linux. - Removed trailing whitespace. - Update Kconfig help text links to reflect the new file locations. Signed-off-by: Michael Krufky <mkrufky@linuxtv.org> Signed-off-by: Mauro Carvalho Chehab <mchehab@infradead.org>
2006-03-20[PATCH] USB: ZC0301 driver bugfixLuca Risolia
ZC0301 driver bugfix. Use correct PID/VID USB entries. Signed-off-by: Luca Risolia <luca.risolia@studio.unibo.it> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] USB: ZC0301 driver updatesLuca Risolia
ZC0301 driver updates. Changes: + new, - removed, * cleanup, @ bugfix @ Need usb_get|put_dev() when disconnecting, if the device is open * Cleanups and updates in the documentation + Use per-device sensor structures + Add frame_timeout module parameter Signed-off-by: Luca Risolia <luca.risolia@studio.unibo.it> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
2006-03-20[PATCH] USB: ET61X[12]51 driver updatesLuca Risolia
USB: ET61X[12]51 driver updates Changes: + new, - removed, * cleanup, @ bugfix @ Fix stream_interrupt() @ Fix vidioc_enum_input() and split vidioc_gs_input() @ Need usb_get|put_dev() when disconnecting, if the device is open * Use wait_event_interruptible_timeout() instead of wait_event_interruptible() when waiting for video frames * replace wake_up_interruptible(&wait_stream) with wake_up(&wait_stream) * Cleanups and updates in the documentation * Use mutexes instead of semaphores + Use per-device sensor structures + Add support for PAS202BCA image sensors + Add frame_timeout module parameter Signed-off-by: Luca Risolia <luca.risolia@studio.unibo.it> Signed-off-by: Greg Kroah-Hartman <gregkh@suse.de>
