The existing priv field stores subdev private data owned by the subdev
driver. Host (bridge) drivers might need to store per-subdev
host-specific data, such as a pointer to platform data.
Add a v4l2_subdev host_priv field to store host-specific data, and
rename the existing priv field to dev_priv.
Signed-off-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
Acked-by: Hans Verkuil <hverkuil@xs4all.nl>
Signed-off-by: Hans Verkuil <hverkuil@xs4all.nl>
Reviewed-by: Laurent Pinchart <laurent.pinchart@ideasonboard.com>
* 'for-next' of git://git.kernel.org/pub/scm/linux/kernel/git/jikos/trivial: (48 commits)
Documentation: update broken web addresses.
fix comment typo "choosed" -> "chosen"
hostap:hostap_hw.c Fix typo in comment
Fix spelling contorller -> controller in comments
Kconfig.debug: FAIL_IO_TIMEOUT: typo Faul -> Fault
fs/Kconfig: Fix typo Userpace -> Userspace
Removing dead MACH_U300_BS26
drivers/infiniband: Remove unnecessary casts of private_data
fs/ocfs2: Remove unnecessary casts of private_data
libfc: use ARRAY_SIZE
scsi: bfa: use ARRAY_SIZE
drm: i915: use ARRAY_SIZE
drm: drm_edid: use ARRAY_SIZE
synclink: use ARRAY_SIZE
block: cciss: use ARRAY_SIZE
comment typo fixes: charater => character
fix comment typos concerning "challenge"
arm: plat-spear: fix typo in kerneldoc
reiserfs: typo comment fix
update email address
Below you will find an updated version from the original series bunching all patches into one big patch
updating broken web addresses that are located in Documentation/*
Some of the addresses date as far far back as 1995 etc... so searching became a bit difficult,
the best way to deal with these is to use web.archive.org to locate these addresses that are outdated.
Now there are also some addresses pointing to .spec files some are located, but some(after searching
on the companies site)where still no where to be found. In this case I just changed the address
to the company site this way the users can contact the company and they can locate them for the users.
Signed-off-by: Thomas Weber <weber@corscience.de>
Signed-off-by: Mike Frysinger <vapier.adi@gmail.com>
Cc: Paulo Marques <pmarques@grupopie.com>
Cc: Randy Dunlap <rdunlap@xenotime.net>
Cc: Michael Neuling <mikey@neuling.org>
This adds support for the KWorld PlusTV 340U and KWorld UB345-Q ATSC
sticks, which are really the same device. The sticks have an eMPIA
em2870 usb bridge chipset, an LG Electronics LGDT3304 ATSC/QAM
demodulator and an NXP TDA18271HD tuner -- early versions of the 340U
have a a TDA18271HD/C1, later models and the UB435-Q have a C2.
The stick has been tested succesfully with both VSB_8 and QAM_256 signals.
Its using lgdt3304 support added to the lgdt3305 driver by a prior patch,
rather than the current lgdt3304 driver, as its severely lacking in
functionality by comparison (see said patch for details).
Signed-off-by: Jarod Wilson <jarod@redhat.com>
Signed-off-by: Michael Krufky <mkrufky@kernellabs.com>
family
This patch adds support for TechnoTrend TT-budget T-3000 DVB-T card.
Signed-off-by: Vadim Catana <vadim.catana@gmail.com>
Add Genius iSlim 310 webcam to the supported list of the PAC7302 driver.
For more information see http://linuxtv.org/wiki/index.php/PixArt_PAC7301/PAC7302 .
Signed-off-by: Márton Németh <nm127@freemail.hu>
Signed-off-by: Jean-François Moine <moinejf@free.fr>
Signed-off-by: Andy Walls <awalls@md.metrocast.net>
This change adds support for Avermedia M733A. The original version for
linux 2.6.31 was sent to me from Avermedia, original author is unknown.
I ported it to current kernels, expanded and fixed key code handling for
RM-K6 remote control, and added an additional pci id also supported.
[mchehab@redhat.com: make checkpatch.pl happier]
Signed-off-by: Herton Ronaldo Krzesinski <herton@mandriva.com.br>
Signed-off-by: Warren Bosworth Focke <wbfocke@gmail.com>
[dougsland@redhat.com: Fixed cards numbers reject due changes in saa7134.h]
Signed-off-by: Beholder Intl. Ltd. Dmitry Belimov <d.belimov@gmail.com>
Signed-off-by: Douglas Schilling Landgraf <dougsland@redhat.com>
I have 3 IVC-200 cards (with 4 video channels on each).
2 of the cards identify theirselves as 000[0-3]:a155 (ids already in
cardlist) and another one identifies itself as 080[0-3]:a155, which ids
were unknown so far.
Note - it's IVC-200, not IVC-200G.
Signed-off-by: Kirill Smelkov <kirr@mns.spb.ru>
Add documentation on how to use V4L2 events, both for V4L2 drivers and for
V4L2 applications.
Signed-off-by: Sakari Ailus <sakari.ailus@maxwell.research.nokia.com>
Add documentation on using V4L2 file handles (v4l2_fh) in V4L2 drivers.
cropping
Signed-off-by: Guennadi Liakhovetski <g.liakhovetski@gmx.de>
The firmware were seen to be needed with some tm6000 devices that don't
work with version 2.7.
Thanks-to: Bee Hock Goh <beehock@gmail.com>
Signed-off-by: Stefan Ringel <stefan.ringel@arcor.de>
After unregister_device all fileops are blocked, except for ioctls.
So it is not just the open that is blocked, others are as well.
Add support for design which has an em2863/tvp5150 and uses the standard
empia USB ID. In Sander's case, it was branded as an "Eminent model EM3705"
Thanks to Sander Van Ginkel for testing and help debugging the support.
[mchehab@redhat.com: move it to a vague card number slot (card=29)]
Signed-off-by: Devin Heitmueller <dheitmueller@kernellabs.com>
There are some missing entries there
Adds the following models:
- 0c45:624c
- 0c45:628c
- 0458:704a
- 0458:704c
Signed-off-by: Brian Johnson <brijohn@gmail.com>
Adds new capture boards Hawell HW-404M7 and HW-808M7. Those cards have 4
or 8 SAA7130 chips and for the work it only needs initialize registers.
The value of those registers were dumped under Windows using flytest.
But board haven't EEPROM.
For the first chip:
SAA7130 (0x7130, SubVenID:1131, SubDevID:0000, Rev: 01)
I2C slave devices found:
No devices
GPIO pins:
Mode : 0x00389C00
Value: 0x00016C00
Video input: 3
Audio input: Analog Line1
For other chips:
No devices
GPIO pins:
Mode : 0x00389200
Value: 0x00010000
Video input: 3
Signed-off-by: Vladimir Ermakov <vooon341@gmail.com>
gscpa Documentation: add cpia1 cameras
Sony makes custome tuners for its GigaPocket line of ivtv based capture
cards. This adds an entry to the tuner-types list for such tuners.
Parameters are based on experiments by Eric Anderson <rico99@sbcglobal.net>.
Signed-off-by: Andy Walls <awalls@radix.net>
CC: Jonathan Corbet <corbet@lwn.net>
CC: Reviewed-by: Randy Dunlap <rdunlap@xenotime.net>
Videobuf is a moderately complex API which most V4L2 drivers should use,
but its documentation is...sparse. This document attempts to improve the
situation.
Signed-off-by: Jonathan Corbet <corbet@lwn.net>
video :
use the V4L2_STD macros to select the proper audio setting.
radio :
add preemphasis ctr.
test it by the command:
v4l2-ctl -d /dev/radio0 --set-ctrl=pre_emphasis_settings=1
[mchehab@redhat.com: folded documentation patch]
Signed-off-by: Huang Shijie <shijie8@gmail.com>
pd-common.h contains the common data structures, while
vendorcmds.h contains the vendor commands for firmware.
[mchehab@redhat.com: Folded the 10 patches with the driver]
I tested only tv and composite. Video works fine but no audio.
Signed-off-by: Kusanagi Kouichi <slash@ac.auone-net.jp>
sn9c2028 drivers
gspca.txt: add cams supported by mr97310a, sq905(c) and sn9c2028 drivers
Signed-off-by: Theodore Kilgore <kilgota@banach.math.auburn.edu>
The two sensors ov772x and ov965x have too much differences.
Signed-off-by: Jean-Francois Moine <moinejf@free.fr>
Add lost configuration for our TV card.
Tested-by: Francesco Lavra <francescolavra@interfree.it>
algorithm
The sh_mobile_ceu_camera driver implements an advanced algorithm, combining
scaling and cropping on the client and on the host. Due to its complexity the
algorithm deserves separate documentation.
create mode 100644 Documentation/video4linux/sh_mobile_ceu_camera.txt
Many drivers access the device number (video_device::v4l2_devnode::num)
in order to print the video device node name. Add and use a helper
function to retrieve the video_device node name.
git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6
* 'for_linus' of git://git.kernel.org/pub/scm/linux/kernel/git/mchehab/linux-2.6: (345 commits)
V4L/DVB (13542): ir-keytable: Allow dynamic table change
V4L/DVB (13541): atbm8830: replace 64-bit division and floating point usage
V4L/DVB (13540): ir-common: Cleanup get key evdev code
V4L/DVB (13539): ir-common: add __func__ for debug messages
V4L/DVB (13538): ir-common: Use a dynamic keycode table
V4L/DVB (13537): ir: Prepare the code for dynamic keycode table allocation
V4L/DVB (13536): em28xx: Use the full RC5 code on HVR-950 Remote Controller
V4L/DVB (13535): ir-common: Add a hauppauge new table with the complete RC5 code
V4L/DVB (13534): ir-common: Remove some unused fields/structs
V4L/DVB (13533): ir: use dynamic tables, instead of static ones
V4L/DVB (13532): ir-common: Add infrastructure to use a dynamic keycode table
V4L/DVB (13531): ir-common: rename the debug routine to allow exporting it
V4L/DVB (13458): go7007: subdev conversion
V4L/DVB (13457): s2250: subdev conversion
V4L/DVB (13456): s2250: Change module structure
V4L/DVB (13528): em28xx: add support for em2800 VC211A card
em28xx: don't reduce scale to half size for em2800
em28xx: don't load audio modules when AC97 is mis-detected
em28xx: em2800 chips support max width of 640
V4L/DVB (13523): dvb-bt8xx: fix compile warning
Fix up trivial conflicts due to spelling fixes from the trivial tree in
Documentation/video4linux/gspca.txt
drivers/media/video/cx18/cx18-mailbox.h
Adds support to VC211A em2800 card. As this board doesn't have eeprom,
and uses a common set of i2c address, it has no way to add any
autodetection for it.
The patch were tested by me and by Raimundo on his board. Thanks to
those tests, several bugs related to em2800 support were corrected.
for producing the usbsnoop dump, used to get the gpio's and allowing me
to remotelly access his machine and to the needed tests.
Thanks-to: Raimundo Eduvirgnes de Oliveira <eduvirgens@yahoo.com.br>
It was really confusing to have media-specs, v4l2-spec and dvb-spec.
So this patch removes v4l2-spec and dvb-spec. The docs in dvb-spec and
the V4L1_API.html file were moved to media-specs/old-docs.
Removed all references to v4l2-spec and dvb-spec.
Tested-by: Enrique Dominguez <enrique.pinos@gmail.com>
Signed-off-by: Antoine Jacquet <royale@zerezo.com>
Add Prof 7301 PCI DVB-S2 card
The card based on stv0903 demod, stb6100 tuner.
Signed-off-by: Igor M. Liplianin <liplianin@me.by>
Adds support for cx23885 card Mygica X8558 Pro DMB-TH
Signed-off-by: David T. L. Wong <davidtlwong@gmail.com>
